rsjmeijer Geplaatst: 24 december 2007 Delen Geplaatst: 24 december 2007 Ik ontving onderstaande email van PACE mbt een update voor de 810. Hello, A software update (v1.0.35) for the Pace DS810XE High-Definition set-top box is available on the following satellites: HotBird @ 13.0°E: 12476 H 27500 / PID 1999 Astra 1 @ 19.2°E: 12148 H 27500 / PID 2402 EuroBird 1 @ 28.5°E / Astra 2 @ 28.2°E: 11428 H 27500 / PID 2402 To download the new software please enter the 'Setup menu' and select 'Software update'. Next select the appropriate satellite and ensure that the transponder parameters match those given above. Then press <OK> to start the update. The download will take several minutes, during which time the box should not be turned off. After the download is complete we recommend resetting the box using the 'Factory Reset' selection in the 'Setup Menu'. This will erase all the stored user settings. Please note that this step can be omitted, for example if you want to keep your own channel lists. The main areas of improvement compared with previous software version are as follows: Correction of 4:3 video display when viewing SD channels on HDMI output in some instances Greek language added Improved stability of the application Improved channel scanning of some satellites Improved handling of certain CAM modules Warm regards, Pace Micro Technology plc Heb hem nog niet geprobeerd, doe ik later deze week. een sat groet van Hobby Robby Link naar reactie Delen op andere sites Meer opties om te delen...
