Dish TV Geplaatst: 28 januari 2008 Geplaatst: 28 januari 2008 Ik heb mijn Dreambox 7025 geupgrade naar Gemini 3.20. Er stond hiervoor Gemini 3.00 op (met beeld en geluid ). Na de update van Gemini krijg ik geen beeld meer op de TV. IK maak gebruik van NewCS 1.50 en mgcamd 1.27. De uitout van NewCS: This is NewCS 1.50 - the New CardServer by Butter-team.. Compiled on Oct 26 2007 at 16:31:52 Reading Config file from /var/tuxbox/config/newcs.xml No certificate specified in config, trying to look in current dir.. No certificate found, dependencies will be disabled.. TCP-log password is enabled, set to: NewCSpwd TCP-log set to simple mode level: normal type: init output: console,tcp logger config: level 1 type 3 output 5 Console log options: level 1 type 3 TCP log options: level 1 type 3 [ 15:07:46 ] [ Box detect ] Box type 6 [ 15:07:46 ] [ Config ] Enabling SSL engine [ 15:07:46 ] [ Config ] SSL engine disabled due to Certificate errors [ 15:07:46 ] [ Config ] /dev/sci0 ECM priority: round [ 15:07:46 ] [ Config ] /dev/sci1 ECM priority: round [ 15:07:46 ] [ httpd ] httpd-user: newcs, password: newcs, accesslevel: admin [ 15:07:46 ] [ EMM Cache ] Initialising Cache with 10 entries [ 15:07:46 ] [ ECM Cache ] Initialising Cache with 10 entries [ NewCS ] Process ID is: 1199 [ 15:07:46 ] [ Loader ] Starting Telnet on port 1001 [ 15:07:46 ] [ Loader ] Started HTTP-server on port: 8080 [ 15:07:46 ] [ Loader ] Reader type 5 on node /dev/sci0 [ 15:07:46 ] [ Sci ] Opening device /dev/sci0 [ 15:07:48 ] [ ATR ] T=14 1etu=625.00us Guardtime:17etu WWT:9600etu [ 15:07:48 ] [ ATR ] Historical bytes: I R D E T O A C S V 5 . 0 [ 15:07:48 ] [ Loader ] Init Irdeto card [ 15:07:49 ] [ Keyman ] Adding key 2EC31D type 0 on Provider 000000 for caid 0602 ID=0 [ 15:07:49 ] [ Keyman ] Adding key 4E8D7 type 1 on Provider 000000 for caid 0602 ID=0 [ 15:07:49 ] [ Keyman ] Adding key 600 type 1 on Provider 000001 for caid 0602 ID=1 [ 15:07:49 ] [ Keyman ] Adding key FFFFFF type 1 on Provider 000002 for caid 0602 ID=2 [ 15:07:49 ] [ Keyman ] Adding key FFFFFF type 1 on Provider 000003 for caid 0602 ID=3 [ 15:07:50 ] [ Loader ] Card 0602 on port /dev/sci0 ready [ 15:07:50 ] [ Loader ] Starting Newcamd Server on port 34000 [ 15:07:50 ] [ Loader ] Reader type 5 on node /dev/sci1 [ 15:07:50 ] [ Sci ] Opening device /dev/sci1 [ 15:07:50 ] [ Sci ] No card present in reader [ 15:07:50 ] [ Loader ] Clearing all autosids on reader ... [ 15:07:50 ] [ Loader ] Reset failed ... [ 15:07:50 ] [ Loader ] Starting Newcamd Server on port 34001 [ 15:07:50 ] [ NewCS ] Ready to GO! En die van mgcamd: tuxbox mgcamd v1.27b by mixvt (compiled Dec 31 2007 16:50:38) [mg] Net:1:1:0:10s Show ecm:1, emm:1 Up:1 Au:1 Dir:0 Osd:no:80:0 Cache:7 Log:2:192.168.1.10:28007 Reread:0 [mg] Ecm cache time: 15 Box type: dm7025 root@dm7025:/usr/bin> Conax.Key error 2: No such file or directory SoftCam.Key error 2: No such file or directory AutoRoll.Key error 2: No such file or directory Conax.Key error 2: No such file or directory [config] newcamd route = dummy:192.168.1.10:34000 server newcs newcamd keep alive: 0, incoming port: 12000 [mgcam] emm thread started [mgcamd] tps update started. [newcamd] Connecting to 192.168.1.10:34000... [ 15:08:28 ] [ Newcamd:34000 ] User dummy logged in, client: Mgcamd [newcamd] Login to 192.168.1.10:34000 as dummy accepted (0ms) [newcamd] Card data from 192.168.1.10:34000 (0ms): EMM enabled: UA yes SA yes GA yes, Card serial: XXXXXXXX Userid 1 caid 602 providers 4 Idents: 000000 000001 000002 000003 ids: 4E8D7 1000600 2FFFFFF 3FFFFFF root@dm7025:/usr/bin> got 56 cmd 9F [mg0] namespace FFFF0000 t-id 8 on-id 1F4 [mg0] descramble on 5, source 2 [mg0] service 1F45 index 0 pmt pid B4 (1) ECM: CaID: 0x0602 -> CaPID: 0x0036 ProvID: 000000 ECM: CaID: 0x0604 -> CaPID: 0x0FA3 ProvID: 000000 [mg0] No irdeto key(s) found for id 0 keynr 00 [mg0] -> ECM to newcamd 192.168.1.10:34000 [mg0] newcamd route 192.168.1.10:34000 cant decode (201ms) [mg0] network can't decode [mg0] pid 0x0036 failed to decode. [mg0] No irdeto key(s) found for id 0 keynr 00 [mg0] -> ECM to newcamd 192.168.1.10:34000 [ 15:08:58 ] [ Newcamd ] ECM -> dummy (NOT OK) [mg0] <- CW from newcamd 192.168.1.10:34000 (297ms) [mg0] 297 msec -- Mon Jan 28 15:08:58 2008 ===== Irdeto ECM on CaID 0x0602, pid 0x0036 ====== prov: 000000 cw0:0 80 A8 DE 06 7E 97 D3 E8 cw1:0 56 DD 92 C5 BB E0 53 EE [mg0] irdeto using chid 00D3 version 41 [mgcamd] emm started Starting emm for newcamd shared card *EMM: CaID: 0x0602 -> CaPID: 0x0030 ProvID: 000000 EMM: CaID: 0x0604 -> CaPID: 0x0031 ProvID: 000000 [ 15:08:59 ] [ Newcamd ] ECM -> dummy (OK) [newcamd] EMM-S -> 192.168.1.10:34000 [newcamd] EMM answer from 192.168.1.10:34000, 3:82 [newcamd] EMM-S -> 192.168.1.10:34000 [newcamd] EMM answer from 192.168.1.10:34000, 3:82 [mg0] -> ECM to newcamd 192.168.1.10:34000 [newcamd] EMM-S -> 192.168.1.10:34000 [mg0] <- CW from newcamd 192.168.1.10:34000 (298ms) [mg0] 298 msec -- Mon Jan 28 15:09:07 2008 ===== Irdeto ECM on CaID 0x0602, pid 0x0036 ====== prov: 000000 cw0:0 0F FB C6 D0 03 F4 AD A4 cw1:0 56 DD 92 C5 BB E0 53 EE [mg0] irdeto using chid 00D3 version 41 [newcamd] EMM answer from 192.168.1.10:34000, 3:82 [ 15:09:07 ] [ Newcamd ] ECM -> dummy (OK) [newcamd] EMM-U -> 192.168.1.10:34000 [newcamd] EMM answer from 192.168.1.10:34000, 3:82 [newcamd] EMM-S -> 192.168.1.10:34000 [newcamd] EMM answer from 192.168.1.10:34000, 3:82 [newcamd] EMM-S -> 192.168.1.10:34000 [newcamd] EMM answer from 192.168.1.10:34000, 3:82 [mg0] stoping camd.. [mgcamd] emm stopped got 56 cmd 9F [mg0] namespace FFFF0000 t-id 8 on-id 1F4 [mg0] descramble on 5, source 2 [mg0] service 1F43 index 0 pmt pid F0 (2) ECM: CaID: 0x0602 -> CaPID: 0x0033 ProvID: 000000 ECM: CaID: 0x0604 -> CaPID: 0x0FA1 ProvID: 000000 [mg0] No irdeto key(s) found for id 0 keynr 00 [mg0] -> ECM to newcamd 192.168.1.10:34000 [mg0] newcamd route 192.168.1.10:34000 cant decode (199ms) [mg0] network can't decode [mg0] pid 0x0033 failed to decode. [mg0] No irdeto key(s) found for id 0 keynr 00 [mg0] -> ECM to newcamd 192.168.1.10:34000 [ 15:09:24 ] [ Newcamd ] ECM -> dummy (NOT OK) [mg0] <- CW from newcamd 192.168.1.10:34000 (297ms) [mg0] 297 msec -- Mon Jan 28 15:09:24 2008 ===== Irdeto ECM on CaID 0x0602, pid 0x0033 ====== prov: 000000 cw0:0 3C BE EC E6 46 A9 BE AD cw1:0 53 6D 13 D3 E3 D7 AD 67 [mg0] irdeto using chid 00D3 version 41 [mgcamd] emm started [ 15:09:24 ] [ Newcamd ] ECM -> dummy (OK) Starting emm for newcamd shared card *EMM: CaID: 0x0602 -> CaPID: 0x0030 ProvID: 000000 EMM: CaID: 0x0604 -> CaPID: 0x0031 ProvID: 000000 [newcamd] EMM-S -> 192.168.1.10:34000 [newcamd] EMM cached [mg0] -> ECM to newcamd 192.168.1.10:34000 [mg0] <- CW from newcamd 192.168.1.10:34000 (298ms) [mg0] 298 msec -- Mon Jan 28 15:09:28 2008 ===== Irdeto ECM on CaID 0x0602, pid 0x0033 ====== prov: 000000 cw0:0 3C BE EC E6 46 A9 BE AD cw1:0 ED 16 0C 0F 5B D8 BB EE [mg0] irdeto using chid 00D3 version 41 [ 15:09:28 ] [ Newcamd ] ECM -> dummy (OK) [mg0] stoping camd.. [mgcamd] emm stopped got 8 cmd 9F Ik krijg ook EMM en ECM's binnen: Newcamd Port: 34000 - CAID: 0602 - Reader: 0 (Casema) ID Username Status Ok ECM Bd ECM EMM Hostname Client Spdr AU SO 02 dummy 00d 00:02:15 5 3 6 192.168.1.10 Mgcamd X V X Ik heb de kaart al in een andere decoder (samsung) gedaan en daar heb ik gewoon beeld. Mis ik nog iets in de newcs.xml? Want op Gemini 3.00 had ik newcs 1.31 en nu bij 3.20 newcs 1.50. Ik heb de config's wel aangepast want die verschilde. DM7025 - 2x DVB-C - Seagate CE 160Gb HDD - Casema TVD - Gemini 4.20 - CCcam 2.0.11 - Transcend 512Mb CF - Sharp Aquos LC-32GD1E
Ron Geplaatst: 29 januari 2008 Geplaatst: 29 januari 2008 Ik begrijp niet waarom je deze combinatie van newcs en mgcamd nog gebruikt. CCcam is inmiddels veel beter en eenvoudiger te configureren. Met een beetje geluk draait CCcam zelfs zonder enige configuratie. Ron
Dish TV Geplaatst: 29 januari 2008 Auteur Geplaatst: 29 januari 2008 Origineel bericht van: Toxic[Q ]Ik begrijp niet waarom je deze combinatie van newcs en mgcamd nog gebruikt. CCcam is inmiddels veel beter en eenvoudiger te configureren. Met een beetje geluk draait CCcam zelfs zonder enige configuratie. Ron Bedoel je dan alleen CCcam? Of i.c.m. mgcamd of newcs? Onder Blue Panel kan ik (bij installatie van CCcam en newcs) als camd kiezen voor: CCCam/newcs, alleen CCcam of common interface. Moet ik nog veel instellen in de cccam.cfg? Ik heb (helaas) geen ervaring met CCcam... Als ik CCcam start via putty krijg ik ook geen output terug, maar dat kan misschien omdat ik de cccam.cfg nog niet heb ingesteld! DM7025 - 2x DVB-C - Seagate CE 160Gb HDD - Casema TVD - Gemini 4.20 - CCcam 2.0.11 - Transcend 512Mb CF - Sharp Aquos LC-32GD1E
Buzzz Geplaatst: 29 januari 2008 Geplaatst: 29 januari 2008 Probeer "cccam -dv", dan krijg je wél de log te zien. Hier zie je hoe ik CCcam i.c.m. NewCS gebruik in mijn DBOX-II. Voor een dreambox werkt het wellicht met alleen CCcam, dat zou je ff uit moeten zoeken. Ik vind CCcam iig een stuk beter werken dan mgcamd in m'n DBOX-II! Nokia D-BOX II AVIA500 - Multicam 3.0 - Sportster Pro 1.10 RC010 - NewCS 1.50 - CCcam 2.04 Nokia D-BOX II AVIA500 - Sportster Pro 1.10 RC010 - CCcam 2.04
Dish TV Geplaatst: 29 januari 2008 Auteur Geplaatst: 29 januari 2008 Oke, dank je. Met CCCam lukt het nog niet: 14:08:35.015 CCcam: ====================================================================== 14:08:35.019 CCcam: starting CCcam 2.0.5 compiled on Jan 15 2008@20:33:27 14:08:35.020 CCcam: ====================================================================== 14:08:35.021 CCcam: online using nodeId 474fecfdac87dd03 14:08:35.037 CCcam: dvb api3 detected 14:08:35.039 CCcam: DM7025 detected 14:08:35.039 CCcam: create 8 cam device(s) 14:08:35.241 CCcam: irdeto card found 14:08:37.092 CCcam: card added to broker with caid 602 14:08:37.464 CCcam: card detect fail 14:08:37.466 CCcam: readKeyfile: cannot open /var/keys/SoftCam.Key or not found 14:08:37.467 CCcam: readKeyfile: cannot open /var/keys/AutoRoll.Key or not found 14:08:37.468 CCcam: static cw not found or bad 14:08:37.470 CCcam: parsed 0 entries from /var/etc/CCcam.prio 14:08:37.541 CCcam: added 510 provider names from /var/etc/CCcam.providers 14:08:37.543 CCcam: added 4 channel names from /var/etc/CCcam.channelinfo 14:08:37.544 CCcam: server started on port 12000 14:08:39.555 CCcam: found irdeto caid: 0x602 ecmpid: 0x36 id: 0x0 14:08:39.556 CCcam: found irdeto caid: 0x604 ecmpid: 0xfa3 id: 0x0 14:08:39.556 CCcam: cam[0] set PMT for sid=1f45 14:08:39.557 CCcam: start EMM 14:08:39.763 CCcam: chid 000B 14:08:39.763 CCcam: chid 0051 14:08:39.763 CCcam: chid 270F 14:08:39.764 CCcam: cam[0] ecm even nok caid:0x604 id:0x0 pid:0xfa3 Nova/LTV/Showtime/SCT/Spice Platinum (I2) 14:08:39.813 CCcam: EMM demux 1 set 14:08:39.814 CCcam: EMM: start filter on irdeto emmpid: 0x30 caid: 0x602 id: 0x0 14:08:39.815 CCcam: EMM: start filter on irdeto emmpid: 0x31 caid: 0x604 id: 0x0 14:08:40.087 CCcam: chid 0008 14:08:40.087 CCcam: chid 00D3 14:08:40.087 CCcam: chid 270F 14:08:40.088 CCcam: local ecm -> card /dev/sci0 0x602(0x000) sid 0x1f45 14:08:40.088 CCcam: local ecm <- card /dev/sci0 error 14:08:40.088 CCcam: local ecm -> card /dev/sci0 0x602(0x000) sid 0x1f45 14:08:40.357 CCcam: local ecm <- card /dev/sci0 ok 14:08:40.358 CCcam: cam[0] ecm even ok caid:0x602 id:0x0 pid:0x36 Pink Plus, BulSatCom,C+ NL (I2) 14:08:42.565 CCcam: local emm -> card /dev/sci0 0x602(0x000) 14:08:42.782 CCcam: local emm <- card /dev/sci0 ok 14:08:43.086 CCcam: chid 00D3 14:08:43.087 CCcam: local ecm -> card /dev/sci0 0x602(0x000) sid 0x1f45 14:08:43.356 CCcam: local ecm <- card /dev/sci0 ok 14:08:43.358 CCcam: cam[0] ecm odd ok caid:0x602 id:0x0 pid:0x36 Pink Plus, BulSatCom,C+ NL (I2) Ik kan inmiddels ook bij de webinfo page op poort 16001. Ik heb daar geen active clients of servers staan: Connected clients: 0 +---------+---------------+------------+------------+-----+-----+--------+----------------------+ | Username| Host | Connected | Idle time | ECM | EMM | Version| Last used share | +---------+---------------+------------+------------+-----+-----+--------+----------------------+ +---------+---------------+------------+------------+-----+-----+--------+----------------------+ Server connections: 0 +----------------------+------------+-----+--------+----------------+-------+-------------------------------+ | Host | Connected | Type| Version| NodeID | Cards | CAID/Idents | +----------------------+------------+-----+--------+----------------+-------+-------------------------------+ +----------------------+------------+-----+--------+----------------+-------+-------------------------------+ DM7025 - 2x DVB-C - Seagate CE 160Gb HDD - Casema TVD - Gemini 4.20 - CCcam 2.0.11 - Transcend 512Mb CF - Sharp Aquos LC-32GD1E
Buzzz Geplaatst: 29 januari 2008 Geplaatst: 29 januari 2008 Code: 14:08:37.464 CCcam: card detect fail Dit moet je eerst zien te fiksen! NewCS toch wel uitgeschakeld? Nokia D-BOX II AVIA500 - Multicam 3.0 - Sportster Pro 1.10 RC010 - NewCS 1.50 - CCcam 2.04 Nokia D-BOX II AVIA500 - Sportster Pro 1.10 RC010 - CCcam 2.04
Dish TV Geplaatst: 29 januari 2008 Auteur Geplaatst: 29 januari 2008 Origineel bericht van: Buzzz Code: 14:08:37.464 CCcam: card detect fail Dit moet je eerst zien te fiksen! NewCS toch wel uitgeschakeld? Uiteraard... Ik was wel bezig met NewCS 1.50 en in de .xml file daarvan stond wel een pincode (4x '0') die ik gebruikt heb. Zou de kaart lock-out zijn? Ik heb het net nog even getest maar ik heb wel beeld op een Samsung ontvanger... DM7025 - 2x DVB-C - Seagate CE 160Gb HDD - Casema TVD - Gemini 4.20 - CCcam 2.0.11 - Transcend 512Mb CF - Sharp Aquos LC-32GD1E
Ron Geplaatst: 29 januari 2008 Geplaatst: 29 januari 2008 Ik vermoed dat je een oude kaart hebt en die leest de DM7025 op een of andere manier niet. (4004?) Het enige dat dan nog helpt is een externe cardreader gebruiken. Ron
Dish TV Geplaatst: 29 januari 2008 Auteur Geplaatst: 29 januari 2008 Wat ik dan niet snap is waarom het dan met Gemini 3.00 wel werkte (newcs - mgcamd) 2 dagen geleden... Ik heb trouwens een 4015 kaart. DM7025 - 2x DVB-C - Seagate CE 160Gb HDD - Casema TVD - Gemini 4.20 - CCcam 2.0.11 - Transcend 512Mb CF - Sharp Aquos LC-32GD1E
Ron Geplaatst: 30 januari 2008 Geplaatst: 30 januari 2008 Dan zul je waarschijnlijk de juiste camkey (ik heb geen idee welke dat is voor een 4015 kaart) in de CCcam.cfg moeten zetten. Dan wordt deze kaart kennelijk nog niet herkend door CCcam. Ron
Dish TV Geplaatst: 30 januari 2008 Auteur Geplaatst: 30 januari 2008 Aha, maar de CAMDATA en de CAMKEY heb ik van deze kaart, die staat namelijk in de newcs.xml. En drie keer raden wat er gebeurde toen ik deze invulde in de cccam.cfg: Jawel ik heb weer beeld! SUPER! Dit zijn de CAMDATA/KEY regels voor een 4015 kaart: CAMKEY: /dev/sci0 11 22 33 44 55 66 77 88 CAMDATA: /dev/sci0 3C 86 33 AA C0 D3 67 53 3D EC 7B B2 EE ED EB 8C A3 AD A5 2E 58 B9 9B B3 46 72 78 32 77 A1 DA AC 3B 61 06 AD 09 09 77 4E 03 1B 2A 6E 30 19 5B 43 76 83 AD 0F C5 99 B8 7D 08 CE A4 7B E1 B6 C7 6A Oh ja, de card detect fail blijft bestaan... En zo te zien gaan de EMM's en ECM's ook goed. DM7025 - 2x DVB-C - Seagate CE 160Gb HDD - Casema TVD - Gemini 4.20 - CCcam 2.0.11 - Transcend 512Mb CF - Sharp Aquos LC-32GD1E
Buzzz Geplaatst: 30 januari 2008 Geplaatst: 30 januari 2008 Mooi dat 't weer werkt! Wat betreft de card detect fail; misschien heeft de kaartlezer geen schakelaar die fysiek een kaart detecteert, of dat deze in de config niet ingeschakeld staat? Och, zolang het werkt zou ik me er niet heel druk om maken trouwens... Nokia D-BOX II AVIA500 - Multicam 3.0 - Sportster Pro 1.10 RC010 - NewCS 1.50 - CCcam 2.04 Nokia D-BOX II AVIA500 - Sportster Pro 1.10 RC010 - CCcam 2.04
Dish TV Geplaatst: 30 januari 2008 Auteur Geplaatst: 30 januari 2008 De kaart zit rechtstreeks in de 7025, in het onderste slot. Ik heb geen schakelaars (micro switches) gezien... En inderdaad: het werkt, dus ik ben allang blij! DM7025 - 2x DVB-C - Seagate CE 160Gb HDD - Casema TVD - Gemini 4.20 - CCcam 2.0.11 - Transcend 512Mb CF - Sharp Aquos LC-32GD1E
Ron Geplaatst: 30 januari 2008 Geplaatst: 30 januari 2008 Mooi, en ik ben ook erg blij met je positieve instelling en terugkoppeling over de (juiste) camkey. Zo hebben andere leden er ook wat aan! 100 punten! Ron
