HDTV-dekoder [Kathrein UFS910]
Mischien is dit een alernativ voor de 8000??
Voor de HDTV dekoder "Kathrein UFS910" heeft het SF-Team met een paar EMU:s gekomen Prijs? Ja dit ligt omkring op 2800 sek
Highly integrated HDTV decoder for the latest video compression technologies supports H.264/AVC, VC1/Windows Media 9 Series and Dual MPEG-2
Geneva, January 5, 2005 - STMicroelectronics (NYSE: STM) has today announced the world's first single-chip Set-top Box (STB) solution supporting the High Definition H.264/AVC and VC1 specifications, which are poised to enable the next generation of high quality consumer video systems and broadcast services. ST is the world's leading supplier of ICs for set-top boxes*, and the introduction of the new STB7100 allows manufacturers to in-troduce products that will enable this market.
The extraordinary level of integration of the new device - which combines all the STB func-tions and multi-standard decoding circuitry into a single chip, rather than being an add-on processor for an existing product - coupled with its production using ST's state-of-the-art 90nm process technology, results in the most cost-efficient solution and minimizes both de-sign and production costs for STB makers.
Both VC1 - Microsoft's Windows Media 9 Series codec - and the H.264/AVC (Advanced Video Coding) standard, also known as MPEG-4 Part 10, are ultra-efficient, fully scalable video technologies that produces high quality video at lower data rates than current solutions for everything from HDTV and DVD to 3G (third generation) mobile phones. Services broad-cast using H.264 use considerably less bandwidth than the currently widely used MPEG-2 coding scheme, and at a much lower bitrate, allowing broadcasters to economically transmit more high definition programming. Compression efficiency is improved by more than 50%.
The latest advanced codec technologies for DVD-Audio and DVD security encryption are embedded in the new decoder, and the use of a powerful ST40 CPU makes the STB7100 the ideal platform for Car Multimedia Centers able to directly drive - as a Master device - appli-cations such as GPS, at the same time as handling DVD and audio.
"By creating our STB7100 H.264 solution as a single chip in 90nm technology instead of tak-ing the simpler co-processor path, ST is providing manufacturers with by far the most cost-effective base for their products in this market," said Christos Lagomichos, General Manager of ST's Set-Top Box Division. "The demand for new H.264 and VC1 video codec chips is in-credible, and the availability of the STB7100 means that consumers will soon have HDTV boxes, IP-TV and DVDs that use the latest standard, and broadcasters will be encouraged to further develop their services. And this is the ideal platform for the HD-DVD and Blue-Ray DVD technologies."
The STB7100 can simultaneously decode multiple HD streams and output the resultant video to two television sets, or display picture-in-picture. Its CPU core is a high-performance 300MHz ST40, ST's 32-bit RISC family based on the SuperH™ architecture and widely used across digital consumer applications. It supports all of the current STB operating systems and middleware, with power to spare for software enhancements in the future.
The new device is based on an innovative video decoding architecture which combines hard-ware and software techniques to allow systems to be upgraded in the field to support new standards as they become available. For Digital Video Recorder (DVR) applications it fea-tures embedded peripheral interfaces - including serial, ATA and USB 2.0 - to allow external devices to be added easily to an STB or DVD player, either during manufacture or by the viewer, in order to provide additional functionality. Viewers increasingly use digital video re-cording for program time shifting. Other peripherals that could be connected to a set-top box through the USB interface include digital cameras, printers, and memory cards.
The latest advanced codec technologies for DVD-Audio and DVD security encryption are also embedded in the new decoder, and the use of the powerful ST40 CPU makes the STB7100 the ideal platform for Car Multimedia Centers able to directly drive - as Master de-vice - applications such as GPS, at same time as handling DVD and audio. It is a true multi-ple application chip.
The STB7100 is available now in sample quantities in a 35 x 35 PBGA package and costs $29 when purchased in large volumes. Volume production is planned for early 2005.
About STMicroelectronics
STMicroelectronics is a global leader in developing and delivering semiconductor solutions across the spectrum of microelectronics applications. An unrivalled combination of silicon and system expertise, manufacturing strength, Intellectual Property (IP) portfolio and strate-gic partners positions the Company at the forefront of System-on-Chip (SoC) technology and its products play a key role in enabling today's convergence markets. The Company's shares are traded on the New York Stock Exchange, on Euronext Paris and on the Milan Stock Ex-change. In 2003, the Company's net revenues were $7.24 billion and net earnings were $253 million. Further information on ST can be found at www.st.com. zie bijlage
  • Reacties 61
Geplaatste afbeeldingen
Heb ik nu plusminus 2 mnd, beeldkwal vindt ik persoonlijk beter als de 7025 op plasma.In de volgende firmware update zou ook PVR zijn via een van de drie 2.0 usb.
Hobbyisten zijn zelfs bezig met een sata erin te plaatsen(zou een sata connector op mainboard zitten).Alternatieve firmware is ontwikkeld door SFteam met radegast erin
hiermee connect ik naar mijn CD kaart en zefs premiere HD en Discovery HD is te zien met de juiste keys.
Groetjes astradriver
Mmm, ziet er heel interesant uit, zeker als ik de lage prijs zie (rond de 300 Euro) Ik zie helaas alleen nog maar Duitse winkels die 'm leveren, ben benieuwd wanneer die in Nederland leverbaar is.
Ik zag op 'n Tjechisch forum dat SF al druk bezig is met Images & dat Gbox er via 'n omweg er ook al op loopt.
Klopt ik weet niet of ik de gbog mag bijvoegen als bijlage. Verders gbox for UFS910 (gbox2cs via mpcs)
This is a BETA version of a mpcs-cardserver with gbox support.
With this mpcs it is possible to connect any emu with
camd3, newcamd or radegast support to the gbox network.
At this stage of development it works only in one direction!!!
ECMS from the client over camd3, newcamd or radegast protocol
are forwarded to the gbox network and the CW´s back to the client.
This version might be buggy.
Ja, ik zag die Gbox server ook op die site staan. Jammer dat 't maar 1 kant op werkt. Maar ongetwijfeld zal er snel 'n officiele versie voor deze receiver verschijnen. Zeker nu deze receiver 'n goed betaalbaar alternatief voor de DM8000 is, die nog steeds niet verschenen is.
Interessant toestel (gezien de prijs en HD).
Maar het lijkt dat deze enkel DiSEqc 1.0 heeft.
Klopt dit?
Dus dit zou betekenen dat je geen rotor kan aansturen.
hoi,
het board voor ufs910 is publiek, ofschoon ze er een en ander op plaatsen dat niet publiek is of aan het grijze grenst.
je kunt dus de ontwikkeling mooi lezen indien je een peut German kent <img src="/forums/images/graemlins/grin.gif" alt="" />
maar ik schreef er al een heel tijdje geleden over, dit is gegarandeerd een degelijk stukkie hardware met linux software
die middels de ethernet aansluiting en de usb front and back aansluiting heel veel mogelijkheden biedt
ik kijk al een tijdje loensend naar deze HD receiver.
dat deze receiver dus ook verdiende aandacht krijgt is perfect.
(een half jaar geleden nog mekkerden enkelen over de beschikbaarheid van HD en PVR tegelijk)
cheers
Blitzkrieg Bop
Ramones
Het is te hopen want ik heb wel echte interesse.
En deze heeft ten minste USB 2.0
Ik heb intussen ergens gelezen dat er ook een CCcam versie gaat komen voor de Kathrein.
Zie hem al vanaf 269 euro in Duitsland. Lijkt me zeker een interessante ontvanger.
En hier een link waar hij 13 pagina's lang op een forum wordt besproken. Hd schiujnt erg goed te zijn via Hdmi maar sd via Hdmi valt erg tegen. (aldus berichten op forum aldaar)
Lees dat pvr via usb hd nu ook kan:\
dat ding kann ALLES !!!! mittlerweilen...
(ausser NOAD glaub ich)
ansonsten...
sata-hd intern geht...
USB-Hd extern geht...
Netzwerkaufnahmen auf //wasweisichwohin... geht auch
streamen vom Zentralserver geht daher auch ...
eigener kernel (samt config und tree)... ist da
images sind auch da...
addons für images sind natürlich auch da... (((JAA auch die...)))
referenzbildqualität in SD und HDMI ist.... auch da
http://www.vdr-portal.de/board/thread.php?postid=617110
Ksn iemand dat bevestigen?
Hoezo alternatief voor de DM8000?
De DM8000 heeft GÉÉN HDCP dus je praat helemaal niet over een vervanger van..
Het wachten is simpelweg op een ontvanger die een HDCP licensie heeft en HDMI uitgang en ook nog eens overweg kan met de nodige cams.
Het zou super zijn als dit misschien eindelijk eens wat wordt vooral gezien het prijskaartje. <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" />
