Lamko Geplaatst: 26 december 2008 Geplaatst: 26 december 2008 Log Opensasc Code: /usr/bin# LD_LIBRARY_PATH=/usr/local/src/opensasc/sc/PLUGINS/lib/ ./sasc-ng -j 0:2 --cam-budget --sid-allpid --sid-nocache[code]Dec 26 21:30:01.042 : Version: 0.0.2-54M/54Dec 26 21:30:01.043 CAM: initializing plugin: SoftCam (0.9.0-Unknown): A software emulated CAMDec 26 21:30:01.043 CAM(general.info): SC version 0.9.0-Unknown initializingDec 26 21:30:01.043 CAM: starting plugin:Dec 26 21:30:01.043 CAM(general.info): SC version 0.9.0-Unknown startingDec 26 21:30:01.043 CAM(core.load): ** Plugin config:Dec 26 21:30:01.043 CAM(core.load): ** Key updates (AU) are enabled (active CAIDs) (no prestart)Dec 26 21:30:01.043 CAM(core.load): ** Local systems DON'T take priority over cached remoteDec 26 21:30:01.043 CAM(core.load): ** Concurrent FF recordings are NOT allowedDec 26 21:30:01.043 CAM(core.load): ** Force transfermode with digital audioDec 26 21:30:01.043 CAM(core.load): ** ScCaps are 1 2 0 0 0 0 0 0 0 0Dec 26 21:30:01.043 CAM(core.load): ** Ignored CAIDs 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000Dec 26 21:30:01.043 CAM(general.info): loading cardclient config from ./sc_files/cardclient.confDec 26 21:30:01.043 CAM(cardclient.core): hostname=127.0.0.1 port=20248 emm=1 emmCaids 1801/ffffDec 26 21:30:01.043 CAM(cardclient.core): Camd35: username=benutzer1 password=password2 ucrc=b20a17d1Dec 26 21:30:01.043 CAM(cardclient.core): client 'Camd35' readyDec 26 21:30:01.044 CAM(general.error): failed open ./sc_files/SoftCam.Key: No such file or directoryDec 26 21:30:01.044 CAM(general.error): failed open ./sc_files/smartcard.conf: No such file or directoryDec 26 21:30:01.044 CAM(general.error): no keys loaded for softcam!Dec 26 21:30:01.044 CAM(core.load): ** registered systems:Dec 26 21:30:01.044 CAM(core.load): ** Cardclient (pri -15)Dec 26 21:30:01.044 CAM(core.load): ** Conax (pri -10)Dec 26 21:30:01.044 CAM(core.load): ** ConstCW (pri -20)Dec 26 21:30:01.044 CAM(core.load): ** Cryptoworks (pri -10)Dec 26 21:30:01.044 CAM(core.load): ** Irdeto (pri -10)Dec 26 21:30:01.044 CAM(core.load): ** Nagra (pri -10)Dec 26 21:30:01.044 CAM(core.load): ** Nagra2 (pri -10)Dec 26 21:30:01.044 CAM(core.load): ** SC-Conax (pri -5)Dec 26 21:30:01.044 CAM(core.load): ** SC-Cryptoworks (pri -5)Dec 26 21:30:01.044 CAM(core.load): ** SC-Irdeto (pri -5)Dec 26 21:30:01.044 CAM(core.load): ** SC-Nagra (pri -5)Dec 26 21:30:01.044 CAM(core.load): ** SC-Seca (pri -5)Dec 26 21:30:01.044 CAM(core.load): ** SC-Viaccess (pri -5)Dec 26 21:30:01.044 CAM(core.load): ** SC-VideoGuard2 (pri -5)Dec 26 21:30:01.044 CAM(core.load): ** Seca (pri -10)Dec 26 21:30:01.044 CAM(core.load): ** @SHL (pri -10)Dec 26 21:30:01.044 CAM(core.load): ** Viaccess (pri -10)Dec 26 21:30:01.044 CAM(general.warn): no smartcard interface defined!Dec 26 21:30:02.051 frontend: Starting thread on /dev/dvb/adapter2/frontend1The thread scheduling parameters indicate:policy = 0priority = 0Dec 26 21:30:02.055 demux: Starting thread on /dev/dvb/adapter2/demux1The thread scheduling parameters indicate:policy = 0priority = 0Dec 26 21:30:02.055 dvr: Starting thread on /dev/dvb/adapter2/dvr1The thread scheduling parameters indicate:policy = 1priority = 99Dec 26 21:30:02.056 : Listening on port 5456 Log Camd3 Code: ./camd3.sh: line 1: !/bin/sh: Bestand of map bestaat niet26.12.2008 21:30:56 camd3: BOXTYPE: 226.12.2008 21:30:56 camd3: LOG: 226.12.2008 21:30:56 camd3: UDP_PORT: 2024826.12.2008 21:30:56 camd3: HTTP_PORT: 908026.12.2008 21:30:56 camd3: DNS_CACHE: 600 sec26.12.2008 21:30:56 camd3: SOCKET: /tmp/camd.socket26.12.2008 21:30:56 camd3: KEYS: /var/keys/camd3.keys26.12.2008 21:30:56 camd3: SERVERS: /var/keys/camd3.servers26.12.2008 21:30:56 camd3: USERS: /var/keys/camd3.users26.12.2008 21:30:56 camd3: Slot /dev/ttyS0: (carddetect=CTS) initialisiere...root@lammert-desktop:~# 26.12.2008 21:30:56 camd3: fahre runter...26.12.2008 21:30:56 camd3: UDP: fahre runter...26.12.2008 21:30:56 camd3: Slot /dev/ttyS0: schliesse...26.12.2008 21:30:56 camd3: Slot /dev/ttyS0: warte auf Monitor...26.12.2008 21:30:56 camd3: HTTP: stopped26.12.2008 21:30:56 camd3: Slot /dev/ttyS0: geschlossen26.12.2008 21:30:56 camd3: KeyDB: beendet26.12.2008 21:30:56 camd3: camd v3.869 - erfolgreich beendet26.12.2008 21:30:57 camd3: Slot /dev/ttyS0: starte Monitor...26.12.2008 21:30:57 camd3: Slot /dev/ttyS0: bereit26.12.2008 21:30:57 camd3: /dev/dvb/card0/ca0 No such file or directory26.12.2008 21:30:57 camd3: /dev/dvb/card0/ca1 No such file or directory26.12.2008 21:30:57 camd3: UserDB(new): USER=benutzer1 PASS=password2 FROM=any SERVICES=any26.12.2008 21:30:57 camd3: UserDB(new): USER=benutzer110 PASS=password10 FROM=any SERVICES=1702:000000:0008:0:0,1722:000000:0008:0:0,26.12.2008 21:30:57 camd3: UserDB(update): USER=benutzer110 PASS=password10 FROM=any SERVICES=1702:000000:0008:0:0,1722:000000:0008:0:0,26.12.2008 21:30:57 camd3: error parse line #38 in /var/keys/camd3.keys26.12.2008 21:30:57 camd3: error parse line #39 in /var/keys/camd3.keys26.12.2008 21:30:57 camd3: error parse line #40 in /var/keys/camd3.keys26.12.2008 21:30:57 camd3: error parse line #41 in /var/keys/camd3.keys26.12.2008 21:30:57 camd3: error parse line #42 in /var/keys/camd3.keys26.12.2008 21:30:57 camd3: error parse line #43 in /var/keys/camd3.keys26.12.2008 21:30:57 camd3: error parse line #51 in /var/keys/camd3.keys26.12.2008 21:30:57 camd3: error parse line #55 in /var/keys/camd3.keys26.12.2008 21:30:57 camd3: error parse line #58 in /var/keys/camd3.keys26.12.2008 21:30:57 camd3: KeyDB: gestartet26.12.2008 21:30:57 camd3: HTTP: started on port 908026.12.2008 21:30:57 camd3: camd v3.869 - erfolgreich gestartet26.12.2008 21:30:59 camd3: Slot /dev/ttyS0: ATR -> 3b 24 00 30 42 30 30 26.12.2008 21:30:59 camd3: Slot /dev/ttyS0: Karte gefunden -> initialisiere...26.12.2008 21:31:01 camd3: Slot /dev/ttyS0: Karte erkannt26.12.2008 21:31:01 camd3: Slot /dev/ttyS0: TYPE -> CONAX26.12.2008 21:31:01 camd3: Slot /dev/ttyS0: CAID -> 0B0026.12.2008 21:31:01 camd3: Slot /dev/ttyS0: VER -> 0001 Net of hij gewoon niet wil inloggen op de camd3 server Mythbuntu 12.04 Celeron 220 op Mini-ITX D201GLY2, 1 GB Ram,2x1,5 TB HDD, Digitenne op TerraTec Cinergy, CCcam
Hans Houwaard Geplaatst: 30 december 2008 Geplaatst: 30 december 2008 Ik heb vergelijkbare resultaten, de ecm en emm verzoeken komen nooit bij de server aan. Dit is volgens mij een gevolg van s2api drivers en niet volledig s2api compatibel sasc-ng en applicatie. Bij gaat het binnen mythtv mis, sasc-ng ontvangt hiervan verkeerde info en stuurt vervolgens nooit de ecm emm verzoeken naar de ingesteld server. Ik heb dit met Newcs en CCCam ondervonden. Ik heb hier nog geen oplossing voor gevonden, ik heb namelijk geen driver kunnen vinden met de oude api die ook mijn kaart ondersteund. Hans MythBuntu 12.04 LTS (MythTV 0.26) Kernel 3.5.0-19-generic Hauppage NovaS2 HD DVB-S/S2 TeVii S470 DVB-S2 Asus NVidia 9600 GT Samsung LE40A552 LCD TV
Lamko Geplaatst: 30 december 2008 Geplaatst: 30 december 2008 Kan k je wel uit de droom helpen ik heb geen s2api driver geladen. Denk eerder dat sasc-ng aan stront is ! Mythbuntu 12.04 Celeron 220 op Mini-ITX D201GLY2, 1 GB Ram,2x1,5 TB HDD, Digitenne op TerraTec Cinergy, CCcam
Hans Houwaard Geplaatst: 30 december 2008 Geplaatst: 30 december 2008 Origineel bericht van: Lamko @Hans Waar blijf je nu steken dan ? Ik heb nu twee installs naast elkaar. Een met MythBuntu 8.04.1 met Weekly Builds geinstalleerd. Weekly Builds is bij mij stabieler dan de Ubuntu versie, dat is dus een aanrader. Zie de howto op de mythbuntu site. In deze versie krijg ik sasc-ng niet aan de praat met NewCS of met CCCam, omdat de emc en emm verzoeken niet bij de server aankomen. Door de error die ik in de log tegenkom, vermoed ik dat de 0.21 versie van MythTV met de s2api driver en sasc-ng problemen geeft. Ik heb daarnaast MythBuntu 8.10 met een eigen build van s2api en SASC-NG gepatch voor s2api met een eigen build van MythTV 0.22. Deze werkt nog niet goed, waarschijnlijk doordat een goede patch van sasc-ng voor s2api nog niet goed is uitontwikkeld. In ieder geval werkt MythTV niet met de sasc-ng dvb adapter en wel met de fysieke adapter. Hierdoor zal ik ook geen channels kunnen decoden met MythTV. In deze omgeving heb ik ook VDR gebouwd en XBMC geinstalleerd. Deze beide lijken te werken met cccam, maar ik vind de combinatie XBMC en VDR minder dan MythTV. Dat is dan zuiver kijkend naar functionaliteit. Het liefst heb ik een werkende MythTV 0.22 met s2api en Sasc-ng, maar zover lijkt het nog niet te zijn. Ik heb dus wel mythtv, maar geen gedecode kanalen of VDR en XBMC en gedecode kanalen. Hans MythBuntu 12.04 LTS (MythTV 0.26) Kernel 3.5.0-19-generic Hauppage NovaS2 HD DVB-S/S2 TeVii S470 DVB-S2 Asus NVidia 9600 GT Samsung LE40A552 LCD TV
Lamko Geplaatst: 30 december 2008 Geplaatst: 30 december 2008 Ligt dus wel aan sasc-ng maar dan aan de config ervan stond op emmCaids 1801/ffff zo opende hij alleen premiere kanalen op de sat. Heb deze ff naar 0000/0000 verandert in de cardclient.conf En Beeld! in mplayer wel n beetje vaag trouwens van de loopback devices : /usr/bin# LD_LIBRARY_PATH=/usr/local/src/opensasc/sc/PLUGINS/lib/ ./sasc-ng -d 0xf0a -j 0:2 --cam-budget mplayer dvb://3@"TMF" Heb een dubbele tuner dat zijn 0 en 1 en ik dacht dat de dvbloopback modules 2 en 3 zouden zijn. Dan zou je toch zeggen met een sasc joinregel echte (0 dus) koppelen aan virtuele (2 dus) En dan moet ik om te kijken mplayer vertellen dat hij de 3e moet pakken ????? Wat heeft 3 er mee te maken, naja het werkt in iedergeval in mplayer, behalve Private, dan krijg ik dit : CAM(conax.key): missing 21 E key CAM(core.ecm): system: no key found for C 21 M Op de KPN box is deze met een pincode beveiligd zou t hier aan kunnen liggen ? Verder zegt mplayer bij een paar kanalen zoals Eurosport couldnt find channel maar hij staat toch echt in de channels.conf Iemand die me een paar dingetjes uit kan leggen :edit mplayer telt dus vanaf 1 Mythbuntu 12.04 Celeron 220 op Mini-ITX D201GLY2, 1 GB Ram,2x1,5 TB HDD, Digitenne op TerraTec Cinergy, CCcam
Rigolo Geplaatst: 30 december 2008 Auteur Geplaatst: 30 december 2008 Misschien is het goed om ook wat van mij te laten horen :-) Ik ben vorig weekend druk bezig geweest mijn MythTV systeem met 3 DVB-C TT C-1500 adapters te herbouwen. Ik heb onder aan de wiki pagina op mythtv.nl wat kleine regels codes geplaatst die ik nu gebruik bij het aanmaken en draaien van sasc-ng. Waar ik zelf idd nog mee zit zijn die libraries. Ik heb ze verplaatst naar /usr/lib/open-sasc-ng (dus in een eigen directory) en een conf bestand neergezet in /etc/ld.so.conf.d/ (dit alles onder Mythbuntu 8.10) Wat ik begreep is dat je eigenlijk alleen de libs nodig heb voor de encryptie die je wenst. Maar als ik bijvoorbeeld de conax files verwijder uit de /usr/lib directory dan begint sasc-ng hier toch over te klagen dat deze weg zijn. Dus als iemand weet hoe dat nou precies zit zou ik dat graag willen weten. Maar alles draait wel. Ik draai dus met 3 echte en 3 virtuele kaarten. MythTV draait ook gewoon op virtuele kaarten en ook en instellen van de kanalen lijst ging vrij simpel. Ik heb gewoon een channesl.conf met alleen de zenders uit het basis pakket geimporteerd en daarna handmatig de frequenties van de transport streams recht gezet. Toen draaide het meteen. Wel de transports verwijderd waar geen netid aan vast zet en die met netid 1000 laten staan en aangepast. Ook multirec werkt en ik heb maandag avond 6 programma's tegelijkertijd opgenomen .... tenminste .. als je het goed vind dat er een aantal maar 0 Bytes groot zijn :-) Dit probleem had ik vaker gehoord en ik ben daar wat meer ingedoken. Wat mij opvalt is het volgende: Stel je hebt transponder 1 met kanaal A, B en C daar op en transponder 2 met kanaal D, E en F Als je eerst iets van kanaal A opneemt en daarna (op de zelfde DVB kaart) iets opneemt van kanaal D (op andere transponder dus andere frequentie) dan gaat alles goed. Maar wil je wat opnemen van kanaal B dan lukt dit niet. ALs ik in de sasc-ng logs kijk dan zie ik dat er een CHANNEL: Tuning frontend verzoek binnen komt, gevolgd door de melding: CHANNEL: Skipping cache reset since tuning matches last tune. Dus omdat er geen tuning nodig is (want B zit op de zelfde transponder 1 als A) dan wordt er niks opgenomen. Je ziet ook niet dat er een PID filter wordt opgestart. Er gebeurt gewoon helemaal niks volgens sasc-ng. Ik moet nog uitzoeken of dit komt omdat na 1 minuut sasc-ng de verbinding naar de cardserver verbreekt ( met melding : CAM(core.net): Idle timeout, disconnected 127.0.0.1:34000) of dat er wat anders aan de hand is. Teven moet ik nog kijken wat er gebeurt als je multirec gebruikt en dus tijdens het opnemen van een programma van kanaal A ook iets van kanaal C wil opnemen maar bijvoorbeeld 10 minuten later. Gaat er dan ook iets fout met die "cache" reset of niet. Voor deze test moet ik even goed een scenario uitschrijven en de recording schedules goed instellen dat ze ook vanaf 1 dvb kaart opgenomen worden. Als mogelijke tussen "oplossing" zit ik te denken om een soort "waakvlammetje" te maken. Een recording schedule binnen MythTV die voor elke kaart elk half uur 30 second probeert op te nemen van een kanaal op een transponder waar weinig zenders op zitten waar ik naar kijk. En deze dan een extreem lage prio geven zodat alle andere schedules er voorrang op hebben zodat deze niet worden onderbroken. En deze recordings dan op een eigen kleine locatie plaatsen en snel later verlopen zodat ze niet je hele systeem vol zetten mer 48 opnamens van niks. Heeft iemand anders soortgelijke problemen? Dan hoor ik het graag. En hoe gaat VDR hier eigenlijk mee om? komt dit probleem ook daar voor? dit omdat onderwater sasc-ng gewoon de vdr-sc code gebruikt (van wel bijna een jaar gelden .. dat wel) Hein p.s. Misschien hiervan toch maar een eigen topic van maken??
Lamko Geplaatst: 31 december 2008 Geplaatst: 31 december 2008 Lijkt me een goed plan ! We gaan verder in Mythbuntu 8.04/8.10 - Opensasc-ng problemen Mythbuntu 12.04 Celeron 220 op Mini-ITX D201GLY2, 1 GB Ram,2x1,5 TB HDD, Digitenne op TerraTec Cinergy, CCcam
Moderator Matchless Geplaatst: 2 januari 2009 Moderator Geplaatst: 2 januari 2009 Dan sluit ik deze als jullie het goedvinden. zo niet hoor ik het wel.. Een smartphone is een hulpmiddel, geen levensstijl Kijk rond IN de wereld in plaats van voorover gebogen NAAR de wereld.
