Gast Geplaatst: 25 oktober 2006 Geplaatst: 25 oktober 2006 RELEASE NOTES 1.3.211.230 (October 20 2006), relative to 1.2.211.183 (August 2 2006) New Features: - recording popup switched off - more USB devices are accepted now Bugfixes: - Improved performance with long lists of audiotracks/subtitle languages - Improved performance of Personal Planner with long lists - Fast Scan implemented for L1/L2, NL & Flanders - box stuck in standby with unformatted HDD - Audio level on VCR SCART loop mode - reference transponder for astra 2a,2b updated - net5 added to dutch channellist - Terrestrial: Spontanious deactivation of active antenna - finish country added to quick installation guide (defaults to TS mode recording) - offline descrambling broken - TimeShift not working with Irdeto + TVV cams - No reset after OTA & SW update - Space Used bar in Offline Descrambling misplaced - Austrian pre-programmed channel list - CI Slots interchanged - 2xREC+TS on same transponder doesn't work - Wrong highlighting of event in EPG - Zapping around in TV vlaanderen bouquet with Canal Digital CAM+CARD will stop descrambling - Improvement of trickmodes in TS-mode - German Channel list not in right order - Offline Descrambling not working properly in standby - Mon-Fri events also occur in the past if programmed a number of existing events ahead -Time not fetched when boot into standby & EPG collection is ON - Hanger in editing room - Offline descrambling does not work when 2 CI modules are inserted - Cursor on empty position after channelsearch on satellite Thor - Picture viewer not working when subtitles are on - Database: Invalid channels: remove TSI 1, TSI 2, TSR 1, TSR 2 / Hotbird 12399H from database - Cosmetic (german language): "%" sign is not shown completely - Subchannel icon appear although there are no subchannels. - Wrong channel in PIP after swap (zap in PIP) - Add warning when changing OSD on VCR scart - Delay in zapping while EPG collection is ON
Norman Geplaatst: 25 oktober 2006 Geplaatst: 25 oktober 2006 Leuke bijkomstigheid is dat mijn 2 usb sticks nu wel worden herkend <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> Inverto 7000
Breebosje Geplaatst: 26 oktober 2006 Geplaatst: 26 oktober 2006 Ik heb de nieuwe firmware erop gekregen. Na wat zoekwerk heb ik het bin. bestand van de website van de importeur gehaald want ik had problemen met het rar. bestand van Rob Van Der Does Toch bedankt Rob want dakzij jouw is het ons toch gelukt. Nu hebben we nog een probleem dat als we een film ofzo gedecodeerd hebben en terug uit de bibliotheek gaan kunnen we nadien niet terug de bib openen vooraleer de PVR terug uit & in te schakelen. Heeft er nog iemand problemen mee hoe kunnen we dit oplossen??? Extrend ET8000 ...<br />nl. 1x met TV-Vlaanderen & 1x met Canaal Digital<br /><br />Grtjs Breebosje
JosFop4Sat Geplaatst: 26 oktober 2006 Geplaatst: 26 oktober 2006 Heb je na de upgrade wel een fabrieksreset (alleen inslellingen) en reboot gedaan? You can never solve a problem on the level on which it was createdGroeten, JosVU+DUO2-2-S2; 1xT/C; OpenATV 5.1; Logitech 700;Maximum E85 HB,A1,A2,A3
bladerunner Geplaatst: 26 oktober 2006 Geplaatst: 26 oktober 2006 Even een vraag m.b.t. de nieuwe software, als je time-shift gebruikt is er dan nog steeds het 'tijd-icoon' zichtbaar boven in beeld zoals bij een opname ook het 'rec.-icoon'. Alvast bedankt. Richard
Gast Geplaatst: 26 oktober 2006 Geplaatst: 26 oktober 2006 Time-shift tijd: ja, aanwezig, niet uitschakelbaar; Opname-symbool:ja, aanwezig, uitschakelbaar zoals altijd.
bladerunner Geplaatst: 26 oktober 2006 Geplaatst: 26 oktober 2006 Citaat: Time-shift tijd: ja, aanwezig, niet uitschakelbaar; Opname-symbool:ja, aanwezig, uitschakelbaar zoals altijd. REC Jammer, ik had deze informatie liever niet in beeld omdat het display dit al weergeeft. Automatisch i.p.v. de blauwe knop heeft dan toch mijn voorkeur. TIME SHIFT Bij time-shift blijft mijn beeld 'boxed', of is hier ook een oplossing voor ergens in het menu?
Gast Geplaatst: 26 oktober 2006 Geplaatst: 26 oktober 2006 Citaat: TIME SHIFT Bij time-shift blijft mijn beeld 'boxed', of is hier ook een oplossing voor ergens in het menu? Nee, helaas. Zo snel gaat het inwilligen van wensen niet.
bladerunner Geplaatst: 28 oktober 2006 Geplaatst: 28 oktober 2006 Ik krijg het 'probleem' wel verholpen via het menu van mijn TV maar gemak dient de mens. En zoals misschien al je weet; 'Aan hen die veel wensen, ontbreekt veel.' <img src="/forums/images/graemlins/grin.gif" alt="" />
Gast Geplaatst: 28 oktober 2006 Geplaatst: 28 oktober 2006 Kan je op de TV een Logo uitschakelen? Wat komt daar dan voor in de plaats? Ik ken deze optie wel van D-scaler (TV-software voor op de PC), maar niet van een TV. Welk merk/type?
Norman Geplaatst: 28 oktober 2006 Geplaatst: 28 oktober 2006 Hallo, Ik heb op dit moment bij geen EPG meer ( nu en daarna nog wel ) verder gaat hij niet meer, ligt dit aan de nieuwe firmware of is cd weer aan het kl...ten nu de tijd weer wordt verzet?? Norman Inverto 7000
JosFop4Sat Geplaatst: 28 oktober 2006 Geplaatst: 28 oktober 2006 Ik heb al van meerdere mensen gehoord dat de meerdaagse EPG van CD niet meer werkt. You can never solve a problem on the level on which it was createdGroeten, JosVU+DUO2-2-S2; 1xT/C; OpenATV 5.1; Logitech 700;Maximum E85 HB,A1,A2,A3
Gast Geplaatst: 28 oktober 2006 Geplaatst: 28 oktober 2006 Ligt waarschijnlijk aan CD. Die hebben de laatste tijd wel vaker problemen.
bladerunner Geplaatst: 28 oktober 2006 Geplaatst: 28 oktober 2006 Citaat: Kan je op de TV een Logo uitschakelen? Wat komt daar dan voor in de plaats? Ik ken deze optie wel van D-scaler (TV-software voor op de PC), maar niet van een TV. Welk merk/type? In mijn geval is het niet een kwestie van het logo uitschakelen maar er voor zorgdragen dat door het time-shift de opname niet 'boxed' wordt getoond. Zodoende 'verdwijnt' de time-shift indicator boven uit beeld, Ik heb een Loewe Nemos 32.
Norman Geplaatst: 28 oktober 2006 Geplaatst: 28 oktober 2006 Hallo, Als ik het wel goed heb kan je een opgenomen film op de achtergrond laten decoderen. Heb dat geprobeerd maar als ik de betreffende film selecteer om te decoderen, dan op de blauwe toets druk gaat hij de film decoderen. ALs ik dan op exit ( verlaten ) druk stopt hij ook met decoderen?? dit is toch niet juist, hij zou toch moeten doorgaan met decoderen?? Of doe ik iets niet goed. Norman Inverto 7000
