(<:0031515>[1-9]xxxxxS0 | <:0>0<:31>[1-7]xxxxxxxxS0 | <:0>0<:31>[89]x. | <:>00x. )
dit is mijn huidige dialplan. met hekjes gaat ie niet bellen, zonder hekjes wel (moet dan eerst wel de lijn kiezen d.m.v het hekje). het regionummer-probleem is hiermee wel opgelost waarvoor dank.
merDe
deze ruimte is te huur
Probeer deze eens:
(<:#><:0031515>[1-9]xxxxxS0 | <:#><:0>0<:31>[1-7]xxxxxxxxS0 | <:#><:0>0<:31>[89]x. | <:#><:>00x. )
Big fellow
“Success is not final, failure is not fatal: it is the courage to continue that counts.” ~ Winston Churchill
Hier ook nog iets op GoT gevonden, uitleg van de syntax van Dialplans.
[color:"brown"]Dial Plans
Dial plans can be very confusing at first glance. However they are invaluable feature of the SPA-3000 so you should at least learn the basics of how they work.
Dial Plan Syntax
( ) - The entire dial plan must be surrounded by an open and close bracket.
| - Each individual dial plan must be separated by a pipe | character.
0-9 - Treated as normal digits
x - Treated as any normal digit 0-9 on phone
* - Treated as normal * character on phone
# - Treated as normal # character on phone
. - Repetition
< : > - Replacement, eg <02:612> means replace 02 with 612
<:@gw0> - Gateway 0 is the PSTN line
<:@gw1> - Gateway 1 (Advanced Feature)
<:@gw2> - Gateway 2 (Advanced Feature)
<:@gw3> - Gateway 3 (Advanced Feature)
<:@gw4> - Gateway 4 (Advanced Feature)
S0 - Dial Immediately
! - Barring a number, place this at the end of the number to bar it
, - Provides a dial tone
[ ] - Limiting choices, eg [24] means either 2 or 4, [2-5] means 2,3,4 and 5, [24-68]
means 2,4,5,6,8
Example Dial Plans
Dial Plan 1: (000S0<:@gw0>)
Description: The above dial plan is extremely simple, yet extremely important. When
you dial 000 (Emergency number) your call will go out through Gateway 0
(<:@gw0) which is your normal PSTN line, immediately (S0) after you have
dialed the 3rd 0.
Dial Plan 2: (000S0<:@gw0>|1800xxxxxxS0<:@gw0>)
Description: The above dial plan contains two individual plans, building on from Dial
Plan 1. You will notice that a | separates the 1st dial plan from the 2nd .The
2nd dial plan is used to route 1800 numbers through the your PSTN line. It
works the same way as the 1st dial plan, in that when you dial a 1800 number
followed by 6 other digits (0-9) it will be directed through your PSTN line.
Dial Plan 3: (<*1:0123456789>)
Description: This plan demonstrates replacement. If you dial a * followed by a 1 then the
number 0123456789 would be dialed.
Dial Plan 4: (<0:61>[2-9]xxxxxxxxS0)
Description: This plan demonstrates replacement and limiting choices. When you dial an 0
followed by a 2,3,4,5,6,7,8 or 9 and then nine of any other digit (0-9) it will
prepend 61 and remove the 0. So if you rang 02 123456789 the actual number
that would be called would be 61 2 123456789.
Dial Plan 5: (1900xxxxxx!)
Description: This plan demonstrates number barring. If you enter a 1900 followed by 6
more digits (0-9) you call will not be placed.
Dial Plan 6: (<#9:>xx.<:@gw0>)
Description: This plan demonstrates replacement and repetition. When you enter a #9
followed by any number of digits(a timeout is used to determine the end) it
will go out through the PSTN line (Gateway 0).
Putting it all together
Dial Plan 7: (000S0<:@gw0>|1800xxxxxxS0<:@gw0>|1300xxxxS0<:@gw0>|
1900xxxxxx!| 0[2-9]xxxxxxxxS0|<#9:>xx.<:@gw0>)
Description: This plan combines elements from all the above dial plans. It routes all 000,
1800, 1300 calls out via the PSTN line. Its bars 1900 numbers. It allows an
Australian land line to be called and it also allows you to select the PSTN line
by dialing a #9.[/color]
@OkA : zal es kijken
@Big Fellow : neen, in het info-scherm zie ik dat ie weer een #'je belt. als ik uit het dialplan haal zoals in mijn eerdere posting, werkt het wel (handmatig # 'je drukken).
ik kan er mee leven, wordt een lange-termijn klus <img src="/forums/images/graemlins/smile.gif" alt="" />
merDe
Waarom draai je de lijnen niet om???? gebeld worden op lijn 2 en bellen op lijn 1.
Zo werkt het bij mij prima.
Scheelt een hoop werk en de uitkomst blijft gelijk.
Pjotr
