Gast Geplaatst: 5 november 2005 Geplaatst: 5 november 2005 Citaat: iemand een idee hoe dit komt? Sportster Pro 1.0 Image Sagem D-BOX2 - Kernel 2.4.31-dbox2 (21:35:36)... dbox login: root /var # cd bin /var/bin # cd emu /var/emu # ./newcs Reading Config file /var/tuxbox/config/newcs.xml level: normal type: init output: all logger config: level 1 type 3 output 255 log file: logger: cant open file , file log disabled udp log: host port 0 Host lookup of failed logger: cant connect udp to :0, udp log disabled tcp port: 3001 [ 21:36:27 ] logger: bind error: error! 98: Address already in use logger: tcp port open failed, tcp log disabled [ 21:36:27 ] [ Box detect ] Box type 4 [ 21:36:27 ] [ SID ] Adding SID 0000 on Reader "multicam" [Allow] [ 21:36:27 ] [ SID ] Adding SID 0000 on Reader multicam [Deny] [ 21:36:27 ] [ Config ] /dev/tts/1 ECM priority: round [ 21:36:27 ] [ EMM Cache ] Initialising Cache with 10 entries [ 21:36:27 ] [ ECM Cache ] Initialising Cache with 10 entries [ NewCS ] Process id 289 [ 21:36:27 ] [ Loader ] Reader type dbox on node /dev/tts/1 [ 21:36:27 ] [ Dbox ] Opening device /dev/tts/1 [ 21:36:28 ] [ Loader ] Unknown card [ 21:36:28 ] [ Loader ] Trying Irdeto (T=14) [ 21:36:28 ] [ Loader ] Reader type dbox on node /dev/tts/1 [ 21:36:28 ] [ Dbox ] Opening device /dev/tts/1 [ 21:36:30 ] [ Loader ] Unknown card [ 21:36:30 ] [ NewCS ] Ready to GO! <img src="/forums/images/graemlins/smile.gif" alt="" /> /var/emu # [ 21:36:30 ] [ Loader ] Reader type dbox on node /dev/tts/1 [ 21:36:30 ] [ Dbox ] Opening device /dev/tts/1 [ 21:36:31 ] [ Loader ] Unknown card [ 21:36:31 ] [ Loader ] Trying Irdeto (T=14) [ 21:36:31 ] [ Loader ] Reader type dbox on node /dev/tts/1 Ik heb 2 images geprobeerd deze sporter en een enimage image. mvg, Sander Multcam even op 6MHZ zettten en je probleem is opgelost.
duncanvdlinden Geplaatst: 5 november 2005 Geplaatst: 5 november 2005 Citaat: Oke, gewoon één simpele vraag. Ik heb een dbox2 met een sportster 1.0 image nederlands In de dbox2 zit een multicam. Hoe krijg ik beeld? Kortom, wat moet ik verder nog aanpassen je moet mgcamd en newcamd downloaden met de ingebouwde updater van sportster pro, deze moet je uitschakelen. dan moet je zoeken naar de newcs r3 emu downloaden, deze plaatsen in /var/emu/ de benodigde config file daarvan editten. dan start je vanuit telnet die newcs, deze start ook newcamd server mee. als dit helemaal goed gaat, dan kun je de mgcamd client starten, ook uitvoeren vanuit telnet. Dbox: Sagem 1x Intel mulicam.ng(autoclock) sporster pro 1.03 rc15
Gast Geplaatst: 6 november 2005 Geplaatst: 6 november 2005 Thankx, maar ik dacht dat er al kan en klare images waren. Denk stop er een tvhome kaartje in, en het draait. Hier gaat me allemaal teveel tijd in zitten. Koop wel een originele samsung, dan werkt het gewoon zeker, zonder daar uren werk in te stoppen. Maar toch bedankt Ecco
Weazel Geplaatst: 6 november 2005 Geplaatst: 6 november 2005 newe versie van newcs is uit http://www.sat4all.com/forums/showflat.p...;page=0#1013905
Gast Geplaatst: 7 november 2005 Geplaatst: 7 november 2005 Citaat: Thankx, maar ik dacht dat er al kan en klare images waren. Denk stop er een tvhome kaartje in, en het draait. Hier gaat me allemaal teveel tijd in zitten. Koop wel een originele samsung, dan werkt het gewoon zeker, zonder daar uren werk in te stoppen. Maar toch bedankt Ecco Ik irriteer me aan deze en de voorafgaande gemaakte post. Ten eerste verwacht je een antwoord op een door jou uitgedrukt 'simpele' vraag wat nu inmiddels al 20 pagina's lang is en ik krijg het idee dat er totaal niet eens de moeite is genomen dit topic door te nemen. Ten tweede had je allang kunnen weten dat een dbox2 decoder geen standaard huis tuin & keuken decoder is toen je je eigen dbox2 ging aanschaffen, en dat je er zowiezo meer vanaf moet weten om het te programmeren. Ten derde is je laatste post totaal overbodig, je had kunnen weten door even terug te bladeren dat er allang kant en klare images aanwezig zijn en dat je het zelfs na kan reproduceren in +/- 10 minuten werk. Vervolgens sluit je af dat je een Samsung decoder wil aanschaffen omdat je ervan overtuigt bent dat het niet werkt... en uren werk? Laat me niet lachen. Het verbaasd me dat een moderator hier nog niet heeft huisgehouden.
Ron Geplaatst: 7 november 2005 Geplaatst: 7 november 2005 Ecco, de volgende keer exit? Regels lezen of opzouten om maar even in jouw taalgebruik "stijl" verder te gaan.
Gast Geplaatst: 7 november 2005 Geplaatst: 7 november 2005 Ik ben volgens jou 'schijterig' als ik me netjes aan de wetgeving wil houden? Irdeto heeft reeds aangekondigd dat dergelijke images gepubliceerd en verwezen wordt op websites illegaal zijn, waar FastLemmy en Frenck mee zijn geconfronteerd. Ik pas me daarom aan, net als de rest. Dat jij het een probleem vind moet je bij Irdeto wezen. Inmiddels is je 'spot' aangepast, want ik kan me niet herinneren dat ik jou toestemming heb gegeven om mijn url te posten.
Gast Geplaatst: 7 november 2005 Geplaatst: 7 november 2005 Doe mij de exit dan maar, want hier wordt ik geen steek wijzer. En pSycho, je doet je naam eer aan. ecco [color:"red"] op verzoek exit [/color]
Gast Geplaatst: 8 november 2005 Geplaatst: 8 november 2005 Al maanden volg ik dit topic, en met veel plezien moet ik zeggen. Ook ik heb de Sportster inmiddels met veel genoegen draaien. Het is echter wel jammer dat ondanks de kennis op deze site niemand de moeite neemt e.e.a. goed op papier te zetten. Daarom kon ik het niet laten me vandaag ook te registreren en toch even te reageren. Het gros van de box eigenaren is een leek op dit gebied. Daarom kon ik me de vraag van de heer of mevrouw ecco goed voorstellen. Hoewel ik de reactie van pSycho-Y2K kan begrijpen, vind ik hem wel een beetje kortzichtig, en inderdaad denigrerend ! Jammer en daarbij wat zeggen ze toch altijd? twee vechten, twee schuld
Moderator Matchless Geplaatst: 8 november 2005 Moderator Geplaatst: 8 november 2005 Citaat: Het gros van de box eigenaren is een leek op dit gebied. Daarom kon ik me de vraag van de heer of mevrouw ecco goed voorstellen. Zolang het bij een vraag blijft is er niks mis. Gaat een lid de normale regels te buiten door te schelden,vloeken, grove taal of dreigingen dan kan hij/zij verwachten dat hij/zij een uitbrander krijgt van een mod. Maar nu weer ontopic graag want dit heeft weinig met de hobby te maken. Een smartphone is een hulpmiddel, geen levensstijl Kijk rond IN de wereld in plaats van voorover gebogen NAAR de wereld.
dboxje Geplaatst: 8 november 2005 Geplaatst: 8 november 2005 Inderdaad! laten we maar weer on-topic gaan... Heb een vraagje over het volgende: Na het wisselen van een paar zenders of het omschakelen naar een zender waar ik geen recht op heb (en dus ook niet kan bekijken) blijven, soms, andere gecodeerde zenders ook niet zichtbaar. Het lijk erop dat 1 van de mgcamd processen stopt. Na het herstarten ervan doet alles het weer. Iemand enig idee?
Weazel Geplaatst: 8 november 2005 Geplaatst: 8 november 2005 ik heb er ook last van mgcamd of evocamd heeft een camd reset nodig na een reboot. waar zal dat aan liggen?
Gast Geplaatst: 8 november 2005 Geplaatst: 8 november 2005 Dit komt mij ook bekend voor nu je het zegt. Misschien dat Neutrino hier wat moeilijk over doet, aangezien Enigma daar geen last van heeft (toen het nog werkte). We zouden de code even moeten bestuderen, maar voor zover ik weet heb ik in mijn start.local de emu's eenmalig laten opstarten en vervolgens zie ik in de terminal dan ook alleen die processen en geen dubbel gestarte emu's. Nog even over het vorige akkefietje: Sorry dat ik zo uit de school klapte, het was niet de bedoeling om er een negatieve toon aan te geven. Ik was geirriteerd door zijn gedrag en stijl en ik had dat anders aan kunnen pakken. Voor eventuele vragen over kant en klare images sta ik ter beschikking.
