Heb zojuist een zenderscan uitgevoerd ivm de nieuwe transponderindeling (@Home regio 9700) maar op 1 of andere manier zit stream 8 er niet tussen (geen Film 1, 1+1, 1.2, 1.3 kanalen)... waar zou dit aan kunnen liggen?
Dit is mijn scan-setting uit cables.xml:
<cable name="@Home-Regio9700" flags="9">
<transponder frequency="313000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="361000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="353000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="345000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="818000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="329000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="810000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="305000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="762000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="618000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="610000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="337000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="321000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="247000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="255000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="263000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="369000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="295000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="235000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="754000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="586000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="271000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="287000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="279000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
</cable>
Wat is me tevens afvroeg is waar fec_inner en polarization voor staat?
  • Reacties 250
Wat je eens moet proberen is om die regel met freq. 305000000 op een andere plek te zetten.
Ik heb dit probleem ook eens gehad en hem toen bovenin gezet en toen vondt hij hem wel.
Wat de oorzaak is weet ik nog altijd niet, mar het werkte toen bij mij wel.
suc6
Vu duo2 met pli
Heb het probleem opgelost, iets heel aparts: Bij Fast Scan ON zag hij stream 8, bij OFF niet.... m.a.w. bij een tragere scan is hij minder scherp met zoeken? Beetje onlogisch <img src="/forums/images/graemlins/tongue.gif" alt="" /> Maar goed, hij heeft nu alle zenders gevonden.
<cable name="@test" flags="9">
<transponder frequency="252000000" symbol_rate="6875000" fec_inner="0" modulation="3"/>
<transponder frequency="235000000" symbol_rate="6875000" fec_inner="1" modulation="3"/>
</cable>
Regio Limburg (id 1111), ik krijg de zenders van transponder 22 niet aan de gang. Ik krijg alle zenders op deze transponder er niet bij...iemand nog idee wat te kunnen doen? Ook handmatig scannen werkt op deze freq?
is Casema inmiddels ook eens wat aan het bijplaatsen, of kunnen we dat pas op zn vroegst in Q1 2008 gaan verwachten? Als ik nu een manual netwerkscan doe op 290 dan nog weinig nieuws te bekennen, zijn er specifieke freqs bekend voor Casema?
Xtrend ET10000 met Quad Inverto Ultra
kan iemand me aangeven wat het verschil tussen de volgende bestandjes..cables.xml..services.xml..satellites.xml...en waar ik ze op mijn dreambox moet plaatsen om ze te kunnen gebruiken..
dreambox 7025+, gemini, ccCam 2.0.4.
Kant en klare lijst TVhome Enigma 2 lamedb.
regio 1111 ( brabant, limburg ).
Alles ingedeeld in bouqeut list.
- TV home basis
- TV home compleet
- Radio TV home basis
- Radio TV home compleet
datum 15-12-2007
Limboconnect
Dreambox 7025, 300GB HD (Openpli)
Astra-Hotbird,Ziggo
XBMC
Kant en klare lijst Astra, Hotbird, TVhome(1111) Enigma 2 lamedb.
datum 15-12-2007
Limboconnect
Astra-Hotbird,Ziggo
XBMC
Echt niemand een idee? Handmatig zoeken werkt niet naar transponder 22. Kant en klare lijst middels Dreambox Edit kanelen geimporteerd werkt ook niet. Krijg steeds de melding 'Service could not be found!'. <img src="/forums/images/graemlins/crazy.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
is er iemand die hier uit kan leggen hoe ik een volledige scan uitvoer met een dreambox 500C in de regio almelo.... ik krijg het maar niet voor elkaar. hij vind wel een stuk 90 zenders maar zenders zoals nederland 1,2,3 rtl etc pakt ie niet.
Lijkt op het probleem hier sinds @Home een nieuwe zenderindeling heeft. <img src="/forums/images/graemlins/wink.gif" alt="" />
nee helaas is dit niet mijn probleem, ik heb geen nederland 1,2,3 rtl4,5,6,7 etc humor tv ook niet en noem maar op... kan dit liggen aan het feit dat ik geen goede cable.xml heb ?
Maar dan kun je de zenders toch met de juiste freqentie met handmatig zoeken wel vinden. <img src="/forums/images/graemlins/confused.gif" alt="" />
Gast
