Sigma Geplaatst: 2 oktober 2006 Geplaatst: 2 oktober 2006 allen lees nu eens de text file die ooit bij de update zat daar stond duidelijk in dat de multiple descramble service alleen werkt bij de PIP functie dus dit is een overbodige discusie zie hier onder regel NR14 1. IRD Status (1) System ID : 406 (2) Loader Version : L4.06 (3) Device Version : v5.2.69 (4) Application Version : TF-NCPC 5.11.85/TF-NPC 5.11.85 (5) Last Update : June 02 2005 2. Improvements of this version (1) The MP3 files with two ID3 headers can be playback from this version. (2) The Prev/Next keys can be used in the status of timeshift bar to move the playback position to the start of timeshift buffer or live picture. The Prev/Next mean the positioning keys of PIP sub-picture (|< or >|). (3) The current time will be shown in the "Timer Setting" menu. (4) There was no sound in case of MP3 playback with pin code window. It is fixed. (5) The service was not changed with V- key in case of the service count under 4 in EPG. It is fixed. (6) There was some cases that all the services were grayed in the service list while recording. It may be fixed :-) (7) The descrambling problem in the multifeed services is fixed. (8) Some new TAP functions are supported. Please refer to the new TAP document which will be avaialbe in several days. (9) The system hanged up when the EPG key was pressed in the file list while playback. It is fixed. (10) The system did not check the collision of recording reservation after changing the duration in the "End of Recording" window. It is fixed. (11) The subtitle was not erased in some cases. It is fixed. (12) The recording file with the recording time less than 1 minute will be deleted. Some previous firmwares had this problem. (13) The recording file name might be "***-2" even though there is no file of "***". It is fixed. Some previous firmwares had this problem. [color:"red"] (14) Dual descrambling in PIP is supported with the dual descambling CAM such as some versions of Aston CAM. [/color] (15) You can set the second audio and subtitle language. These selections will be activated if there is no track for the first language. (16) There was some display problem in the file list in case of some special characters in the file name. It is fixed. (17) The system hanged up when pressing OK key in "Conditional Access" menu. (TF5500PVR only) It is fixed. The last firmware had this problem. (18) There were the problems of freezing sub-picture or diabling timeshift in case of exchanging main-picture and sub-picture which is the service of different TP from the main picture. It is fixed. (19) The system hanged up in case of a very long time of turbo mode in Altair. It is fixed. (20) The system hanged up in case of starting recording with "Enrty Information" window.It is fixed. (21) The packet data of new PID was omitted if the PID information was changed at the starting point of recording. It is fixed. (22) There were some cases that it is impossible to activate the copy function for the recorded file. If you tried to copy the file at this case, the 0 MB file was created. No file will be made from this version. Mvrgr Sigma DM8000HD-PVR/DvD_DM7020HD-V2_DM800Se-V2_DM525 Harddisk Samsung 2TB__Tuner A :draaibaar Tuner B :vast Tuner C Tuner D Vantage 8000 S TWIN HDTV PVR
Neptunus Geplaatst: 2 oktober 2006 Geplaatst: 2 oktober 2006 Citaat: Hebben jullie ook gemerkt dat de Aston 1.07 een langere module is waardoor het klepje van de Topfield 5010/5510 niet goed sluit? Het kaartje drukt tegen de achterkant van het klepje aan waardoor deze klep van de Topfield niet naadloos sluit. Niet dat ik er last van heb maar is mij gewoon opgevallen. Hij is bij niet langer (de cam dan hé) maar wel moeilijker in te brengen (ik heb weer over de cam, viezeriken) de randen zijn dikker dan de aston 1.5, dat is lastig omdat ik bij oude opnamen de cam eruit trek om overschrijven van sleutels te voorkomen. Dreambox 8000 & VU+ Duo Synology DS201 NASITV van KPN + digitenne LG55B6V Oled TV
cosmos Geplaatst: 2 oktober 2006 Geplaatst: 2 oktober 2006 Citaat: Hij is bij niet langer (de cam dan hé) maar wel moeilijker in te brengen (ik heb weer over de cam, viezeriken) de randen zijn dikker dan de aston 1.5, dat is lastig omdat ik bij oude opnamen de cam eruit trek om overschrijven van sleutels te voorkomen. <img src="/forums/images/graemlins/grin.gif" alt="" /> Hij is ietsjes langer, neem een normale module mar en zet maar eens op elkaar. De kaart in de Aston Dual steekt ietsjes uit waardoor deze ietsjes tegen de achterkant van het klepje van de Topfield drukt waardoor het klepje niet naadloos sluit. DM8000 1TB HDD - ICVS + GP3 DM7025+ SC 300GB HDD/4GB CF + Dumbo - ICVS + GP3 Visiosat BIG Bisat |15°W|5°W|0.8°W|4.8°E|9°E|13°E|19.2°E|23.5°E|
Sigma Geplaatst: 3 oktober 2006 Geplaatst: 3 oktober 2006 ja ook hier geen probleem met het sluiten van het klepje Mvrgr Sigma DM8000HD-PVR/DvD_DM7020HD-V2_DM800Se-V2_DM525 Harddisk Samsung 2TB__Tuner A :draaibaar Tuner B :vast Tuner C Tuner D Vantage 8000 S TWIN HDTV PVR
Neptunus Geplaatst: 3 oktober 2006 Geplaatst: 3 oktober 2006 Nee, ik heb ook geen problemen met de sluiten van het klepje, het gaat erom die die module zeer stroef in de opening kan worden geschoven, de kaart er later in kan helemaal niet, de kaart eruit trekken waarbij de module moet blijven zitten ook niet. De module eruit trekken gaat zeer moeizaam, ik wilde al gaan vijlen! Vreemd dat ik daar niemand over hoor??? Dreambox 8000 & VU+ Duo Synology DS201 NASITV van KPN + digitenne LG55B6V Oled TV
MpF1 Geplaatst: 3 oktober 2006 Geplaatst: 3 oktober 2006 Ik had hier hetzelfde probleem en heb dus een klein vijltje gepakt en heel voorzichtig klein stukje aan beide kanten van de sleuf weg gevijld nu past de module perfect. <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> Dreambox One Ultra HD/Dreambox 8000 HD/Dreambox 500 HD/2x Xtrend ET400
Coszmo Geplaatst: 3 oktober 2006 Geplaatst: 3 oktober 2006 Volgens mij kijk je naar tuner 1 en druk je dan op de opname toets . Dan gaat het bij mij ook mis als ik iets opneem. Als je het in een timer zet met als default tuner 2 gaat het prima en neemt hij alles zonder mankeren op terwijl je zelf naar een gecodeerde uitzending kijkt. Eigenlijk , en dat zal je ook zeggen , moet hij vanzelf overschakelen naar een andere tuner als je de opname toets indrukt maar dat doet hij dus niet. <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> GROETEN ANTON AB IPBox 9000HD - Topfield 5500 PVR M-Vision FCIS7000+ No Name Schotel 100cm+Stab 120+MTI Bleuline Quad lnb 0,2Db
Coszmo Geplaatst: 3 oktober 2006 Geplaatst: 3 oktober 2006 Je zult wel gelijk hebben Sigma maar hoe kan ik dan een gecodeerde zender bekijken en een tweede , gecodeerde zender , opnemen? <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> GROETEN ANTON AB IPBox 9000HD - Topfield 5500 PVR M-Vision FCIS7000+ No Name Schotel 100cm+Stab 120+MTI Bleuline Quad lnb 0,2Db
Sigma Geplaatst: 3 oktober 2006 Geplaatst: 3 oktober 2006 ik kijk met tuner 1 en neem op met tuner 2 of andersom maar ik heb twee schotels en ik denk dat dat dus wel werkt want ik heb hier nog nooit een mislukte opname gehad wel niet vergeten de opname te decoderen Mvrgr Sigma DM8000HD-PVR/DvD_DM7020HD-V2_DM800Se-V2_DM525 Harddisk Samsung 2TB__Tuner A :draaibaar Tuner B :vast Tuner C Tuner D Vantage 8000 S TWIN HDTV PVR
Coszmo Geplaatst: 3 oktober 2006 Geplaatst: 3 oktober 2006 Precies , zo gaat het bij mij ook met getimede zenders. Dan neemt hijook op van tuner 2. In de haast vergeet ik 1 ding . Hij neemt gecodeerd op en niet gedecodeerd dus inderdaad dual decoderen werkt niet vandaar dat hij in de knoei komt zoals Vincent al zei. \ Is hier ook al eerder aan de orde geweest <img src="/forums/images/graemlins/grin.gif" alt="" /> <img src="/forums/images/graemlins/grin.gif" alt="" /> GROETEN ANTON AB IPBox 9000HD - Topfield 5500 PVR M-Vision FCIS7000+ No Name Schotel 100cm+Stab 120+MTI Bleuline Quad lnb 0,2Db
oldebroek Geplaatst: 3 oktober 2006 Geplaatst: 3 oktober 2006 <<Je zult wel gelijk hebben Sigma maar hoe kan ik dan een gecodeerde zender bekijken en een tweede , gecodeerde zender , opnemen?>> ik zie in je profiel dat je jags epg 3.0 gebruikt, even je instellingen goed zetten in jags menupunt 3- Record:default tuner zet deze op 4, nooit geen last meer van zwarte opnames (ik neem aan dat je jag gebruikt om timers te zetten) Groet JR Je hoeft niet aan een boom te hangen om een eikel te zijn.
Coszmo Geplaatst: 4 oktober 2006 Geplaatst: 4 oktober 2006 Ga ik uitproberen Bedankt <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> GROETEN ANTON AB IPBox 9000HD - Topfield 5500 PVR M-Vision FCIS7000+ No Name Schotel 100cm+Stab 120+MTI Bleuline Quad lnb 0,2Db
