Gast Gman2oo6 Geplaatst: 23 oktober 2008 Geplaatst: 23 oktober 2008 Prepared by : Dexter & pen1010b Release date : October 23. 2008 Changes: * added: NLB Panel (start with green button) onscreen menu, webif alternative * added: Incubus camd v0.5 (not configured! will crash box if not configured) * added: mount usb stick or Harddrive with Windows filesystem at bootup * added: format usb stick with Windows filesystem in Webif * added: hdd sleep period configure option * added: restore var from usb * added: switch between nlb and dgs webif (dgs webif has WebTV support!) * added: plugins - tetris,pong,sudoku,weather * updated: cam scripts * updated: mbox Build 0015 * updated: format usb stick with Linux filesystem for multiboot in webif * updated: Full German translation update (Byti) * updated: Full Swedish translation update (Wikings1) * updated: Full Danish translation update (pen1010b) * updated: Documentation on nlb mod features. * fixed: mount usb stick with Windows filesystem * fixed: multiboot - now supports usb_all and usb_all_noboot images * Thanks to Byti,Spiderman,Wikings1,teleka for intensive testing and reports hier de uitgebreide versie wat er veranderd is Image mod by Dexter & pen1010b **************************************** **** Updated: 23 october 2008 **** **************************************** Features of NLB Image - Onscreen panel for stop/start of most features found in webif and more. - Customized startup, faster load times - Added support for external usb serial port (PL2303 USB-Serial) - Added binary utils - ssh / scp / sftp (client tools) - fw_printenv / fw_setenv (uboot environment see/change) - strace - cron daemon - alternative thttp daemon (not used) - Emu included (in /data folder, Read-Only) new updates should be placed in /var/bin .. (see name in [] ) - [newcs] newcs 1.62 (newest 23.10.200 - [incubusCamd.sh4] incubus 0.5 (newest 22.10.200 (DISABLE TIMESHIFT TO MAKE THIS EMU WORK!) - [mgcamd130] mgcamd 1.30 for nordic viasat users - [mgcamd] mgcamd 1.30d ( use 1.30 if you are viasat nordic user, for faster channel switching) - mpcs 0.9d - [mbox.sh40] mbox II 0.4 Build 005 (3.10.200 - [evocamd] evocamd - Samba (Windows networking sharing) - ftp / telnet / ssh server - terminfo for top (primarily) - USB multiboot (see below for details on how to use it) - supports all_noboot images too.. (except AbCom image) - WebIf (details below) - Bootscript for loading at every startup - /var/S59_bootscript and remember "# chmod 755" on script ***** WebIf ----- ----- The webif is your control center of the NLB mod image. Default login is: root and password: relook If you need to update access table for ip addresses allowed to access webif, please edit the /var/etc/httpd.conf You find a line here ie. A: 192.168. Enter your network segment here, example A: 172.24. or a specific public ip A: 212.242.1.12 Save file, and reboot box, and you got access to the webif. - System information * Processes - List current applications running on IPBox * Change SWAP HDD - Activate Swap or disable it. * CPU Info - get IPBox cpu info details * System Boot information - output of "dmesg" startup of box. can be used even if your box shows "PANIC". - System options * restart samba - restart windows sharing service. * Samba status - Activate or stop samba/windows sharing services * Change HDD filesystem - Choose between ext2/ext3 or existing. ext2 filesystem will run FSCK (filesystem checks) ext3 filesystem skips FSCK * telnet status - Activate or stop telnet service * ssh status - Activate or stop ssh service * ftp status - Activate or stop ftp service * Restart box - Reboot your box - Firmware options * Upgrade FW - Upgrade firmware from img file in /var or /media folder. transfer .img file to /var or /media folder and select this option to upgrade firmware. * Multiboot - Read below for details - USB options * SWAP - activate or disable swap on USB key * Format USB - format a usb pendrive/stick for use with box - and for multiboot setup * NOTE: USB Stick will be mounted on IP900 as HDD if above 2GB And this means it cannot be formatted in webif on ip900. * Mount USB - mount a USB stick on box, to access files on it location: /mnt/data * Copy /var - make backup of /var to your usb stick * backup db.dat to usb - copy your db.dat file to your usb stick * restore db.dat from usb - restore db.dat (will be named db.dat.edited) requires reboot to take effect. * List contents of usb - list contents of usb stick, if mounted. - IPBox options * HDD/NFS media folder change - NOT ENABLED AS OF THIS WRITING! * Change Fan - enable/disable fan in Ipbox. * Show time in led - activate Time in VFD display. * Change led - Change VFD brightness (0-7) * stop sbox at next boot - will disable start of "satbox" application at next boot (debug) * Assign color button - Read/Yellow/Green buttons can be assigned functions most options above + more described below here. WideScreen - stretch tv picture on TV's that do not do it automatically. ecm info - show current ecm info on tv hdd temp - Show HDD temperature on tv display restart cam - says what it does stop cam - -- !! -- Soft updater - run your /var/bin/soft script * Change skin - Change the look of your menus in DGStation satbox application. * Skin: Crash Blue * Skin: Crash Grey * Skin: Crash DeepBlue * display HDD temp - show current temperature of HDD - Emu * Change mbox status - Stop/start mbox at next boot. * Remember to use "change emu" also to choose this one * Change mgcamd status - Stop/start mgcamd at next boot. * Remember to use "change emu" also to choose this one * Change emu - Select between evocamd / mgcamd / mbox , to be automatically startup at boot. * Stop Emu - Stop running emu. * Restart Emu - Restart running emu. * Change newcs status - choose to stop or start newcs at bootup. * Change newcs config - Choose between both/upper/lower newcs default config - this will overwrite your existing configuration. * ECM - Show current ECM of provider. * Mgcamd shares - show current connections * Card stats - mgcamd status * Info about cards - if gbox peer enabled, shows current list of cards. ************************** EMU DEFAULT CONFIGURATIONS -------------------------- -------------------------- mgcamd included is a default config to run with newcs and use internal card readers (activated default) originally tested with Viasat and CanalDigital cards. mbox included is a default config to run with newcs and use internal card readers (activated default) Tested with CanalDigital card. Now includes 32100.list, 32101.list with default all channel opened. evocam is included, but there are no defaults for anything configured! incubusCamd is included, but defaults are still in testing and this is a beta release of cam. ************* USB MULTIBOOT ------------- ------------- - Multiboot feature gives you the option to boot off a usb pendrive/stick, so you can more easily place as many files you wish into the root file system, with the only limit of the usb filesystem size. - It also uses the USB key for /var storage, so each image will have its own setup. - Removing the usb key, will cause box to boot flash image. - USB key should be formatted in webif, before use - other USB key cannot be used/formatted in webif, when you are running multiboot. Instructions for usb multiboot ------------------------------ - Format a usb key in webif (USB Options - Format USB) if used in DGS box during mp3 playback or photo album, it will not work. - Wait for an OK from formatting (takes 30-60 seconds depending on size) - Placing firmware on usb key procedure - * For /media folder - with ftp copy an .img file to the /media folder - Only SifTeam / NLB images will work. - * For /mnt/data folder - mount usb key in webif (USB options - Mount USB) - select Firmware Options - Multiboot - in field "Enter name ...." write a suitable name for image - in "Choose file to put on usb" select image to put on usb - in front of img file you can see location of file. - Press "extract" to extract image to usb. - when finished (takes 2-3 minutes), reselect "Firmware Options - Multiboot" - In bottom "Select USB bootimage to use" you can now see your image. ? if it is not shown and extract failed, make sure your usb was formatted with a unix fs, ie. using format usb in webif. - You can choose to "Change" and mark which image to load at next boot or - You can choose to "Delete" firmwareimage from usb. - Selecting "Flash boot" will make box boot your flash / disable usb boot. - Reboot box to start usb firmware. veel plezier ps als het in het nederlands moet hoor ik het wel
bellejt Geplaatst: 24 oktober 2008 Geplaatst: 24 oktober 2008 Nederlands zou wel makkelijker zijn. Groetjes,salutations,greetings. 1 x Gibertini 1,10 vast 3 sats + 1 x Triax 88 cm rotor Vu + Duo2 twin sat tuner 4 X DVB-S2 en 1 x turbo DVB-C + OpenVix + idem dual tuner and vu duo2 fallback tuner Octagon SF8008 4K Openvix (via ethernetconnectie/WIFI fallbacktuner)
omanski Geplaatst: 24 oktober 2008 Geplaatst: 24 oktober 2008 Citaat: Nederlands zou wel makkelijker zijn. Ik steun deze motie..... Groetuhhh...Omanski. -------------------- CubeRevo 9000HD-twin, Topfield 5000pvr, Aston dual & X-cam Premium Philips DSX 7072(2x), DSX 7071, Funke 99cm, Polarmount met Actuator,Invacom Lnb.
ppaap Geplaatst: 24 oktober 2008 Geplaatst: 24 oktober 2008 ja dat zou wel makkelijker zijn in nederlands ppaap
bash! Geplaatst: 24 oktober 2008 Geplaatst: 24 oktober 2008 ja.. het zou ook wel handig zijn als iemand hem er even bij mij in komt zetten There is nothing wrong with having a strong opinion... if it comes with an open mind!
D_liver Geplaatst: 24 oktober 2008 Geplaatst: 24 oktober 2008 Nog gemakkelijker als ik flash roep dient de box gelijk geflashed te worden met het laatste actuele image. Ja er wordt aan gewerkt 2 x Maxytec Multibox 4K 1 x Zgemma H9 combo
bash! Geplaatst: 24 oktober 2008 Geplaatst: 24 oktober 2008 hmm ok.. maar wordt er dan ook automatisch een kop koffie gezet en gebracht terwijl je wacht? Anders heb ik er niets aan There is nothing wrong with having a strong opinion... if it comes with an open mind!
maja Geplaatst: 25 oktober 2008 Geplaatst: 25 oktober 2008 Je kunt ook de automatische vertaaldienst van google gebruiken. Ik heb het geprobeerd en het werkt. Je gaat naar http://translate.google.com op deze site zie je wat je moet doen. Je geeft deze website in je gaat naar het onderwerp en het is gelijk vertaald.
fdm Geplaatst: 28 oktober 2008 Geplaatst: 28 oktober 2008 Ik heb vaeb deze flash erin gezet met Incubuscamd erin. Geen blocages meer en werkt perfekt! Het is hoogstwaarschijnlijk dat er binnenkort iets onwaarschijnlijks gaat gebeuren.
Riekus Quattro Geplaatst: 29 oktober 2008 Geplaatst: 29 oktober 2008 Hallo Forum, Heb de NLB 8340 geïnstalleerd en moet zeggen werkt op zich prima. Ik heb alleen (net als in de vorige update )nog steeds dat als ik de tuner op standby zet ik zwart beeld heb. Ik hoor dan wel geluid van de kabeltv maar geen beeld, als ik dan de tuner helemaal uit zet heb ik wel beeld. Tevens is het zo dat ik na het afspelen van MP3's bevroren beeld heb als ik terugkeer naar de sateliet TV. Is dit gerelateerd aan de nieuwe NLB versies(de 7712 had dit niet), of moet ik instellingen of iets dergelijks aanpassen ?? Gr.Rob
goofy17 Geplaatst: 31 oktober 2008 Geplaatst: 31 oktober 2008 Toch lukt het mij maar niet mijn canal digitaal kaartje te lezen via de interne cardreader. Wat zou ik fout kunnen hebben staan?
Gast koffie54 Geplaatst: 31 oktober 2008 Geplaatst: 31 oktober 2008 Nou zal haast niet maar zit je kaart er wel goed om in chip omlaag?
Gast Stepdriver Geplaatst: 31 oktober 2008 Geplaatst: 31 oktober 2008 Deze software geeft bij mij ook alleen maar problemen, ik krijg alleen maar vrij te ontvangen zenders te zien. De CD kaart krijg ik met geen mogelijkheid aan de gang. Mgcamd en newcs worden netjes gestart, maar het is net alsof de kaart niet vrijgegeven wordt. Ik ga nu maar weer terug naar de oude 8107 software van NLB omdat deze wel gewoon werkte.
JaxcC Geplaatst: 31 oktober 2008 Geplaatst: 31 oktober 2008 Origineel bericht van: Stepdriver Deze software geeft bij mij ook alleen maar problemen, ik krijg alleen maar vrij te ontvangen zenders te zien. De CD kaart krijg ik met geen mogelijkheid aan de gang. Mgcamd en newcs worden netjes gestart, maar het is net alsof de kaart niet vrijgegeven wordt. Ik ga nu maar weer terug naar de oude 8107 software van NLB omdat deze wel gewoon werkte. Mgcamd en newcs werken perfect in de laatste image . Alleen de directory structuur van de NLB images is anders als originele DGS image en Sifteam!! Even zoeken en je zult ZEER tevreden zijn over deze image en zijn opties cheers
Gast Stepdriver Geplaatst: 31 oktober 2008 Geplaatst: 31 oktober 2008 Hoe kan dit nou goed werken?? Al vanaf 9 uur vanochtend bezig op de goede manier, maar nu alleen nog maar panic en rare dingen gezien. NLB 8340 werkt dus echt niet, NLB 8107 wil ook al niet meer opstarten, dgs 8340 geeft aan: service niet beschikbaar en zo kan ik nog wel even doorgaan. Ik ben me er niet van bewust dat ik iets fout doe, dit ding is om moe van te worden... En zeg niet dat de kaart verkeerd zit of dat soort onzin, het werkt gewoon niet naar behoren!
