Gast Geplaatst: 3 januari 2005 Delen Geplaatst: 3 januari 2005 al geprobeerd: -jtag -flash erase (lukt niet) -erase image -nieuwe image dat alles gaat verder volgens verwachting maar toch start het apparaat niet door: Dreambox DM7000 loaded at: 00500000 0061F1F8 relocated to: 00400000 0051F1F8 board data at: 0051C128 0051C168 relocated to: 0040546C 004054AC zimage at: 004059CC 0051B4D8 avail ram: 00520000 02000000 Linux/PPC load: console=ttyS0,115200 root=dv/mtdblock0 Uncompressing Linux...done. Now booting the kernel Linux version 2.6.8.1 (ghost@client) (gcc version 3.2.3) #2 Fri Aug 27 14:23:06 CEST 2004 Built 1 zonelists Kernel command line: console=ttyS0,115200 root=dv/mtdblock0 PID hash table entries: 256 (order 8: 2048 bytes) Console: colour dummy device 80x25 Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) Memory: 29712k available (2000k kernel code, 604k data, 80k init, 0k highmem) Calibrating delay loop... 501.76 BogoMIPS Mount-cache hash table entries: 512 (order: 0, 4096 bytes) NET: Registered protocol family 16 SCSI subsystem initialized usbcore: registered new driver usbfs usbcore: registered new driver hub devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au) devfs: boot_options: 0x1 JFFS2 version 2.2. © 2001-2003 Red Hat, Inc. Serial: 8250/16550 driver $Revision: 1.90 $ 7 ports, IRQ sharing disabled ttyS0 at MMIO 0x0 (irq = 20) is a 16550A ttyS1 at MMIO 0x0 (irq = 21) is a 16550A ttyS2 at MMIO 0x0 (irq = 31) is a 16550A loop: loaded (max 8 devices) smc91x.c: v1.0, mar 07 2003 by Nicolas Pitre <nico@cam.org> irq 28 setup to non-critical eth0: SMC91C11xFD (rev 1) at 0xc306a300 IRQ 28 [nowait] eth0: Ethernet addr: 00:09:34:0f:57:bf Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2 ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx OCP ide ver:2.0 IBM STB04xxx IDE driver version 2.0 mapped 400f0000 to c306c000 OCP ide: waiting for drive spinupioports for drive 0 @ c0291b88 ..Drive spun up Probing IDE interface ide0... Using deadline io scheduler dreambox: flash mapping: 800000 at 7f800000 DreamBOX rev3+: Found 1 x16 devices at 0x0 in 16-bit bank Intel/Sharp Extended Query Table at 0x0031 cfi_cmdset_0001: Erase suspend on write enabled Using buffer write method disable flash VPP Creating 7 MTD partitions on "DreamBOX rev3+": 0x00000000-0x00600000 : "DreamBOX cramfs+squashfs" 0x00600000-0x007c0000 : "DreamBOX jffs2" 0x007c0000-0x00800000 : "DreamBOX OpenBIOS" 0x00000000-0x007c0000 : "DreamBOX (w/o bootloader)" 0x00000000-0x00800000 : "DreamBOX (w/ bootloader)" 0x00120000-0x00600000 : "DreamBOX SquashedFS" 0x00000000-0x00120000 : "DreamBOX Cramfs" USB #0 at 0xe0010000 irq 18 setup to non-critical drivers/usb/host/ohci-ocp.c: ohci_hcd (OCP) at 0xe0010000, irq 18 ocp_usb 07: new USB bus registered, assigned bus number 1 hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected Initializing USB Mass Storage driver... usbcore: registered new driver usb-storage USB Mass Storage support registered. mice: PS/2 mouse device common for all mice i2c /dev entries driver IBM IIC driver v2.1 irq 9 setup to non-critical ibm-iic0: using standard (100 kHz) mode irq 10 setup to non-critical ibm-iic0: using standard (100 kHz) mode NET: Registered protocol family 2 IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 2048 bind 4096) NET: Registered protocol family 1 NET: Registered protocol family 17 Root-NFS: No NFS server available, giving up. VFS: Unable to mount root fs via NFS, trying floppy. VFS: Cannot open root device "dv/mtdblock0" or unknown-block(2,0) Please append a correct "root=" boot option Kernel panic: VFS: Unable to mount root fs on unknown-block(2,0) <0>Rebooting in 180 seconds.. Nog iemand een suggestie? Link naar reactie Delen op andere sites Meer opties om te delen...
paardengek Geplaatst: 3 januari 2005 Delen Geplaatst: 3 januari 2005 dmb, Misschien heb je dit al gedaan: # verwijder eventueel je harddisk # verwijder eventueel je usb-stick En probeer eens met dreamup 2.14b de image serieel er in te flashen. Dit gaat met dreamup 2.14. Zet de dreambox helemaal uit (dus de stroom eraf). Haal eventueel de scartkabels/lnb coax kabel usb-stick etc eraf. Sluit de nulmodemkabel aan op de dreambox en op de compoort van je pc. Start het progje dreamup op en druk op connect. Zet dan de stroom op de dreambox (dreambox gaat aan). Je kunt nu aan een voortgangsbalk zien, dat er een verbinding wordt gelegd. Als de verbinding er is dan klik je op erase in dreamup (hoeft net persé) . Als dat gebeurd is dan klik je op flash en selecteer je de gewenste image en druk op ok. Nu moet er een voortgangsbalk beginnen te lopen. Is dat niet zo, dan druk je nogmaals op flash en selecteer je nogmaals de gewenste image en druk op ok. Er loopt nu een voortgangsbalk. Het flashen duurt ca 10 minuten. Na het flashen, sluit je de scartkabels en het netwerkkabel en de lnb coax kabel eventueel weer aan. Start de dreambox op en druk op de linker boventoets naast de lcd scherm, totdat er verschijnt: Flash erase. Hierna start de dreambox weer, en zet nu de instellingen goed, ook de netwerkinstellingen. Zet er d.m.v. bijv dreamboxedit een recente settingslijst erin (bijv pet123 of joske: www.dreamboxworld.com ) Installeer eventueel een emu en ftp de daarbij behorende keys naar de dreambox. Nu zou het moeten lukken, zolang er nog een logo zichtbaar op het lcd scherm staat, moet de box serieel benaderbaar zijn. Veel kijkplezier, Met vriendelijke groet, paardengek Door veel lezen en prutsen kom je er wel! Link naar reactie Delen op andere sites Meer opties om te delen...
Crest Geplaatst: 3 januari 2005 Delen Geplaatst: 3 januari 2005 Harddisk er uithalen. Voorzichtig doen hoor! Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 4 januari 2005 Delen Geplaatst: 4 januari 2005 Er zit geen harddisk in (had alles via pc lopen) De erase image en laatste versie van Dream zijn serieel geflashed. Dat lukt op zich. Het gaat fout bij de kernel init ?? Iemand enig idee waar dit mee samen hangt? Link naar reactie Delen op andere sites Meer opties om te delen...
MR_B Geplaatst: 4 januari 2005 Delen Geplaatst: 4 januari 2005 al eens zonder lnb aansluiting geprobeerd? Een beetje van mezelf en een beetje van jullie.... Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 5 januari 2005 Delen Geplaatst: 5 januari 2005 helaas maakt dat geen verschil... Link naar reactie Delen op andere sites Meer opties om te delen...
dAF2000 Geplaatst: 5 januari 2005 Delen Geplaatst: 5 januari 2005 De regel bovenaan "root=dv/mtdblock0" is fout. Dit moet "root=/dev/mtdblock/0" zijn. Sluit een serieele kabel aan, start Hyperterminal op en druk op de spatiebalk als de tekst met "DM7000" voorbij komt. Typ achter de regel die je dan ziet die "root=/dev/mtdblock/0" in. Dan zou 't zo uit m'n hoofd moeten lukken. Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 5 januari 2005 Delen Geplaatst: 5 januari 2005 helaas, net geprobeerd, zelfde resultaat.. Link naar reactie Delen op andere sites Meer opties om te delen...
dAF2000 Geplaatst: 5 januari 2005 Delen Geplaatst: 5 januari 2005 Zelfde foutmelding als deze weer? VFS: Cannot open root device "dv/mtdblock0" or unknown-block(2,0) Please append a correct "root=" boot option Kernel panic: VFS: Unable to mount root fs on unknown-block(2,0) Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 5 januari 2005 Delen Geplaatst: 5 januari 2005 ja alleen natuurlijk mtdblock/0 ipv mtdblock0 Link naar reactie Delen op andere sites Meer opties om te delen...
dAF2000 Geplaatst: 5 januari 2005 Delen Geplaatst: 5 januari 2005 En /dev in plaats van dv dus... om zeker te weten... Ik heb effe niet een Dreambox aan een serieele kabel hangen, maar lukt 't ook om de hele regel te wissen en dan alles weer opnieuw te typen met de goede /dev/mtdblock/0 en de rest? Ik ben eigenlijk wel overtuigd dat hier 't probleem zit, zo te zien aan de logging. Link naar reactie Delen op andere sites Meer opties om te delen...
mirakels Geplaatst: 5 januari 2005 Delen Geplaatst: 5 januari 2005 Het lijkt erop dat er in de dreambox bios iets is gewijzigd waardoor de /dev verandert is in dv. De kernel start wel op maar kan daardoor geen goed rootdevice vinden. Als het goed is kan je dat met een seriele connectie aanpassen. Zie bijvoorbeeld de volgende 2 sites: http://www.reink.nl/dreambox-linux.html en http://ds9a.nl/dreambox/ Hm, in feite staat daar wat daf2000 al heeft geschreven... <img src="/ubbthreads/images/graemlins/anoniem.gif" alt="" /> <img src="/ubbthreads/images/graemlins/anoniem.gif" alt="" /> DM7000, noname 58 cm bord met SM3D12 rotor, 46GB 2.5in hitachi hdd Link naar reactie Delen op andere sites Meer opties om te delen...
