Gast Geplaatst: 7 februari 2002 Geplaatst: 7 februari 2002 Read me for Multidec 8.0 TV-hacking by Happysat and Erazor 29-01-2002.<p>Introduction: Who operates this program without an official subscription of premiere World or other providers, makes itself punishable!!!! This program is not written by me, only this assistance file!! You find this program and more @ www.netzagent.com/freetv.<p>1. What do u need:<p>DVB-S Card with running drivers (note Multidec only runs on Hauppauge/Technotrend cards supported with driver 2.08 and 1.3 Data Only) Windows (98/me/2k/Xp) with Direct X installed Free HD-space ;-) PC @ 300 MHz New key file (for decrypting channels found @the bottom of this page or is included) It's not needed to have a Common Interface or Smartcard it's all done with Softcam. Supported DVB-S Cards as far as i now MD runs on: Hauppauge/Technotrend/Galaxis and Skystar1 (Skystar2/ SATDEM/or Pentamedia are NOT WORKING ) Multidec has it's one HAL-Driver<p>Update Patched DLL HAL-Driver<p>(Old one have bad registration info inside)<p>No more error message on Skystar1 DVB-S <p> Multidec-HAL-Driver MDHALDR could not be registerd.!<p>Solution: -Uninstall Windriver, in registry delete windriver and HAL-treiber(driver) reboot after that.<p>2. Program Installation:<p>Download English Multidec GEEN URLS!!://members.home.nl/happysat/MD/MD80_English.rar (Keys/DVB-list and Softcam 1.2 allready included) Extract MD80_English.rar from you're download directory and run Multidec.exe. For the Orginal german MD GEEN URLS!!://freetv.321host-it.com/digi/md80/MD80.zip For Italian Multidec8.0 (click here) and complete Help-Tutorial (Click-here) Extract MD80Dll.zip and place the extracted files in the root of Multidec. GEEN URLS!!://freetv.321host-it.com/digi/md80/MD80dll.zip Place the keyfile also in the root of MD. GEEN URLS!!://www.erazor2001.f2s.com/files/softcam.key (updated 3-2-2002)<p> 3. Program Configuration and channels scanning: Start Multidec. If the program not starts there's smth wrong with the driver , make sure btw all europeonline software is stopped like Fazzt and also the dvb data app or reboot. Now is a black field with a menu border before you. Goes first on on the first " Saxxxx " and on LBN to adjustments.<p>Set the adjustments for the card and LNB by yourself. With LNB I would set however min frequency to 11600 and with channel/available symbol rates only the 27500 and 22000 (otherwise only 0 for all symbolrates). <p>All you have to do now is scan all channels. Goto Kanäle/Scannen/Alle Frequenzen and hit start. Scanning may take some time!!<p>If it's all 2 much work you can import a DVB settings list from GEEN URLS!!://members.home.nl/happysat/MD/Astra.dvb all astra channels, GEEN URLS!!://members.home.nl/happysat/MD/AllSats27012002.dvb all other sat's and transponders GEEN URLS!!://members.home.nl/happysat/MD/Astra_Hotbird02022002.dvb Working for Palco-PPV , select kanale/import channel list to import the list.<p>The channel list has to be sorted out to much crap in it now, Goto Kanäle/Kanalliste/Konfigurieren and check the box under Digital Programme. Approx 500 channels will apear in the list. ca. 100 Free To Air and ca. 200Decrypted channels .<p>4. Doublecheck:<p>Are channels available? Does one get picture and tone with unencrypted programs? (otherwise LNB or other is falsely adjusted) ,is above on the right logging and the soft Ci menu enabled.? (Not needed when using the english Multidec all is include) (MDsoftci.dll from MD80dll.zip must be located in the root of Multidec!!) And do u have the keys in Soft-Ci/Soft-Cam ? (The key file has to be also in the root as said above!!)<p>Dont change this!<p>To the point:<p>For each programm you need a key wich is stored in a key file (see above). Untill now only betacrypt/Irdeto and Seca programms can be decrypted. Select a channel ( decrypted offcourse ) from the list, make sure it's broadcasting and not decrypted with Viaccess (for example we try premiere Movie 3).<p>Double click on the channel to see the properties.<p>Down left in the window there are three lines, all Betacrypt/Irdeto. ECM is very important (102b). Now we goto the"Soft-CI/Soft-Cam"menu. in that window a ECM-Pid and a key are required. The key is in the files stored and.. Called "Start mit Key-Dateien". But fisrt the ECM-Pid has to be entered, The ECM-Pid is formatted the following way 0xXXXX where XXXX is the ECM, which we read as above.<p> STRIKE. Now u have a picture and a sound and this windows will pop-up, this may not take any longer than 3 seconds, otherwise the ECM-Pid is wrong, or the current channel doesnt broadcast ATM<p> Note: every channel has it's own ECM-Pid...!!!!!!!!!!<p>5.Technical: Actually one can " decode " each channel, since one keeps the data unencrypted, but the hardware blocks these and lets it through only with the cards. This software pretends the PCI card a premiere or other card or lets the hardware through the data to the software. The keys are modified repeatedly by the ECM and must be updated.<p>6. Any questions:<p>Often are several encodings (and EMCs) in the window. First try out Irdeto if it not works try Seca.<p>Some programs leave themselves not to be decoded (no signature for keys)<p>Either one needs the new keys, or the channel cannot be decoded for example some ORF/Taquilla channels. Sometimes the pictures/sound does freeze up on Multidec it's course of the decoding, close Multidec and restart it again. <p> Can I also use the Tv-output of the Sat card , if one decodes? Yes, even if Multidec is minimized that goes still, since the audio and video data go directly from the card to the output. <p>6.Tips<p>Full-screen on Multidec -->>Ausgabe check Overlay , Check Nur ein halbbild and check Direct x overlay mit karten interrupt. Full-Screen on English version --->>> Display check Overlay, Check Half-Image display output and syncronize card with interrupt.<p>7.Updates:<p>GEEN URLS!!://members.home.nl/happysat/MD/MD80_English.rar Full version ( Keys/DVB-list/Seca.KD and Softcam 1.2 allready included+palco-fix) 03-02-2002<p>GEEN URLS!!://members.home.nl/sashara/a/MD8_ITA.rar Italian Multidec Translation done by Flossy-Vaffanculo sat<p>GEEN URLS!!://members.home.nl/happysat/MD/MdHalReg.rar Fixed HAL-Driver for Skystar1 cards<p>GEEN URLS!!://members.home.nl/raduga/pvas2014.zip MD recording can be fixed with this program<p>GEEN URLS!!://www.erazor2001.f2s.com/files/soft-ci12.rar Softcam 1.2 (has a small bug fix for Italian Palco-PPV)<p>GEEN URLS!!://www.erazor2001.f2s.com/files/softcam.key Updated keyfile (Palco-fix) 03-02-2002<p>GEEN URLS!!://erazor2001.portland.co.uk/files/k-id.rar Auto Detect Decrypt channels key file (Palco ect) 03-02-2002 <p>GEEN URLS!!://members.home.nl/happysat/MD/Astra_Hotbird02022002.dvb Astra/Hotbird DVB Diseqc Paclo works on this one 03-02-2002 <p>GEEN URLS!!://members.home.nl/raduga/md80Flossytutorial01.zip Italian Help Document flossy@linuxfreemail.com for Italian explanation problem<p>Disclaimer 1. Online-contents The author reserves the right not to be responsible for the topicality, correctness, completeness or quality of the information provided. Liability claims regarding damage caused by the use of any information provided, including any kind of information which is incomplete or incorrect, will therefore be rejected. All offers are not-binding and without obligation. Parts of the pages or the complete publication including all offers and information might be extended, changed or partly or completely deleted by the author without separate announcement. 2. Referrals and links The Author is not responsible for any contents linked or referred to from his pages - unless he has full knowlegde of illegal contents and would be able to prevent the visitors of his site from viewing those pages. If any damage occurs by the use of information presented there, only the author of the respective pages might be liable, not the one who has linked to these pages. Furthermore the author is not liable for any postings or messages published by users of discussion boards, guestbooks or mailinglists provided on his page. <p>3. Copyright The author intended not to use any copyrighted material for the publication or, if not possible, to indicate the copyright of the respective object. The copyright for any material created by the author is reserved. Any duplication or use of such diagrams, sounds or texts in other electronic or printed publications is not permitted without the author's agreement. <p>4. Legal force of this disclaimer This disclaimer is to be regarded as part of the internet publication which you were referred from. If sections or individual formulations of this text are not legal or correct, the content or validity of the other parts remain uninfluenced by this fact. <p>Mucha tnx to : Erazor (for help and updates), Satscan (keyfile/dvb-import list), Flossy from Vaffanculo-Sat :-)) (For Palco-keys/dvb-diseqc-list and the stream provider fix in Irdeto),and mzr90 for telling about the HAL-DRIVER FIX :-)<p>Greetings to all people on File Fetch Manager..!!!!!!!!!!!!!!<p>Any Comments about this help file or something u dont understand ------ -->>>
