Satlook Geplaatst: 9 februari 2007 Geplaatst: 9 februari 2007 Weer een nieuwe versie vvan het TDT team: TD eXtreme 3.0 (8mb-eXtreme30-tr.bin) -------------------------------------------------------------- md5sum: 316310729f0abc8501d2590dd59c5fca 8mb-eXtreme30-tr.bin -After new image installed you can update plugins manuelly just upload plugin you want to test to /var/plugins folder and reboot tripledragon thats all -Osd ipk menu added ,you can check xml file and see how it works (thanks magu) -For Osd ipk option you must upload this files 1. make a new folder on /var/etc/xmlmenu and upload there tdturkey.xml file 2. to /var/plugins folder upload libgo2.so file 3. to /var/bin folder upload tdbackup.sh file and make chmod 775 4. webpanel option removed from the image if you want to use it you can download it as ipk files from the board 5. evocamd d+ au lib files fixed Thanks to Fello <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> DM8000 HD - Newnigma VU+ duo - PLI Triple dragon - PICmod cronbear1 image Echostar 7000 viaccess Gregorian 120 & 90 cm Visiosat bisat
