NewCS 1.31 en UDPLogger: 1.72 client for mgcamd, NewCS werkt niet meer
ik kan niet meer inloggen mijn server met dit programma UDPLogger: 1.72 client for evocamd, mgcamd, NewCS
dit is test xml file
<?xml version="1.0"?>
For setup-issues, look in readme.txt!
If there are other troubles, try different forums or irc channels around <img src="/forums/images/graemlins/blush.gif" alt="" />)
<newCSconfig>
<readers name="Card Readers">
<device>
<name>phoenix</name>
<type>Phoenix</type>
<node>/dev/ttyS0</node>
<mhz>600</mhz> <!-- or 357 -->
<parity>even</parity>
<export>yes</export>
<enabled>yes</enabled>
<blocksa>No</blocksa>
<blockua>No</blockua>
<blockga>No</blockga>
<boxkey>0000000000</boxkey>
<PTShandshake>no</PTShandshake>
<crypto-special>no</crypto-special>
<carddetect>no</carddetect>
<newcamd_port>10120</newcamd_port>
<priority>round</priority> <!-- hard is default -->
<sid>
<allow>
<!-- valid value for id are:
4 numbers, if the service id is 3 numbers, add a 0 infront of it. -->
<id></id>
</allow>
<deny>
<id></id>
</deny>
</sid>
</device>
</readers>
<radegastserver>
<!-- valid value for enable are:
0,1 - Enable or Disable radegast server. -->
<enabled>no</enabled>
<!-- valid value for port are:
0,65535 - Which port to listen for incomming connections. -->
<port>10001</port>
<!-- valid value for allow are:
ALL - Not active yet. -->
<allow>
<hostname>127.0.0.1</hostname>
</allow>
</radegastserver>
<cache>
<emm>10</emm>
<ecm>10</ecm>
</cache>
<debug>
<level>normal</level>
<type>init</type>
<output>all</output>
<logfile></logfile>
<console_options></console_options>
<file_options></file_options>
<udp_host>192.168.1.10</udp_host>
<udp_port>1000</udp_port>
<udp_options></udp_options>
<tcp_port>3001</tcp_port>
<tcp_options></tcp_options>
</debug>
<newcamdserver>
<name>tvserver</name>
<deskey>10 16 02 14 05 06 07 18 09 10 11 12 13 14</deskey>
<userfile></userfile>
<user>
<name>local</name>
<password>local</password>
<au>on</au>
</user>
<user>
<name>jos</name>
<password>jos</password>
<au>on</au>
</user>
<user>
<name>home</name>
<password>home</password>
<au>on</au>
</user>
</newcamdserver>
</newCSconfig>
wat gaat er fout
ÿûÿý"
A Butter Team Creation
Password :
NewCS-1: Port 3001
------ Connected ------
* [color:"red"] [/color]
