guus0007 Geplaatst: 13 september 2008 Delen Geplaatst: 13 september 2008 Wie kan me helpen aan settingslijst voor in de 7025 van limburg. Kan alles ontvangen maar krijg geen eredevisie de 4 kanalen. Ook niet met handmatige scan. Alvast bedankt. Link naar reactie Delen op andere sites Meer opties om te delen...
De_Muts Geplaatst: 15 september 2008 Delen Geplaatst: 15 september 2008 maak een nieuwe cables.xml file en zet daar het volgende in: <?xml version="1.0" encoding="iso-8859-1" ?> - <cables> - <cable name="Ziggo" satfeed="true" flags="9"> <transponder frequency="444000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="420000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="364000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="372000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="380000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="460000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="396000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="292000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="404000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="284000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="276000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="268000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="388000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> \ <transponder frequency="412000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="682750000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="658750000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="562750000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="356000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="428000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="252000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="260000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="452000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="436000000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="690750000" symbol_rate="6875000" fec_inner="0" modulation="3" /> <transponder frequency="826750000" symbol_rate="6875000" fec_inner="0" modulation="3" /> </cable> </cables> Als dit is gedaan ff alles uploaden naar de box via FTP en dan de box herstarten . Vervolgens een scan laten uitvoeren en je hebt alles incl eredivisie live. Nog wel een abo afsluiten anders kun je niet kijken. suc6 PvdH VU+Duo2 (2xs2+2xDVBC) (OpenPLI) + Vu+ Solo SE v2 (Dual C) (OpenPLI) + DM800HD se (OpenPLI 4.0) + DM One UHD Combo Triax 80CM Multifeed (13-19-23-28) Ziggo (Full Package) Link naar reactie Delen op andere sites Meer opties om te delen...
