@All
Ik heb hier een Philips LX3600 van een collega staan.De speler heeft problemen met het afspelen van DVD-schijfjes. Soms speelt het apparaat eventjes probleemloos om vervolgens te stoppen met de mededeling no disc.
CD-schijfjes geven geen problemen.
Wie weet raad?
Phil
DM-800HD se -|- stab HH120 -|
Kan een defecte laser zijn of een software fout.
Topfield TF5000ci met aston 1.05, Amiko alien 8900, 80cm schotel gericht op astra 1 en 3 (duo lnb)
Brobeer inderdaad eerst nieuwe software
A. Preparation to upgrade the firmware:
1. Unzip lx3600d_v29.zip ( see file attached ).
2. Start the CD Burning software and create a new CD project (data
disc) with the following settings:
File system : ISO9660
Format : Mode1, CD-ROM
Recording mode : Single Session (Track-At-Once), Finalized CD
3. Place the content of the zip-archive (1 file) into the root directory of
the new CD project.
4. Burn the data onto a blank CDR.
Note: ISO9660 is mandatory, UDF discs are not supported !
The final CDROM must not contain any other data except the file
from the zip-archive.
B. Procedure to apply the firmware upgrade:
1. Power up the set and open tray.
2. Insert the prepared Upgrade CDROM and close the tray.
3. The set will response and display the following messages:
" LOAD [after the disc is read the tray will open to remove the disc]
" ERASE 0 -> ERASE F ..... -> ERASE 0
" WRITE F ..... -> WRITE 0
" UPG END [displayed only for a short moment, if unsuccessful
ERROR is shown]
" DISC
" LOAD [tray will close indicating that the upgrade process is
completed]
4. Unplug the set to disconnect the mains supply.
5. The whole process should last for about 5 minutes.
C. Reprogramming the DVD version Matrix
1. Put the set in Stop mode with tray open
2. Press buttons -9- -9- -9- -9- -AUDIO- -a- on the Remote
Control, where a is as given below:
1 = /22 & /25 Europe 2 = /93 China
3 = /69 Asia Pacific 4 = /75 Australia/New Zealand
5 = IK India Kit 6 = /78 Latam
7 = LK Brazil Kit 9 = /17 USA
D. How to read out the firmware versions to confirm upgrading
1. Power up the set and open tray in DVD mode.
2. Press -OSD- on the Remote control.
3. The TV screen will show:
SERVO: servo version no REG: region number
Model - software date in yymmdd - V version no stroke
version
841810-lx3600d_v29.zip
@ fransv
Waar heb je deze software vandaan? Ik heb ongeveer dezelfde
problemen met een LX 3000.
Zou je mij de link kunnen geven? ( evt via PM)
Praatjes vullen geen gaatjes, maar PUR wel !!!!!
Dream 800HD 13/19.2/23.5/28.2
Voor de LX3000 !!!!!!!
The upgrade addresses the following issue:
- Sound is muted during tracknumber increase on CDs with live music
content or on CDs recorded in disc-at-once mode.
All older sets brought in for repair should be upgraded as preventive action.
A. Preparation to upgrade software:
1. Unzip the zip-archive attached to this Service Newsletter
Disc) with the following settings:
File system: ISO9660, JOLIET
Format: MODE 1: CDROM
Recording mode: SINGLE SESSION (TRACK-AT-ONCE),
FINALIZED CD
the new CD project.
B. Procedure to apply the software upgrade:
1. Power up the set and open the DVD tray.
3. The TV screen will show the following messages in sequence:
disc loading ® bank30.rom ® writing ® done
4. The whole process takes less than 10 seconds after which the set
shuts down and the TV screen becomes dark.
Note: Do not press any buttons or interrupt the mains supply during
the entire upgrading process, otherwise the set may become
defective.
5. Unplug & replug the mains cable
6. Open the DVD tray and remove Upgrade CDROM.
7. Reset the system by using the Remote control, select
System Menu ® Feature setup ® Default ® Reset
C. How to read out the software versions to confirm upgrading
1. Open the DVD tray
2. Press <123> on the Remote control.
3. The software version VER 0517 1 xx y is displayed on the TV
screen. The region code (digit y) should remain as before
upgrading, otherwise restore the region code as descibed in the
Service Manual on page 2-1.
D. Before returning the set to customer
1. Check & ensure that the TV system and Video out are setup as in
the table below ( snl2003-03-10.jpg).
REMARKS :
Zip-archive file lx3000d_v0517_1.zip is for LX2000D and LX3000D
family except /35S
842443-lx3000d_ver_0517_1.zip
Ik ga er mee aan de slag, bedankt <img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" />
  • 1 jaar later...
Bij mij is het precies andersom. Hij speelt wel DVD's maar geen CD's?????
