Nabilo v. 0.8 for Mutant 200s Final2 and others
Nog niet getest maar juist gereleased: <img src="/forums/images/graemlins/tongue.gif" alt="" />
1)
CubeCafe Nabilo DARKSTAR
http://www.relook-support.com/wbb2/thread.php?postid=11767#post11767
2)
Mutant-200 COLOSSEUM 1.0 MAX VAR
http://www.relook-support.com/wbb2/thread.php?postid=11766#post11766
3)
Mutant-200 Nabilo v. 0.8 Final2
http://www.relook-support.com/wbb2/thread.php?threadid=1905
1)
Unofficial Nabilo DARKSTAR for IPBox 250s
Here is the ##GECENSUREERDE TEKST OF URL## Image DARKSTAR
The main new of this version is that the skin system have been entirely recoded.
The new skin system is a singificative improvement in ##GECENSUREERDE TEKST OF URL## Images story.
This 0.8 version is MORE AND MORE STABLE AND FAST.
Many graphics objects have been added (##GECENSUREERDE TEKST OF URL## Image DARKSTAR is the first image in the world to have an Analogic Clock in the OSD).
There is a new way to manage extra/light skin.
In this 0.8 version, when OSD is shown you can press the button OK to have INSTANTLY the extra skin information on OSD.
You can set an option too to have a persistent clock on the television screen.
The new skin Validation 8 used all the new graphic improvments of the 0.8 versions with a very high quality style effect.
Warning: You can use only Skins for V. 0.8++ on this image.
Busybox: 1.2.2
Kernel: 2.6.17 By Sandali
Uboot: 1.1.1 By Sandali
Graphics additions by ##GECENSUREERDE TEKST OF URL## team
Graphics Develop Consulting by Vali, Matrix, Army and Porto
Web Interface: ##GECENSUREERDE TEKST OF URL## edition by Army
automount HDD Master
automount CF Slave
Support Sharp Tuner 288 / 299
Fix About window
Fix Remote controll
Fix password. Default is: ipbox
Fixed webif css
and more...
Build for ipbox by Black§kettle
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
2)
Unofficial COLOSSEUM IMAGES
COLOSSEUM IPBOX 200s 1.0 MAX VAR IMAGE
Released 24.07.2007
Immagine per FLASH
Attenzione:
questa immagine MAX VAR è utile solo se installata in FLASH, e per questo è stata testata solo in FLASH IPBOX 200s.
- Enigma 1.09 - CVS aggiornato al 25/09/2006, mod. CTEAM
- Linux version 2.6.17 by Sandali
- Uboot by Sandali
- Firmware release 1.1.0, 25.09.2006
- busybox v1.01
- WebIf 5.9.7-Expert-Enhanced (CTEAM)
- Tuxtxt v. 1.98
Novità Colosseum 1.0
IPBox 200 MaxVar:
- MAXVAR
- Più di 2,8 Megabytes di spazio disponibile in /var per addons sul IPBOX 200s!
- Flash Erase automatico
- al primo boot, l'immagine effettuerà automaticamente il FlashErase, settando automaticamente tutti i suoi parametri di default (anche se prima avevate caricato una immagine diversa).
In qualsiasi momento, è possibile effettuare il flash erase andando nel menu di enigma: "Impostazioni avanzate" -> "Reset di fabbrica"
- Possibilità di usare un telecomando programmabile (esempio: Philips Pronto)
Come la sorella maggiore, anche la Colosseum IPBOX 200s offre la possibilità di utilizzare un telecomando programmabile con codici diversi, utile per chi ha più di un IPBOX nella stessa stanza, o a portata di telecomando.
- EPG Wizard incluso
Nella Colosseum IPBOX 200s, EPG Wizard è settato per scaricare l'EPG nella directory /nfs, disponibile solo attraverso il mount di uno share nfs esterno.
Altre peculiarità Colosseum:
- Start indipendente di Cardserver e/o emu
Nella Colosseum è implementato un nuovo emu manager, capace di gestire separatamente le emu e i cardservers.
Potranno essere avviate le emu SENZA il bisogno di riavviare il cardserver, la cui comunicazione non verrà interrotta, e con un notevole guadagno di tempo per il cambio.
L'opzione è "smart", in quanto l'immagine predispone da sola l'avvio della sola emu oppure di entrambi, a seconda dell'esigenza.
Restano inalterate le opzioni di abbinamento emu-provider e emu-canale, anche qui con riconoscimento automatico della necessità di avvio del cardserver.
- Una nuova WEB INTERFACE, con una opzione UNICA, mai vista prima d'ora su altre immagini !!!
Si possono facilmente editare, comodamente dalla web interface, tutti i files di configurazione della emu attiva al momento, modificandoli a nostro piacimento e salvandoli direttamente nell'immagine, con un solo click del mouse!.
Questa opzione, siamo sicuri, farà la felicità degli "smanettatori" più incalliti !!
- Nuovo Skin e nuove nuove info in OSD, ringraziamo per la cortese collaborazione uno dei più stimati skiner italiani, Army per lo skin "Army Nemesis".
Oltre alle vecchie, le nuove info in OSD (che peraltro erano già abbastanza completo) sono "7025-like" (implementate in Enigma2), e precisamente:
La data odierna in OSD (Giorno settimana, giorno mese anno), e l'ora corrente, completa dell'indicazione dei secondi.
Inoltre è ora disponibile la visualizzazione di alcune info avanzate in OSD.
- Nuovo pannello di setup Inadyn, potenziato e ampliato
- aMule ready (pannello setup incluso in CCC panel)
Necessita di aMule plugin esterno, non fornito di default con l'immagine
- Nuovo file con i links per il download degli addons.
Il link per gli addons generici (plugins, skins, settings, games, locales...) è fornito di default con l'immagine.
Il link per il download emu NON è incluso nell'immagine, l'utente dovrà editare il file /var/CTEAM/downloads.url
- Come sempre, vari altri fixes e improvements su tutta l'immagine.
- inseriti nuovi Custom scripts, due dedicati ad infos e diritti delle smartcards con NewCS
- Zapping Lite Skin
Si possono avere due skins distinti contemporaneamente.
Durante lo zapping con le frecce del telecomando (canali adiacenti), viene visualizzato un secondo skin, generalmente con informazioni minime (lite skin), ma a scelta anche completo come il primo ed organizzato diversamente a video, con piena possibilità creative per gli sviluppatori di skins.
Per tornare al full skin basta premere OK, mentre se si fa zapping con lo skin completo già visibile, viene mantenuto fino allo scadere del suo timeout (o non si preme ancora OK).
Il Zapping Lite Skin è disabilitabile dal CCC panel in OSD setup.
- Colosseum Advanced Infos
Potente finestra, unica nel suo genere, ricchissima di informazioni, variabili e personalizzate per ciascuna emu. E' possibile anche editare e lanciare scripts definiti dall'utente con output direttamente in finestra, salvati in /var/CTEAM/scripts/customX.sh, dove X è un numero da 1 a 9
- Movie recording directory
E' possibile scegliere la device/directory dove andranno salvate le registrazioni.
E' possibile scegliere fra tre locazioni di default e due definibili dall'utente.
Viene effettuato il test automatico istantaneo della posizione scelta, con visualizzazione dello spazio libero per registrare, in ** e HH:MM (stimato).
La finestra contiene una utile scorciatoia alla finestra "Mounts" di enigma, dove è possibile effettuare il mount/umount delle periferiche collegate al IPBOX, prima di selezionarle per la registrazione.
- CTEAM custom scripts:
si possono definire fino a 9 scripts lanciabili dalla finestra Advanced Infos.
L'output verrà visualizzato a schermo.
- Scorciatoie
Tasto BLU:
1 click: Colosseum Control Center (CCC) panel
2 clicks singoli: finestra "Utilities"
3 clicks singoli: finestra "Enigma Extra Setup"
Tasto GIALLO:
doppio click: attiva la finestra "Colosseum Advanced Infos"
Tasto VERDE:
doppio click: attiva direttamente la finestra "Timer List"
- Finestra Plugins
la finestra Plugins ora è più grande, visualizza 13 elementi nella lista (prima erano 8, come standard enigma)
Caratteristiche uniche CTEAM:
- Blocco parentale a tempo - definisci l'orario giornaliero di attivazione della
protezione.
- EPG Wizard - scarica solo i canali che vuoi in maniera totalmente automatica
- L' OSD più completo di informazioni attualmente disponibile
Altre caratteristiche:
- Colosseum Control Center Panel (Tasto blu), aggiornabile tramite internet
- Movie recording directory, scegli il device dove registrare
- Visualizzazione di SNR - AGC- BER direttamente nell'OSD
- Visualizzazione del nome del Provider direttaamente nell'OSD
- Visualizzazione di canale Multi-audio e Televideo direttamente nell'OSD
- Visualizzazione delle informazioni sullo stream direttamente nell'OSD
- Visualizzazione della Codifica utilizzata per il canale direttamente nell'OSD
- Visualizzazione dell' Emulatore attualmente usato direttamente nell'OSD
- Visualizzazione dell'orario hh:mm:ss e data corrente completa nell' OSD
- Visualizzazione di info avanzate sul decoding direttamente in OSD
- Download degli Addons direttamente via Internet
- Installazione Manuale degli Addons da /tmp
- Addons manager per installare e deinstallare gli Addons
- Installazione degli Addons direttamente su USB o HDD
- Controllo della directory /var e verifica dello spazio libero
- Setup Avanzato dello SWAP file tramite CCC Panel
- OSD timeout configurabile tramite CCC panel menu
- 2 Skins: Army Nemesis 4:3 e Megalight 4:3
- Colossemu è configurabile totalmente via Software
- SAMBA è incluso nell'immagine
- Fino a 9 scripts definibili dall'utente, con output a video.
- Aggiunto al menu di spegnimento dell'opzione "restart enigma" (hot restart)
- Recover Movies (nel menu Enigma Extra Setup)
- Visualizzazione delle ultime CTEAM - EDG news
!!! ATTENZIONE - IMPORTANTE:
!!! QUESTO FIRMWARE NON CONTIENE CHIAVI, NE' EMULATORI, NE' INDIRIZZI PER SCARICARE MATERIALE ILLEGALE DI NESSUN TIPO.
!!! EDG NON E' RESPONSABILE IN NESSUN MODO DELL'USO CHE GLI UTENTI NE FARANNO, DI LORO SPONTANEA VOLONTA'.
!!! WARNING - IMPORTANT DISCLAIMER:
!!! THIS FIRMWARE DOES NOT INCLUDE KEYS, NOR EMULATORS, NOR URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE.
!!! EDG IS NOT RESPONSIBLE IN ANY WAY FOR WHAT THE USERS WILL DO WITH THIS FIRMWARE.
3)
Unofficial Nabilo v. 0.8 for Mutant 200s Final2
Here is the ##GECENSUREERDE TEKST OF URL## Image V. 0.8.
Many graphics objects have been added (##GECENSUREERDE TEKST OF URL## Image v 0.8 is the first image in the world to have an Analogic Clock in the OSD).
Busybox: 1.2.2
Fix About window
Fix Remote controll
