Gorefest Geplaatst: 19 april 2007 Geplaatst: 19 april 2007 Clarkebelt heeft nieuwe software voor de Echostar PVR-5020 vrijgegeven: Volgende is veranderd sinds 1215: Bugs: * Dutch text for the icon <> was wrong --> Fixed * Dutch text for Zoom function in EPG was wrong --> Fixed * Double entries in EPG --> Fixed * Some people reported problems that timers did not fire --> Fixed * Channel number mismatch in Favorite lists --> Fixed * No EPG when receiving channels via Tuner 2 --> Fixed * Some people reported Viacess channel problem on TPS --> Fixed * Problems with main and pip in combination with cryptoworks dual cam --> Fixed * Support for HDD ST3400832ACE 400GB --> Improved * Timer overlap function --> Improved Features: * User can set default timer padding in HDD option menu. * In EPG menu, if user press rec key on the current event, a record will start for the event. * Progress banner added in "running recordings" screen. * Stopping recordings has been simplified, when recording is running press stop key and see! * When renaming recordings in the file manager, user can move cursor position for easy renaming so you don't need to type complete name again. * In EPG current time is shown with a green line. * In EPG current event has green color. After loading this software turn the receiver off with the switch on the back for about 30 seconds! And please do a factory reset!! Clarkebelt Gigablue Quad Plus 2x DVB-S2 2x DVB-C
ikky Geplaatst: 19 april 2007 Geplaatst: 19 april 2007 Wow de verbeteringen gaan maar door. <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> Mannen van clackbelt bedankt. <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> Zal de software er zometeen ff opzetten.
Martijntje Geplaatst: 19 april 2007 Geplaatst: 19 april 2007 Whats padding ? Is dat soms een uitlooptijd van de opname of zo. Verder weer super, en ik zal hem er zsm in zetten bedankt !
DeBeek Geplaatst: 19 april 2007 Geplaatst: 19 april 2007 Citaat: Whats padding ? Is dat soms een uitlooptijd van de opname of zo. Deze vraag is juist beantwoord. Je mag door voor de koelkast. !!!
Martijntje Geplaatst: 19 april 2007 Geplaatst: 19 april 2007 Dank je, DE BEEK , alleen een uitloop aan het eind, of ook in het begin dan ? Ps: ik moet inderdaad een nieuwe koelkast ! Grtz,
DeBeek Geplaatst: 19 april 2007 Geplaatst: 19 april 2007 Helaas alleen aan het einde, Misschien dat het begin in een volgende BETA komt. Zet hem er gauw op, hij werkt perfect. ps. het is een strijkijzer geworden
Martijntje Geplaatst: 19 april 2007 Geplaatst: 19 april 2007 Maar de sit werkt bij mij niet momenteel, dus ik probeer het vanavond nog wel even Prettige avond.
DeBeek Geplaatst: 19 april 2007 Geplaatst: 19 april 2007 Omdat de site van Clarkebelt momenteel moeilijk te bereiken is staat de nieuwe firm in de BIJLAGE.
Gerard 76 Geplaatst: 19 april 2007 Geplaatst: 19 april 2007 Heel nuttig DeBeek <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> Ik kreeg het ook al niet voor mekaar met de site van Clarkebelt. Eerst maar eens alle kanalen saven op de PC, en na de factory reset weer terugzetten. Gaan de favorietenlijsten dan trouwens ook mee?
DeBeek Geplaatst: 19 april 2007 Geplaatst: 19 april 2007 Alles gaat mee, Echter met een Factory Reset betekend dit (helaas) dat je alles opnieuw moet installeren. Het terug zetten van de oude lijst "kan" problemen geven. Je kan het natuurlijk proberen.
Korretje Geplaatst: 19 april 2007 Geplaatst: 19 april 2007 Erg mooi....maar inderdaad die "factory reset" ben ik niet zo blij mee....dat is weer heel veel werk om alles weer zo mooi terug te krijgen zoals ik het nu heb. Moeten ze toch nog iets op vinden...dat je een kopie kunt maken van de zender lijst en deze ook kunt terug lezen (desnoods in een nieuwe database)...nu ben je een half jaar aan het sleutelen geweest...kun je weer opnieuw beginnen. Groetjes, Kor Xtrend ET 9000, schotel 68 cm. Draaibaar
DeBeek Geplaatst: 19 april 2007 Geplaatst: 19 april 2007 Helemaal met je eens, Ik heb het volgende gedaan, huidige lijst gesaved, Factory reset gegeven, tuner uit en aan gezet ( schakelaar achterop ) Daarna de lijst weer terug gezet. Tot nu toe werkt alles, ( is natuurlijk niet 100% gegarandeerd. ) Voordeel is je kan op je gemak een nieuwe maken, deze weer saven, oude terug zetten, En wanneer je er zin in hebt weer verder gaan.
Gerard 76 Geplaatst: 19 april 2007 Geplaatst: 19 april 2007 Het zal iig de moeite waard zijn <img src="/forums/images/graemlins/smile.gif" alt="" /> Petje af voor het Clarkebelt-team <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" />
Gorefest Geplaatst: 20 april 2007 Auteur Geplaatst: 20 april 2007 Tot nu toe lijkt alles goed te gaan met terug gezette settings. Gigablue Quad Plus 2x DVB-S2 2x DVB-C
