Nieuwe Firmware 2.14 , Official DGS 2.14 images released for 400s, 200s
Hehe eindelijk <img src="/forums/images/graemlins/grin.gif" alt="" />
48 March-18-2007 56
[relook 400s] 2.14 version PAL Type.
1. You should download all the attached images in order(serial_uboot.img, serial_kernel_root.img, serial_db.img).
2. That is better for you to backup channel list using PC Editor before downloading the above images.
Reference)
1. Downloading the attached images through the network updating is quicker than the serial cable. But, the image of usb type for Mutant is for network updating purpose only. If you use PC editor, you can download this image too.
2. If you wish to use the softwares which are included in a standard plug-in, please download DB.
They are included in the file of serial_db.img or usb_db.img
Caution)
1. If you use the software of the previous 2.9 version, you should dowload the serial_uboot.img using flashtool via serial cable.
2. Unplugging the power code may cause serious damage on mutant while u-boot img's downloading.
Please refer to README file before you start downloading the firmware attached above.
To get patch files related to GPL license,please click HERE
version
- boot loader
U-Boot 1.1.1
- application
2.14.
- database
1.17
2.14 Changes
(A : added, F : bug fixed, M : modified/improved of functions, B : Known Bugs)
- F: led on/off does not work properly.
- F: Lost IP address when stand by mode.
- F: Local time should not be upgraded when record/reserve schedule exist.
- F: epg search problem when there are no epg.
- F: no live banner in specific channel
relook400s_2.14_PAL.zip (5.28 MB)
Ik had ook meer verwacht. Ik ben een tijdje bezig geweest met een developer van DGS om onder andere de problemen met het opnemen van de ondertiteling en teletekst. Die veranderingen zie ik niet terug helaas.
Xtrend ET9500 - OpenPLi powered
Dan zal dit probleem ook nog niet opgelost zijn.....
Wat wel duidelijk is dat de ontwikkeling van de software niet op z'n gat ligt.
De software loopt bij mij zonder veel problemen (=panics). Prima ontvangertje!
