Gast Geplaatst: 22 februari 2007 Delen Geplaatst: 22 februari 2007 Ik heb op mijn D-Box2 Sportster Pro v1.07 lopen i.c.m. MGCamd/NewCS wat al sinds half november stabiel en snel functioneert. Ik wou gisteren vervolgens TV kijken (via TV-Home), maar ik merkte dat het beeld zwart bleef.. zelfs na herstarten en na een dag wachten hielp dit niets. Ik heb MGCamd opgestart vanuit een telnet en dit is de output die ik kreeg: Citaat: /var # mgcamd AES URL: http://some.host.com/keys.php tuxbox mgcamd v1.16 by mixvt (compiled Nov 13 2006 15:47:34) [mg] Net:1:7:0:10s Show ecm:0, emm:0 Up:2 Au:1 Dir:0 Osd:no:3 Cache:7 Log:3:127. 0.0.1:28007 Reread:1 [mg] Ecm cache time: 15 Box type: dbox2 /var # Conax.Key: error! 2: No such file or directory SoftCam.Key: error! 2: No such file or directory AutoRoll.Key: error! 2: No such file or directory Conax.Key: error! 2: No such file or directory [config] newcamd route = local:127.0.0.1:15000 server cardserv newcamd keep alive: 0, incoming port: 12000 [newcamd] Connecting to 127.0.0.1:15000... [mgcamd] aes update over http started [newcamd] Login to 127.0.0.1:15000 as local accepted (73ms) [newcamd] Card data from 127.0.0.1:15000 (110ms): EMM enabled, Card serial: ******** Userid 1 caid 604 providers 4 Idents: 000000 000001 000002 000003 ids: 5A60D 1FFFFFF 2FFFFFF 3FFFFFF got 27 cmd 9F [mg] Net:1:7:0:10s Show ecm:0, emm:0 Up:2 Au:1 Dir:0 Osd:no:3 Cache:7 Log:3:127. 0.0.1:28007 Reread:1 [mg] Ecm cache time: 15 [mg0] service 2713 index 0 pmt pid 0 (1) ECM: CaID: 0x0604 -> CaPID: 0x138B ProvID: 000000 [mg0] -> ECM to newcamd 127.0.0.1:15000 [mg0] newcamd route 127.0.0.1:15000 cant decode (285ms) [mg0] network can't decode [mg0] -> ECM to newcamd 127.0.0.1:15000 [mg0] newcamd route 127.0.0.1:15000 cant decode (219ms) [mg0] network can't decode [mg0] -> ECM to newcamd 127.0.0.1:15000 [mg0] newcamd route 127.0.0.1:15000 cant decode (195ms) [mg0] network can't decode [mg0] -> ECM to newcamd 127.0.0.1:15000 [mg0] newcamd route 127.0.0.1:15000 cant decode (245ms) [mg0] network can't decode [mgcam] emm thread started Starting emm for newcamd shared card *EMM: CaID: 0x0604 -> CaPID: 0x041C ProvID: 000000 [mg0] -> ECM to newcamd 127.0.0.1:15000 [mg0] newcamd route 127.0.0.1:15000 cant decode (8ms) [mg0] network can't decode [mg0] -> ECM to newcamd 127.0.0.1:15000 [mg0] newcamd route 127.0.0.1:15000 cant decode (8ms) [mg0] network can't decode Vanaf dit stuk komt ie in een loop terecht, wat is hier precies gebeurd? Wat kan ik er vervolgens aan doen? Ik heb zelfs een backup-image erop geflashed die ik destijds had gemaakt toen het nog prima werkte, zelfs hier is de output zoals hierboven <img src="/forums/images/graemlins/frown.gif" alt="" /> Ik had al een poging ondernomen om CCcam te gebruiken, maar dit werkte niet erg goed, daarnaast waren de topics Dreambox gericht en niet D-Box2. Kan iemand mij hiermee helpen? Ik kom hier niet uit <img src="/forums/images/graemlins/frown.gif" alt="" /> Link naar reactie Delen op andere sites Meer opties om te delen...
Yopeople Geplaatst: 23 februari 2007 Delen Geplaatst: 23 februari 2007 Met de kaart in een offciële ontvanger heb je nog wel beeld? Af en toe zend @home een pulse naar je kaart die alleen via officiële ontvanger te ontvangen is, gisteren had ik daar last van. Kaart liep al 3/4 jaar prima in een niet officiële ontvanger. (Bovenstaande output had ik trouwens geen last van, kaart werd wel netjes herkend) Kaart in officiële ontvanger gedaan en gebeld met @home. Zij hebben vervolgens de pulse nogmaals gestuurd en de kaart werkte weer. Ik heb begrepen dat het binnenkort mogelijk wordt om deze pulse zelf via internet te sturen door in te loggen op een website van @home, zover is het nu nog niet.... Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 23 februari 2007 Delen Geplaatst: 23 februari 2007 Je moet de kaart inderdaad even in een originele ontvanger stoppen, totdat je weer beeld hebt. Heb ik ook gehad een paar maanden geleden. Daarna loopt ie weer als vanouds! Ik heb verder geen puls aan hoeven vragen ofzo... Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 23 februari 2007 Delen Geplaatst: 23 februari 2007 Ahh super, ik schrok al dat m'n software en configs niet meer klopten <img src="/forums/images/graemlins/smile.gif" alt="" /> Dank jullie wel! @Yopeople, de kaart werd in de NewCS output herkend, had alleen de MGcamd log gepost <img src="/forums/images/graemlins/wink.gif" alt="" /> Link naar reactie Delen op andere sites Meer opties om te delen...
dream-on Geplaatst: 6 maart 2007 Delen Geplaatst: 6 maart 2007 is deze puls toevallig vannacht geweest? bij mij is plots alles zwart.... <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/frown.gif" alt="" /> Vu duo2 met pli Link naar reactie Delen op andere sites Meer opties om te delen...
