Dish TV Geplaatst: 22 augustus 2007 Delen Geplaatst: 22 augustus 2007 Ik heb sinds gisteren geen beeld meer op mijn 7025 via Casema. Ik heb net geupgrade van Gemini 2.3 naar 3.0. Ik maak gebruik van mgcamd 1.24 en newcs 1.30. Via de web pagina van de 7025 die ik bij NewCS onder users dit: Output van NewCS: This is NewCS 1.30 - the New CardServer by Butter-team.. Compiled on Aug 3 2007 at 08:43:41 Reading Config file from /var/tuxbox/config/newcs.xml TCP-log password is disabled! level: normal type: init output: all logger config: level 1 type 3 output 255 Console log options: level 1 type 3 log file: logger: cant open file , file log disabled udp log: host 192.168.1.10 port 1000 UDP log options: level 1 type 3 tcp port: 3001 TCP log options: level 1 type 3 [ 19:09:48 ] [ Box detect ] Box type 6 [ 19:09:48 ] [ Config ] /dev/sci0 ECM priority: round [ 19:09:48 ] [ Config ] /dev/sci1 ECM priority: round [ 19:09:48 ] [ EMM Cache ] Initialising Cache with 10 entries [ 19:09:48 ] [ ECM Cache ] Initialising Cache with 10 entries [ NewCS ] Process ID is: 1186 [ 19:09:48 ] [ Loader ] Reader type 5 on node /dev/sci0 [ 19:09:48 ] [ Sci ] Opening device /dev/sci0 [ 19:09:53 ] [ ATR ] T=14 1etu=625.00us Guardtime:17etu WWT:9600etu [ 19:09:53 ] [ ATR ] Historical bytes: I R D E T O A C S V 5 . 0 [ 19:09:53 ] [ Loader ] Init Irdeto card [ 19:09:53 ] [ Keyman ] Adding key 2EC31D type 0 on Provider 000000 for caid 0602 ID=0 [ 19:09:54 ] [ Keyman ] Adding key 4E8D7 type 1 on Provider 000000 for caid 0602 ID=0 [ 19:09:54 ] [ Keyman ] Adding key 600 type 1 on Provider 000001 for caid 0602 ID=1 [ 19:09:54 ] [ Keyman ] Adding key FFFFFF type 1 on Provider 000002 for caid 0602 ID=2 [ 19:09:54 ] [ Keyman ] Adding key FFFFFF type 1 on Provider 000003 for caid 0602 ID=3 [ 19:09:55 ] [ Loader ] Card 0602 on port /dev/sci0 ready [ 19:09:55 ] [ Loader ] Starting Newcamd Server on port 34000 [ 19:09:55 ] [ Loader ] Reader type 5 on node /dev/sci1 [ 19:09:55 ] [ Sci ] Opening device /dev/sci1 [ 19:09:55 ] [ Sci ] No card present in reader [ 19:09:55 ] [ Loader ] Reset failed ... [ 19:09:55 ] [ Loader ] Starting Newcamd Server on port 34001 [ 19:09:55 ] [ NewCS ] Ready to GO! <img src="/forums/images/graemlins/smile.gif" alt="" /> Output van MgCamd: tuxbox mgcamd v1.24 by mixvt (compiled Jun 17 2007 22:39:02) [mg] Net:1:1:0:10s Show ecm:1, emm:1 Up:1 Au:1 Dir:0 Osd:no:80:0 Cache:7 Log:2:192.168.1.10:28007 Reread:0 [mg] Ecm cache time: 15 Box type: dm7025 root@dm7025:/usr/bin> Conax.Key error 2: No such file or directory SoftCam.Key error 2: No such file or directory AutoRoll.Key error 2: No such file or directory Conax.Key error 2: No such file or directory [config] newcamd route = dummy:192.168.1.10:34000 server newcs [config] newcamd route = dummy:192.168.1.10:34001 server newcs newcamd keep alive: 0, incoming port: 12000 [mgcam] emm thread started [mgcamd] tps update started. [newcamd] Connecting to 192.168.1.10:34000... [newcamd] Connecting to 192.168.1.10:34001... [ 19:11:41 ] [ Newcamd:34000 ] User dummy logged in, client: Mgcamd [ 19:11:41 ] [ Newcamd:34001 ] User dummy logged in, client: Mgcamd [newcamd] Login to 192.168.1.10:34000 as dummy accepted (9ms) [newcamd] Login to 192.168.1.10:34001 as dummy accepted (0ms) [newcamd] Card data from 192.168.1.10:34000 (10ms): EMM enabled: UA yes SA yes GA yes, Card serial: xxxxxxxx Userid 1 caid 602 providers 4 Idents: 000000 000001 000002 000003 ids: 4E8D7 1000600 2FFFFFF 3FFFFFF [newcamd] Card data from 192.168.1.10:34001 (5ms): EMM enabled: UA yes SA yes GA yes, Card serial: 0 Userid 1 caid 0 providers 1 Idents: 000000 ids: 0 .-------------------------------------.---- --- -- - - | Newcamd Port: 34000 | CAID: 0602 | Reader: 0 (Casema) |------------------------------------------------------------------------------------------------------------------------------------. | ID | Username | Logon Status | Ok ECM | Bad ECM | EMM | Hostname | Client | Spider | AU | SO | |----|-----------------|--------------|----------|----------|----------|---------------------------|------------|--------|-----|-----| | 02 | dummy | 00d 00:01:40 | 0 | 108 | 11 | 192.168.1.10 | Mgcamd | Yes | On | Off | '------------------------------------------------------------------------------------------------------------------------------------' Ik krijg alleen maar Bad ECM's binnen. Ik heb een Casema kaart met nummer 4015 Heeft iemand een idee wat dit kan zijn? <img src="/forums/images/graemlins/confused.gif" alt="" /> DM7025 - 2x DVB-C - Seagate CE 160Gb HDD - Casema TVD - Gemini 4.20 - CCcam 2.0.11 - Transcend 512Mb CF - Sharp Aquos LC-32GD1E Link naar reactie Delen op andere sites Meer opties om te delen...
DRG Geplaatst: 22 augustus 2007 Delen Geplaatst: 22 augustus 2007 ik had het zelf ook na een klein jaar draaien... lijkt erop dat de kaart weer opnieuw geactiveerd moet worden. ik heb het met camd3 gedaan maar je kan uiteraard ook even een orginele ontvanger proberen. Diverse meuk... maar dat boeit niemand toch.. Link naar reactie Delen op andere sites Meer opties om te delen...
Dish TV Geplaatst: 22 augustus 2007 Auteur Delen Geplaatst: 22 augustus 2007 Hmm, dat is niet zo mooi. Ik heb niet de originele ontvanger niet meer... Dan vrees ik dat ik de Casema moet gaan bellen om de kaart op te sturen. Hoe werkt dat met CAM3D? Ik heb even gezocht op het forum maar kan zosnel even niet zien waarvoor deze tool dient. Zijn er nog meer optie's of ligt dit puur aan de kaart? DM7025 - 2x DVB-C - Seagate CE 160Gb HDD - Casema TVD - Gemini 4.20 - CCcam 2.0.11 - Transcend 512Mb CF - Sharp Aquos LC-32GD1E Link naar reactie Delen op andere sites Meer opties om te delen...
DRG Geplaatst: 23 augustus 2007 Delen Geplaatst: 23 augustus 2007 ik denk niet dat casema kaartjes activeert via de post.. dat gaat via de kabel.. Camd3 is een emu net als bijvoorbeeld cccam, alleen blijkt camd3 wel de "activatiepuls" te kunnen verwerken. Er bestaat een mips versie van camd3 die zou op een dm7025 moeten draaien ,maar er zijn mensen hier die dat tegenspreken. zoek voor meer info maar eens op C3 update hier. Diverse meuk... maar dat boeit niemand toch.. Link naar reactie Delen op andere sites Meer opties om te delen...
Dish TV Geplaatst: 23 augustus 2007 Auteur Delen Geplaatst: 23 augustus 2007 De vorige keer heb ik de kaart ook terug gestuurd naar Casema en hebben ze 'm ook geheractiveerd <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" />. Ze weten inmiddels ook dat sommige Casema klanten een Dreambox hebben <img src="/forums/images/graemlins/wink.gif" alt="" /> Toch vind ik het raar, de AU optie staat aan en het heeft bijna een jaar prima gewerkt. Nog even een vraag over die camd3: moet ik dan nog bellen om te vragen of ze een update puls sturen of moet ik 'm dan op het SBS6 kanaal zetten en een uurtje wachten? Ik zie ook in de config van camd3 dat de 7025 er niet tussen staat: # Wenn Parameter gebraucht wird - '#' (Kommentarzeichen) entfernen und eure Werte reinsetzen!!!!! # # # # Boxtyp(optional): 1-dbox2, 2-dm7000, 3-dm7020, 4-dm500, # 5-dm56xx/Triax, 7-elanvision, 9-server only, 10-relook, 11-dm600 # 12-ufs910 # Default is 9 - server only # BOXTYPE=1 DM7025 - 2x DVB-C - Seagate CE 160Gb HDD - Casema TVD - Gemini 4.20 - CCcam 2.0.11 - Transcend 512Mb CF - Sharp Aquos LC-32GD1E Link naar reactie Delen op andere sites Meer opties om te delen...
DRG Geplaatst: 23 augustus 2007 Delen Geplaatst: 23 augustus 2007 het lijkt erop dat elk jaar de kaart een heractivatie nodig heeft, de AU optie icm mgcamd lijkt alleen de sleutelwissels bij te werken. ik zie inderdaad dat er geen boxtyp is voor de dm7025.. volgens dreamboxworld.com zou hij wel geschikt zijn voor de dm7025. laat het eens staan zo en start camd3 eens ? Diverse meuk... maar dat boeit niemand toch.. Link naar reactie Delen op andere sites Meer opties om te delen...
Dish TV Geplaatst: 23 augustus 2007 Auteur Delen Geplaatst: 23 augustus 2007 Oke, ik zal het vanavond eens proberen met de boxtype op 9... DM7025 - 2x DVB-C - Seagate CE 160Gb HDD - Casema TVD - Gemini 4.20 - CCcam 2.0.11 - Transcend 512Mb CF - Sharp Aquos LC-32GD1E Link naar reactie Delen op andere sites Meer opties om te delen...
Dish TV Geplaatst: 23 augustus 2007 Auteur Delen Geplaatst: 23 augustus 2007 Ik lees op bijna elk forum dat camd3 niet op de 7025 werkt... Maar ja, het gaat maar om 1 activatie puls! <img src="/forums/images/graemlins/grin.gif" alt="" /> DM7025 - 2x DVB-C - Seagate CE 160Gb HDD - Casema TVD - Gemini 4.20 - CCcam 2.0.11 - Transcend 512Mb CF - Sharp Aquos LC-32GD1E Link naar reactie Delen op andere sites Meer opties om te delen...
Dish TV Geplaatst: 23 augustus 2007 Auteur Delen Geplaatst: 23 augustus 2007 Ik heb camd3 op de 7025 gezet en gestart: root@dm7025:/usr/bin> 23.08.2007 17:02:15 camd3: BOXTYPE: server 23.08.2007 17:02:15 camd3: LOG: 2 23.08.2007 17:02:15 camd3: UDP_PORT: 20248 23.08.2007 17:02:15 camd3: HTTP_PORT: 9080 23.08.2007 17:02:15 camd3: DNS_CACHE: 60 sec 23.08.2007 17:02:15 camd3: UserDB(add): USER=benutzer1 PASS=password2 FROM=any SERVICES=all 23.08.2007 17:02:15 camd3: /var/keys/pw_start.services not found 23.08.2007 17:02:15 camd3: UserDB(add): USER=benutzer110 PASS=password10 FROM=any SERVICES=all 23.08.2007 17:02:15 camd3: /var/keys/pw_start.services not found 23.08.2007 17:02:15 camd3: UserDB(update): USER=benutzer110 PASS=password10 FROM=any SERVICES=all 23.08.2007 17:02:15 camd3: error parse line #38 in camd3.keys 23.08.2007 17:02:15 camd3: error parse line #39 in camd3.keys 23.08.2007 17:02:15 camd3: error parse line #40 in camd3.keys 23.08.2007 17:02:15 camd3: error parse line #41 in camd3.keys 23.08.2007 17:02:15 camd3: error parse line #42 in camd3.keys 23.08.2007 17:02:15 camd3: error parse line #43 in camd3.keys 23.08.2007 17:02:15 camd3: error parse line #44 in camd3.keys 23.08.2007 17:02:15 camd3: error parse line #52 in camd3.keys 23.08.2007 17:02:15 camd3: KeyDB: started 23.08.2007 17:02:15 camd3: HTTP: started on port 9080 23.08.2007 17:02:15 camd3: Slot /dev/tts/0: (carddetect=CAR) initialisiere... 23.08.2007 17:02:15 camd3: Slot /dev/tts/0: starte Monitor... 23.08.2007 17:02:15 camd3: slot /dev/tts/0: ready 23.08.2007 17:02:15 camd3: Slot /dev/ttyS0: (carddetect=CTS) initialisiere... 23.08.2007 17:02:15 camd3: Slot /dev/ttyS0: Warnung: IO-Fehler! 23.08.2007 17:02:15 camd3: Slot /dev/sci0: (carddetect=password3) initialisiere... 23.08.2007 17:02:15 camd3: Slot /dev/sci0: Warnung: IO-Fehler! 23.08.2007 17:02:15 camd3: Slot /dev/sci1: (carddetect=password2) initialisiere... 23.08.2007 17:02:15 camd3: Slot /dev/sci1: Warnung: IO-Fehler! 23.08.2007 17:02:15 camd3: Slot localhost: initialisiere... 23.08.2007 17:02:15 camd3: Slot localhost: starte Monitor... 23.08.2007 17:02:15 camd3: Slot localhost:22222 -> Operation now in progress 23.08.2007 17:02:15 camd3: Slot /dev/cardreader1: (carddetect=password2) initialisiere... 23.08.2007 17:02:15 camd3: Slot /dev/cardreader1: Warnung: IO-Fehler! 23.08.2007 17:02:15 camd3: camd v3.893 beta2 - erfolgreich gestartet 23.08.2007 17:02:16 camd3: slot /dev/tts/0: card in 23.08.2007 17:02:16 camd3: Slot localhost:22222 -> Operation now in progress 23.08.2007 17:02:17 camd3: Slot localhost:22222 -> Operation now in progress 23.08.2007 17:02:18 camd3: Slot localhost:22222 -> Operation now in progress 23.08.2007 17:02:19 camd3: Slot localhost:22222 -> Operation now in progress 23.08.2007 17:02:20 camd3: Slot localhost:22222 -> Operation now in progress 23.08.2007 17:02:21 camd3: Slot localhost:22222 -> Operation now in progress 23.08.2007 17:02:22 camd3: Slot localhost:22222 -> Operation now in progress 23.08.2007 17:02:23 camd3: Slot localhost:22222 -> Operation now in progress 23.08.2007 17:02:24 camd3: Slot localhost:22222 -> Operation now in progress 23.08.2007 17:02:25 camd3: Slot localhost:22222 -> Operation now in progress 23.08.2007 17:02:26 camd3: Slot localhost:22222 -> Operation now in progress En nog geen resultaat <img src="/forums/images/graemlins/crazy.gif" alt="" /> DM7025 - 2x DVB-C - Seagate CE 160Gb HDD - Casema TVD - Gemini 4.20 - CCcam 2.0.11 - Transcend 512Mb CF - Sharp Aquos LC-32GD1E Link naar reactie Delen op andere sites Meer opties om te delen...
DRG Geplaatst: 23 augustus 2007 Delen Geplaatst: 23 augustus 2007 hmm.. ik vraag me af of camd3 wel update als je alleen server draait.. misschien is dan opsturen het beste ? Diverse meuk... maar dat boeit niemand toch.. Link naar reactie Delen op andere sites Meer opties om te delen...
Dish TV Geplaatst: 23 augustus 2007 Auteur Delen Geplaatst: 23 augustus 2007 Ik vrees het ook... DM7025 - 2x DVB-C - Seagate CE 160Gb HDD - Casema TVD - Gemini 4.20 - CCcam 2.0.11 - Transcend 512Mb CF - Sharp Aquos LC-32GD1E Link naar reactie Delen op andere sites Meer opties om te delen...
Dish TV Geplaatst: 24 augustus 2007 Auteur Delen Geplaatst: 24 augustus 2007 De kaart is sinds vanochtend onderweg naar Casema. Ik laat nog wel weten of ik weet TV kan kijken als ik de kaart terug heb... DM7025 - 2x DVB-C - Seagate CE 160Gb HDD - Casema TVD - Gemini 4.20 - CCcam 2.0.11 - Transcend 512Mb CF - Sharp Aquos LC-32GD1E Link naar reactie Delen op andere sites Meer opties om te delen...
Dish TV Geplaatst: 31 augustus 2007 Auteur Delen Geplaatst: 31 augustus 2007 Kaart vanmiddag terug gehad van Casema (opnieuw geactiveerd). Maar het werkt nog steeds niet! Ik krijg nog steeds alleen maar BAD ECM binnen. Iemand nog een idee? <img src="/forums/images/graemlins/confused.gif" alt="" /> DM7025 - 2x DVB-C - Seagate CE 160Gb HDD - Casema TVD - Gemini 4.20 - CCcam 2.0.11 - Transcend 512Mb CF - Sharp Aquos LC-32GD1E Link naar reactie Delen op andere sites Meer opties om te delen...
DRG Geplaatst: 31 augustus 2007 Delen Geplaatst: 31 augustus 2007 zie je wel de emm updates langkomen ? als ik 40 minuten bij @home geen emm update doorlaat dan gaat ook hier het beeld op zwart. Diverse meuk... maar dat boeit niemand toch.. Link naar reactie Delen op andere sites Meer opties om te delen...
BushWhacker Geplaatst: 31 augustus 2007 Delen Geplaatst: 31 augustus 2007 Als ik aan het opnemen ben op mijn DVB-S (Seca2) dan krijg ik geen EMMs meer binnen op mijn DVB-C tuner. Lijkt een beetje hetzelfde. gr, BW DM7020HD - 1TB HDD 2.5" - 2x DVB-C/T (Ziggo) - OpenPLi 3.0 (29-01-2013) DM7025 - 2x DVB-C (Ziggo) - OpenPLi 2.1 (04-04-2012) Link naar reactie Delen op andere sites Meer opties om te delen...
