Gast Geplaatst: 23 januari 2007 Geplaatst: 23 januari 2007 hier nog wat bugs van een site uit europa over topfield wel niet in het nederlands Hi! Also, hier mal die Buglist der aktuellen beta: --- CAS-Timeshiftbuffer Bug If you fill the complete timeshiftbuffer with a scrambled channel (which is descrambled by your CAM/Smartcard) and than jump back a few seconds (e.g. 10 seconds with the blue key) in this buffer, the stream is scrambled from the position where you left the livestream and go back within the buffer. This only happens if the timeshiftbuffer is filled completely! Multicrypt Bug If you use Multicrypt function for your CAM and you start playback of a previous made recording (doesn't matter if CAS or FreeTV) while you are recording a scrambled service, this recording can't be decrambled from the moment where you start the playback. If you disable the Multicrypt function, there is no bad influence for the running recording if you start playback of a previous made recording. Multicrypt Bug 2 If you use Multicrypt function for your CAM and a scrambled recording is running and you switch to a different scrambled channel, the recording can't be descrambled from the position where you change the channel. Timesettings Bug (lowest Prio) If you enter the Timesetting Menu, the time will be reset to the last received time of a channel which is confirmed for updating Time. Example: If you limit the time update to channels on Frequency 12345MHz and watch a channel from this frequency at 10:20 o'clock the last time and watch other channels for about 30 Minutes from this time on, the time will be reset to 10:20 o'clock if you now access the Timesettings Menu. Wrong color of Dollarsigns If y recording is running on the inactive Tuner (e.g. Tuner 2) and the same channel is running on the active Tuner (e.g. Tuner 1), the recording is scrambled but shows a green Dollarsign. Non-Recording Timer A lot of our users make use of the Non-Recording timer (timer without recroding) to update their EPG-Date by the EPG TAPs. With actual firmware, the Receiver often didn't return into StandBy Mode after the time which is defined in this Non-Recording timer. With older Firmware (September 2005) this happen very seldom. If you maybe can take a look at that? You maybe can use Jags EPG to give it try with a EPG-Update during the timer is running?
Happy2000 Geplaatst: 24 januari 2007 Auteur Geplaatst: 24 januari 2007 Citaat: Ja en de software is niet van o6 DEC maar van 26 DEC maar dat terzijde <img src="/forums/images/graemlins/grin.gif" alt="" /> ............ Ik bedoel hiermee december 2006 <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> VU+ Ultimo 4K - DVB-C FBC - DVB-S FBC Tuners - VTI Image. Dreambox 8000HD PVR - 2x DVB-C 2x DVB-S Tuners - OpenATV, Image.Multi Focus Dish E85, 28,2E - 23,5E - 19,2E - 13E - 9E
Gast Geplaatst: 24 januari 2007 Geplaatst: 24 januari 2007 dus als je de epg gebruik dan kun je deze er beter niet opzetten .
mrbeegee Geplaatst: 24 januari 2007 Geplaatst: 24 januari 2007 Sinds ik de FW erop heb zitter er in al mijn opnames incl. timeshift allerlei storingen, blokjes e.d. <img src="/forums/images/graemlins/frown.gif" alt="" /><img src="/forums/images/graemlins/mad.gif" alt="" /> Ik ben nu toch maar eens teruggegaan naar de FW van juni 2005 ivm springen in gecodeerde opnames. TF5500PVR (Fw aug-07)HD: WD2500AVJB; X-cam Orion. Taps: 3PG, QuickJump, Mediamanager, Nicedisplay, Quicktimer; 2e ontvanger: Sony KDL-26EX555 met Aston 1.07 (Fw 2.26); Schotel: Triax TDS Ø 64cm met CD DUO LNB quad ;
Gast Geplaatst: 24 januari 2007 Geplaatst: 24 januari 2007 dat is nou net de reden dat ik ook de juni 2005 firmware draai
oldebroek Geplaatst: 24 januari 2007 Geplaatst: 24 januari 2007 De nieuwe software werkt hier perfekt, nog geen foutjes ontdekt. Wat wel is opgevallen: Springen in gecodeerde opnames met de silverline tap werkt nu net zo goed met de aston als op de oude software met de x-cam Opstarten van het display bij boot, kan nu goed zien dat ze er een soort 'safemode' voor de alfanumerieke (wat een woord)display hebben ingesleuteld. Zoals gezegd werkt prima, mijn Toppy werkt hier top! Je hoeft niet aan een boom te hangen om een eikel te zijn.
Gast Geplaatst: 24 januari 2007 Geplaatst: 24 januari 2007 Citaat: dus als je de epg gebruik dan kun je deze er beter niet opzetten . Nou, als ik de EPG in het menu aan zet en daarna niet meer opnieuw naar het EPG menu ga werkt de EPG gewoon. Als ik later toch weer via het menu naar EPG ga zet hij de EPG bij mij steeds op uit (Ook als ik de ontvanger een keer uit en aan heb gezet). De EPG info haalt hij verder gewoon op, alleen merkt ik wel dat als er nieuwe EPG data is binnengehaald deze data meteen op het scherm verschijnt. Ik moet eerst van kanaal wisselen voordat hij de programma's weergeeft. Bij mij werkt de EPG dus wel met deze versie maar niet zo soepel als de voorgaande versies. Nu dus maar weer hopen dat dit in de beta versie zit en dat het in de uiteindelijke versie weer is opgelost.
mrbeegee Geplaatst: 28 januari 2007 Geplaatst: 28 januari 2007 Citaat: Sinds ik de FW erop heb zitter er in al mijn opnames incl. timeshift allerlei storingen, blokjes e.d. <img src="/forums/images/graemlins/frown.gif" alt="" /><img src="/forums/images/graemlins/mad.gif" alt="" /> Ik ben nu toch maar eens teruggegaan naar de FW van juni 2005 ivm springen in gecodeerde opnames. Ik kwam erachter dat dat mijn HD vrijwel vol zat dus dat zou ook voor vreemde effecten kunnen zorgen. En omdat anderen geen problemen hebben met de FW heb ik hem nogmaals erop gezet en de opnames zijn tot nu toe goed.( mijn HD is nu weer halfvol) Tijdens het veranderen van de FW kreeg ik ook weer problemen met de volgorde van taps. De TF bleef maar vastlopen na op stop te drukken in de play-mode. Na veel verschillende volgorde's geprobeerd te hebben kwam ik erachter dat het met name door Nice Display!! veroorzaakt werd(uiteraard icm andere taps) Uiteindelijk heb ik een nieuwere versie erop gezet(V1.8 beta 1) en ook JAG vernieuwd(v3.0 beta 2) en nu gaat het eindelijk weer goed. TF5500PVR (Fw aug-07)HD: WD2500AVJB; X-cam Orion. Taps: 3PG, QuickJump, Mediamanager, Nicedisplay, Quicktimer; 2e ontvanger: Sony KDL-26EX555 met Aston 1.07 (Fw 2.26); Schotel: Triax TDS Ø 64cm met CD DUO LNB quad ;
Gast Geplaatst: 2 februari 2007 Geplaatst: 2 februari 2007 hier hetzelfde probleem met de epg .voor de rest draai het goed ook het springen en spoelen met de silverline 0.4 maar ik ben weer terug naar de juni 2005 ivm de epg
Beobuddy Geplaatst: 2 februari 2007 Geplaatst: 2 februari 2007 Het vastlopen nadat ik op stop had gedrukt heb ik ook last van gehad. Bij mij was dat de combinatie bij de Silverline tap "Bookmark plaatsen bij 2x stop" op ->ja en de Mediamanager tap met de optie "Stopmenu" bij het stoppen van het weergeven van een eerder opgenomen programma. Na het stoppen liep de TF vast (zwart beeld, geen beweging in te krijgen). Door de bookmark functie bij Silverline op "nee"te zetten" kreeg ik wel weer het stopmenu van Mediamanager in beeld. Ik heb ook last van een afwezig hulpmenu bij het weergeven van de zenderlijst. Voorheen kwam er een menu met rode toets voor andere sat, opties onder blauw of zo iets. Nu heb ik alleen de zenderlijst. Wel heb ik (positief) ervaren dat bij het weergeven van ondertiteling, zoals bij de BBC, dat de ondertiteling niet meer blijft staan totdat die wordt vervangen door de volgende regel. Nu verdwijnt de ondertiteling gewoon weer. Soms had ik aan het einde van het programma de laatste regel de vermelding wie de ondertiteling had gedaan en dat bleef staan tot het volgende programma ergens. DM8000HD PVR, DM800HD met OpenPli! ,T90 met 2x Octo en 2x Qua op A1,2,3 en HB.
