Gast Geplaatst: 20 mei 2004 Geplaatst: 20 mei 2004 Vond het volgende bericht, en in het licht van de NTV+ files zou het wel eens waar kunnen zijn. Citaat: Hi folks, We now have full *Via2* algo. All credit to some fine Russian hacker, who succeeded, with a little help from NTV+, who should maybe think about employing him rather than the fools who chose to make key updates for that provider. Here is the position in light of that algo information with regard to BF of Viaccess system. As we argued all along (contrary to too many posts to the opposite to mention), 16 byte keys in case of *Viaccess2* providers must be split to two 8 byte keys to be processed. This is what does occur. We knew from calculations made from logs that the mask in *Via2* remained the same as in *Via1*, and argued so from the start. That also is the case. In fact, in one circumstance the algo for *Via2* does still equal the algo for *Via1*. If the second 8 modifier bytes of the 16 bytes stored for keys in *Via2* are zeroes, then *Via2* is *Via1*. We knew *Via1* providers could be added to a *Via2* card in MOSCing and work, and this now gives the reason why. So there is a circumstance in which current BF could deliver a key that opens a *Via2* provider. If such a circumstance would be used in practice, then it would only ever be used in the very first gen of *Via2* cards which, in fact, we happen to be bruting. So it's technically possible, but in our judgment now extremely unlikely. Certainly in the foreseeable future, unless PCs get many, many powers faster, bruting of the Viaccess system for ops and MKs is over. We don't intend to take any unilateral decision from above in closing the current BF, but rather will leave it up to you the members to make your own decisions in the matter. You have the facts: it is technically possible to find a working key for a provider by this BF, but it's our judgment that chances of that practically are very, very slim. To all those of you who have contributed, big and small, throughout this effort, our continuing respect. If there had been more like you, prepared to contribute a little rather than just take, we would have discovered all this info on *Via2* a couple of years ago now. Right now we don't have any new BF project in the pipeline for those of you who might wish to stop on Via2, but we will maybe have a head scratch and see what we can come up with. Across all CAS, the possibilities are quite limited in terms of any practical BFs, but we shall see. If we come up with something interesting, we'll, of course, let you know. Current Via2 BF areas will be left available for those who wish to continue with them. *Edit, topic naam aangepast
Gast Geplaatst: 20 mei 2004 Geplaatst: 20 mei 2004 ehm volgens mij ben je met dit bericht wel een beetje laat aangezien er al VIA 2 fixes zijn voor firmware op de goldboxes.. <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Gast Geplaatst: 20 mei 2004 Geplaatst: 20 mei 2004 Die via2 fixes zijn voor NTV+ op 36,0e maar hier wordt gesproken dat nu de volledige algo gevonden waardoor het mogelijk is alle Via2 gecodeerde zenders te gaan ontsluiten. Hopelijk binnenkort weer veel natuur op 13.0e te bewonderen <img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" />
Bigfoot Geplaatst: 20 mei 2004 Geplaatst: 20 mei 2004 Als je dit Engelse bericht goed leest concludeer je dat ze weliswaar het algoritme kennen, maar dat het zeer moeilijk is om vervolgens met Brute Force (BF) de keys te kraken. Eigenlijk geven ze hun Brute Force project op. Keys die voor 36 Oost bekend zijn waren gevonden door bugs in de kaart maar die verwacht men niet meer in de toekomst of voor andere providers. Slecht nieuws dus.....
Gast Geplaatst: 20 mei 2004 Geplaatst: 20 mei 2004 Zo kun je het ook lezen ja, maar volgens mij kun je met een bekend algo meer dan alleen BF'n, ze geven wel aan nog niet te weten hoe nu verder te gaan. Mischien iets te vlot geweest, echter gaf men bij Seca ook niet op nadat er op enkele kaarten een bug gevonden was, mischien dat een commerciele tak het weer oppikt en verder gaat waar de BF groep faald ? Voor de DB gebruikers, ik kwam op Sat-keys.xxx een NTV+ emu tegen, alleen niet kunnen testen, voor NTV heb ik een te kleine dish <img src="/ubbthreads/images/graemlins/frown.gif" alt="" /> ** NTV+ Emu geeft aan dat het de Radegast Deamon is, waarschijnlijk fake dus. Ik test nog even verder.
Gast Geplaatst: 20 mei 2004 Geplaatst: 20 mei 2004 uit betrouwbare bron vernomen dat ntv+ op 13 oost open ligt via 2 keys bekend zijn
Gast Geplaatst: 20 mei 2004 Geplaatst: 20 mei 2004 Citaat: uit betrouwbare bron vernomen dat ntv+ op 13 oost open ligt @JohnDoe, Al vaker is op dit board in vergelijkbare gevallen gezegd dat er sprake is van een betrouwbare bron. Veelal bleek het achteraf niet te kloppen. Kun jij zelf reproduceren wat je vernomen hebt? Met vriendelijke groeten <img src="/ubbthreads/images/graemlins/wink.gif" alt="" /> sattaz
Gast Geplaatst: 20 mei 2004 Geplaatst: 20 mei 2004 @Sattaz zie pm heb je net mijn bron openbaar gemaakt, maar dat niet online gezet, ivm de ogenschijnlijk veel pm's die hij dan zou krijgen... en vraag mij het niet, want ik geef zijn/haar nick toch niet prijs !!
Gast Geplaatst: 20 mei 2004 Geplaatst: 20 mei 2004 dit algo is niet zo moeilijk <img src="/ubbthreads/images/graemlins/smile.gif" alt="" /> alleen de key is 2 keer zo lang....
Gast Geplaatst: 20 mei 2004 Geplaatst: 20 mei 2004 Betrouwbare bron??? De NTV die hier bedoeld wordt kun je alleen ontvangen met een heeeeeeeele grote schotel en zit op 36 graden. En daar zijn bijna alle keys van bekend. Alleen de 08 niet. En aangezien ze daar (heel ver weg) schakelen tussen de keys krijg je af en toe freezings als de 08 voorbij komt. Op 13 graden waren ook de keys van RTV International bekend maar die zijn ook over naar de 08. Die keys kun je overigens overal vinden.
Gast Geplaatst: 20 mei 2004 Geplaatst: 20 mei 2004 dan heb ik zojuist een typefout gemaakt .. 13 oost 11938 daar ging het om
holles Geplaatst: 21 mei 2004 Geplaatst: 21 mei 2004 Via2 heeft een tijdje open gelegen voor zowel NTV+ op 36 oost als RTV op 13 oost. Dit ging via een bekende key. Beide zijn begin mei overgestapt naar de 08 key. Voor NTV+ is deze key bekend maar voor RTV niet. De meeste kanalen van 36 oost zijn dus open. Op 13 oost blijft het zwart. De bedoelde emu is een aangepaste Radegast emu en is geen fake volgens diverse russische sites. Heb hem zelf getest in de dreambox en bijna alles wat met radegast open gaat gaat met deze emu ook open. Via2 heb ik niet kunnen testen (RTV gebruikte al de 08-key). Vu+ Solo2 met OpenPli via WaveFrontier T90 met bereik 5E t/m 53E
spirit_rules Geplaatst: 21 mei 2004 Geplaatst: 21 mei 2004 Citaat: uit betrouwbare bron vernomen dat ntv+ op 13 oost open ligt via 2 keys bekend zijn <img src="/ubbthreads/images/graemlins/smirk.gif" alt="" /> idd klopt dit 13. e Citaat: Voor NTV+ is deze key bekend maar voor RTV niet 13 rtv <img src="/ubbthreads/images/graemlins/loep.gif" alt="" /> [color:"blue"] Spirit_rules [/color] ------------------------------------------------- Open Firmwarmware Multi taal_171005_0430 Member van het Openfirmware Team
Bigfoot Geplaatst: 22 mei 2004 Geplaatst: 22 mei 2004 Zijn dez keys te gebruiken in dezelde files als voor Viaccess-1?
Tonskidutch Geplaatst: 22 mei 2004 Geplaatst: 22 mei 2004 lijkt me stug.. bigfoot.. <img src="/ubbthreads/images/graemlins/smile.gif" alt="" /> cheers Les Djinns (Trentemoeller Remix) Djuma Soundsystems
