[9000 ] Afspelen van opgenomen bestanden lukt niet altijd
hmm mag mijn post niet editten dus dan maar zo
ook dit veranderen
<boxkey>0000000000</boxkey>
<rsa>0000000000</rsa>
even aan de file toevoegen waar die nog niet staat
( dus die waar nu staat )
<name>Card no boxkey</name>
daar komt ie bij
zo ziet mijne nu uit en nu werken beide cardreaders
Code:
<newCSconfig>        <readers name="Card Readers">                <device>                        <name>Card boxkey 0000000000</name>                        <type>sci</type>                        <mhz>357</mhz>                        <node>/dev/sci0</node>                        <export>yes</export>                        <enabled>yes</enabled>                        <blocksa>No</blocksa>                        <blockua>No</blockua>                        <blockga>No</blockga>			<boxkey>0000000000</boxkey>			<rsa>0000000000</rsa>                        <PTShandshake>no</PTShandshake>                        <crypto-special>no</crypto-special>                        <carddetect>yes</carddetect>                        <newcamd_port>32100</newcamd_port>                        <priority>round</priority>                </device>                <device>                        <name>Card boxkey 0000000000</name>                        <type>sci</type>                        <mhz>357</mhz>                        <node>/dev/sci1</node>                        <export>yes</export>                        <enabled>yes</enabled>                        <blocksa>No</blocksa>                        <blockua>No</blockua>                        <blockga>No</blockga>			<boxkey>0000000000</boxkey>			<rsa>0000000000</rsa>                        <PTShandshake>no</PTShandshake>                        <crypto-special>no</crypto-special>                        <carddetect>yes</carddetect>                        <newcamd_port>32101</newcamd_port>                        <priority>round</priority>                </device>        </readers>        <cache>                <emm>10</emm>                <ecm>10</ecm>        </cache>        <httpd>                <server> <!-- Port to accept connections on -->                        <port>9000</port>                        <enabled>yes</enabled>                </server>                <user>                        <name>root</name>                        <password>relook</password>                        <accesslevel>admin</accesslevel>                </user>        </httpd>        <debug>                <level>normal</level>                <type>init</type>                <output>console</output>                <logfile></logfile>                <console_options></console_options>                <file_options></file_options>        </debug>        <newcamdserver>                <enabled>yes</enabled>                <name>cardserv</name>                <deskey>11 12 13 14 15 16 17 18 19 10 11 12 13 14</deskey>                <!-- <userfile>/tmp/users.txt</userfile> -->                <user>                        <name>ip9000</name>                        <password>nlbimage</password>                        <au>on</au>                        <cardlevel>1</cardlevel>                </user>                <user>                        <name>ip9000pip</name>                        <password>nlbimage</password>                        <au>on</au>                        <cardlevel>1</cardlevel>                </user>                <user>                        <name>ip9000rec</name>                        <password>nlbimage</password>                        <au>on</au>                        <cardlevel>1</cardlevel>                </user>                <user>                        <name>ip9002</name>                        <password>nlbimage</password>                        <au>on</au>                        <cardlevel>1</cardlevel>                </user>                <user>                        <name>ip9002pip</name>                        <password>nlbimage</password>                        <au>on</au>                        <cardlevel>1</cardlevel>                </user>                <user>                        <name>ip9002rec</name>                        <password>nlbimage</password>                        <au>on</au>                        <cardlevel>1</cardlevel>                </user>        </newcamdserver></newCSconfig>
<vergeet wat ik heb gezegt dit gaat niet via webif je kunt dan alleen upper of lower selecteren >
Als je NLB webif gebruikt kan je wel kiezen, cardreader A, Cardreader B og beide.
Je hoeft niet aan een boom te hangen om een eikel te zijn.
ik heb via NLB webif gekeken en heb alleen deze optie
- newcs with only upper card slot config is used
- newcs with only lower card slot config is used
- newcs config with regular slot config is used
- newcs config with german slot config is used
- newcs config with nordic slot is used
de 3de doet bij mij helemaal niks
en de rest spreekt voor zich
heb het dus handmatig gedaan en dat werkt
dus selecteer ik optie 3 dan ziet het zo uit
doe ik het handmatig dan heb ik hem zo
Origineel bericht van: oldebroek
Dit klopt idd alleen bij deze versie 88xx niet. (bug) Volgens mij kun dit (bij deze versie) via Webif 1x kiezen en als je dan verder drukt dan heb je pech want dan komt 'both' niet meer terug. Het schijnt ook opgelost te worden als je German Slot kiest maar bij mij werkt dit niet. Probeer nu handmatig maar nu doen ze het helemaal niet meer :D
Bedankt voor je hulp GMan maar het ligt toch ergens anders aan blijkbaar (Heb ik dat???). Inmiddels terug naar 8833 en die heeft hetzelfde probleem. Ik heb nu wel 2x boxkey staan maar toch werkt de bovenste lezer niet. Als ik in de map Data kijk dan zie ik daar de andere XML files staan. Als de XML handmatig in Keys zet dan wordt die weer overschreven als je via WebIf de kaartlezer wilt aanpassen door de newcs.xml uit de map data. Wat ik opmerk is dat de newcs.xml in de map data NIET wordt aangepast als je via Webif bv German kiest. Gekke is dat de kaartlezers het wel doen voor mijn andere box (Share). Ben alweer 1 uur aan het klote en ruzie met mijn vrouw waarom ik niet opsta....
