Kabel Images TVHome voor de Dbox2
ok ik heb mijn mastera op mijn pc nu en heb de windows versie van newcs opgestart.
nu zie ik dit,
Reading Config file newcs.xml
level: normal
type: init
output: all
logger config: level 1 type 3 output 255
log file:
logger: cant open file , file log disabled
udp log: host port 0
tcp port: 0
logger: tcp port open failed, tcp log disabled
[ 13:03:11 ] [ Box detect ] Windows 2000 Build 2195
[ 13:03:11 ] [ Config ] com1 ECM priority: round
[ 13:03:11 ] [ EMM Cache ] Initialising Cache with 10 entries
[ 13:03:11 ] [ ECM Cache ] Initialising Cache with 10 entries
[ 13:03:11 ] [ Loader ] Reader type phoenix on node com1
[ 13:03:11 ] [ Phoenix ] Opening device com1
[ 13:03:11 ] [ Phoenix ] Setting baud to 16129
[ 13:03:11 ] [ Phoenix ] Failed changing baud to 16129, trying 16457 instead
[ 13:03:11 ] [ Phoenix ] Setting baud to 16457
[ 13:03:12 ] [ Loader ] Unknown card
[ 13:03:12 ] [ Loader ] Trying Irdeto (T=14)
[ 13:03:12 ] [ Loader ] Reader type phoenix on node com1
[ 13:03:12 ] [ Phoenix ] Opening device com1
[ 13:03:12 ] [ Phoenix ] Setting baud to 9600
[ 13:03:12 ] [ Loader ] Init Irdeto card
[ 13:03:13 ] [ Keyman ] Adding key type 0 on Provider 000000 for caid 0604 ID=0
[ 13:03:13 ] [ Keyman ] Adding key type 1 on Provider 000000 for caid 0604 ID=0
[ 13:03:13 ] [ Keyman ] Adding key type 1 on Provider 000001 for caid 0604 ID=1
[ 13:03:13 ] [ Keyman ] Adding key type 1 on Provider 000002 for caid 0604 ID=2
[ 13:03:13 ] [ Keyman ] Adding key type 1 on Provider 000003 for caid 0604 ID=3
[ 13:03:13 ] [ Keyman ] Adding key type 9 on Provider 000000 for caid 0604 ID=0
[ 13:03:13 ] [ Loader ] Card 0604 on port com1 ready
[ 13:03:13 ] [ Loader ] Starting Newcamd Server on port 10110
Nu heb ik in newcamd.conf staan dat ie naar het ip van mijn computer moet en connecten op poort 10110.
Wachtwoord enz ingevoerd maar connecten ho maar.
Wie heeft er nog een hint voor mij?
Gr Cb1
  • Reacties 591
Geplaatste afbeeldingen
CB1, heb nu eindelijk hetzelfde output in mijn terminalvenster (maar dan poort 15000) <img src="/forums/images/graemlins/smile.gif" alt="" />
Sagem D-Box2 met Multicam en NewCS en MGCamd draaiende op de Dbox.
Wat bleek, bij de Sagem moet de kaart er echt ver in, hoe stroef het ook gaat (kreeg echt de indruk dat de kaart kapot ging)
/var/emu # ./newcs
Reading Config file /var/tuxbox/config/newcs.xml
level: normal
type: init
output: all
log file:
Host lookup of failed
logger: cant connect udp to :0, udp log disabled
tcp port: 3001
[ 13:09:18 ] [ Box detect ] Box type 4
[ 13:09:18 ] [ Config ] /dev/tts/1 ECM priority: round
[ 13:09:18 ] [ EMM Cache ] Initialising Cache with 10 entries
[ 13:09:18 ] [ ECM Cache ] Initialising Cache with 10 entries
[ NewCS ] Process id 229
[ 13:09:18 ] [ Loader ] Reader type dbox on node /dev/tts/1
[ 13:09:18 ] [ Dbox ] Opening device /dev/tts/1
[ 13:09:19 ] [ Loader ] Unknown card
[ 13:09:19 ] [ Loader ] Trying Irdeto (T=14)
[ 13:09:19 ] [ Loader ] Reader type dbox on node /dev/tts/1
[ 13:09:19 ] [ Dbox ] Opening device /dev/tts/1
[ 13:09:21 ] [ Loader ] Init Irdeto card
[ 13:09:21 ] [ Keyman ] Adding key type 0 on Provider 000000 for caid 0604 ID=0
[ 13:09:21 ] [ Keyman ] Adding key type 1 on Provider 000000 for caid 0604 ID=0
[ 13:09:21 ] [ Keyman ] Adding key type 1 on Provider 000001 for caid 0604 ID=1
[ 13:09:22 ] [ Keyman ] Adding key type 1 on Provider 000002 for caid 0604 ID=2
[ 13:09:22 ] [ Keyman ] Adding key type 1 on Provider 000003 for caid 0604 ID=3
[ 13:09:22 ] [ Loader ] Card 0604 on port /dev/tts/1 ready
[ 13:09:22 ] [ Loader ] Starting Newcamd Server on port 15000
[ 13:09:22 ] [ NewCS ] Ready to GO! <img src="/forums/images/graemlins/smile.gif" alt="" />
/var/emu #
Mooi nu moet ik nog hehe.
de server draaid maar krijg geen connectie.
Moet ik bij de windows versie ook met een hexeditor 11 22 33 44 55 66 77 88 vervangen voor 00?
wordt een beetje deprie van.
vorige week zondag de hele dag bijna en nu ook al vanaf 10 uur vanmorgen maar nog steeds niets.
moet het nu toch doen lijkt mij.
Cb1
CWS = 192.168.1.2 15000 local local 01 02 03 04 05 06 07 08 09 10 11 12 13 14 lan cardserv
= ip computer
<newCSconfig>
<readers name="Card Readers">
<device>
<name>phoenix</name>
<type>Phoenix</type>
<node>COM1</node>
<mhz>600</mhz> <!-- or 357 -->
<parity>odd</parity>
<export>yes</export>
<enabled>yes</enabled>
<blocksa>No</blocksa>
<blockua>No</blockua>
<blockga>No</blockga>
<boxid>0000000000</boxid>
<PTShandshake>no</PTShandshake> <!-- Set to yes(if wanted) for cryptoworks, Viacess and cas7 Conax-->
<crypto-special>no</crypto-special>
<carddetect>yes</carddetect>
<newcamd_port>15000</newcamd_port>
<priority>round</priority> <!-- hard is default -->
<sid>
<allow>
<!-- valid value for id are:
4 numbers, if the service id is 3 numbers, add a 0 infront of it. -->
<id></id>
</allow>
<deny>
<id></id>
</deny>
</sid>
</device>
</readers>
<radegastserver>
<enabled>no</enabled>
<port>10001</port>
<allow>ALL</allow>
</radegastserver>
<cache>
<emm>10</emm>
<ecm>10</ecm>
</cache>
<debug>
<level>normal</level>
<type>init</type>
<output>all</output>
<logfile></logfile>
<console_options></console_options>
<file_options></file_options>
<udp_host></udp_host>
<udp_port></udp_port>
<udp_options></udp_options>
<tcp_port>3001</tcp_port>
<tcp_options></tcp_options>
</debug>
<newcamdserver>
<name>cardserv</name>
<deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
<userfile></userfile>
<user>
<name>dummy</name>
<password>dummy</password>
<au>on</au>
</user>
<user>
<name>local</name>
<password>local</password>
<au>on</au>
mgcamd config
# EMM messages
# 00 don't show any EMM's (default)
# 01 show only valid EMM's
# 02 show valid and bad EMM's with complete data display
M: { 02 }
# ECM messages
# 00 don't show any ECM's
# 01 show only valid ECM's (default)
# 02 show valid and bad ECM's with complete data display
C: { 02 }
# AU
# 00 is ignored (default)
# 01 enable AU
# 02 AU Auto
A: { 01 }
# Key update
# 01 update only new keys (default)
# 02 update all keys (used for valid PMK checking)
U: { 01 }
# Key files folder
# 00 keyfiles in /var/keys (default)
# 01 keyfiles in /var/tmp
T: { 00 }
# network mode, use summ for several clients
# 00 no network (default)
# 01 newcamd netclient
# 02 radegast netclient
# 04 camd3 netclient
G: { 01 }
# network retry
# 00 disable (default)
# 01 retry every new ecm
# 02 try to connect to offline shares every 10 min
# 03 both
N: { 01 }
# network ecm timeout in seconds
K: { 10 }
# newcamd dead routes connect retry, sec
Q: { 600 }
# network shares priority
# 00 newcamd, radegast, camd3 (default)
# 01 camd3, radegast, newcamd
# 02 newcamd, camd3, radegast
P: { 02 }
# on screen display type
# 00 No OSD (default)
# 01 neutrino
# 02 enigma
O: { 00 }
# on screen display Options
# 01 show emu ecm
# 02 show network shares messages
# 03 all (default)
# 04 show decoding failed / fta
# 08 show emm keys update
S: { 03 }
# Log options
# 00 Off (default)
# 01 Network
# 02 console
# 03 both
L: { 00 } 127.0.0.1 28007
# cache ecm pids and data used to open channels,
# store pids in /tmp/ca_cache.list at exit, load at startup,
# same syntax as restore.list
# 00 Off (default)
# 01 Ecm pids cache
# 02 Ecm data cache
# 03 both caches
H: { 00 }
# reread files on zap:
# 00 No (default)
# 01 config (including priority and ignore, but not replace/cache)
# 02 config and keys
# 03 both
R: { 00 }
# debug
# 00 off (default)
# 01 on
D: { 00 }
heb alles gedaan maar niets nada noppes.
heb ook letterlijk alles gekopieerd van je en het ip veranderd in het ip van de computer waar alles op draait.
snap er niets van.
Cb1
Alles schijnt nu te werken dwz de kaart wordt herkend, de processen draaien.
Zit ik alleen nog met mijn probleem dat ik alleen FTA's kan zien <img src="/forums/images/graemlins/confused.gif" alt="" />
Het is een originele kaart die ik vrijdag heb gekocht.
Enige idee wat dat zou kunnen zijn? Toch nog de settings (zie bijlage) ? Of?
Help!
1008414-settings.zip
DM800 HD - Met OpenPLI
Dat is bedoeling als het weer werkt
de dbox heeft ip 10.0.0.32
de comp (server) 10.0.0.13
newcs heb ik poort 14000 staan.
user en passw local local
ik draai met newcamd.
hier heb ik CWS_MULTIPLE = 10.0.0.13 14000 local local 01 02 03 04 05 06 07 08 09 10 11 12 13 14 lan cardserv
maar hoe zit het met de cardserv?
moet dit geen newcs zijn?
Volgens mij strand het hierop.
Cb1
Voor alle duidelijkheid:
Nokia Dbox2 met Mastera IV op de seriele poort / originele TVHome kaart
@Timelezzz
Wil je misschien even je newcs.xml en newcamd.config als bijlage willen toevoegen aan een post.
heeft ie gedaan
zie al een fout
in new camd
CWS = localhost 15000 localhost w8woord 01 02 03 04 05 06 07 08 09 10 11 12 13 14 lan cardserv
local host kan je ook vervangen door 127.0.0.1
en pasward is verkeerd
CWS = 127.0.0.1 15000 localhost localhost 01 02 03 04 05 06 07 08 09 10 11 12 13 14 lan cardserv
moet het zijn
cb1 zoals jij de naam geeft in newcs.xml voor de newcamd server zo moet hij ook in newcamd.conf genoemd worden waarom heb jij cws multiple?
setting voor multicam en externe programmer vershillen kwa ip nr's enzo dus kijk daar mee uit
Die resets van newcs had ik ook.
Oplossing: newcamd NIET door de Dbox laten opstarten (als extra emu).
De newcamd wordt door de Newcs opgestart als alles ok is.
@Weazel: ik zal eens kijken hoe een en ander staat dan.
Kom ik op terug.
@Timelezzz: ik starte op de dbox newcs op in telnet.
Moet ik newcs dan in het emumenu opstarten?
@all: op dit moment start ik newcs windows versie op de comp.
En probeer met de comp te connecten maar tot nu toe zonder resultaat.
Cb1
Ik zit nu met dit dilemma:
De connecties worden gemaakt en de configs zijn oké afaik.
Dit is de output van de nullmodem als ik zap. Wat zou er hier gebeuren?
Dat laatste stuk is door ZapIt, waarschijnlijk een bouqetten applicatie?
tuxbox mgcamd by mixvt Aug 29 2005 12:01:03 (netclient, beta14)
[mg] Net:1:1:2:10s Show ecm:2, emm:2 Up:1 Au:1 Dir:0 Osd:neutrino:3 Cache:0 Log:
2:127.0.0.1:28007 Reread:0
AutoRoll.Key: No such file or directory
/var/keys/Conax.Key: No such file or directory
SoftCam.Key: No such file or directory
newcamd connect timeout 2000, keep alive: 0
connecting to newcamd route local:192.168.0.200:15000...
[ 15:03:01 ] [ Newcamd:15000 ] Connection from 192.168.0.200
Client <- Server:
000: 25 B7 6A 79 B8 73 9F 86 4B D3 16 C2 60 01
Client -> Server:
000: E0 00 1A 6C 6F 63 61 6C 00 24 31 24 61 62 63 64
010: 65 66 67 68 24 75 77 62 37 4D 52 45 75 30 73 79
020: 43 69 5A 4D 43 50 4A 49 31 44 31 00
Connecting to 127.0.0.1[127.0.0.1]:80
[ 15:03:01 ] [ Newcamd:15000 ] User local logged in, client: Generic
[mg] newcamd route 192.168.0.200:15000: get msg problem, will try to reconnect
Client <- Server:
000: E1 00 00
[newcamd client] login to 192.168.0.200 as local accepted
Client -> Server:
000: E3 00 00
mylist 100% |*****************************| 2311 --:-- ETA
Client <- Server:
000: E4 10 38 01 06 04 00 00 00 00 18 66 26 EC 04 00
010: 00 00 00 00 00 00 00 00 1B 00 00 00 01 00 00 00
020: 00 00 FF FF FF 00 00 02 00 00 00 00 00 FF FF FF
030: 00 00 03 00 00 00 00 00 FF FF FF
EMM enabled, Card serial: 186626EC
userid 1 caid 604 providers 4
idents: 000000 000001 000002 000003
ids: 1B00 FFFFFF FFFFFF FFFFFF
mych 100% |*****************************| 11 --:-- ETA
1b03e86979
BBC 3
found channel number: 10
zapped to BBC 3
PES, queue 0 normal.
[zapit] ONID:0x3E8 TSID:0x1B PMT-PID:0x44C
got 42 cmd 9F
[mg0] service 6979 index 0 pmt pid 44C, pids: 0x1450
[mg0] camd stoping..
[CBasicClient] connect failed.
/tmp/camd.sock01: No such file or directory
/tmp/camd.sock02: No such file or directory
/tmp/camd.sock03: No such file or directory
/tmp/camd.sock04: No such file or directory
video: 0x1450
pcr: 0x1450
