michel130 Geplaatst: 25 augustus 2008 Delen Geplaatst: 25 augustus 2008 Van de site. Release Date : 22 Aug 2008 Firmware Version : 01-17-080812-15-POP-402-000 Release Note : 1. Requires NMT apps 00-17-080808-15-POP-402 2. Those with firmware prior to 080612, please step through 01-17-080612-15-POP-402-000 firmware, before updating to this firmware. 3. System/Browser - Language added: "Japanese" and "Slovenian" - USB HDD spindown - Minor url encoding/decoding fixes - Web Services editable URL increased to 10 - File operation UI (copy, move, delete, add, remove, clear) - Press FILEMODE key - Previous Angle and TimeSeek key for File operation obsoleted - Fixed wrong name at left plane for Data Disc main page - Fixed myiHome folder with space or other special character unable to access content - Fixed screen saver images in themes not working - Changed File Operation menu font size to smaller to match rest of browser - Changes in FTP password handling to reduce corruption. - Fixed time zone setting not effective bug - Fixed a bug where local html with parameters cannot be loaded - Fixed hang while browsing MSP and some memory leak issue 4. Playback - Aspect ratio/TV zoom improvements: "4:3 Letterbox", "4:3 Pan-Scan", "16:9", "16:10", "Actual size", "Fullscreen" - Revert back to turn off SPDIF only when go to standby, instead of turn off SPDIF when exits playback. - audio volume range change from -48dB~1dB to -43dB~6dB (44 is 0dB, boosted volume indicated in Red) - Fix info display bug (garbled characters) in audio playback - Screensaver for audio playback - Ogg Vorbis and Vorbis in MKV support - Fixed wmv no sound after playback mov h.264 files - Fixed ts clips audio detection error for Breakfast_20080708_06300900.ts - Fixed data CD unable to access - Earlier detection of width/height and Aspect Ratio information - New MKV demux from Haali, improved MKV decode performance above 33Mbps from local HDD, SMB and NFS shares. HTTP performance still below 20Mbps - Auto TV fix in DVD navigation - Fixed ISO crash on VESA mode - Fixed play apps cannot start when there is problems with themes - Fixed sometimes DVD navigation return immediately enter into screen saver - fixed certain VC1 in MKV playback freeze on the first frame - fixed MKV audio track switching involving Vorbis - Improved MKV DTS audio drop(stuttering) issue - Fine-tune MKV seek and fast forward - Improved SVCD detection. - Fixed PMT detection error causing wrong video subtrack selected - Fixed DVD audio: cannot set to Chinese - Fixed HDMI output blackout after ISO playback and standby - Added ".img" ISO file extension support - Fixed 5~6 sec of audio recovery when audio subtrack changed - Fixed some WMA and WMV+WMA not able to switch audio channel - Fixed MKV aspect ratio scaling 5. Subtitle - Changed to 8bpp font, should improve subtitle text - Subtitle rendering fix - Yellow/Black subtitle - Fixed subtitle text wrapping went out of screen - Increased text width for new subtitle color option - Fixed slight flashing when in 1080p24 output - Fixed external subtitle disappear after seek in MKV - Fixed certain SMI subtitle causes playback freeze 6. Photo app - Fixed photo slideshow unable to repeat - Photo slideshow, added "No transition effect" 7. Network - Improved bitrate throughput of playback over SMB to ~38Mbps, up from ~25Mbps. Same as NFS performance now. - Fixed dummy IP (-) on manual network when no network available - Fixed samba name and passwords too long cannot be saved correctly - Added ability to name your Network Shares, instead of just pathname - Samba browsing on Media Source page - Integrated NZBGet and Transmission BT client to firmware (except BT UI) - Fixed unable to add NFS URL if the share folder name contains only a single letter - Fixed NFS client mount failure - "Remote Samba Servers" renamed to "Network Browser". - Latest Atheros WiFi driver v3.2.0.17 - Known issue: WEP connection is not working. - Fixed system bootup freeze with USB WiFi plugged in - Fixed auto-login latency for unmounted NFS share - Fixed cannot add torrent from MSP->Vuze 8. Known issues - due to Pathname changes for Network Shares, may break some YAMJ and GBPVR generated HTML links - some FLAC sampling frequencies may play faster/slower Dreambox 7000S & 500 & 800 - Maxtor 80GB en Samsung 500GB - USBstick Swap - schotel 80 & 110cm - Moteck SG2100 - lnb titanium 0,2 db & duo lnb - openPLI - Satje07 settings - cccam 2.1.4 Link naar reactie Delen op andere sites Meer opties om te delen...
conc Geplaatst: 25 augustus 2008 Delen Geplaatst: 25 augustus 2008 De NZBget is een geweldige toevoeging. Je laad een NZB, Popcorn download de PAR en RAR files repareren en uitpakken gaat automatisch. En dan kijken maar. Link naar reactie Delen op andere sites Meer opties om te delen...
WPW Geplaatst: 25 augustus 2008 Delen Geplaatst: 25 augustus 2008 Hmm lekker, de eene vastloper na de andere... en dat alleen maar met foto's... gr, WPW. -=[Deze ruimte is opzettelijk leeg gelaten]=- Link naar reactie Delen op andere sites Meer opties om te delen...
rienan Geplaatst: 25 augustus 2008 Delen Geplaatst: 25 augustus 2008 ja dat moet een stuk beter gaan,maar waar vind ik de nzbget.config?? je moet in de config enkele instellingen veranderen maar hoe kom ik in de root van de hdd. Gr Rienan AZbox premium HD en een htpc asrock ion 330 + een plasma 43" +een archos 10.1 tablet. Link naar reactie Delen op andere sites Meer opties om te delen...
Jürgen Geplaatst: 25 augustus 2008 Delen Geplaatst: 25 augustus 2008 Via SMB kun je vanuit de WIN PC of laptop naar de PH. Je komt niet in de Root maar er is nu wel een map .nzbget aangemaakt. In deze map staat naast een aantal andere mappen ook het bestand nzbget.conf. Met een editor zoals b.v. TextPad kun je dit bestand muteren. MacBook Air M2 2022 - iPad Air 2021 - Iphone XR - Apple TV 4 2021 Link naar reactie Delen op andere sites Meer opties om te delen...
michel130 Geplaatst: 25 augustus 2008 Auteur Delen Geplaatst: 25 augustus 2008 Je moet wel even hidden files uitzetten anders zie je hem niet. Vast lopers heb ik nog niet gehad met deze firmware. Dreambox 7000S & 500 & 800 - Maxtor 80GB en Samsung 500GB - USBstick Swap - schotel 80 & 110cm - Moteck SG2100 - lnb titanium 0,2 db & duo lnb - openPLI - Satje07 settings - cccam 2.1.4 Link naar reactie Delen op andere sites Meer opties om te delen...
rienan Geplaatst: 25 augustus 2008 Delen Geplaatst: 25 augustus 2008 Ja dat was em,bedankt.Verborgen bestanden stond uit. Gr Rienan AZbox premium HD en een htpc asrock ion 330 + een plasma 43" +een archos 10.1 tablet. Link naar reactie Delen op andere sites Meer opties om te delen...
cowo Geplaatst: 26 augustus 2008 Delen Geplaatst: 26 augustus 2008 Origineel bericht van: conc De NZBget is een geweldige toevoeging. Je laad een NZB, Popcorn download de PAR en RAR files repareren en uitpakken gaat automatisch. En dan kijken maar. Dat klinkt inderdaad super, maar zou je in het kort kunnen uitleggen hoe je dat werkend krijgt? Met bovenstaande reacties kom ik er ook niet uit. Alvast bedankt!! Link naar reactie Delen op andere sites Meer opties om te delen...
conc Geplaatst: 26 augustus 2008 Delen Geplaatst: 26 augustus 2008 Op je hdd staat een map nzbget in deze map zit een config file. Deze config file moet je bewerken met bv WordPad. Code: # Host-name of news server server1.host=news.yourserver.com <- Put the server name behind the = # Port to connect to (default 119 if not specified) server1.port=119 <- change the port if it is different from 119 # Username to use for authentication server1.username=USERNAME <- your username # Password to use for authentication server1.password=PASSWORD <- your password # Maximal number of simultaneous connections to this server server1.connections=4 <- the maximum of concurrent connection (or less) Ga daarna naar http://ip.of.your.pch:8066. Link naar reactie Delen op andere sites Meer opties om te delen...
cowo Geplaatst: 26 augustus 2008 Delen Geplaatst: 26 augustus 2008 Geweldig bedankt voor deze info. Ik ga ermee aan de slag. Moet ik zo toch werkend krijgen. Super! Link naar reactie Delen op andere sites Meer opties om te delen...
groko Geplaatst: 28 augustus 2008 Delen Geplaatst: 28 augustus 2008 Ik ben met deze firmware echt super tevreden. Zodra je nzbget goed hebt geconfigureerd even de boel resetten en het draait als een zonnetje Heb ook het formaat op auto staan en dan helemaal geen problemen meer met afkappingen in het beeld Heb hem laatst te koop gezet maar ga het weekend maar even goed nadenken of ik hem wel echt kwijt wil. There's only two reasons to own a video camera, chase tornados and make sex tapes. And I don't see a cow in no tree, Tommy Lee! Link naar reactie Delen op andere sites Meer opties om te delen...
limbo Geplaatst: 3 oktober 2008 Delen Geplaatst: 3 oktober 2008 Ik heb vandaag de popcorn hour A110 besteld, en waarschijnlijk is deze binnen 24-48 uur geleverd. Mijn vraag, is de firmware upgrade ook geschikt voor de A110? Groet, Limbo Link naar reactie Delen op andere sites Meer opties om te delen...
Jean-Claude Geplaatst: 3 oktober 2008 Delen Geplaatst: 3 oktober 2008 de A100 en A110 hebben aparte upgrades. Maar daar hoef je je niet veel van aan tre trekken, gewoon upgraden via de setup en het internet, en dan pakt ie zelf wel de juiste upgrade modules. het upgraden is ook cumulatief : je gaat het dus meerder keren na elkaar moeten doen, tot wanneer je de laatste versie geinstalleerd hebt. DreamBox 8000+Xtrend ET10000+Gigablue UHD 4K, openPLi, CCcam, CD+TVV kaarten (gene zever), wavefrontier T90, EMP Centauri 33/12 multiswitch en VEEL te weinig slaap. Link naar reactie Delen op andere sites Meer opties om te delen...
Gast tzrider Geplaatst: 3 oktober 2008 Delen Geplaatst: 3 oktober 2008 Heb de A-110 hier inmiddels al een weekje staan. Mijn A-100 draai nu met 2.5 inch HDD als webserver en de A-110 draait films van de 1 tB USB HDD. Ze hebben zichzelf trouwens weer overtroffen. Inplaats van onduidelijke LEDjes brandt er nu een zeer irritante rode LED zodra je de 110 uitzet. Link naar reactie Delen op andere sites Meer opties om te delen...
Rootical Geplaatst: 4 oktober 2008 Delen Geplaatst: 4 oktober 2008 Als ik het zo lees op de website zijn er alleen wat modificaties geweest aan de hdmi en audio hardware, en zijn de usb poorten aan de achterkant geplaatst? Wat merk je in de praktijk aan deze veranderingen tegenover de A100? Link naar reactie Delen op andere sites Meer opties om te delen...
