info op spaanse site Phillips DST5816
Het volgende:<P>We began with first of the small things that have commanded to us... I believe that it does not have waste, therefore I stick all the content to you of the email and you will see. The sender of this email is Kilouiski: Being one of the Webs more visited and with more popular forums, I send east software to you: The Bonny-secaboxser.exe, that when Bonny me sent it (is its author) its name was " Secaboxser.exe ", I believe that you have it hung in the Web with a similar name. It only serves TO EXTRACT the data of eprom and flash of receivers DSX7071, DSX6071 and DST5816. The project of Bonny (author of the IC-prog, as you know) is to modify firmware and to make it multilingual, with which would have access to all the aids that the remote control for all the suppliers gives. Not only that, but which also the channels with the DVBEditor can be published, that is a format very known by which they have Nokias, and that had great development due to the facilities to obtain the software of Nokia many years ago, which allowed to " Brains " like Uli (Dr Overflow) and many others to develop fantastic applications, that are only appraised in their right value when it has been tried to make something similar. Memory the rapidity, amiability and precision whereupon answered Uli to me the first time that I sent a mail to him, altogether contrasts with the " gentlemen " of Philips, experts in the policy to throw balls outside and not to say anything. I have several post office that demonstrate it. And there is an enormous amount of free channels to choose, to group and to order for being able to accede to them of the form that more comfortable is to him to each one. If there is somebody interested in this project with contacts in Philips, that uses them, because it is the best form to stop and to accelerate the results: to be able soft TO WRITE and to be able to modify firmware. For example, the second program that I command to you, is a utility of Philips Suresnes, that LEE and WRITES. I was already sent it to Bonny days ago, and perhaps by comparison, tracks can be removed. As I see that there is much level in some of the forums, I believe that it will be advisable that this is within reach of all. Because the one of which twenty thousand pesetas remove to one to put firmware in Spanish, seems a little expensive. Rubén is the friend who me passed it, just like the version 1.15b of the Mediaserax. In gratefulness to each one of them, I precede with its name the one of the obtained programs. And nothing else that to say, that if I race, I write a book. The truth is that it turns out very rewarding to collaborate with people those who not even is known, with the idea common to learn and to share knowledge: Each advance, each obstacle saved, produces a non-paymentable satisfaction. I animate all! Kilouiski Next to the email it sends the archives to us: Bonny-secaboxser.exe Rubén-Mediasat prog.zip Rubén-mediaseraxv1_15b.zip In another email sends the instructions to us: Instrucciones.txt
Receiver: VU+ Solo 4K
Gast
