bbbb Geplaatst: 23 juli 2004 Delen Geplaatst: 23 juli 2004 ruDREAM 23-07-2004 HOT FIX -------------------------------------------------------------------------------- http://212.248.21.184/r u d r e a m/108_rd_v20040723.1449.img (remove blanks) md5: 3128178f057ac59ebfbf224abe61f911 Welcome to ruDREAM image based on: kernel v.2.6.5 enigma v.1.08 ( mod ruDREAM ) module v.1.08 EMU & CARDREADER in image: DreamCrypt v.1.08 Features: internet keyupdate internet addonupdate remember emu type for chanel and bouquet Plugins: EMUD v.1.10 EMUSET v.1.17 ADDONMANAGER v.2.00 SCRIPTSERVICE v.2.04 VIEWFILE v.1.00 ALL EMU (available to download) OTHER ADDON (available to download) Games: TETRIS v.1.4 OTHER GAMES (available to download) Change button funtion: BLUE button - emuset YELLO button - plugins list AUDIO button - sound stream & mode select TEXT button - video text RED button - EPG List for current channel RED button - double click for show EPG Style menu Support: http://www.allrussian.info/board.php?boardid=49 irc channel #dbox2 (dalnet) Special thx: kindzadza, mixvt, lucgas, chameleon, pnk66, shopen, puh, xphile, sphinx, Tom0000, mad*spike, mizu, jirka, FvS, ddv. Compiled by: ruDREAM team WARNING!!! ======== only for this image: 1. not use mode OSD for EMU, because of many EMU have bug 2. restore/bakup function is not compatible with old images ChangeLog & notes: =========================================== 23-07-2004: new SCRIPTSERVICE v.2.04: - added simple runscript and show script menu, for the detailed information look readme.txt - added new command mvfile, for the detailed information look readme.txt - fixing bug in command runmenuonfile new ADDONMANAGER v.2.00: - added opportunity of show md5 and size the packed file with addon new EMUSET v.1.19: - fixing small bug in editor config file for newcamd - added support the new version camd3, while only simple dialogue new SCRIPTSERVICE MENU: - added dialog install addon external MultiView EPG - added option enable/disable auto-update frontprocessor - added EMU’s special info (for newcamd EMU) new in ENIGMA: - added opportunity of show md5 the image for software update - added opportunity of enable/disable show zap error descrambled - added opportunity of enable/disable use external plugin for show EPG - added opportunity of show dialog chose EPG style at double click red button - added by pressing the red button it is shown EPG the chosen style (smart red button) - fixing bug for selecting channel in Multi EPG dialog - fixing bug LCD in mode main menu - fixing BIG BUG in cache EPG, big TNX ddv - fixing bug sofware update menu other - fixing small bug in file rcS for debug - added opportunity in rcS script for enable/disable setting IP config - update satellite.xml NOTES: ===== (*) available manual installation and loading through the menu (**) available manual installation -cvs update [19-07-2004] P’S’ As with an output of image the structure of additions which can be loaded through the menu or under direct references is updated, direct references can be found in a file: http:// 212.248.21.184/r u d r e a m/addons.xml (remove blanks) __________________ =============== Alexvrs vriendelijke groeten bbbb Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 23 juli 2004 Delen Geplaatst: 23 juli 2004 Ik had hier een bugfix gewilt van het NFS hickup probleem! Beetje jammer! Link naar reactie Delen op andere sites Meer opties om te delen...
bbbb Geplaatst: 23 juli 2004 Auteur Delen Geplaatst: 23 juli 2004 Posten bij satindustry daar kijk Alexvrs altijd voor bugs die nog in de image zitten vriendelijke groeten bbbb Link naar reactie Delen op andere sites Meer opties om te delen...
michel130 Geplaatst: 23 juli 2004 Delen Geplaatst: 23 juli 2004 zo is binnen (duurde wel lang) maar dat heb ik wel voor over want ik vind deze tot nu toe de beste samen met hydra image. Straks even proberen maar nu nog even lekker surfen op het web. Bedankt voor de informatie en de nieuwe image. Dreambox 7000S & 500 & 800 - Maxtor 80GB en Samsung 500GB - USBstick Swap - schotel 80 & 110cm - Moteck SG2100 - lnb titanium 0,2 db & duo lnb - openPLI - Satje07 settings - cccam 2.1.4 Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 23 juli 2004 Delen Geplaatst: 23 juli 2004 Het downloaden gaat inderdaad erg traag ...zowel met de dreambox als met m'n PC (2,89kB/sec) <img src="/ubbthreads/images/graemlins/biggthumpdown.gif" alt="" /> maar zoals ze zeggen ...geduld is een schone zaak ...en zal worden beloond (hoop ik) <img src="/ubbthreads/images/graemlins/grin.gif" alt="" /> Link naar reactie Delen op andere sites Meer opties om te delen...
bbbb Geplaatst: 23 juli 2004 Auteur Delen Geplaatst: 23 juli 2004 De multiview pluging van Pentvear hebben ze mooi weg gewerkt.Je moet de pluging eerst downloaden service selecteren ,info.Dan kan je kiezen kanaal epg,muli epg, muliview epg .Dit vind ik nou het leuke van de rudream team.Ze hebben altijd van die speciale dingen vriendelijke groeten bbbb Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 23 juli 2004 Delen Geplaatst: 23 juli 2004 perfekte image die rudream alleen probleem is een beetje groot flash zit heel vlug te vol. dus draait altans beter in usb stick of op hdd <img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" /> maar vraagje wat wil dat zeggen enable disable frontproc update. als dat toch niet lukt bij de meeste wat heeft die optie dan voor nut????? of zie ik wat over het hoofd <img src="/ubbthreads/images/graemlins/anoniem.gif" alt="" /> doppie Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 23 juli 2004 Delen Geplaatst: 23 juli 2004 Citaat: De multiview pluging van Pentvear hebben ze mooi weg gewerkt.Je moet de pluging eerst downloaden service selecteren ,info.Dan kan je kiezen kanaal epg,muli epg, muliview epg .Dit vind ik nou het leuke van de rudream team.Ze hebben altijd van die speciale dingen Dubbel klik op rood werkt ook hoor :-) Ik heb trouwens net even opnames gemaakt met newcamd ...het freez probleem lijkt ook tot het verleden te horen <img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" /> Ik heb in ieder geval niets hoeven te wijzigen. Zat dit probleem nu in de cvs welke nu geupdate is? gr, Ruko Link naar reactie Delen op andere sites Meer opties om te delen...
Elst Stars Geplaatst: 24 juli 2004 Delen Geplaatst: 24 juli 2004 Heb 'm binnen en ga vanavond bezig. Voor mij heeft Rudream nog steeds de mooiste images, Maar Hydra toch wel de meest stabiele. Werken beide erg goed via internet. DM800HD SE 250Gb SATA TechniSat DigiDisch 45cm 4 in 1 Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 24 juli 2004 Delen Geplaatst: 24 juli 2004 Citaat: Het downloaden gaat inderdaad erg traag ...zowel met de dreambox als met m'n PC (2,89kB/sec) <img src="/ubbthreads/images/graemlins/biggthumpdown.gif" alt="" /> maar zoals ze zeggen ...geduld is een schone zaak ...en zal worden beloond (hoop ik) <img src="/ubbthreads/images/graemlins/grin.gif" alt="" /> Duurde ook behoorlijk lang voordat ik 'm binnen had. ruDREAM images zijn altijd erg populair, dus die server slipt zo dicht! Ik heb iig 'n file mirror aangemaakt voor de liefhebbers (kijk ff in m'n profiel, voor de link <img src="/ubbthreads/images/graemlins/wink.gif" alt="" /> ) Link naar reactie Delen op andere sites Meer opties om te delen...
bbbb Geplaatst: 24 juli 2004 Auteur Delen Geplaatst: 24 juli 2004 Ik vind hydra ook goed. Maar ik mis de interface voor newcamd .En ook een keyconverter vriendelijke groeten bbbb Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 24 juli 2004 Delen Geplaatst: 24 juli 2004 @SE 94.4 kB/sec is i.d.d. andere koek. Je loopt nog steeds snel na de vierdaagse zeg <img src="/ubbthreads/images/graemlins/loldev.gif" alt="" /> Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 24 juli 2004 Delen Geplaatst: 24 juli 2004 Citaat: @SE 94.4 kB/sec is i.d.d. andere koek. Je loopt nog steeds snel na de vierdaagse zeg <img src="/ubbthreads/images/graemlins/loldev.gif" alt="" /> Heb idd. nog geen blaren op de voeten <img src="/ubbthreads/images/graemlins/laugh.gif" alt="" /> Heb er gisteren trouwens niks van meegekregen, want ik zat bij m'n schoonfamilie te bbqen <img src="/ubbthreads/images/graemlins/smirk.gif" alt="" /> Voor de rest vd. week was 't hier in Nijmegen kei-gezellig! Goed, dit wordt errug offtopic... Ik las net dat er wat mensen waren die problemen met de keys hadden, dus lees de oplossingen ff hier:http://www.sat4all.com/ubbthreads/showfl...;fpart=1#657839 Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 24 juli 2004 Delen Geplaatst: 24 juli 2004 Wat mij nog niet duidelijk is in deze en de vorige image is : - wat doen de opties in autoexec setup (CMD1,2,3,4,5 enable /disable) ik weet niet eens waar de letters CMD voor staan <img src="/ubbthreads/images/graemlins/confused.gif" alt="" /> - In de expert: memory manager heb ik "Use for var folder USB" geselecteerd, deze heeft keurig de folder op usb gezet, maar waarom staat hij ook nog steeds in de flash ? - Ik krijg regelmatig bij de keuze download addons de foutmelding "error: server replied 403 Access Forbidden" met de url eronder. Is dit een overbelasting van de server ? <img src="/ubbthreads/images/graemlins/kweetniet.gif" alt="" /> alvast bedankt, RuKo Link naar reactie Delen op andere sites Meer opties om te delen...
bbbb Geplaatst: 24 juli 2004 Auteur Delen Geplaatst: 24 juli 2004 Hoogwarschijnlijk een bug kijk hier maar eens naar Alexvrs update_script_2004.07.24.tar.gz (2 KB, 23 ðàç ñãðóæåíî) http://www.allrussian.info/thread.php?th...&page=2 vriendelijke groeten bbbb Link naar reactie Delen op andere sites Meer opties om te delen...
