Gast Geplaatst: 6 juni 2002 Geplaatst: 6 juni 2002 Hello, I have try to make log on a nokia receiver with MM (Pentacrypt). But with no success. I have try many differents speed port but without success. Is any one have the right settings for logging ? I use season type card adapter whithout external power supply. I have tested with many log soft or emu and nothing work... What is the speed of data ? What is the speed for ATR ? Or there is some prob with ATR delay ? @ushtar : - I have take a look , you sure linux to compile your project, i have searched for an SDK for ARM7 ans picked some info about ARM7 embeded on MM. I want to make some project for it, if you have some infos, it will be great for me.. Like init, register and anything like that. I have a little analysed your code in ASM but it is hard labour for well understanding what it does... So you made great jobs, wizard!! But i dunno rip your code or patch it. I repect your work! I would like to take at start or seeing my project grows by itself <img border="0" title="" alt="[smile]" src="images/icons/smile.gif" /> - Did you have a solution with success for universal settings for logging with MagicModul. Best regards, CU L8tr
