Not posted here yet so here it is, orion 3.000 for xcam premium orion.
At last EasyTv on astra works now.
This firmware is quite different from previous versions and uses different format for keyfile. Load firmware to block 2 and keyfile to block 14.
In cam menu you can not edit keys, but you can edit caid's. For example, crypto 0D03 is not there so E! Europe on hotbird doesn't clear. By changing a caid you don't need (like 0602) into 0D03, it will work. Same thing for Biss. Caids need to be entered in decimal, and after changing and saving you need to restart receiver. Xcrypt, viaccess and seca caids are fixed in firmware but not viewable in menu.orion_3000 version support CAS as below.
Xcrypt
Viaccess
VG(nds)
Mediaguard
Irdeto
Griffin
CTI
Cryptoworks - ChinaCrypt
Conax
orion_3000 version support EMU as below
cryptoworks
Irdeto1
Nagra1
Nagra2
Viacess
Seca1
BISS
and almost samrt card working on orion_3000.
From further tests it seems K3 card doesn't work with it and also Inxtc is not working with my receiver (it does with previous versions), the 2 Redlights are ok.
<img src="/forums/images/graemlins/wink.gif" alt="" />Groeten maxhum
kan je deze orion_3000 plaatsen in de Orion met de cas2 denk dus de Orion_3000_4Keyfile_02-11-06.key op 14 en Orion_3000_4.bix op 2
wat zijn de + punten
grtz,
Inderdaad bix op 2 en keyfile op 14 .
En er is ook al een keyeditor.
Testen met een cas kan geen kwaad je kan zo weer terug naar de vorige firmw.
+ punt? easy tv is toch leuk.De keyfile is dus compleet anders en niet uitwisselbaar met een gewone xcam softcam. groeten
even een reactie op duikertje:
Originally Posted by kamilz++ View Post
is that a new cam ?
if yes :
-> what the hell gonna happen the current xcam's
-> why the f*ck they made this new cam
if not :
-> is this a joke ? <img src="/forums/images/graemlins/grin.gif" alt="" />
idd atv, orf, easy TV ,redlight en andere gaan open toppie nu nog ff wachten tot zondag als ik mijn TV Vlaanderen smartcard terug heb of deze ook werkt en zijn updates binnenkrijgt
grtz,
Nu nog een versie voor de Angel, dan ben ik weer blij!
Keep sending 'm up! VU+Duo op Pli, Amiko 8900 Alien, Visiosat Bisatellite G4 + 17/8 multiswitch (en op reserve een TF 4000plus)
ja inderdaad werkt op zich goed en snel deze versie.
maar op een originele seca smartkaart heb ik geen beeld wel irdeto 2,
dus ik ben ook benieuwd of die tv vlaanderen smartkaart gaat werken,ik denk het
niet.
Hoi,
Heb 'm ook ff getest. ORF/ATV+ gaan open. Seca 2 kaart van CanalDigitaal werkt niet. Dus vooralsnog geen optie.
Helaas....
Gr,
Crypty
Vu+ Duo Twin HD PVR
Dreambox 7025 PVR
4x Quad LNB DiseqC -> Astra 1, Astra 2, Astra 3 & Hotbird
Triax 78cm Schotel
Kan het zijn dat hij kapot is gegaan? Als ik de nieuwe firmware erop zet, eindigt dat na 2 x update flash met de melding: Xcam0 not respond [87025353].
Is dat een slecht teken? Hij deed het nog wel voordat ik deze update deed. Nu niet meer...
ET10000
DM7020HD
Linux laptop en Linux zelfbouw NAS
