Frans B Geplaatst: 10 oktober 2007 Auteur Geplaatst: 10 oktober 2007 Hier een antwoord van Astra : Thank you for contacting ASTRA. The channels on the frequencies 12515 and 12574 are broadcasted via the ASTRA 1G satellite. Crete is not located within the the footprint of this satellite (which can be consulted on http://www.ses-astra.com/corpSite/site_en/04_ASTRAFleet/03_satellite_list/astra1g/index.php ) and ASTRA can not guarantee the reception of channels outside of the satellite footprints. We do not have any reports of outages on these frequencies. The footprints of ASTRA 1KR and ASTRA 1L cover Crete. To see what channels are available via these satellites, please use the channel finder on our website: http://www.ses-astra.com/backoffice/findAChannel_en/index.php. By downloading the complete TV and radio channel lists, you will find out which channels are available via these satellites. Kind regards, The ASTRA Team System Administrator (niet van deze site)
PetrosCrete Geplaatst: 10 oktober 2007 Geplaatst: 10 oktober 2007 @,Frans Oud nieuws in de vorm van een mailtje <img src="/forums/images/graemlins/grin.gif" alt="" /> Gewoon afwachten en dagen tellen, tevens hopen dat ze naar de 1KR of 1L overstappen en dat zie ik nog niet gebeuren! Grtz, Ben
Gast Geplaatst: 10 oktober 2007 Geplaatst: 10 oktober 2007 Citaat: Hier een antwoord van Astra : Thank you for contacting ASTRA. The channels on the frequencies 12515 and 12574 are broadcasted via the ASTRA 1G satellite. Crete is not located within the the footprint of this satellite (which can be consulted onhttp://www.ses-astra.com/corpSite/site_en/04_ASTRAFleet/03_satellite_list/astra1g/index.php ) and ASTRA can not guarantee the reception of channels outside of the satellite footprints. We do not have any reports of outages on these frequencies. The footprints of ASTRA 1KR and ASTRA 1L cover Crete. To see what channels are available via these satellites, please use the channel finder on our website:http://www.ses-astra.com/backoffice/findAChannel_en/index.php. By downloading the complete TV and radio channel lists, you will find out which channels are available via these satellites. Kind regards, The ASTRA Team Een korte vertaling: De frequenties 12515 en 12574 worden uitgezonden via de satelliet Astra 1G. Kreta bevindt zich niet binnen de footprint en SES-Astra kan geen ontvangst garanderen. We weten niet hoe de ontvangst buiten de footprint is. Bij de satellieten Astra 1KR en Astra 1L ligt Kreta wel binnen de footprint. Op onze website kunt u zien welke zenders via die satellieten te ontvangen zijn. Met vriendelijke groeten, Het Astra team
Gast Geplaatst: 11 oktober 2007 Geplaatst: 11 oktober 2007 Citaat: Indien inderdaad alle Nederlandse Transponders 1,6 Db achteruit gegaan zijn vraag ik mij nogmaals af waarom de RTL's als vanouds binnen komen en juist de Tp 105 (1G) zo enorm is terug gelopen? Wil alleen maar meer kennis opdoen, en daar heb ik met alle respect geen duidelijk antwoord op gekregen. @PetrosCrete, Volgens mij heb ik daar toch eerder in dit topic een (duidelijk) antwoord op gegeven: "@PetrosCrete, Het feit dat dit tijdstip samenvalt met het sterk(er) uitzenden van enkele andere (naburige) transponders doet minimaal vermoeden dat dit er iets mee te maken heeft. Tegelijkertijd heb ik hier in Nederland kunnen constateren dat Nederlandse transponders met ongeveer 1,6 dB in sterkte achteruit zijn gegaan in het afgelopen jaar. Dan is niet onaannemelijk dat in (de buurt van) Kreta de signaalsterkte eveneens achteruit is gegaan. Bovenstaande (en eventueel nog andere) factoren hebben waarschijnlijk tot de verslechterde ontvangstsituatie geleid." Kijk eens naar de transponderlijst van Astra op 19,2 Oost. Daar zit op 12515 H de transponder die sinds kort moeilijk is te ontvangen op Kreta. Er zijn 3 transponders die uitzenden op een frequentie die in de buurt ligt van 12515 H: 1) 12480 V die (iets?) sterker uitzendt dan 12515 H 2) 12545 H die veel sterker uitzendt (via Astra 1L) dan 12515 H 3) 12522 V is een DVB-S2 transponder met bijna dezelfde frequentie als 12515 H Zo'n beetje vanaf het moment dat 12545 H en 12522 V (volledig) operationeel zijn is de transponder 12515 H op Kreta in de problemen gekomen. Ik vraag me af of op Kreta voor transponder 12574 H (o.a. BVN) ook sinds kort de ontvangst een stuk moeilijker is geworden?! De situatie is immers vergelijkbaar met transponder 12515H. Bij transponder 12574 H zijn er eveneens 3 transponders die uitzenden op een frequentie die in de buurt ligt. Dat zijn 12552 V, 12545 H en 12581 V. Zolang er geen aantoonbare andere duidelijke veranderingen bij de overige frequenties van Astra 19,2 Oost hebben plaatsgevonden en/of zijn bekend gemaakt denk ik dat de kans groot is dat de verslechterde ontvangst op Kreta te maken heeft met hetgeen ik hierboven beschreven heb. In ieder geval lijkt degene die de satellieten van Astra 19,2 Oost beheert, te weten SES-Astra, weinig moeite te doen om meer info te verschaffen of te verkrijgen (indien zij de oorzaak van de problemen niet zou kennen). Met vriendelijke groeten <img src="/forums/images/graemlins/wink.gif" alt="" /> sattaz
Frans B Geplaatst: 11 oktober 2007 Auteur Geplaatst: 11 oktober 2007 de BVN op 12574 is iets beter te ontvangen als ik de transponder frequentie op 12578 instel. Dus er iets naast. Hetzelfde wat we vroeger moesten den als er 2 radiozenders zegen elkaar zaten.... Morgen ga ik bj iemand een twin invacom plaatsen, waar nu een gewone twin lnb zit. Ben benieuwd hoe het afloopt. System Administrator (niet van deze site)
Gast Geplaatst: 11 oktober 2007 Geplaatst: 11 oktober 2007 Citaat: Morgen ga ik bj iemand een twin invacom plaatsen, waar nu een gewone twin lnb zit. Ben benieuwd hoe het afloopt. @Frans B, Gaat het hier om een offset schotel? Zo ja, dan zou je eens een MTI Highline lnb kunnen proberen, vooropgesteld dat je dat al niet eens eerder geprobeerd hebt. De MTI Highline lnb geeft bij mij (en vele anderen) duidelijk betere resultaten dan de Invacom lnb. Zie bijvoorbeeld Test van MTI AP82-XT2N twin lnb Met vriendelijke groeten <img src="/forums/images/graemlins/wink.gif" alt="" /> sattaz
PetrosCrete Geplaatst: 12 oktober 2007 Geplaatst: 12 oktober 2007 @ Sattaz, Het kwartje (neen niet dat van Kok) is gevallen <img src="/forums/images/graemlins/blush.gif" alt="" /> Thanks <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> Ben
Frans B Geplaatst: 13 oktober 2007 Auteur Geplaatst: 13 oktober 2007 Ik heb dus die invacom erop geplaatst. Het signaal was duidelijk beter. (vooropgesteld dat de schotel goed staat ). Nu is er weer beeld op alle nederlandse transponders. MTI lnb heb ik niet liggen, maar wel besteld. Ik heb echter nog een andere test gedaan : een quattro lnb en daarvan de H uitgang gebruikt. Dit gaf een verbluffend beter signaal ! Volgens mij komen de problemen dus echt door die andere, heel sterke, verticale transponders ! System Administrator (niet van deze site)
Gast Geplaatst: 29 oktober 2007 Geplaatst: 29 oktober 2007 @Frans B, Ik neem aan dat je inmiddels de MTI lnb binnen hebt. Kun je wat concrete resultaten melden? Met name de vergelijking tussen Invacom, MTI en quattro lnb (waarbij slechts de horizontale uitgang gebruikt wordt) lijkt mij best wel interessant. Met vriendelijke groeten <img src="/forums/images/graemlins/wink.gif" alt="" /> sattaz
Frans B Geplaatst: 29 oktober 2007 Auteur Geplaatst: 29 oktober 2007 MTI lnb heb ik nog steeds niet binnen. Wel een test gedaan met een normale MTI : geen ontvangst. Met een quattro LNB heb ik iets meer qualiteit dan met de invacom, maar dan mis je weer een een hoop transponders. Ik heb inmiddels zo'n 10 schotels aangepast met een invacom lnb, en tevens de focus afstand iets aangepast. Dit geeft een naar omstandigheden, goed resultaat. Alle andere lnb's geven te weinig signaal om een storingsvrij beeld te hebben. Heb ook nog een simple universal lnb opengemaakt en de V antenne eruitgesloopt, maar dat werkt dus niet. System Administrator (niet van deze site)
Gast Geplaatst: 29 oktober 2007 Geplaatst: 29 oktober 2007 Misschien bruikbaar. Omdat ik de Invacom TWH 031 vervangen heb door een MTI High Line twin (die maar niet lekker wil werken als er twee ontvangers tegelijk aktief zijn) heb ik de Invacom , een ALPS twin BSNE 601B en een Hirschmann cs300s eens in een 55cm schotel gedaan en uitgericht op Sirius. Licht bewolkt om 17.00. Op zwakke transponders was ALPS matig, de Invacom beter maar de Hirschmann deed het het best. C/N waarden met een VHSat viking 2003 op Discovery spain (een sterke transponder) 8.1; 9.6; 10.2. Op Taraf ALPS geen lock, Invacom lock en C/N 5.1 en de Hirschmann lock 6.1. De cs300s zit er nu permanent in. Bij regen geen Taraf transponder, rest wel.
