Gast tzrider Geplaatst: 30 oktober 2008 Geplaatst: 30 oktober 2008 (als TF 7700 HSCI bezitter begin ik bijna te janken als ik dit zie) Nieuwe firmware 01-17-081023-15-POP-402-000 http://www.hdd-player.de/syabas/showthread.php?tid=4687 1. Requires NMT apps 00-17-081023-15-POP-402 2. Playback - MKV HTTP streaming performance improved - MKV Chapters support. - MKV chapter key handling (follows WMP) - use PREV/NEXT key to switch chapter - at each chapter, - pressing PREV once will goto start of that chapter - pressing PREV twice will goto previous chapter - pressing PREV twice at 1st chapter will goto previous clip if in playlist - pressing NEXT once will goto start of next chapter - pressing NEXT once at last chapter will goto next clip if in playlist - Fixed ISO playback over USB occasional hang issue - Fixed some FLAC playback at wrong sampling frequency - Fixed certain TS substream (mostly teletext) incorrectly detected as DTS - Fixed certain TS with mixed Hi-Def and standard audio subtracks losing audio - Audio with new info display and ID3v2 (album art if available) - ID3 parsing for local (HDD, USB storage) content only - Press Info key to display - Added filename and bitrate in video info display. - RMVB support (requires new myiHome v5.1.0 and above to perform transcoding) - Fixed certain microDVD SUB file will cause hang - Fixed thumbnail display issue from WMP servers - Moved Video Zoom option from "Preferences" to "Audio/Video" page, separating into 2 options - Video Zoom [Actual Size | Fit To Screen | Crop | Full Screen] - TV Type [4:3 | 16:9 | 16:10] - Prebuffering control - new HTML extension tag supported, "prebuf=xxx" property tag added to anchor tag to set the size of the pre-buffer - Fixed no dimension information displayed for certain M1V/M2V files - display MP3 album art in actual size - Fixed exception handling for music album art - added handling of FLAC file with ID3 header - DTS-core passthrough fixed - Fixed audio switch between DTS-HD and other codec no output issue - Video playback progressive zoom and pan - press "Zoom" key to cycle through zoom mode, magnify mode and pan mode - use arrow key to adjust value (only left/right key for zoom/magnify) - moves viewport when panning, instead of the image - added exit zoom mode - change pan step size to 1 - save pan/zoom setting for each zoom profile (FullScreen, Actual Size etc) to RAM. - Audio output fixes - fixed some AVI with DTS 96/24 output - fixed AVI with PCM output noise when set to 5.1 - fixed HDMI no DTS output when AC3 set to PCM mode - Fixed for 24 bit encoded FLAC playback - Fixed playback video_ts over SMB stuttering issue - Fixed Brightness/Saturation/Contrast not applied correctly in DVD playback - Added language selection for DVD subtitle/audio (Danish etc) - Fixed DVD with single subtitle track cannot be displayed - Modified Volume range to improve usable range - Volume range -15~+15, max 15dB, min -28dB. - red number if >0dB, indicating boosted volume - green number if <0dB - white at 0dB - Fixed volume not saved when it is 0dB - Detect .dts as DTS-WAV, starts playback with 0dB to allow uncorrupted passthrough - Fixed WAV header parsing for certain wav file - Fixed HD-DVD remux, DD+ track no audio downmix output - Fixed M2T PMT detection bug - Fixed DTS-WAV output issue when surround mode is set to 5.1 - Fixed inaccurate running video bitrate - Rectified "repeat", "suspend" key mapping in ISO playback - Fixed incorrect playlist OSD display when music playback from myiHome - Fixed decoder crash when playing a MKV without audio track - Fixed incorrect downsampling of PCM audio for HDMI output source sampling rate > 48kHz - Fixed incorrect WAV playback sampling rate (set at 48kHz) 3. Photo app - New Photo app - added more information on display - eliminate black-out gap between slides - able to display monochrome JPEG - auto rotation for photo (JPEG) - based on EXIF orientation and below 2048x2048 - Brightness/contrast/saturation change ("Setup" + arrow keys) - Slideshow fixes - Auto rotation for jpeg 2111 profile - Known issue: Color distortion at the bottom of picture after +-90deg rotate. - Color settings to follow preset value - changed pan to moving viewport, instead of image (same as for movies) - fixed mis-aligned position when performing zoom - Fixed decoder crashed when displaying certain GIF file through HDMI - Fixed certain JPEG rotation will crash decoder - Known issues: - for GIF/BMP/PNG, will clear screen when manually switch previous/next slide - color distortion at bottom of photo when panning. - no rotation for BMP GIF PNG - no rotation for JPEG >= 2048x2048 - JPEG > 15MB cannot be displayed through HTTP - BMP > 2272x1712, PNG > 4000x2400 cannot be displayed - checking - Note: myiHome will transcode and scale-down BMP/GIF/PNG to JPEG 4. System/Browser - Atheros WiFi WEP issue fixes - added HDMI/DVI colorspace Setup option - fixed wrong navigation flow after adding network share - Modified Web Services UI pages - Fixed when USB drive added/removed, issue with media source page refresh - Turkish, Danish translation added - Browser caching to harddisk - Various translation fixes - WiFi graceful teardown during reboot/shutdown to avoid crash. - Browser modification - pressing SOURCE key at "Media source" page will goto "Web Services" - fixed browser using wrong cached image - added "new folder" and "rename" functions in File Operation menu - faster fileplayer sort - Fixed garbled text at network share -> username/password page - Various new libs to resolve crash issue Usenet download under certain condition - Fixed CD-ROM folders not sorted on top of file list - Fixed occasional inaccurate WiFi auto-scan list - Workaround inaccurate width calculation for some fixed-width character - Cut Browser parsing time to about half (reduce about 0.2s) - Fixed ISO file does not support relative path on fileplayer - Fixed NMT apps start/stop status shown incorectly - Fixed NMT apps status refresh in SEtup page and "Reset Factory Setting" handling - Fixed failure to access Clutch interface - Fixed broken browser history 5. Network - NFS servers browsing supported - SMB client fixes, additional checking to prevent from redirect to invalid/stale share folder - Handling when network lost - proper unmount and page redirection - NFS client fixes, reduce the retry time on NFS mount from 2 mins to 1 min - Revert network IP checking for SMB/NFS share before mount attempt - Fixed reset to factory settings occasionally failed after network configuration changed 6. Subtitle - Fixed extended character misaligned in MKV embedded subtitle - Fixed bi-direction issue in Hebrew *.SUB - Subtitle menu re-ordered and text modified - A"Time"->"On/Off"->"Color"->"Size"->"Position" - Fixed Subtitle from myiHomeLite bug (QA#495) 7. Casgle client - changed Casgle client name from "Casgle Client" to "Casgle iDVR" - opened Casgle client service for SD mode too 8. Known issues - PNG/TIFF support over myiHome broken
michel130 Geplaatst: 30 oktober 2008 Geplaatst: 30 oktober 2008 Thanks, voor de info. Kunnen we hem weer erin plaatsen. alleen jammer dat er nog steeds geen mms bij zit zodat je windows media streams live van internet kan afspelen. Dreambox 7000S & 500 & 800 - Maxtor 80GB en Samsung 500GB - USBstick Swap - schotel 80 & 110cm - Moteck SG2100 - lnb titanium 0,2 db & duo lnb - openPLI - Satje07 settings - cccam 2.1.4
alejandro Geplaatst: 31 oktober 2008 Geplaatst: 31 oktober 2008 Zo, aardig wat updates/aanpassingen, mooi. wat ik mij afvraag, waarom kan het volgende niet: in een map staan 10 films, ik kijk de eerste, als ik dan op next druk dat ik naar de volgende film ga..? Ik moet eerst op stop drukken, vervolgens de volgende aanklikken/drukken, is dit ook zo met mp3? Vastberaden, geen arrogantie!
winwiz Geplaatst: 31 oktober 2008 Geplaatst: 31 oktober 2008 Je moet, als je in een map staat, niet op de enter drukken (ronde knop in het kwadrant, maar op de play knop. Dan speelt hij alles af wat in die map staat. Dit werkt ook zo bij MP3's Synology DS414 + DS1815+(8GB) + iPad Pro 10.5 64Gb (iOS 11) + iPhone 7+ 128 GB (iOS 11) + MacbookPro 15" 2016 (MacOS High Siera 10.13) + Apple Watch Series 3 (WOS 4) + Apple TV3 + Apple TV4 + Nvidia Shield + Microsoft Gecertificeerd.
alejandro Geplaatst: 31 oktober 2008 Geplaatst: 31 oktober 2008 Was alles in het leven maar zo simpel, dank je voor de uitleg. Vastberaden, geen arrogantie!
Jürgen Geplaatst: 31 oktober 2008 Geplaatst: 31 oktober 2008 Origineel bericht van: winwiz Je moet, als je in een map staat, niet op de enter drukken (ronde knop in het kwadrant, maar op de play knop. Dan speelt hij alles af wat in die map staat. Je hebt gelijk behalve als het gaat om het afspelen van een DVD VIDEO_TS map (files). Hierbij kun je de DVD alleen afspelen als je op Enter drukt. Als je hierbij op Play drukt gebeurt er niets. MacBook Air M2 2022 - iPad Air 2021 - Iphone XR - Apple TV 4 2021
Jürgen Geplaatst: 31 oktober 2008 Geplaatst: 31 oktober 2008 Ik heb trouwens met deze nieuwe FW toch wel problemen met het afspelen van DVD VIDEO_TS mappen die op de HDD van mijn PC staan en die via SMB Server zijn geshared. Volgens eerder geplaatste berichten op het forum Networked Mediatank zou dit probleem met de nieuwe FW tot het verleden behoren. Zodra ik de VIDEO_TS map aanklik hangt de A100 en helpt alleen nog maar de stekker eruit. VIDEO_TS mappen die op de ingebouwde HDD van de A100 staan worden probleemloos afgespeeld. MacBook Air M2 2022 - iPad Air 2021 - Iphone XR - Apple TV 4 2021
marcel1970 Geplaatst: 1 november 2008 Geplaatst: 1 november 2008 Citaat: (als TF 7700 HSCI bezitter begin ik bijna te janken als ik dit zie) Vanwaar deze opmerking? (ben zelf ook tf 7700 hci bezitter) Ikzelf heb de a110 waarvoor nog geen nieuwe firmware is..de grootste verbetering voor mij lijkt me de chapter support in mkv bestanden..Ik hoop iig dat de update ook gau voor de a110 beschikbaar komt "My next wife will be normal"
Gast tzrider Geplaatst: 1 november 2008 Geplaatst: 1 november 2008 Citaat: Vanwaar deze opmerking? Ooit wel eens documentatie van Topfield gezienwat er nu in een nieuwe firmware is veranderd ??
Jean-Claude Geplaatst: 6 november 2008 Geplaatst: 6 november 2008 er zit ook nog een andere vervelende bug in deze update : bij het afspelen van een TS via NFS loopt de PCH-100 vast na een 20-tal minuten, en is een manuele reboot noodzakelijk. als ik die TS naar een HD kopieer en afspeel via Samba, dan speelt deze wél normaal af. heel vervelend omdat ik nog steeds geen samba verbinding met mijn dreambox kan opzetten. (ik krijg nu wel geen "no contents found" meer, maar een andere melding "ressource busy")..... DreamBox 8000+Xtrend ET10000+Gigablue UHD 4K, openPLi, CCcam, CD+TVV kaarten (gene zever), wavefrontier T90, EMP Centauri 33/12 multiswitch en VEEL te weinig slaap.
MagicOnline Geplaatst: 9 november 2008 Geplaatst: 9 november 2008 Je moet de nfs share op de dreambox wel delen als /media en op de PCH vul je dan in: nfs//IpAdresVanDreambox:/media Werkt prima dan CDS: Wij bieden goede beeldkwaliteit, dat u geen goed beeld heeft ligt niet aan onze bandbreedte.
michel130 Geplaatst: 9 november 2008 Geplaatst: 9 november 2008 Ik heb nfs aangezet op de dreambox. Als ik dan op de pch naar de dreambox wil linken krijg ik unkown ik heb user name en password erin gezet, maar helaas. Maar op dreambox heb ik alleen nfs aangezet, hoe kan je die dan share als media? Dreambox 7000S & 500 & 800 - Maxtor 80GB en Samsung 500GB - USBstick Swap - schotel 80 & 110cm - Moteck SG2100 - lnb titanium 0,2 db & duo lnb - openPLI - Satje07 settings - cccam 2.1.4
Jean-Claude Geplaatst: 9 november 2008 Geplaatst: 9 november 2008 hoe je via nfs verbinding maakt met de dreambox heb ik al hier uitgelegd. Als je dezelfde instellingen neemt dan zou het moeten werken. DreamBox 8000+Xtrend ET10000+Gigablue UHD 4K, openPLi, CCcam, CD+TVV kaarten (gene zever), wavefrontier T90, EMP Centauri 33/12 multiswitch en VEEL te weinig slaap.
michel130 Geplaatst: 9 november 2008 Geplaatst: 9 november 2008 Mooi dat werkt. Thanks. Kan ik eindelijk via de pch kijken op de dreambox. Dreambox 7000S & 500 & 800 - Maxtor 80GB en Samsung 500GB - USBstick Swap - schotel 80 & 110cm - Moteck SG2100 - lnb titanium 0,2 db & duo lnb - openPLI - Satje07 settings - cccam 2.1.4
michel130 Geplaatst: 25 november 2008 Geplaatst: 25 november 2008 Heeft iemand ook al met deze firmware van dreambox HDTV > kunnen streamen naar popcornhour. Mij lukt het niet meer om met deze firmware te steamen voorheen ging het wel goed, in de config heb ik niks anders ingesteld, alleen een ander firmware en in dreambox gemini image inplaats van pli image Dreambox 7000S & 500 & 800 - Maxtor 80GB en Samsung 500GB - USBstick Swap - schotel 80 & 110cm - Moteck SG2100 - lnb titanium 0,2 db & duo lnb - openPLI - Satje07 settings - cccam 2.1.4
