wiltop Geplaatst: 8 augustus 2007 Geplaatst: 8 augustus 2007 ik heb een card splitty , kan een seca card delen met 3 ontvangers. met humax en @sat 9500 gaat dat prima , maar dbox2 met multicam werkt niet. stop ik de orginele kaart in dbox2 gaat 't wel. wat zou de reden kunnen zijn 2 x dm800hd + 1 x dm8000 3 x vuduo + 1 x vuduo2 1 x coolstream 1 x nas 2413
DRG Geplaatst: 9 augustus 2007 Geplaatst: 9 augustus 2007 Als je de output van je camd post dan kunnen we zien wat er mis gaat <img src="/forums/images/graemlins/wink.gif" alt="" /> Diverse meuk... maar dat boeit niemand toch..
wiltop Geplaatst: 16 augustus 2007 Auteur Geplaatst: 16 augustus 2007 oke , zal ik doen /tmp/currentservices.xml: No such file or directory [cardserver 01:00:17] compiled Mar 23 2006, 23:01:35 [cinfo.socket] sucessfull created $Id: controld.cpp,v 1.124 2006/06/27 10:21:59 barf Exp $ [cardserver 01:00:17] Card 0/0 reset [controld] Boxtype detected: (1, Nokia D-BOX 2) [controld]: ROUTEVIDEO v1 = 5 a1 = 1 v2 = 1 a2 = 0 v3 = 1 a3 = 1 fblk=1 [nhttpd ] Neutrino HTTP-Server starting.. [LCDFONT] initializing core... [LCDFONT] adding font /share/fonts/micron.ttf...OK (Micron/Regular) [LCDFONT] adding font /share/f onts/micron_bold.ttf...OK (Micron/Bold) [LCDFONT] adding font /share/fonts/pakenh am.ttf...OK (Fette Engschrift/Regular) [LCDFONT] Intializing font cache... [cardse rver 01:00:20] Card 0/0 reset failed [cardserver 01:00:20] Card 1/0 reset [cardser ver 01:00:22] Card 1/0 init Seca card [neutrino] frameBuffer Instance created 812k video mem avia_gt_gv: set_input_mode (mode=2) avia_gt_gv: set_input_size (width=720, height=576) [neutrino] Software update enabled [neutrino] enable flash [deutsch.locale] missin g entry: moviebrowser.edit_book_name_info2 [deutsch.locale] missing entry: moviebrowser.edit_book_pos_info2 [deutsch.locale] has 2 missing entrys [lcdd] ti me-skin not found -> using default... [lcdd] weekday-skin not found -> using defa ult... [lcdd] date-skin not found -> using default... [lcdd] month-skin not found -> using default... [LCDFONT] initializing core... [LCDFONT] adding font /share/fo nts/12.pcf.gz...OK (Fix12/Regular) [LCDFONT] adding font /share/fonts/14B.pcf.gz. ..OK (Fix14/Bold) [LCDFONT] adding font /share/fonts/15B.pcf.gz...OK (Fix15/Bold) [LCDFONT] Intializing font cache... [LCDFONT] FTC_Face_Requester (Fix15/Bold) [LCD FONT] FTC_Face_Requester (Fix14/Bold) [cardserver 01:00:25] Card 1/0 init failed / dev/input/event1: No such file or directory [neutrino] menue setup loading locales : scandir: No such file or directory tuxbo x mgcamd v1.24 by mixvt (compiled Jun 17 2007 22:38:37) [mg] Net:1:7:2:10s Show e cm:1, emm:1 Up:4 Au:2 Dir:0 Osd:neutrino:80:15 Cache:7 Log:3:172.16.1.1:28007 Re read:4 [mg] Ecm cache time: 15 Box type: dbox2 Conax.Key error 2: No such file or d irectory Keys readed Conax.Key error 2: No such file or directory ignore caid 1831 i gnore caid 1722 ignore caid 1702 priority caid 0628 ecm replace 213F:0100:000202:06 A7 -> 0100:000030:06A7 ecm replace 2140:0100:000202:06A8 -> 0100:000030:06A8 ecm r eplace 2141:0100:000202:06A9 -> 0100:000030:06A9 caid replace 1722 -> 1801 [cinfo] cannot connect to cryptinfo: No such file or directory [neutrino] received 38 sa ts [config] newcamd route = local:127.0.0.1:10001 server cardserv newcamd keep ali ve: 0, incoming port: 0 [mgcam] emm thread started [mgcamd] tps update started. [ne wcamd] Connecting to 127.0.0.1:10001... [basicsocket] send_data: Resource tempora rily unavailable [newcamd] Connection to 127.0.0.1:10001 failed (52ms) [neutrino] registering as event client [sectionsd] getUTC: read: Connection timed out [crypti nfo.socket] sucessfull created [basicsocket] send_data: Resource temporarily unav ailable [basicsocket] send_data: Resource temporarily unavailable [basicsocket] se nd_data: Resource temporarily unavailable [basicsocket] send_data: Resource tempo rarily unavailable [basicsocket] send_data: Resource temporarily unavailable [basi csocket] send_data: Resource temporarily unavailable [basicsocket] send_data: Res ource temporarily unavailable [basicsocket] send_data: Resource temporarily unava ilable [basicsocket] send_data: Resource temporarily unavailable [basicsocket] sen d_data: Resource temporarily unavailable [basicsocket] send_data: Resource tempor arily unavailable [basicsocket] send_data: Resource temporarily unavailable [basic socket] send_data: Resource temporarily unavailable [basicsocket] send_data: Reso urce temporarily unavailable [neutrino] initialized everything avia_gt_core: maski ng unhandled irq reg 0 bit 6 avia_gt_core: masking unhandled irq reg 0 bit 7 [cryptinfo] CAT ( 0622 0100 ) K2-Cryptinfo unk PES, queue 0 normal. got 105 cmd 9F avia_gt_core: masking unhandled irq reg 1 bit 15 [mg0] service FAC index 0 pmt pid 0 (1) ECM: CaID: 0x0622 -> CaPID: 0x0568 Prov ID: 000000 ECM: CaID: 0x0100 -> CaPID: 0x0644 ProvID: 00006A ECM: CaID: 0x0100 -> CaPID: 0x0662 ProvID: 00006C [cryptinfo] DEC ( 0000 ) K2-Cryptinfo unk FREE T O AIR [cryptinfo] DEC ( 0000 ) K2-Cryptinfo unk FREE TO AIR [mg0] No irdeto key(s) found for id 0 keynr 00 [mg0] network can't decode [mg0] pid 0x0568 failed to dec ode. [mg0] No irdeto key(s) found for id 0 keynr 00 [mg0] network can't decode [mg0 ] pid 0x0568 failed to decode. [mg0] No irdeto key(s) found for id 0 keynr 00 [mg0 ] network can't decode [mg0] pid 0x0568 failed to decode. [mg0] No irdeto key(s) f ound for id 0 keynr 00 [mg0] network can't decode [mg0] pid 0x0568 failed to decod e. [mg0] No seca key(s) found for id 6A keynr 0c [mg0] network can't decode [mg0] p id 0x0644 failed to decode. [mg0] No seca key(s) found for id 6C keynr 0c [mg0] ne twork can't decode [mg0] pid 0x0662 failed to decode. [mgcamd] emm started EMM: Ca ID: 0x0622 -> CaPID: 0x0136 ProvID: 000000 EMM: CaID: 0x0100 -> CaPID: 0x00B6 ProvID: 000000 EMM: CaID: 0x0100 -> CaPID: 0x00B7 ProvID: 00006A EMM: CaID: 0x0 100 -> CaPID: 0x00B9 ProvID: 00006C EMM: CaID: 0x0D02 -> CaPID: 0x1389 ProvID: 000000 [mgcamd] emm stopped [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 fa iled to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to deco de. [mg0] pid 0x0644 failed to decode. [mg0] pid 0x0662 failed to decode. [newcamd] Connecting to 127.0.0.1:10001... [newcamd] Connection to 127.0.0.1:10001 failed (0ms) [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] p id 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0644 fa iled to decode. [mg0] pid 0x0662 failed to decode. [mg0] pid 0x0568 failed to deco de. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0644 failed to decode. [mg0] pid 0x0662 fail ed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode . [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0 x0644 failed to decode. [mg0] pid 0x0662 failed to decode. [mg1] pid 0x056D failed to decode. [mg1] pid 0x056D failed to decode. [mg1] pid 0x 056D failed to decode. [newcamd] Connecting to 127.0.0.1:10001... [newcamd] Connec tion to 127.0.0.1:10001 failed (14ms) [mg1] pid 0x0649 failed to decode. [mg1] pid 0x056D failed to decode. [mg1] pid 0x056D failed to decode. [mg1] pid 0x056D fail ed to decode. [mg1] pid 0x0649 failed to decode. [mg1] pid 0x056D failed to decode . [mg1] pid 0x056D failed to decode. [mg1] pid 0x056D failed to decode. [mg1] pid 0 x0649 failed to decode. [newcamd] Connecting to 127.0.0.1:10001... [newcamd] Conne ction to 127.0.0.1:10001 failed (19ms) [mg1] pid 0x056D failed to decode. [mg1] pi d 0x056D failed to decode. [mg1] pid 0x056D failed to decode. [mg1] pid 0x0649 fai led to decode. [mg1] pid 0x056D failed to decode. [mg1] pid 0x056D failed to decod e. [mg1] pid 0x056D failed to decode. [mg1] pid 0x0649 failed to decode. [mg1] pid 0x056D failed to decode. [mg1] pid 0x056D failed to decode. [mg1] pid 0x056D faile d to decode. [newcamd] Connecting to 127.0.0.1:10001... [mg1] pid 0x0649 failed to decode. [newcamd] Connection to 127.0.0.1:10001 failed (48ms) [newcamd] Connectin g to 127.0.0.1:10001... [newcamd] Connection to 127.0.0.1:10001 failed (8ms) [mg1] pid 0x056D failed to decode. [mg1] pid 0x056D failed to decode. [mg1] pid 0x056D failed to decode. [mg1] pid 0x0649 failed to decode. [mg1] pid 0x056D failed to de code. [mg1] pid 0x056D failed to decode. [mg1] pid 0x056D failed to decode. [mg1] p id 0x0649 failed to decode. [newcamd] Connecting to 127.0.0.1:10001... [newcamd] C onnection to 127.0.0.1:10001 failed (28ms) [mg1] pid 0x056D failed to decode. [mg1 ] pid 0x056D failed to decode. [mg1] pid 0x056D failed to decode. [mg1] pid 0x0649 failed to decode. [mg1] pid 0x056D failed to decode. [mg1] pid 0x056D failed to d ecode. [mg1] pid 0x056D failed to decode. [mg1] pid 0x0649 failed to decode. [newca md] Connecting to 2 x dm800hd + 1 x dm8000 3 x vuduo + 1 x vuduo2 1 x coolstream 1 x nas 2413
wiltop Geplaatst: 16 augustus 2007 Auteur Geplaatst: 16 augustus 2007 dit is met orginele kaart [mg0] -> ECM to newcamd 127.0.0.1:10001 Client -> Server: -- Thu Aug 16 11:41:14 2007 ---------------------------------------------------- 000: 80 00 61 00 6a 00 0 0 fc 10 01 71 85 7d 1e f0 df ..a.j.....q..... 010: 0c be 1e 57 f5 41 94 ea 5c 24 49 fc f3 1a a6 bb ...W.A..\$I..... 020: 39 7a 6b 77 a7 52 20 89 b7 82 71 1e 24 e6 ce 9a 9zkw.R ...q.$... 030: 02 87 39 6f 91 cc 11 7a 4a 4b d0 56 f3 b0 26 a8 ..9o...zJK.V..&. 040: 4a 35 3b 65 04 bb 5f 9f 8b 3d 43 7c 03 3f 92 28 J5;e.._..= C..?.( 050: 8c 84 73 9d ec 64 da 10 eb 21 16 e5 7a 75 3c 9a ..s..d...!..zu<. 060: 1c ec 4f 0e ..O. Client <- Server: -- Thu Aug 16 11:41:16 2007 ---------------------------------------------------- 000: 80 10 10 00 00 08 08 60 a0 00 00 00 00 00 00 00 .......`........ 010: 28 01 29 (.) [mg0] <- CW from newcamd 127.0.0.1:10001 (557ms) 557 msec -- Thu Aug 16 11:41:16 2007 ===== Seca ECM on CaID 0x0100, pid 0 x0644 ====== prov: 00006A cw0:0 00 00 08 08 60 A0 00 00 cw1:0 00 00 00 00 00 28 01 29 [newcamd] Connecting to 192.168.001.001:6001... [newcamd] Connection to 192.168 .001.001:6001 failed (28ms) [mg0] -> ECM to newcamd 127.0.0.1:10001 Client -> Serv er: -- Thu Aug 16 11:41:27 2007 ------------------------------------------------- --- 000: 81 00 61 00 6a 00 00 fc 10 01 c0 85 b8 4e a5 04 ..a.j........N.. 010: cb 97 5c 8e 47 0d 3f a5 1c c4 01 ef f0 f7 cf 98 ..\.G.?......... 020: a7 3e aa 14 50 ea e8 1e 4d 45 a2 c0 27 d3 f8 4f .>..P...ME..'..O 030: 5d a7 12 2c 29 49 78 f b 2d d7 42 cc ea 25 dd 48 ]..,)Ix.-.B..%.H 040: 34 e5 7c a6 8b 84 83 b3 96 c6 37 5d ad fa 93 ee 4.........7].... 050: f1 bd 32 15 b4 5d 6b 86 dc 0d 5e 2d d5 e7 82 0f ..2..]k...^-.... 060: 0f 98 da 94 .. .. Client <- Server: -- Thu Aug 16 11:41:29 2007 --------------------------------- ------------------- 000: 81 10 10 00 00 20 20 90 90 00 20 00 00 00 00 00 ..... ... ..... 010: 28 01 29 (.) [mg0] <- CW f rom newcamd 127.0.0.1:10001 (680ms) 680 msec -- Thu Aug 16 11:41:29 2007 ===== Sec a ECM on CaID 0x0100, pid 0x0644 ====== prov: 00006A cw0:0 00 00 20 20 90 90 00 20 cw1:0 00 00 00 00 00 28 01 29 [newcamd] Connecting to 192.168.001.001:6001. n't decode [mg1] pid 0x0567 failed to decode. [mg1] No irdeto key(s) found for id 0 keynr 00 [mg1] network can't decode [mg1] pid 0x0567 failed to decode. [mg1] No i rdeto key(s) found for id 0 keynr 00 [mg1] network can't decode [mg1] pid 0x0567 f ailed to decode. [mg1] No irdeto key(s) found for id 0 keynr 00 [mg1] network can' t decode [mg1] pid 0x0567 failed to decode. [mg1] No seca key(s) found for id 6A k eynr 0c [mg1] -> ECM to newcamd 127.0.0.1:10001 Client -> Server: -- Thu Aug 16 12 :07:48 2007 ---------------------------------------------------- 000: 80 00 61 00 6a 00 00 fc 10 01 65 01 a5 0e d7 84 ..a.j.....e..... 010: 93 e4 33 e5 c3 4e df a 4 e4 9e d8 72 58 29 5f 27 ..3..N.....rX)_' 020: e9 b9 59 c9 7f f4 23 0d 29 9d af 4f 69 b4 8f 8d ..Y...#.)..Oi... 030: 75 56 37 75 ca aa 79 30 92 a2 43 ac 34 f1 82 48 uV7u..y0..C.4..H 040: a8 d9 70 25 1f 12 e8 a1 3a d3 12 73 c9 94 d6 d6 ..p %....:..s.... 050: d1 37 94 63 3a bf 61 ae 55 48 cd b3 5f 2d 88 fc .7.c:.a.UH.._ -.. 060: 16 c7 4e 3b ..N; Client <- Server: -- Thu Aug 16 12:07:50 2007 ---------------------------------------------------- 0 00: 80 10 10 58 08 20 80 00 00 00 00 f8 75 db 48 79 ...X. ......u.Hy 010: 40 7f 38 @.8 [mg1] <- CW from newcamd 127.0.0. 1:10001 (692ms) 692 msec -- Thu Aug 16 12:07:50 2007 ===== Seca ECM on CaID 0x0100 , pid 0x0643 ====== prov: 00006A cw0:1 58 08 20 80 00 00 00 00 cw1:1 F8 75 DB 48 79 40 7F 38 [controld] VIDEO_EVENT_SIZE_CHANGED 704x576 (4:3 -> 16:9) [mg1] -> ECM t o newcamd 127.0.0.1:10001 Client -> Server: -- Thu Aug 16 12:07:52 2007 ---------- ------------------------------------------ 000: 81 00 61 00 6a 00 00 fc 10 01 2d 61 dd 70 bd d3 ..a.j.....-a.p.. 010: b5 3f d5 f1 9a 21 35 61 c6 d3 43 54 09 63 c 3 04 .?...!5a..CT.c.. 020: 5f 76 e4 5f 76 e9 9e bf eb f0 9f 2e fd 3c 22 8e _v._ v........<". 030: 94 81 8e 08 34 d5 73 46 9e 1b ab 1d 38 84 fe 2d ....4.sF....8. .- 040: dc 77 ec f2 e9 f0 e9 87 0d 95 68 dc c2 63 b2 f1 .w........h..c.. 050: 3e cd 03 05 83 a0 2d 4f 00 78 9e 1b 1a 84 e1 a0 >.....-O.x...... 060: 49 a7 4e 3d I.N= Client <- Server: -- Thu Aug 16 12:07:5 3 2007 ---------------------------------------------------- 000: 81 10 10 40 c0 00 00 00 28 00 28 f8 75 db 48 79 ...@....(.(.u.Hy 010: 40 7f 38 @.8 [mg1] <- CW from newcamd 127.0.0.1:10001 (686ms) 686 ms ec -- Thu Aug 16 12:07:54 2007 ===== Seca ECM on CaID 0x0100, pid 0x0643 ====== pr ov: 00006A cw0:1 40 C0 00 00 00 28 00 28 cw1:1 F8 75 DB 48 79 40 7F 38 [mg1] -> ECM to newcamd 127.0.0.1:10001 Client -> Server: -- Thu Aug 16 12:08:05 2007 -------- -------------------------------------------- 000: 80 00 61 00 6a 00 00 fc 10 01 a 2 b0 44 bb 71 df ..a.j.......D.q. 010: 3c 37 e8 49 30 f8 9a eb a6 2b da 75 15 32 87 ec <7.I0....+.u.2.. 020: 45 8b f4 2d 70 d7 92 c8 fc ad 94 f9 72 da 2c d5 E. .-p.......r.,. 030: da be 9f 4d 06 a4 25 b3 96 35 1e 01 d3 38 29 6c ...M..%..5.. .8)l 040: a4 cd 46 1c b8 bb 67 b5 2f 74 16 41 5d 17 62 71 ..F...g./t.A].bq 050: 4 8 dd 08 49 50 36 b8 16 d2 37 9a af fa 7c fa 6e H..IP6...7.....n 060: e9 c1 67 41 ..gA Client <- Server: -- Thu Aug 16 12:08 :06 2007 ---------------------------------------------------- 000: 80 10 10 40 c0 00 00 00 28 00 28 08 00 08 10 00 ...@....(.(..... 010: 88 80 08 ... [mg1] <- CW from newcamd 127.0.0.1:10001 (691ms) 691 msec -- Thu Aug 16 12:08:07 2007 ===== Seca ECM on CaID 0x0100, pid 0x0643 ====== prov: 00006A cw0:1 40 C0 00 00 00 28 00 28 cw1:1 08 00 08 10 00 88 80 08 [mg1] -> E CM to newcamd 127.0.0.1:10001 Client -> Server: -- Thu Aug 16 12:08:18 2007 ------ ---------------------------------------------- 000: 81 00 61 00 6a 00 00 fc 10 01 2c d1 39 20 5a 4d ..a.j.....,.9 ZM 010: bd 69 78 21 3d 09 ba 10 97 c3 70 d9 c3 0b 92 5d .ix!=.....p....] 020: 22 8a cf 8e 95 86 5c 83 15 1f f9 93 32 4e b2 c9 ".....\.....2N.. 030: 8b ee 55 63 c5 61 d7 d5 6a 8a 3c 12 e0 8d 85 aa ..Uc.a..j. <..... 040: 21 4c 7b 79 87 84 19 26 db 7c a9 ad c5 2a c4 b2 !L{y...&.....*.. 050: 72 b0 d9 8f 31 3e 06 f4 ac 8e 56 cb e4 9c 32 c7 r...1>....V...2. 060: 1a 3c 88 41 .<.A Client <- Server: -- Thu Aug 16 12: 08:19 2007 ---------------------------------------------------- 000: 81 10 10 00 0 8 08 10 40 c0 00 00 08 00 08 10 00 .......@........ 010: 88 80 08 ... [mg1] <- CW from newcamd 127.0.0.1:10001 (685ms) 68 5 msec -- Thu Aug 16 12:08:20 2007 ===== Seca ECM on CaID 0x0100, pid 0x0643 ==== == prov: 00006A cw0:1 00 08 08 10 40 C0 00 00 cw1:1 08 00 08 10 00 88 80 08 [mg1] -> ECM to newcamd 127.0.0.1:10001 Client -> Server: -- Thu Aug 16 12:08:31 2007 ---- ------------------------------------------------ 000: 80 00 61 00 6a 00 00 fc 10 01 20 f6 26 b2 4f 3a ..a.j..... .&.O: 010: 97 99 68 c9 7f a6 ac 3a 6a 53 18 4b f 8 0b 5b 34 ..h....:jS.K..[4 020: e5 68 9b 28 63 c0 94 3f b8 60 36 a5 cf 47 27 04 .h.(c..?.`6..G'. 030: 49 c4 9d 6a 1f 4f 5a 9c d1 cb ee ce cc 31 a6 b4 I..j.OZ. .....1.. 040: 0d 76 0c ab d5 da ff 13 90 05 33 e4 18 4f d1 70 .v........3..O.p 05 0: 9f bd db be 0f b7 7e c0 55 78 ed f8 69 ef f8 08 ........Ux..i... 060: 03 6b 9 2 42 .k.B Client <- Server: -- Thu Aug 16 1 2:08:32 2007 ---------------------------------------------------- 000: 80 10 10 00 08 08 10 40 c0 00 00 40 00 00 40 40 .......@...@..@@ 010: c0 20 20 . [mg1] <- CW from newcamd 127.0.0.1:10001 (690ms) 690 msec -- Thu Aug 16 12:08:33 2007 ===== Seca ECM on CaID 0x0100, pid 0x0643 == ==== prov: 00006A cw0:1 00 08 08 10 40 C0 00 00 cw1:1 40 00 00 40 40 C0 20 20 [mg1] -> ECM to newcamd 127.0.0.1:10001 Client -> Server: -- Thu Aug 16 12:08:44 2007 -- -------------------------------------------------- 000: 81 00 61 00 6a 00 00 fc 1 0 01 40 24 8b 07 e6 7e ..a.j.....@$.... 010: 13 24 03 18 b1 69 a7 29 85 02 20 e7 50 f4 ad d3 .$...i.).. .P... 020: 34 34 bc e5 dc a0 37 b2 1a 03 04 95 0a 4c 23 4d 44....7......L#M 030: d1 db bd d8 f3 a7 a3 48 4e e2 c8 9d 9e e7 d5 d5 ...... .HN....... 040: 40 b7 11 8c 29 4c 46 ad 93 2e b9 18 30 95 56 91 @...)LF.....0.V. 050: 06 34 12 2f dc a4 39 6a 9e 40 d7 38 10 0f e5 02 .4./..9j.@.8.... 060: cd 6f 1c c3 .o.. Client <- Server: -- Thu Aug 16 12:08:45 2007 ---------------------------------------------------- 000: 81 10 10 08 00 28 30 10 10 00 20 40 00 00 40 40 .....(0... @..@@ 010: c0 20 20 . [mg1] <- CW from newcamd 127.0.0.1:10001 (689m s) 689 msec -- Thu Aug 16 12:08:46 2007 ===== Seca ECM on CaID 0x0100, pid 0x0643 ====== prov: 00006A cw0:1 08 00 28 30 10 10 00 20 cw1:1 40 00 00 40 40 C0 20 20 [mg1 ] -> ECM to newcamd 127.0.0.1:10001 Client -> Server: -- Thu Aug 16 12:08:57 2007 ---------------------------------------------------- 000: 80 00 61 00 6a 00 00 fc 10 01 9e 53 21 e6 a7 1e ..a.j......S!... 010: ac 4b db c8 2c ef 9e 99 e9 43 3f 9e 1d 7e 2f ff .K..,....C?.../. 020: d6 5c 31 d3 aa d1 0c 2b 47 4d 60 87 02 fb e c 1a .\1....+GM`..... 030: 85 e2 80 6f 34 80 70 cb 12 f4 93 fa 82 f0 39 69 ...o 4.p.......9i 040: cc 08 6e e7 99 95 ac 26 ed 7a cd cc b9 78 42 d8 ..n....&.z...x B. 050: 48 8e fd d0 3f 4a 0f c9 a9 eb 32 26 4f 27 0b 9e H...?J....2&O'.. 060: c4 27 3c 16 .'<. Client <- Server: -- Thu Aug 16 12:08:58 2007 ---------------------------------------------------- 000: 80 10 1 0 08 00 28 30 10 10 00 20 40 40 20 a0 00 .....(0... @@ .. 010: 08 20 28 . ( [mg1] <- CW from newcamd 127.0.0.1:10001 (68 8ms) 688 msec -- Thu Aug 16 12:08:59 2007 ===== Seca ECM on CaID 0x0100, pid 0x064 3 ====== prov: 00006A cw0:1 08 00 28 30 10 10 00 20 cw1:1 40 40 20 A0 00 08 20 28 [m g1] -> ECM to newcamd 127.0.0.1:10001 Client -> Server: -- Thu Aug 16 12:09:10 20 07 ---------------------------------------------------- 000: 81 00 61 00 6a 00 00 fc 10 01 a5 12 c4 e3 2d 73 ..a.j.........-s 010: 01 53 16 90 ea dd cb 33 79 d7 1 d 31 de 30 43 53 .S.....3y..1.0CS 020: d9 8d 93 86 d7 a2 7c 1f 04 8a ae cf ad ff a1 73 ...............s 030: 61 96 36 0d 99 75 9a e7 4d 25 ba e1 90 c3 7f 12 a. 6..u..M%...... 040: ea ba 0f e7 eb 21 c7 e3 12 e1 f6 e0 ed 69 19 90 .....!...... .i.. 050: 32 fa aa 4e cf 33 fa 47 de 04 c5 8e 5c d4 5d 50 2..N.3.G....\.]P 060: f c a4 a7 75 ...u Client <- Server: -- Thu Au g 16 12:09:11 2007 ---------------------------------------------------- 000: 81 10 10 00 00 20 20 90 90 00 20 40 40 20 a0 00 ..... ... @@ .. 010: 08 20 28 . ( [mg1] <- CW from newcamd 127.0.0.1:10001 ( 687ms) 687 msec -- Thu Aug 16 12:09:12 2007 ===== Seca ECM on CaID 0x0100, pid 0x0 643 ====== prov: 00006A cw0:1 00 00 20 20 90 90 00 20 cw1:1 40 40 20 A0 00 08 20 28.. [new camd] Connection to 192.168.001.001:6001 failed (8ms) 2 x dm800hd + 1 x dm8000 3 x vuduo + 1 x vuduo2 1 x coolstream 1 x nas 2413
wiltop Geplaatst: 16 augustus 2007 Auteur Geplaatst: 16 augustus 2007 Thu Aug 16 18:09:10 CEST 2007 --------------------------------------------------- --- 00: c1 3c 01 fc 5c 10 01 39 a8 6f 26 60 13 6f 10 e8 < \ 9 o&` o 10: bb c7 aa f2 36 83 07 bb b2 78 12 f6 17 fc be 88 6 x 20: 08 43 3e ea 6 7 b4 5a 29 ee 43 8f d1 51 e1 27 84 C> g Z) C Q ' 30: 54 1a 63 04 5d 54 3c a7 fb d3 cf a5 50 3b 14 7f T c ]T< P; 40: ac 73 9a 20 ca 7d e6 19 2a 9f 79 6e 59 dc d3 64 s * ynY d 50: cd 51 ad 55 8c da 11 ce 81 89 07 77 80 88 e f eb Q U w 60: 9c EC M <- Card 1/0 - 0100 - Thu Aug 16 18:09:11 CEST 2007 ---------------------------- -------------------------- 00: 90 00 ECM -> Card 1/0 - 0100 - Thu Aug 16 18:09:11 CEST 2007 ------------------------ ------------------------------ 00: c1 3a 00 00 10 : ECM <- Card 1/0 - 0100 - Thu Aug 16 18:09:11 CEST 2007 ----------------- ------------------------------------- 00: 40 40 00 54 00 08 20 65 48 48 00 75 00 00 00 b6 @@ T eHH u 10: 90 00 Client <- Server 1/0 - 0100 - Thu Aug 16 18:09:12 CEST 2007 ------------------ ----------------------------------------- 00: 81 10 10 40 40 00 80 00 08 20 28 48 48 00 90 00 @@ (HH 10: 00 00 00 Client <- Server: -- Thu Aug 16 18:09:12 2007 --------------------------- ------------------------- 000: 81 10 10 40 40 00 80 00 08 20 28 48 48 00 90 00 . ..@@.... (HH... 010: 00 00 00 ... [mg0] < - CW from newcamd 127.0.0.1:10001 (2919ms) 2919 msec -- Thu Aug 16 18:09:12 2007 = ==== Seca ECM on CaID 0x0100, pid 0x0644 ====== prov: 00006A cw0:0 40 40 00 80 00 08 20 28 cw1:0 48 48 00 90 00 00 00 00 Client -> Server 1/0 - 0100 - Thu Aug 16 18 :09:13 CEST 2007 ----------------------------------------------------------- 00: 8 1 00 61 00 6a 00 00 fc 10 01 dd 36 d2 67 f0 09 a j 6 g 10: 87 9f b8 01 a5 fb 98 c5 34 60 c3 de 3f 97 31 75 4` ? 1u 20: 8c 52 25 a4 fe df 61 00 49 89 c8 10 df cc fb a2 R% a I 30: 9f 1c 5e 7f f4 af 6c 41 b2 87 7 6 ae e0 57 a8 88 ^ lA v W 40: 5a 07 83 3e ce 52 34 e6 63 4b e4 90 7d e7 b7 2c Z > R4 cK , 50: f8 9e 9a f0 b6 c1 42 4e c3 ac 44 31 77 fc b3 7a BN D1w z 60: 33 ba fb 60 3 ` ECM -> Card 1/0 - 0100 - Thu Aug 16 18:09:14 CEST 2007 --------------------------------- --------------------- 00: c1 3c 01 fc 5c 10 01 dd 36 d2 67 f0 09 87 9f b8 < \ 6 g 10: 01 a5 fb 98 c5 34 60 c3 de 3f 97 31 75 8c 52 25 4` ? 1u R % 20: a4 fe df 61 00 49 89 c8 10 df cc fb a2 9f 1c 5e a I ^ 30: 7f f4 af 6c 41 b2 87 76 ae e0 57 a8 88 5a 07 83 lA v W Z 40: 3e ce 52 34 e6 63 4b e4 90 7d e7 b7 2c f8 9e 9a > R4 cK , 50: f0 b6 c1 42 4e c3 ac 44 3 1 77 fc b3 7a 33 ba fb BN D1w z3 60: 60 ` ECM <- Card 1/0 - 0100 - Thu Aug 16 18:09:15 CEST 2007 ---------- -------------------------------------------- 00: 90 00 ECM -> Card 1/0 - 0100 - Thu Aug 16 18:09:15 CEST 2007 ------ ------------------------------------------------ 00: c1 3a 00 00 10 : ECM <- Card 1/0 - 0100 - Thu Aug 16 18:09:16 CEST 200 7 ------------------------------------------------------ 00: 00 08 08 6d 00 20 00 84 00 00 00 2e 20 90 50 0e m . P 10: 90 00 Client <- Server 1/0 - 0100 - Thu Aug 16 18:09:16 CEST 2007 ----------------------------------------------------------- 00: 81 10 10 00 08 08 10 00 20 00 20 00 00 00 00 20 10: 90 50 00 P [cardserver 18:09:20] Thu Aug 16 18:09:20 CEST 2007 [ca rdserver 18:09:20] Card 1/0 removed [cardserver 18:09:20] Card 1/0 Logout: local [newcamd] 127.0.0.1:10001: problem, will try to reconnect [cardserver 18:0 9:20] Card 1/0 Logout: wiltop [newcamd] Connecting to 127.0.0.1:10001... [ newcamd] Connection to 127.0.0.1:10001 failed (0ms) [mg0] -> ECM to newcamd 127.0 .0.1:10001 Client -> Server: -- Thu Aug 16 18:09:21 2007 ------------------------- --------------------------- 000: 80 00 61 00 6a 00 00 fc 10 01 85 e9 80 3e 5c 51 ..a.j........>\Q 010: 38 9c 78 d8 50 cd 42 40 12 3d 00 5f 23 c3 11 c3 8.x.P.B@. =._#... 020: f5 ce 83 30 b4 46 40 b1 9f 0f c4 b4 4d fb 72 6b ...0.F@.....M.rk 030 : 1f ef 48 bc 0b 25 03 9d 9a 7f 38 6c 14 1d 78 95 ..H..%....8l..x. 040: c1 ef dd b2 71 0f 71 41 2d 25 05 68 c0 62 52 b2 ....q.qA-%.h.bR. 050: 59 b4 3e 18 6c 5c 97 d4 dd e2 fa 9d 49 06 bf 90 Y.>.l\......I... 060: 74 7d be 00 t... [mg0] -> cant send ecm to newcamd 127.0.0.1:10001 : -1 [mg0] pid 0x0644 failed to decode. [mg0] pid 0x0662 failed to decode. [mgcamd] emm started EMM: CaID: 0x0622 -> CaPID: 0x0136 ProvID: 000000 EMM: CaID: 0x0100 - > CaPID: 0x00B6 ProvID: 000000 EMM: CaID: 0x0100 -> CaPID: 0x00B7 ProvID: 00006 A EMM: CaID: 0x0100 -> CaPID: 0x00B9 ProvID: 00006C EMM: CaID: 0x0D02 -> CaPID : 0x1389 ProvID: 000000 [mgcamd] emm stopped [newcamd] Connecting to 127.0.0.1:100 01... [newcamd] Connection to 127.0.0.1:10001 failed (28ms) [mg0] pid 0x0568 faile d to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0644 failed to decode. [mg0] pid 0x 0662 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [m g0] pid 0x0644 failed to decode. [mg0] pid 0x0662 failed to decode. [newcamd] Conn ecting to 127.0.0.1:10001... [newcamd] Connection to 127.0.0.1:10001 failed (0ms) [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x 0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0644 failed to decode. [mg0] pid 0x0662 failed to decode. [mg0] pid 0x0568 failed to decode. [m g0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x05 68 failed to decode. [mg0] pid 0x0644 failed to decode. [cardserver 18:09:28] Card 1/0 reset [mg0] pid 0x0662 failed to decode. [newcamd] Connecting to 127.0.0.1:10 001... [newcamd] Connection to 127.0.0.1:10001 failed (28ms) [mg0] pid 0x0568 fail ed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode . [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0644 failed to decode. Init <- Car d 1/0 - Thu Aug 16 18:09:30 CEST 2007 ------------------------------------------- ----- 00: 3b f7 11 00 01 40 96 70 70 07 0e 6c b6 d6 90 00 ; @ pp l [card server 18:09:30] Card 1/0 init Seca card Init -> Card 1/0 - Thu Aug 16 18:09:30 C EST 2007 ------------------------------------------------ 00: c1 34 00 00 03 04 00 01 4 [mg0] pid 0x0662 failed to decode. [mg0] pi d 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 fai led to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0644 failed to decod e. [mg0] pid 0x0662 failed to decode. [newcamd] Connecting to 127.0.0.1:10001... [n ewcamd] Connection to 127.0.0.1:10001 failed (0ms) [mg0] pid 0x0568 failed to dec ode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pi d 0x0568 failed to decode. [mg0] pid 0x0644 failed to decode. [mg0] pid 0x0662 fai led to decode. [cardserver 18:09:33] Card 1/0 init failed [newcamd] Connecting to 127.0.0.1:10001... [newcamd] Connection to 127.0.0.1:10001 failed (28ms) [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 fail ed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0644 failed to decode . [mg0] pid 0x0662 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0 x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0644 failed to decode. [mg0] pid 0x0662 failed to decode. [ newcamd] Connecting to 127.0.0.1:10001... [newcamd] Connection to 127.0.0.1:10001 failed (0ms) [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode . [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0 x0644 failed to decode. [mg0] pid 0x0662 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [mg0] pid 0x0568 failed to decode. [ mg0] pid 0x0568 failed to decode. [mg0] pid 0x0644 failed to decode. [mg0] pid 0x0 662 failed to decode. 2 x dm800hd + 1 x dm8000 3 x vuduo + 1 x vuduo2 1 x coolstream 1 x nas 2413
satbikkel Geplaatst: 17 december 2007 Geplaatst: 17 december 2007 wat voor log dit is weet ik niet, maar wat voor cam word er gekoppeld aan de multicam. word de kaart hier wel goed in herkend? zowel de org. als de splitty ik zal ook eens opscheppen: humax5400, humax5400Z,philips 6072, 2x nokia dbox2 kabel, 1x nokia 9500 sat, sagem dbox2 kabel, samsung 9401r kabel en een lege bankrekening
DRG Geplaatst: 17 december 2007 Geplaatst: 17 december 2007 Mgcamd zie ik maar welke cardserver gebruik je ? Controleer je newcamd.conf / peerlist want je hebt 2 verschillende servers opgegeven , dit veroorzaakt tegenstrijdige meldingen. haal de 192.168.1.1:6001 eruit [mg1] <- CW from newcamd 127.0.0.1:10001 ( [newcamd] Connection to 192.168.001.001:6001 failed (8ms) Diverse meuk... maar dat boeit niemand toch..
