Satori Geplaatst: 25 december 2001 Delen Geplaatst: 25 december 2001 Dynamit heeft versie 4.13 beschikbaar voor BCT1430. (Downloaden bij Dynamit) De BCT1530 kan mbv van extra software gemaakt worden uit BCT1530. Ik had net mijn testopstelling afgebroken, maar ik ga meteen weer testen (De BCT1430). Alle 7 functietoetsen op de afstandbediening zouden nu moeten werken.<p>Dynamit Info:<p>Version 4.13<p>1. This is all in 7 buttons version. I try to do it more comfortable and I make all needed function when you watch TV in 7 button at the top of the remote. PILOT, PROGR, left/right/up/down buttons and OK. With this buttons you can cruise on channels, access to all function in Pilot - two programm guide (more info included), access to channel list - and all old function like change volume.<p>- Button "PROGR" now work like button "E" before Channel List, button "E" now is free.<p>- When you go to Pilote function and use to press "+" button for more info, now I redo this function to "PROGR" button. - Added FREEZE function - you need to press "B" button for that.<p>- Added PIDs info in bunner "+" - so if you want to see PIDs on current channel just press "+" button when you watch channel<p>- also for many requests translated PILOT function to English.<p>- Channel List work now little different - to exit Cannel list press "PROGR" button or "Exit" button. "OK" button it is just to view Channel not view and exit like before.<p>Maybe some dudes with non Polish boxes don't understand what is "PROGR" and "PILOT" button, so for this dudes I attached picture of the Polish remote so you can translate to your box. Or you can go to my pages and see this picture - link at the top of this file.<p>eeprom413.bin and also added eeprom.txt - eeprom setting files only for PIONERO - needed only if you want to load channel list. <p>Happy Viewing and Happy NEW YEAR.<p>Groeten Satori<p>[ 25-12-2001: Bericht gewijzigd door: Satori ]</p> Link naar reactie Delen op andere sites Meer opties om te delen...
Satori Geplaatst: 25 december 2001 Auteur Delen Geplaatst: 25 december 2001 Ik heb net de versie BCT1430 Auto Multi PPV versie 4.13 van Dynamit ge-installeerd en wederom moet ik zeggen dat dit een geweldige verbetering is. De functietoetsen werken perfect en op een natuurljke wijze. De 'E' totes is vervange door de PROG/EPG toets (rechtsboven) en als je een nu een kanaal kiest blijft het menu staan. Dat zapt lekker makkelijk. Verder zijn alle hulpteksten nu in het Engels. Voor de DisEq kun je nog steeds mijn eeprom versie gebruiken.<p>Groeten Satori Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 26 december 2001 Delen Geplaatst: 26 december 2001 Bij kioskue gaat het beeld inderdaad op zwart. Na heen en weer zappen is het beeld weer terug. Verder geen problemen kunnnen ontdekken. Ben ook blij dat de volume regeling weer werkt. Ik moet alleen nog even wennen aan de "zeven knoppen" bediening. Ik zag dat ik ook een totaal andere afstandsbediening heb dan Dynamit! Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 26 december 2001 Delen Geplaatst: 26 december 2001 Is dat dan alleen bij de K's dat het beeld wegvalt of is dat ook bij de T's, c-,...enz <p>Groeten Link naar reactie Delen op andere sites Meer opties om te delen...
Satori Geplaatst: 26 december 2001 Auteur Delen Geplaatst: 26 december 2001 Ik heb gelukkig dezelfde afstandsbediening als Dynamit, dus de 7-keys werken voor mij zeer plezierig.<p>De soft om de 1430 software aan te passen voor de 1530 is bij Dynamit te halen. Extract alle MHW van de 1430 en patch dit in je eigen 1530 soft. Je kunt dit doen met het GLUEDUMP programma<p>Je kunt de soft downloaden bij iespana:<p>http://www.iespana.es/firmwares/pioneer/programas/mh-glue-v0.1.zip<p>Het manual van Dynamit staat op<p>http://www.minsk2000.to/sattv/dynamit/GlueDump003alpha2.zip<p>@freeton Zie het antwoord op je email.<p>Groeten Satori<p>[ 26-12-2001: Bericht gewijzigd door: Satori ]</p> Link naar reactie Delen op andere sites Meer opties om te delen...
Ron Geplaatst: 26 december 2001 Delen Geplaatst: 26 december 2001 heren, mag ik jullie er op wijzen dat wij een nieuw forum hebben dat speciaal bedoeld is voor het knutselen en expirimenteren met MHW firmware? Je vind het onder hardware: MediaHighWay<p>Groetuh,<p>Toxic[Q] Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 26 december 2001 Delen Geplaatst: 26 december 2001 Hallo Satori,<p>Hoe werkt deze 4.13 op gebied van landencodes, werkt deze hetzelfde als de 4.12, als een film begint dat het beeld wegvalt en dat je even terug moet zappen vooraleer dat je beeld hebt?<p>Waar vind je dat ander stukje software voor BCT1530, is dat bijgeleverd of moet je dat appart downloaden bij dynamit?<p>Groeten Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 27 december 2001 Delen Geplaatst: 27 december 2001 @Freeton: Bij mij valt het beeld alleen weg bij K*. overigens alleen als ik de film vanaf het begin kijk. Als ik er na een minuut inval is er niks aan de hand. Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 27 december 2001 Delen Geplaatst: 27 december 2001 Bedankt Satori en secarem <img src="graemlins/thumb.gif" border="0" alt="[Duimpje]" /> <p>Nu kan ik weer verder, eerst komt mijn pioneer 100 aan de beurt en dan mijn 110. <p>Nu zullen we moeten over schakelen naar dat ander forum.<p>Groeten Freeton Link naar reactie Delen op andere sites Meer opties om te delen...
