SATA kabel, hoe lang maximaal
Van wikipedia:
The SATA standard defines a data cable with seven conductors (3 grounds and 4 active data lines in two pairs) and 8 mm wide wafer connectors on each end. SATA cables can have lengths up to 1 m (39 in), and connect one motherboard socket to one hard drive. PATA ribbon cables, in comparison, connect one motherboard socket to up to two hard drives, carry either 40 or 80 wires, and are limited to 45 cm (18 in) in length by the PATA specification (however, cables up to 90 cm (36 in) are readily available). Thus, SATA connectors and cables are easier to fit in closed spaces and reduce obstructions to air cooling. They are more susceptible to accidental unplugging and breakage than PATA, but cables can be purchased that have a 'locking' feature, whereby a small (usually metal) spring holds the plug in the socket
Kortom: max 1 meter en alles wat er boven zit is voor eigen risico.
Zeker... maar die meter is de garantielengte. Zo is P-ATA maar tot geloof iets minder als 50 cm gedefineerd en je koopt ook van die lange meter kabels en dat werkt in de regel ook.
Verwacht zelf dat 2 meter ook wel moet lukken smile
Nu nog een kabel zien in te slaan van die lengte!
