hemertje Geplaatst: 2 oktober 2008 Delen Geplaatst: 2 oktober 2008 A new Enigma2 PLi® Dreambox release is available for download. The Original Enigma2 PLi® Jade Final suite contains the following images: * PLi®-Jade-DM7025 * PLi®-Jade-DM800 See below for fixes & features since the initial PLi® Jade RC release Warning: - For the dm7025 we don't support an online software update from Jade RC to Jade Final - For the dm800 the online software update should work. But note that in order to get the #62 bootloader, you have to flash the nfi - For editing a Enigma2 (HDTV) channellist, you will need a channeleditor which supports fully the service4 type lamedb file, like for example: DreamBoxEdit 3.0 or Dreamset v2.20 Highlights: - Services4 for lamedb support * (PLi Jade Final supports HDTV channels 100%!) - AC3 fixes for BEV/DISH NETWORK, by Updatelee - North America scan fix by Updatelee - Bootloader #62 for DM800 * (fixes crashes on HD channels) - TuxTXT-32bpp: added support for HD framebuffer resolutions (HD skins) - Satellites.xml split in Ka, Ku, C, S, L band Enigma2: - CVS Repository September 30th 2008 - PLi® Repository September 29th 2008 - Services4 for lamedb support * (PLi Jade Final supports HDTV channels 100%!) * For editing a Enigma2 (HDTV) channellist, you will need a channeleditor which supports fully the service4 type lamedb file, like for example: DreamBoxEdit 3.0 or Dreamset v2.20 - Don't allow markers in the servicelist to be selected * (In order to provide some way of deleting markers, we do allow them to be selected while in bouquet editmode) - Wrapping fixed in listboxes, when the top item is a non-selectable item (e.g. marker in a servicelist) - Event progress bars in the servicelist - Servicelist redesigned - AC3 fixes for BEV/DISH NETWORK, by Updatelee - North America scan fix by Updatelee - Only show serviceinfo for 'playable' items in the serviceselector * (Fixes 'no info' in the bouquet list) - Tuxcom / Tuxterm: support for HD framebuffer resolutions (HD skins) - Tuxterm: Support for DM800 - TuxTXT-32bpp: support for HD framebuffer resolutions (HD skins) - Freetype update, several ttf rendering improvements Drivers: - 20080826 drivers for DM7025 - 20080821 drivers for DM800 - Bootloader #62 for DM800 * (Fixes crashes on HDTV channels) Plugins: - Enigma2 plugins 20080926 (including autotimer fix and DVD-Player fixes) - CCcam 2.0.9 SoftCam - RQCamd 0.90 Softcam - Picons updated to 20080930 - Latest Henksat settings Skins: - Converted to latest enigma2 - Skin parsing: assume 'title' and 'text' are utf-8 Mounts: - Additional NET mountpoints added (/media/net1 - net3) Languages: - Several translations updated Support: - Online update support (IPKG feed) - Global satellites.xml updated September 29th 2008 (DVB-S: FEC = Automatic; DVB-S2: FEC = Normal) - Satellite.xml split in Ka, Ku, C, S, L band See our PLi® Wiki... Further: - Thanks to Updatelee for his N.A. AC3 and scanning fixes Many low level changes fixes and other updates... Detailed info, Wiki, FAQ's, HowTo's, TechNotes and information about this and the previous PLi® releases can be found on the PLi® Website: http://www.pli-images.org/downloads.php?cat_id=12 DM8000 + DM800SE + VU+DUO + Wavefrontier T90 + 10LNBs Hemertje.Dreambox Webmaster Sat-nerds Moderator Plinux Member Link naar reactie Delen op andere sites Meer opties om te delen...
Harley Geplaatst: 2 oktober 2008 Delen Geplaatst: 2 oktober 2008 DVD-Player fixes houd in? Kan er nog niet veel mee helaas. VU+ Duo2 - PrismCube Link naar reactie Delen op andere sites Meer opties om te delen...
Henksat Geplaatst: 2 oktober 2008 Delen Geplaatst: 2 oktober 2008 Origineel bericht van: Harley4 DVD-Player fixes houd in? Dat ie beter loopt als ooit tevoren, hier tenminste wel. Dreambox 8000HD, Xtrend et5000 & et9000, Qnap 209-II Pro 2Tb,Wavefrontier T 90,Stab HH120 Triax 78 cm, Triax 78 cm CDS Duo LNB Member of the PLi team Link naar reactie Delen op andere sites Meer opties om te delen...
Harley Geplaatst: 2 oktober 2008 Delen Geplaatst: 2 oktober 2008 Origineel bericht van: Henksat Origineel bericht van: Harley4 DVD-Player fixes houd in? Dat ie beter loopt als ooit tevoren, hier tenminste wel. Vreemd Waardeer het dat jullie er tijd in steken, maar kan hier geen muziek DVD meer afspelen, schokt en wel zeker 1 a2 sec asynchroon. idd vanaf Enigma2 plugins 20080926 VU+ Duo2 - PrismCube Link naar reactie Delen op andere sites Meer opties om te delen...
Henksat Geplaatst: 2 oktober 2008 Delen Geplaatst: 2 oktober 2008 Origineel bericht van: Harley4 Waardeer het dat jullie er tijd in steken, maar kan hier geen muziek DVD meer afspelen, schokt en wel zeker 1 a2 sec asynchroon. Deed ie dat bij jou met andere images ook al niet? Misschien een lokaal probleem? Dreambox 8000HD, Xtrend et5000 & et9000, Qnap 209-II Pro 2Tb,Wavefrontier T 90,Stab HH120 Triax 78 cm, Triax 78 cm CDS Duo LNB Member of the PLi team Link naar reactie Delen op andere sites Meer opties om te delen...
Harley Geplaatst: 2 oktober 2008 Delen Geplaatst: 2 oktober 2008 Origineel bericht van: Henksat Deed ie dat bij jou met andere images ook al niet? Misschien een lokaal probleem? Zou het haast denken, moet wel als ie bij jou het goed doet. ff teruggezocht, tis hier met een update van 21/9 begonnen. Daarvoor werkte het gewoon goed. Zoek wel ff verder. Begrijp alleen nog niet wat die fixes dan moeten inhouden VU+ Duo2 - PrismCube Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Royke79 Geplaatst: 2 oktober 2008 Delen Geplaatst: 2 oktober 2008 Wat houdt hetvolgende in? - AC3 fixes for BEV/DISH NETWORK, by Updatelee Is dit bedoeld voor alle HDTV zenders op is dit iets totaal anders? Link naar reactie Delen op andere sites Meer opties om te delen...
hemertje Geplaatst: 2 oktober 2008 Auteur Delen Geplaatst: 2 oktober 2008 Origineel bericht van: Royke79 Wat houdt hetvolgende in? - AC3 fixes for BEV/DISH NETWORK, by Updatelee Is dit bedoeld voor alle HDTV zenders op is dit iets totaal anders? AC3 geluid werkt nu ook voor de 2 amerikaanse providers DM8000 + DM800SE + VU+DUO + Wavefrontier T90 + 10LNBs Hemertje.Dreambox Webmaster Sat-nerds Moderator Plinux Member Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Royke79 Geplaatst: 2 oktober 2008 Delen Geplaatst: 2 oktober 2008 Als 1e weer geweldig werk van jullie!!! Ik ga deze image gelijk uitproberen. Kan iemand mij wel vertellen of nu de audio/video sync problemen op de HDTV zenders is opgelost of is dit een DMM issue? Link naar reactie Delen op andere sites Meer opties om te delen...
hemertje Geplaatst: 2 oktober 2008 Auteur Delen Geplaatst: 2 oktober 2008 Origineel bericht van: Royke79 Als 1e weer geweldig werk van jullie!!! Ik ga deze image gelijk uitproberen. Kan iemand mij wel vertellen of nu de audio/video sync problemen op de HDTV zenders is opgelost of is dit een DMM issue? dmm DM8000 + DM800SE + VU+DUO + Wavefrontier T90 + 10LNBs Hemertje.Dreambox Webmaster Sat-nerds Moderator Plinux Member Link naar reactie Delen op andere sites Meer opties om te delen...
f650gsrider Geplaatst: 2 oktober 2008 Delen Geplaatst: 2 oktober 2008 Online update voor de 800 is perfekt verlopen Greetz.............René Link naar reactie Delen op andere sites Meer opties om te delen...
osdebos Geplaatst: 2 oktober 2008 Delen Geplaatst: 2 oktober 2008 Installatie verliep vlekkeloos. DVD player plugin krijg ik geen AC3 geluid uit. Had de afgelopen dagen even de laatste Gemini er op en moet toch toegeven dat deze op dit moment mijn voorkeur geniet. Gemini is bij mij in het voordeel door oa een melding als de rotor draait, wel AC3 geluid bij het spelen via DVD player plugin en mkv bestanden af te spelen met de mediacenter plugin (die kreeg ik niet werkend op de PLI Jade final->geen geluid). Verder natuurlijk alle respect voor de makers. Gr. Oscar DM 800 + 7000 + 500S + 500C Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Sjaaky Geplaatst: 2 oktober 2008 Delen Geplaatst: 2 oktober 2008 Om ac3 te krijgen moet je liba52 deinstalleren. Deze library down-mixed ac3 naar stereo zodat het ook op boxen werkt waar geen optische kabel op aangesloten is. Link naar reactie Delen op andere sites Meer opties om te delen...
Harley Geplaatst: 2 oktober 2008 Delen Geplaatst: 2 oktober 2008 Na install youtubeplayer, blijft deze in downloads staan. Kan hem dus ook nergens terugvinden. VU+ Duo2 - PrismCube Link naar reactie Delen op andere sites Meer opties om te delen...
Gast pieterg Geplaatst: 3 oktober 2008 Delen Geplaatst: 3 oktober 2008 Origineel bericht van: Harley4 Na install youtubeplayer, blijft deze in downloads staan. Kan hem dus ook nergens terugvinden. deze bieden we (net als vele andere plugins) aan vanuit een public repository. Er ontbreekt voor deze plugin een dependency (python-gdata), daarom installeert hij momenteel niet, als het goed is heb je daar een foutmelding van gehad tijdens het installeren. Link naar reactie Delen op andere sites Meer opties om te delen...
