dream-on Geplaatst: 26 september 2007 Geplaatst: 26 september 2007 ik snap er niks meer van. ik had de irdeto kaart van een vriend lopen in een cardreader op een windows machine. De xml ziet er als volgt uit: <newCSconfig> <readers name="Phoenix"> <device> <name>Phoenix Interface</name> <type>phoenix</type> <mhz>357</mhz> <!-- com2=357 usb=600 --> <node>com2</node> <parity>odd</parity> <reset>normal</reset> <export>Yes</export> <enabled>Yes</enabled> <blocksa>No</blocksa> <blockua>No</blockua> <blockga>No</blockga> <irdeto-camkey>0000000000000000</irdeto-camkey> <irdeto-camkey-data>0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000</irdeto-camkey-data> <crypto-special>No</crypto-special> <PTShandshake>No</PTShandshake> <carddetect>yes</carddetect> <newcamd_port>12000</newcamd_port> <autosid>Yes</autosid> <Seca-PPV>no</Seca-PPV> <pincode>0000</pincode> <priority>round</priority> </device> </readers> <cache> <emm>20</emm> <ecm>-1</ecm> </cache> <debug> <level>normal</level> <!-- valid value for level are: normal, verbose, spam - How extensive debug should be. --> <type>init</type> <!-- valid value for type are: Init, general, ecm, emm, net, all - Section of debug that should be displayed. --> <output>console</output> <!-- valid value for output are: Console, udp, tcp, file, all - Where to show debug. --> <console_options>normal,net</console_options> <!-- console_options are so you can set own loglevel/type for console-logger: Should hold level and type-tags like above. --> <file_options>normal,all</file_options> <logfile>D:\server NEWCS\log.txt</logfile> <!-- valid value for logfile are: Path and filename - Where to write debug logs if file or all is chosed in output. --> </debug> <newcamdserver> <enabled>Yes</enabled> <name>newcs</name> <deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey> <user> Nu heb ik me zelf een kaartje gekocht welk dus ook werkt in de orginele ontvanger maar deze werkt dus niet in de cardreader...... Iemand een idee waar het probleem in zit??? Vu duo2 met pli
Cypro Geplaatst: 26 september 2007 Geplaatst: 26 september 2007 misschien dat dit helpt; <irdeto-camkey>1122334455667788</irdeto-camkey> <irdeto-camkey-data>3C8633AAC0D367533DEC7BB2EEEDEB8CA3ADA52E58B99BB34672783277A1DAAC3B6106AD0909774E031B2A6E30195B437683AD0FC599B87D08CEA47BE1B6C76A</irdeto-camkey-data> en draait een irdeto2 kaart niet op 600?
dream-on Geplaatst: 26 september 2007 Auteur Geplaatst: 26 september 2007 ik heb de irdeto camkey aangepast: de oude kaart blijft wel werken, de nieuwe niet.......... En mijn kaartlezer werkt alleen als ik hem op 357 zet........... Vu duo2 met pli
DRG Geplaatst: 26 september 2007 Geplaatst: 26 september 2007 de laatste kaarten hadden weer een andere camkey nodig Diverse meuk... maar dat boeit niemand toch..
dream-on Geplaatst: 26 september 2007 Auteur Geplaatst: 26 september 2007 De kaart die werkt begint met 4012xxx De kaart die nie werkt begitn met 4025xxx Wat moet de camkey dan zijn? Vu duo2 met pli
DRG Geplaatst: 27 september 2007 Geplaatst: 27 september 2007 ik zag een camkey voorbij komen voor de 4022 kaarten, ik zou die even proberen. ff zoeken hier <img src="/forums/images/graemlins/wink.gif" alt="" /> gevonden : <img src="/forums/images/graemlins/grin.gif" alt="" /> CAMKEY: C899D027ED1EED1A CAMDATA: 3C2BCE8BA353C3F870CB7BE0D4E439A27B8D3862E08CF3335B9ABB49318DCA715125493476929EA5 A93A6E2A548DF29BF14B6B2A90141DB519B07EB5D95AE5A5 Diverse meuk... maar dat boeit niemand toch..
dream-on Geplaatst: 27 september 2007 Auteur Geplaatst: 27 september 2007 thanks, ga hem morgen ochtend proberen. zou het trouwens helpen als ik newcs 1.3 neem? grts. Vu duo2 met pli
DRG Geplaatst: 28 september 2007 Geplaatst: 28 september 2007 de eerdere versie's van newcs ondersteunen ook de camkey, is niet verplicht maar ik update altijd naar de laatste versie. Diverse meuk... maar dat boeit niemand toch..
DRG Geplaatst: 30 september 2007 Geplaatst: 30 september 2007 Werkt je kaart nu ? is voor de rest ook handig om te weten <img src="/forums/images/graemlins/wink.gif" alt="" /> Diverse meuk... maar dat boeit niemand toch..
dream-on Geplaatst: 30 september 2007 Auteur Geplaatst: 30 september 2007 oeps sorry, heb nog geen tijd en zin gehad wegens een griepje. Ga ik morgen ochtend doen! Je (jullie) horen nog van me! Vu duo2 met pli
dream-on Geplaatst: 1 oktober 2007 Auteur Geplaatst: 1 oktober 2007 <img src="/forums/images/graemlins/frown.gif" alt="" /> hij werkt niet... Terwijl de oude kaart met deze instellingen ook gewoon werkt..... De instellingen zijn nu: <readers name="Phoenix"> <device> <name>Phoenix Interface</name> <type>phoenix</type> <mhz>357</mhz> <!-- com2=357 usb=600 --> <node>COM2</node> <parity>odd</parity> <reset>normal</reset> <export>Yes</export> <enabled>Yes</enabled> <blocksa>No</blocksa> <blockua>No</blockua> <blockga>No</blockga> <irdeto-camkey>C899D027ED1EED1A</irdeto-camkey> <irdeto-camkey-data>3C2BCE8BA353C3F870CB7BE0D4E439A27B8D3862E08CF3335B9ABB49318DCA715125493476929EA5A93A6E2A548DF29BF14B6B2A90141DB519B07EB5D95AE5A5</irdeto-camkey-data> <crypto-special>No</crypto-special> <PTShandshake>No</PTShandshake> <carddetect>yes</carddetect> <newcamd_port>16000</newcamd_port> <autosid>Yes</autosid> <Seca-PPV>no</Seca-PPV> <pincode>0000</pincode> <priority>round</priority> </device> </readers> <cache> <emm>20</emm> <ecm>-1</ecm> </cache> Vu duo2 met pli
appiemulder Geplaatst: 1 oktober 2007 Geplaatst: 1 oktober 2007 <mhz> op 600 ipv 357 dit is de default van Irdeto 2, het werkt bij mij ook wel onder 357 maar misschien zijn de nieuwe kaartjes iets gevoeliger. Ook je cardreader natuurlijk op 6 Mhz zetten. Krijg je bij het starten wel alle keys te zien, en wat is de evt foutmelding.
dream-on Geplaatst: 1 oktober 2007 Auteur Geplaatst: 1 oktober 2007 het vreemde is dat de oude kaart mijn mijn cardpro reader niet werkt op 600mhz. ik zal morgen eens een mastera proberen met 600mhz op beide kaarten. Vu duo2 met pli
dream-on Geplaatst: 2 oktober 2007 Auteur Geplaatst: 2 oktober 2007 helaas. het werkt niet. ik heb de de nieuwe kaart in mijn dbox geplaatst en de config aangepast. en daar werkt ie. Heb ik de kaart getest met een mastera en op 600mhz. Geen beeld!!!!! ik snap er niks van.. Zie in de console ook nergens iets van foutmeldingen.... Vu duo2 met pli
DRG Geplaatst: 2 oktober 2007 Geplaatst: 2 oktober 2007 post de output eens die newcs geeft als je hem start ( wel ff serienummer van je kaart weghalen ) Diverse meuk... maar dat boeit niemand toch..
