mmm Geplaatst: 2 februari 2007 Geplaatst: 2 februari 2007 Hallo, ik heb een Irdeto 2 kaart van de Delta (Zeeland) aangeschaft. Het kaartnummer begint met 4021. Op mijn Dreambox 7025 heb Gemini2.1 draaien, met Mgcamd1.18 en NewCS1.20. Als ik NewCS start, krijg ik de volgende log: Code: [color:"blue"] root@dm7025:~> /usr/bin/newcs_1.20Reading Config file from /var/tuxbox/config/newcs.xmlTCP-log password is disabled!level: normaltype: initoutput: console,udp,tcplogger config: level 1 type 3 output 7Console log options: level 1 type 3udp log: host 192.168.1.3 port 1000UDP log options: level 1 type 3tcp port: 3001TCP log options: level 1 type 3[ 00:12:02 ] [ Box detect ] Box type 6[ 00:12:02 ] [ Config ] /dev/sci0 ECM priority: round[ 00:12:02 ] [ Config ] /dev/sci1 ECM priority: round[ 00:12:02 ] [ Config ] Option <spider> not present for User: dummy, defaulting to NO[ 00:12:02 ] [ EMM Cache ] Initialising Cache with 10 entries[ 00:12:02 ] [ ECM Cache ] Initialising Cache with 10 entries[ NewCS ] Process ID is: 997[ 00:12:02 ] [ Loader ] Reader type 5 on node /dev/sci0[ 00:12:02 ] [ Sci ] Opening device /dev/sci0[ 00:12:02 ] [ Sci ] No card present in reader[ 00:12:02 ] [ Loader ] Reset failed ...[ 00:12:02 ] [ Loader ] Starting Newcamd Server on port 34000[ 00:12:02 ] [ Loader ] Reader type 5 on node /dev/sci1[ 00:12:02 ] [ Sci ] Opening device /dev/sci1[ 00:12:07 ] [ ATR ] T=14 1etu=625.00us Guardtime:17etu WWT:9600etu[ 00:12:07 ] [ ATR ] Historical bytes: I R D E T O A C S V 5 . 3[ 00:12:07 ] [ Loader ] Init Irdeto card[ 00:12:07 ] [ Keyman ] Adding key 86E0BB type 0 on Provider 000000 for caid 0604 ID=0[ 00:12:07 ] [ Keyman ] Adding key 1500 type 1 on Provider 000000 for caid 0604 ID=0[ 00:12:07 ] [ Keyman ] Adding key FFFFFF type 1 on Provider 000001 for caid 0604 ID=1[ 00:12:08 ] [ Keyman ] Adding key FFFFFF type 1 on Provider 000002 for caid 0604 ID=2[ 00:12:08 ] [ Keyman ] Adding key FFFFFF type 1 on Provider 000003 for caid 0604 ID=3[ 00:12:08 ] [ Loader ] Card 0604 on port /dev/sci1 ready[ 00:12:08 ] [ Loader ] Starting Newcamd Server on port 34001[ 00:12:08 ] [ NewCS ] Ready to GO! [/color] Wat ik hieruit kan opmaken, is dat het kaartje in elk geval "gezien" wordt. Weet iemand wat ik nog mis om de kaart werkend te krijgen? Groet, <img src="/forums/images/graemlins/smile.gif" alt="" />
DRG Geplaatst: 6 februari 2007 Geplaatst: 6 februari 2007 post de output eens van mgcamd en vergeet niet om de serienummers van de smartcard even weg te xxxxxx-en <img src="/forums/images/graemlins/wink.gif" alt="" /> Diverse meuk... maar dat boeit niemand toch..
mmm Geplaatst: 6 februari 2007 Auteur Geplaatst: 6 februari 2007 Hoi DRG, in elk geval vast bedankt voor de tip met het serienummer <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> Ik was alvast van plan om een log van mgcamd te posten. Er staat er al een van CCCAM in een ander draadje . Ik heb vanochtend mijn kaart met die van een vriend geruild, dus nog geen log van mijn kaart nu. Mijn kaart zit nu bij hem in een originele box, en werkt daarwel. Maar ik post wel alvast de log van zijn kaart, die WEL werkt <img src="/forums/images/graemlins/smirk.gif" alt="" /> Overigens werkt dat alleen als ik NewCS1.20 samen met Mgcamd1.19 start. (En ook met Mgcamd 1.18). Code: root@dm7025:~> /usr/bin/newcs_1.20Reading Config file from /var/tuxbox/config/newcs.xmlTCP-log password is disabled!level: normaltype: initoutput: console,udp,tcplogger config: level 1 type 3 output 7Console log options: level 1 type 3udp log: host 192.168.1.3 port 1000UDP log options: level 1 type 3tcp port: 3001TCP log options: level 1 type 3[ 18:25:36 ] [ Box detect ] Box type 6[ 18:25:36 ] [ Config ] /dev/sci0 ECM priority: round[ 18:25:36 ] [ Config ] /dev/sci1 ECM priority: round[ 18:25:36 ] [ Config ] Option <spider> not present for User: dummy, defaultingto NO[ 18:25:36 ] [ EMM Cache ] Initialising Cache with 10 entries[ 18:25:36 ] [ ECM Cache ] Initialising Cache with 10 entries[ NewCS ] Process ID is: 1002[ 18:25:36 ] [ Loader ] Reader type 5 on node /dev/sci0[ 18:25:36 ] [ Sci ] Opening device /dev/sci0[ 18:25:36 ] [ Sci ] No card present in reader[ 18:25:36 ] [ Loader ] Reset failed ...[ 18:25:36 ] [ Loader ] Starting Newcamd Server on port 34000[ 18:25:36 ] [ Loader ] Reader type 5 on node /dev/sci1[ 18:25:36 ] [ Sci ] Opening device /dev/sci1[ 18:25:41 ] [ ATR ] T=14 1etu=625.00us Guardtime:17etu WWT:9600etu[ 18:25:41 ] [ ATR ] Historical bytes: I R D E T O A C S V 5 . 0[ 18:25:41 ] [ Loader ] Init Irdeto card[ 18:25:42 ] [ Keyman ] Adding key 6A3E7E type 0 on Provider 000000 for caid 0604 ID=0[ 18:25:42 ] [ Keyman ] Adding key 40424 type 1 on Provider 000000 for caid 0604 ID=0[ 18:25:42 ] [ Keyman ] Adding key FFFFFF type 1 on Provider 000001 for caid 0604 ID=1[ 18:25:42 ] [ Keyman ] Adding key FFFFFF type 1 on Provider 000002 for caid 0604 ID=2[ 18:25:42 ] [ Keyman ] Adding key FFFFFF type 1 on Provider 000003 for caid 0604 ID=3[ 18:25:43 ] [ Loader ] Card 0604 on port /dev/sci1 ready[ 18:25:43 ] [ Loader ] Starting Newcamd Server on port 34001[ 18:25:43 ] [ NewCS ] Ready to GO! :)root@dm7025:~>root@dm7025:~> /usr/bin/mgcamd_1.19tuxbox mgcamd v1.19b by mixvt (compiled Feb 5 2007 18:43:12)[mg] Net:1:7:0:5s Show ecm:1, emm:1 Up:1 Au:2 Dir:0 Osd:no:80:3 Cache:7 Log:3:172.16.1.1:28007 Reread:0[mg] Ecm cache time: 15Box type: dm7025root@dm7025:~> Conax.Key error 2: No such file or directoryKeys readedConax.Key error 2: No such file or directory[config] newcamd route = dummy:127.0.0.1:34000 server newcs[config] newcamd route = dummy:127.0.0.1:34001 server newcsnewcamd keep alive: 0, incoming port: 12000[newcamd] Connecting to 127.0.0.1:34000...[newcamd] Connecting to 127.0.0.1:34001...[mgcam] emm thread started[ 18:26:07 ] [ Newcamd:34001 ] User dummy logged in, client: Mgcamd[ 18:26:07 ] [ Newcamd:34000 ] User dummy logged in, client: Mgcamd[newcamd] Login to 127.0.0.1:34001 as dummy accepted (28ms)[newcamd] Login to 127.0.0.1:34000 as dummy accepted (0ms)[newcamd] Card data from 127.0.0.1:34001 (30ms): EMM enabled: UA yes SA yes GA yes, Card serial: xxxxxxxx Userid 1 caid 604 providers 4 Idents: 000000 000001 000002 000003 ids: 40424 1FFFFFF 2FFFFFF 3FFFFFF[newcamd] Card data from 127.0.0.1:34000 (8ms): EMM enabled: UA yes SA yes GA yes, Card serial: 0 Userid 1 caid 0 providers 1 Idents: 000000 ids: 0got 50 cmd 9F[mg0] namespace FFFF0000 t-id 8 on-id 10EF[mg0] descramble on 5, source 2[mg0] service 323 index 0 pmt pid 334 (1) ECM: CaID: 0x0604 -> CaPID: 0x033C ProvID: 000000[mg0] No irdeto key(s) found for id 0 keynr 00[mg0] -> ECM to newcamd 127.0.0.1:34001[mg0] <- CW from newcamd 127.0.0.1:34001 (278ms)278 msec -- Tue Feb 6 18:26:40 2007===== Irdeto ECM on CaID 0x0604, pid 0x033c ======prov: 000000cw0:0 81 1A A6 41 42 B1 25 18cw1:0 0A A7 A2 53 6E 42 58 08[mg0] irdeto using chid 0002 version 41[mg0] -> ECM to newcamd 127.0.0.1:34001[mg0] <- CW from newcamd 127.0.0.1:34001 (274ms)274 msec -- Tue Feb 6 18:26:43 2007===== Irdeto ECM on CaID 0x0604, pid 0x033c ======prov: 000000cw0:0 81 1A A6 41 42 B1 25 18cw1:0 FB EA D4 B9 0F F8 B2 B9[mg0] irdeto using chid 0002 version 41[mg0] -> ECM to newcamd 127.0.0.1:34001[mg0] <- CW from newcamd 127.0.0.1:34001 (274ms)274 msec -- Tue Feb 6 18:26:57 2007enz. Wat meteen opvalt is dat de kaart van mijn vriend Irdeto V5.0 aangeeft (serie nummer begint met 4012), terwijl mijn kaart een Irdeto V5.3 is. Nou hopelijk heeft men iets aan deze logging. Morgen kan ik dit gaan vergelijken met een logging van mijn kaart. Groet, <img src="/forums/images/graemlins/smile.gif" alt="" />
DRG Geplaatst: 6 februari 2007 Geplaatst: 6 februari 2007 dat ziet er allemaal ok uit... het kan natuurlijk dat jou smartcard een andere versie is waar ook een andere camkey voor nodig is... Diverse meuk... maar dat boeit niemand toch..
mmm Geplaatst: 8 februari 2007 Auteur Geplaatst: 8 februari 2007 Citaat: het kan natuurlijk dat jou smartcard een andere versie is waar ook een andere camkey voor nodig is... Hoi DRG,hoe komen we eigenlijk aan die camkey?Ik heb de volgende toegevoegd aan de newcs.xml: Code: [color:"blue"] : <blockga>no</blockga> <Irdeto-camkey>1122334455667788</Irdeto-camkey> <irdeto-camkey-data>3C8633AAC0D367533DEC7BB2EEEDEB8CA3ADA52E58B99BB34672783277A1DAAC3B6106AD0909774E031B2A6E30195B437683AD0FC599B87D08CEA47BE1B6C76A></irdeto-camkey-data> <boxid></boxid> <PTShandshake>no</PTShandshake>:[/color] Moet dit ook nog aan de mg_cfg worden toegevoegd?OK, hier dus de log (na invoeren van de camkey in newcs.xml): Code: [color:"blue"] root@dm7025:~> /usr/script/mgcamd_1.19_newcs_1.20_cam.sh start[sCRIPT] start: MGcamd-1.19/NewCS-1.20Reading Config file from /var/tuxbox/config/newcs.xmlTCP-log password is disabled!level: normaltype: initoutput: console,udp,tcplogger config: level 1 type 3 output 7Console log options: level 1 type 3udp log: host 192.168.1.3 port 1000UDP log options: level 1 type 3tcp port: 3001TCP log options: level 1 type 3[ 18:42:19 ] [ Box detect ] Box type 6[ 18:42:19 ] [ Config ] /dev/sci0 ECM priority: round[ 18:42:19 ] [ Config ] /dev/sci1 ECM priority: round[ 18:42:19 ] [ Config ] Option <spider> not present for User: dummy, defaulting to NO[ 18:42:19 ] [ EMM Cache ] Initialising Cache with 10 entries[ 18:42:19 ] [ ECM Cache ] Initialising Cache with 10 entries[ NewCS ] Process ID is: 1019[ 18:42:19 ] [ Loader ] Reader type 5 on node /dev/sci0[ 18:42:19 ] [ Sci ] Opening device /dev/sci0[ 18:42:24 ] [ ATR ] T=14 1etu=625.00us Guardtime:17etu WWT:9600etu[ 18:42:24 ] [ ATR ] Historical bytes: I R D E T O A C S V 5 . 3[ 18:42:24 ] [ Loader ] Init Irdeto card[ 18:42:24 ] [ Keyman ] Adding key 86E0BB type 0 on Provider 000000 for caid 0604 ID=0[ 18:42:25 ] [ Keyman ] Adding key 3F4D5 type 1 on Provider 000000 for caid 0604 ID=0[ 18:42:25 ] [ Keyman ] Adding key FFFFFF type 1 on Provider 000001 for caid 0604 ID=1[ 18:42:25 ] [ Keyman ] Adding key FFFFFF type 1 on Provider 000002 for caid 0604 ID=2[ 18:42:25 ] [ Keyman ] Adding key FFFFFF type 1 on Provider 000003 for caid 0604 ID=3[ 18:42:26 ] [ Loader ] Card 0604 on port /dev/sci0 ready[ 18:42:26 ] [ Loader ] Starting Newcamd Server on port 34000[ 18:42:26 ] [ Loader ] Reader type 5 on node /dev/sci1[ 18:42:26 ] [ Sci ] Opening device /dev/sci1[ 18:42:26 ] [ Sci ] No card present in reader[ 18:42:26 ] [ Loader ] Reset failed ...[ 18:42:26 ] [ Loader ] Starting Newcamd Server on port 34001[ 18:42:26 ] [ NewCS ] Ready to GO! :)root@dm7025:~> tuxbox mgcamd v1.19b by mixvt (compiled Feb 5 2007 18:43:12)[mg] Net:1:7:0:5s Show ecm:1, emm:1 Up:1 Au:1 Dir:0 Osd:no:80:3 Cache:7 Log:3:172.16.1.1:28007 Reread:0[mg] Ecm cache time: 15Box type: dm7025Conax.Key error 2: No such file or directoryKeys readedConax.Key error 2: No such file or directory[config] newcamd route = dummy:127.0.0.1:34000 server newcs[config] newcamd route = dummy:127.0.0.1:34001 server newcsnewcamd keep alive: 0, incoming port: 12000[newcamd] Connecting to 127.0.0.1:34000...[newcamd] Connecting to 127.0.0.1:34001...[ 18:42:30 ] [ Newcamd:34001 ] User dummy logged in, client: Mgcamd[ 18:42:30 ] [ Newcamd:34000 ] User dummy logged in, client: Mgcamd[newcamd] Login to 127.0.0.1:34001 as dummy accepted (8ms)[newcamd] Login to 127.0.0.1:34000 as dummy accepted (0ms)[newcamd] Card data from 127.0.0.1:34001 (10ms): EMM enabled: UA yes SA yes GA yes, Card serial: 0 Userid 1 caid 0 providers 1 Idents: 000000 ids: 0[newcamd] Card data from 127.0.0.1:34000 (7ms): EMM enabled: UA yes SA yes GA yes, Card serial: xxxxxxxx Userid 1 caid 604 providers 4 Idents: 000000 000001 000002 000003 ids: 3F4D5 1FFFFFF 2FFFFFF 3FFFFFF[mgcam] emm thread startedgot 50 cmd 9F[mg0] namespace FFFF0000 t-id 8 on-id 10EF[mg0] descramble on 5, source 2[mg0] service 323 index 0 pmt pid 334 (1) ECM: CaID: 0x0604 -> CaPID: 0x033C ProvID: 000000[mg0] No irdeto key(s) found for id 0 keynr 00[mg0] -> ECM to newcamd 127.0.0.1:34000[mg0] <- CW from newcamd 127.0.0.1:34000 (238ms)238 msec -- Thu Feb 8 19:11:32 2007===== Irdeto ECM on CaID 0x0604, pid 0x033c ======prov: 000000cw0:0 50 36 F8 7E 40 0F 62 B1cw1:0 78 A6 D9 F7 B3 EF 12 B4[mg0] irdeto using chid 0002 version 41[mgcamd] emm startedStarting emm for newcamd shared card*EMM: CaID: 0x0604 -> CaPID: 0x0055 ProvID: 000000[newcamd] EMM -> 127.0.0.1:34000[newcamd] EMM answer from 127.0.0.1:34000, 3:82[mg0] -> ECM to newcamd 127.0.0.1:34000[mg0] <- CW from newcamd 127.0.0.1:34000 (238ms)238 msec -- Thu Feb 8 19:11:45 2007===== Irdeto ECM on CaID 0x0604, pid 0x033c ======prov: 000000cw0:0 50 36 F8 7E 40 0F 62 B1cw1:0 78 A6 D9 F7 B3 EF 12 B4[mg0] irdeto using chid 0002 version 41[newcamd] EMM -> 127.0.0.1:34000[newcamd] EMM -> 127.0.0.1:34000[newcamd] EMM answer from 127.0.0.1:34000, 3:82[newcamd] EMM answer from 127.0.0.1:34000, 3:82[newcamd] EMM -> 127.0.0.1:34000[newcamd] EMM answer from 127.0.0.1:34000, 3:82[mg0] -> ECM to newcamd 127.0.0.1:34000[mg0] <- CW from newcamd 127.0.0.1:34000 (238ms)238 msec -- Thu Feb 8 19:11:59 2007===== Irdeto ECM on CaID 0x0604, pid 0x033c ======prov: 000000cw0:0 50 36 F8 7E 40 0F 62 B1cw1:0 78 A6 D9 F7 B3 EF 12 B4[mg0] irdeto using chid 0002 version 41[mg0] -> ECM to newcamd 127.0.0.1:34000[mg0] <- CW from newcamd 127.0.0.1:34000 (238ms)238 msec -- Thu Feb 8 19:12:13 2007===== Irdeto ECM on CaID 0x0604, pid 0x033c ======prov: 000000cw0:0 50 36 F8 7E 40 0F 62 B1cw1:0 78 A6 D9 F7 B3 EF 12 B4[mg0] irdeto using chid 0002 version 41[newcamd] EMM -> 127.0.0.1:34000[newcamd] EMM answer from 127.0.0.1:34000, 3:82[newcamd] EMM -> 127.0.0.1:34000[newcamd] EMM cached[newcamd] EMM -> 127.0.0.1:34000[newcamd] EMM cached[mg0] -> ECM to newcamd 127.0.0.1:34000[mg0] <- CW from newcamd 127.0.0.1:34000 (240ms)240 msec -- Thu Feb 8 19:12:27 2007 [/color] Ik zie helaas niet zo veel verschil met de werkende kaart <img src="/forums/images/graemlins/confused.gif" alt="" />Groet, <img src="/forums/images/graemlins/smile.gif" alt="" />
DRG Geplaatst: 8 februari 2007 Geplaatst: 8 februari 2007 is jou kaart al geactiveerd of is het nog een preview kaart ? Appiemulder heeft de camkeys prijs gegeven... ook geen idee hoe hij er aan is gekomen.. Diverse meuk... maar dat boeit niemand toch..
mmm Geplaatst: 8 februari 2007 Auteur Geplaatst: 8 februari 2007 De kaart is inmiddels geactiveerd. Ten tijde van de eerste log (met mg_camd1.18) was het nog preview. Hier printouts van het "sub" en "users" commando: Code: [color:"blue"] root@dm7025:~> echo sub -1 | nc -w5 127.0.0.1 3001-- entitlements --------- --- -- - - -reading entitlements for card 0.-------------------------------------------------.| Provider | Channel ID | From | To ||----------|------------|------------|------------|| 00 | 0002 | 0x0A24 | 0x0A42 |-------------------------------root@dm7025:~> echo version | nc 127.0.0.1 3001-- Version --------- --- -- - - -Version: 1.20 Release Candidate 13, compiled Dec 29 2006 21:43:34Using /var/tuxbox/config/newcs.xml as config.-------------------------------root@dm7025:~> echo users | nc -w5 127.0.0.1 3001.----------------------------------------.---- --- -- - -| Newcamd Port: 34000 | CAID: 0604 | Reader: 0 (Delta)|---------------------------------------------------------------------------------------------------------------------------------------.| ID | Username | Logon Status | Ok ECM | Bad ECM | EMM | Hostname | Client | Spider | AU | SO ||----|-----------------|-----------------|----------|----------|----------|---------------------------|------------|--------|-----|-----|| 02 | dummy | 00d 00h 07m 21s | 33 | 0 | 72 | 127.0.0.1 | Mgcamd | No | On | Off |'---------------------------------------------------------------------------------------------------------------------------------------'.----------------------------------------.---- --- -- - -| Newcamd Port: 34001 | CAID: 0000 | Reader: 1 (upper)|---------------------------------------------------------------------------------------------------------------------------------------.| ID | Username | Logon Status | Ok ECM | Bad ECM | EMM | Hostname | Client | Spider | AU | SO ||----|-----------------|-----------------|----------|----------|----------|---------------------------|------------|--------|-----|-----|| 02 | dummy | 00d 00h 07m 21s | 0 | 0 | 0 | 127.0.0.1 | Mgcamd | No | On | Off |'---------------------------------------------------------------------------------------------------------------------------------------'root@dm7025:~> [/color] Groet, <img src="/forums/images/graemlins/smile.gif" alt="" />
DRG Geplaatst: 9 februari 2007 Geplaatst: 9 februari 2007 is dat een output van de werkende kaart ? Ik zie dat netjes EMM pakketjes verzonden worden... ziet er allemaal wel ok uit... Diverse meuk... maar dat boeit niemand toch..
mmm Geplaatst: 9 februari 2007 Auteur Geplaatst: 9 februari 2007 Hoi DRG, nee dat is een log van mijn eigen kaart (4021). En inderdaad, lijkt het alsof de communicatie tussen de kaart en de CAMd wel goed werkt, want ik zie ook een groene "I" in de infobalk. Vreemd genoeg bijft het beeld op zwart. Er moet dus nog iets anders aan de hand zijn.... Een timing kwestie ergens? Groet, <img src="/forums/images/graemlins/smile.gif" alt="" />
DRG Geplaatst: 9 februari 2007 Geplaatst: 9 februari 2007 geen meldingen dat SID rejected zijn ? zet anders in newcs.xml autosid uit Diverse meuk... maar dat boeit niemand toch..
mmm Geplaatst: 12 februari 2007 Auteur Geplaatst: 12 februari 2007 Hoi, nee geen SID-reject meldingen. toch nog geprobeerd om autosid uit te zetten. helaas, zonder resultaat. Ik lees weleens vragen van Toxiq om een CAMd te testen met een bepaalde revisie kaart. In zo'n geval ligt het dus aan de revisie van de kaart. Als zo'n kaart niet werkt, hoe wordt dat dan opgelost? In configuratie? of in software? Indien het laatste, hoe werkt zoiets? Kan iemand iets over uitleggen waarom sommige kaarten wel en andere (nog) niet werken? Sturen die dan weer een "nieuw commando" die dan weer in de SoftCam moet worden afgevangen? In dat geval zou een log van mijn kaart dus erg interessant zijn voor de SoftCam-bouwers. Wie weet dit? Groet, <img src="/forums/images/graemlins/smile.gif" alt="" />
DRG Geplaatst: 12 februari 2007 Geplaatst: 12 februari 2007 ik vermoed dat je het in de hoek van de camkey moet zoeken.. Diverse meuk... maar dat boeit niemand toch..
mmm Geplaatst: 15 februari 2007 Auteur Geplaatst: 15 februari 2007 Hoi DRG, het zag er toch niet goed genoeg uit. Het probleem zit 'm toch in de configuratiefiles. Ik meende al eens gelezen te hebben dat er iemand was met een 4021-kaart die 'm werkend had. M.b.v de zoekfunctie die thread eens opgezocht ( Link naar thread), en de daarin geplaatste files in de dreambox gezet. Met dank aan Bjorn-007 en Mart werkt 't nu in elk geval <img src="/forums/images/graemlins/grin.gif" alt="" /> Mocht ik eens tijd over hebben, dan duik ik eens in die files om erachter te komen wat nou precies de "truuk" was. Dank aan DRG, en degenen die me per PM ook nog hebben proberen te helpen voor hun tijd en inzet <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> Groet van een blije mmm, <img src="/forums/images/graemlins/cool.gif" alt="" />
