moreno40 Geplaatst: 20 oktober 2008 Delen Geplaatst: 20 oktober 2008 Available for processor types: sh4 (tested only on Cuberevo, Cuberevo mini, kathrein ufs910 with e2) Use the e2 version on kathrein with enigma 2 on board, the other version on ipbox 9000/900 with dgstation firmwares Card client for protocols: cccam, gbox, newcamd 5.20, newcamd 5.25, radegast old, radegast new, aroureos .conf and .prio files can be inserted in the /var/bin directory, or in /etc, or in /var/keys 20/06/2008, V0.50, First public release camd33 and camd35 is really much unstable so I think it's not yet ready for public, asap it will be ready i'll publish it This is the first release, you can't see any log on the console because I don't wanna people read infos that could put them on the strange way. However logs on console are really good to know if bugs are the cause of your problem or simply if you are so noob to not be able to configure it correctly. Read very well config files and don't say something you don't know. This is not a fully working cam, some functions are not implemented/enabled because they are not ready for public and I think people don't wanna functions that are working not really good as they expected! (also this version is a beta version, but i wanted to put some hopes on people that believe a cam is better than othern one, we have tested the cam on many decoders and we can say this cam is not bad at all also in beta and not full working mode ) So for the first release I choose to public only client side of the cam. I want to thank raton_craquero for givin' me the possibility to know really a lot of things on how to use dvb_api and i have to admit that i really like his config file structure and his log functions, so i decided to use them with his agreement Thank you! Regards, the IncubusCrew! incubusCamd_0.5.zip Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Stepdriver Geplaatst: 20 oktober 2008 Delen Geplaatst: 20 oktober 2008 Hoe dit te gebruiken of te installeren?? Link naar reactie Delen op andere sites Meer opties om te delen...
bash! Geplaatst: 20 oktober 2008 Delen Geplaatst: 20 oktober 2008 In de Siftea image kan je hem al gewoon via het menu downloaden! Ik ben nu aan het testen naar CCcam. Gr, BaZ There is nothing wrong with having a strong opinion... if it comes with an open mind! Link naar reactie Delen op andere sites Meer opties om te delen...
fdm Geplaatst: 21 oktober 2008 Delen Geplaatst: 21 oktober 2008 Ik heb hem zojuist geinstalleerd in mijn 900HD. Nu nog even kijken waar de config staat om deze box op mijn CCcamserver te connecten. Je kunt hem trouwens gewoon bewerken met DCC (root/abcom). Ik ga vanavond verder. Het is hoogstwaarschijnlijk dat er binnenkort iets onwaarschijnlijks gaat gebeuren. Link naar reactie Delen op andere sites Meer opties om te delen...
MagicOnline Geplaatst: 21 oktober 2008 Delen Geplaatst: 21 oktober 2008 Dat staat toch in de readme? .conf and .prio files kun je plaatsen in de /var/bin directory, /etc, of in /var/keys CCcam configuren card_server_url_0=cccam://test:test@192.168.1.6:12000 heb je meerdere boxen draaien met interne kaarten en je wil die connecten: card_server_url_0=cccam://test:test@192.168.1.6:12000 card_server_url_1=cccam://test:test@192.168.1.7:12000 Of 1 CCcam server en 1 gbox server: card_server_url_0=cccam://test:test@192.168.1.6:12000 card_server_url_1=gbox://192.168.1.6:2500:wachtwoord:192.168.1.7:2500:wachtwoord Niet echt moeilijk dus CDS: Wij bieden goede beeldkwaliteit, dat u geen goed beeld heeft ligt niet aan onze bandbreedte. Link naar reactie Delen op andere sites Meer opties om te delen...
fdm Geplaatst: 21 oktober 2008 Delen Geplaatst: 21 oktober 2008 Ok, maar ik moest snel weg, maar wilde absoluut deze cam alvast inladen... Het is hoogstwaarschijnlijk dat er binnenkort iets onwaarschijnlijks gaat gebeuren. Link naar reactie Delen op andere sites Meer opties om te delen...
bash! Geplaatst: 21 oktober 2008 Delen Geplaatst: 21 oktober 2008 Inmiddels hier beeld op mijn CCcam server. Zappen geeft nog een freeze, maar duidelijk is dat het werkt!!! There is nothing wrong with having a strong opinion... if it comes with an open mind! Link naar reactie Delen op andere sites Meer opties om te delen...
Rootical Geplaatst: 21 oktober 2008 Delen Geplaatst: 21 oktober 2008 Hoe browsed deze image door het menu Bash? en zapt je redelijk fatsoenlijk door je zenderlijst? Kan je mss even wat screenshots hiervan plaatsen, ben erg benieuwd hoe de layout eruit ziet. Link naar reactie Delen op andere sites Meer opties om te delen...
IceKiller Geplaatst: 21 oktober 2008 Delen Geplaatst: 21 oktober 2008 euh.... 't is een CAM zoals CCcam maar die ook met gbox etc overweg kan.. 't is niet een image hé. Dreambox 800 + barry allen + 160gb | Dreambox 500 | Dreambox 7020 + 120G + usb stick.. Link naar reactie Delen op andere sites Meer opties om te delen...
bash! Geplaatst: 21 oktober 2008 Delen Geplaatst: 21 oktober 2008 Ok.. zappen werkt soms wel, soms niet.. maar vooruit.. het is versie 0.5! Als hij werkt, dan blijft hij ook echt keurig werken, dus het zit echt in het wisselen van zender (PID) De image is exact het zelfde als de originele image van DGS, maar onder de rode knop zitten een aantal extra menu's (CAM menu, en install menu voor plugins en cams). Je kan de EMU via het menu installeren, maar de config moet je via de console (of FTP) aanpassen volgens bovenstaande reactie. Op zich een eitje dus! Gr, BaZ There is nothing wrong with having a strong opinion... if it comes with an open mind! Link naar reactie Delen op andere sites Meer opties om te delen...
zuurtje Geplaatst: 21 oktober 2008 Delen Geplaatst: 21 oktober 2008 Hoi hoe geef ik de server url aan Zo bv 192.168.1.234 0=cccam://test:test@192.168.2.345:12000 ik krijg namelijk geen contact met m'n server wie kan me verder helpen? Grt zuurtje Topfield 4010 - Dreambox 7020 - Dreambox 7025 - 2x Triax 78cm - 1x Triax 88 cm - 1x Visiobigsatellite - alles natuurlijk draaibaar behalve de bigsatellite Link naar reactie Delen op andere sites Meer opties om te delen...
MagicOnline Geplaatst: 21 oktober 2008 Delen Geplaatst: 21 oktober 2008 Origineel bericht van: zuurtje Hoi hoe geef ik de server url aan Zo bv 192.168.1.234 0=cccam://test:test@192.168.2.345:12000 ik krijg namelijk geen contact met m'n server wie kan me verder helpen? Grt zuurtje Probeer eens: card_server_url_0=cccam://test:test@192.168.2.345:12000 staat gewoon in de readme en ook op de vorige pagina CDS: Wij bieden goede beeldkwaliteit, dat u geen goed beeld heeft ligt niet aan onze bandbreedte. Link naar reactie Delen op andere sites Meer opties om te delen...
fdm Geplaatst: 21 oktober 2008 Delen Geplaatst: 21 oktober 2008 Geweldig! hij doet het fantastisch! geeft netjes mijn C+Fr/Csat/Télésuisse kanalen door. Zelfs SuisseHD is geen probleem. Op de site van mijn server staat onder VERSION incubuscamd. Het kan al niet meer stuk... Het is hoogstwaarschijnlijk dat er binnenkort iets onwaarschijnlijks gaat gebeuren. Link naar reactie Delen op andere sites Meer opties om te delen...
fdm Geplaatst: 21 oktober 2008 Delen Geplaatst: 21 oktober 2008 Indien binnenkort ABcom Enigma uitkomt en deze ook Incubuscamd gebruikt ben ik helemaal gelukkig. Ik vind de huidige OSD maar niets... Het is hoogstwaarschijnlijk dat er binnenkort iets onwaarschijnlijks gaat gebeuren. Link naar reactie Delen op andere sites Meer opties om te delen...
bash! Geplaatst: 21 oktober 2008 Delen Geplaatst: 21 oktober 2008 loopt jouw box wel eens vast als je zapt of kan jij gewoon blijven zappen?? Welke image draai je? Gr, BaZ There is nothing wrong with having a strong opinion... if it comes with an open mind! Link naar reactie Delen op andere sites Meer opties om te delen...
