spaghetto Geplaatst: 19 december 2008 Delen Geplaatst: 19 december 2008 Hallo, Mocht je net als ik gehad heb je dbox niet kunnen flashen via de normale weg dan is er een weg nog,de seriele aansluiting. Ik heb op het internet een tutorial gevonden en deze heb ik zelf uitgeprobeerd(moest wel) en het werkt,alleen is erg langzaam. Hier komt ie en het is in engels.Lsa je slag. Groeten , Spaghetto How To Flash A Dbox2 Using Serial Cable Only. This guide has been written for those who, like myself, found that the only avenue left open to them was to flash their Dbox2 using a serial modem lead, as the normal method of using Image Flashing Assistant (IFA) had not been successful. Make sure before you start this procedure that you print this info out to make it easier to follow and that you place the attached file (u-boot.mot) in the root of C drive. Ignore all quotes "" as they are simply there to simplify matters. Please note that all the input text is "case sensitive" so keep it in lower case only, no CAPITALS. To start with switch off Dbox from the mains and connect it to your PC using serial modem cable only, as this method does not require the use of any network cables or ports. Start up your computer and then start Hyper Terminal by selecting "Start", then "Run" and then type in "hypertrm". This will start Hyper Terminal. Hyper Terminal first asks you to give the new connection a name and an icon, so call the session "dbox" but we can forget about the icon. Click OK. Then when it says "Connect using" select your appropriate com port, usually com1. DO NOT select TCP/IP (Winsock). Then you have to configure the Com port properties, any errors here and the PC will not communicate with the Dbox, so please double check they are as follows:- Bits per second - 9600 Data bits - 8 Parity - None Stop bits - 1 Flow control - Xon/Xoff Press OK to save settings once you have double checked they are as above. Hyper Terminal should now say that it is "connected" in the bottom left hand corner of its window. Now press and hold the "UP" button on your Dbox (not the remote) and turn the power to it back on. Once you see writing like the example given below displayed in the Hyper Terminal window it is safe to release the UP button (normally within seconds). Êdebug: DDF: Calibrating delay loop... debug: DDF: 67.79 BogoMIPS debug: BMon V1.0 mID 01 debug: feID 7a gtxID 0b debug: fpID 5a dsID 01-29.b7.19.07.00.00-d2 debug: HWrev X5 SWrev 0.81 debug: B/Ex/Fl(MB) 32/00/08 WATCHDOG reset enabled debug: &_text 0x10000, &_etext 0x26160, &_data 0x26160, &_edata 0x29c50 debug: &_end 0x347dc, &__stack 0x400000 debug: Memory tests (0x400000 -- 0x2000000) debug: NumberTest: debug: passed debug: MarchTest: debug: passed debug: PermTest: debug: passed dbox2:root> At the prompt type "dl 800000" then press Enter. This message should appear "S record load, offset: 800000" OK, now click on the "Transfer" tab at the top of Hyper Terminal and select "send text file", then when the pop up box appears select "All Files" from the drop down menu at the bottom and then you can negotiate to the location that you have stored the file named "u- boot.mot", for this example we will use the root of C drive. Once you have found it click on it and press "Open" to start the file transfer. At this point you need to find something to do for 45 minutes or so . There is also no on screen verification that it is actually doing anything, but have faith. After the file has been successfully transferred this message should appear:- "dl: start address 0x800000" "dbox2:root >" "dbox2:root >" If so then type in the following:- "chorus 800000" then press Enter. This process starts the file we have just downloaded. We need to stop the attempted connection by pressing the "ctrl" and "c" keys together (ctrl+c) on the keyboard. You need to do this two or three times until the message "Abort" appears. Then type the following:- "loadb 120000 115200" then press Enter. U-boot announces "## Switch Baud rate to 115200 bps and press ENTER...". In Hyper Terminal stop the connection by selecting "Call" then "Disconnect". Click "File" then "Properties" then "Configure" and change the "Bits per second" from "9600" to "115200". Click on OK twice to leave the menus. Select "Call" from Hyper Terminal then "Call" from its menu to reconnect to Dbox. Press Enter on the keyboard to proceed to next step. U-boot announces "## ready for binary (Kermit) download to 0x00120000 at 115200 bps". Click on "Transfer" again on the top of Hyper Terminal and select "Send File". At this point you direct the program to the image that you wish to download into your Dbox. Just use any one of the images available from the download section as they are all "Without Bootloader" already. Once image is selected choose "Kermit" Protocol from the drop down menu at the bottom. Click on "Send". At this point you need to find something to do for another 45 minutes or so . However, this time you can clearly see the progress of the transmitted file within Hyper Terminal and the LCD on the Dbox will show "loading kernel" during the process. After transfer is complete u-boot announces:- "## total size = 0x007E0000 = 8257536 bytes" "## start ADDR = 0x00120000" "## Switch baud rate to 9600 bps and press ESC" In Hyper Terminal stop the connection by selecting "Call" then "Disconnect". Click "File" then "Properties" then "Configure" and change the "Bits per second" back from "115200" to "9600". Click on OK twice to leave the menus. Select "Call" from Hyper Terminal then "Call" from its menu to reconnect to Dbox. Press "Escape" key on the keyboard to proceed to next step. U-boot prompt appears again " = > " so finally type in these instructions:- "protect off 10020000 107fffff" then press Enter. "erase 10020000 107fffff" then press Enter and wait approx 1 minute till it erases all sectors (70 in total). "cp.l 120000 10020000 1f8000" then press Enter. This starts the internal Image Flashing process. Wait approx 2 minutes and "Done" should appear in Hyper Terminal window. Shut down Hyper Terminal program (you need not save anything) unplug Dbox2 from the mains and remove serial lead too. Then apply power to your Dbox2 and hopefully you have just done what you thought was impossible. Well done, you deserve a cuppa. Nokia Dbox1+Amon 5.2 cam + Gregorian Delta Star 90 cm en een nokia Dbox2 erbij. Link naar reactie Delen op andere sites Meer opties om te delen...
Moderator Matchless Geplaatst: 19 december 2008 Moderator Delen Geplaatst: 19 december 2008 en hier dan de U-boot.mot file anders heb je er weinig aan.. Toevallig heb ik een niet meer werkende box hier en zal eens testen of het werkt.. u-boot.zip Een smartphone is een hulpmiddel, geen levensstijl Kijk rond IN de wereld in plaats van voorover gebogen NAAR de wereld. Link naar reactie Delen op andere sites Meer opties om te delen...
spaghetto Geplaatst: 20 december 2008 Auteur Delen Geplaatst: 20 december 2008 Hoi Matchless, Mijn Nokia kon ik niet meer bereiken via de ethernet aansluiting. Ik kon alleen via de rs 232 bereiken. Ik heb er bijna 1,5 uur over gedaan om te flashen. Het is wel gelukt uitendelijk. Ik ben benieuwd naar je bevindingen. Gr.Spaghetto Nokia Dbox1+Amon 5.2 cam + Gregorian Delta Star 90 cm en een nokia Dbox2 erbij. Link naar reactie Delen op andere sites Meer opties om te delen...
Moderator Matchless Geplaatst: 21 december 2008 Moderator Delen Geplaatst: 21 december 2008 Bij mij is het balen. Ik heb 2 decoders en beide doen niet veel meer . 1 decoder heeft het altijd gedaan maar geeft nu alleen een verlicht display zonder info. Ook heb ik hier geen seriele of netwerk toegang meer de 2e geeft wel info maar laat eerst het imfo scherm op het display zien en daarna lade... Via de seriele poort zegt hij dat er 32mB ram inzit maar dat er een onbekende flash chip inzit. dit in een continu loop. Dus ik kan nu niks meer testen..eerst een box proberen te repareren. Een smartphone is een hulpmiddel, geen levensstijl Kijk rond IN de wereld in plaats van voorover gebogen NAAR de wereld. Link naar reactie Delen op andere sites Meer opties om te delen...
spaghetto Geplaatst: 22 december 2008 Auteur Delen Geplaatst: 22 december 2008 Dat is echt balen. Bij mij ging het feilloos.Ik moest wel echt heel lang wachten,precies zoals in de tutorial. Ik gebruik Vista en heb hiervoor hyper terminal ergens gedownload en gebruikt,probleenloos. Wat jij te zien krijgt via de seriele poort,heb ik nooit gehad,waarschijnlijk is de flash geheugen defect?? Nokia Dbox1+Amon 5.2 cam + Gregorian Delta Star 90 cm en een nokia Dbox2 erbij. Link naar reactie Delen op andere sites Meer opties om te delen...
BB2000 Geplaatst: 23 december 2008 Delen Geplaatst: 23 december 2008 @matchless, Is het niet mogelijk om de box opnieuw in debug mode te krijgen?? Voor mij was dit het grootste probleem. Mijn (Philips) DBOX heeft me heel wat uurtjes gekost voordat dit lukte.. Is je 2e box ook dood ten aanzien van UTP/ethernet? Reageerd ie op een ping? Grt, Marcel Cable rules, only for fools... Link naar reactie Delen op andere sites Meer opties om te delen...
Moderator Matchless Geplaatst: 23 december 2008 Moderator Delen Geplaatst: 23 december 2008 de ene box doet helemaal niks de andere geeft dit in het terminal: Citaat: debug: DDF: Calibrating delay loop... debug: DDF: 67.79 BogoMIPS debug: WATCHDOG RESET debug: BMon V1.0 mID 01 debug: feID 7a gtxID 0b debug: fpID 5a dsID 01-21.27.1f.07.00.00-cd debug: HWrev X5 SWrev 0.81 debug: B/Ex/Fl(MB) 32/00/08 WATCHDOG reset enabled dbox2:root> debug: BOOTP/TFTP bootstrap loader (v0.3) debug: debug: Transmitting BOOTP request via broadcast debug: Given up BOOTP/TFTP boot boot net failed Flash-FS bootstrap loader (v1.5) Found Flash-FS superblock version 3.1 Found file /root/platform/nokia-dbox2/kernel/os in Flash-FS debug: Got Block #0032 will verify ELF image, start= 0x800000, size= 158624 verify sig: 262 Branching to 0x40000 U-Boot 1.1.1 (TuxBox) (May 9 2004 - 12:07:48) CPU: PPC823ZTnnA at 67.200 MHz: 2 kB I-Cache 1 kB D-Cache *** Warning: CPU Core has Silicon Bugs -- Check the Errata *** Board: DBOX2, Nokia, BMon V1.0 Watchdog enabled I2C: ready DRAM: 32 MB FLASH: ## Unknown FLASH on Bank 0 - Size = 0x00000000 = 0 MB *** failed *** ### ERROR ### Please RESET the board ### en dat in een loop.. Een smartphone is een hulpmiddel, geen levensstijl Kijk rond IN de wereld in plaats van voorover gebogen NAAR de wereld. Link naar reactie Delen op andere sites Meer opties om te delen...
BB2000 Geplaatst: 24 december 2008 Delen Geplaatst: 24 december 2008 Size = 0x00000000 = 0 MB Hmm, ziet er niet leuk uit om zoiets te lezen.. Zou een defecte flashrom kunnen inhouden. Wil zelf deze conclusie nog niet trekken, zou volgende url eens nalopen en kijken of je hiermee je probleem kunt oplossen (wel in Duits.) http://forum.digitalfernsehen.de/forum/showthread.php?t=77582 Hier wordt tegen de zelfde storing van 0MB aangelopen.. Ben erg benieuwd of je er mee verder komt.. Hoor graag van je! Cable rules, only for fools... Link naar reactie Delen op andere sites Meer opties om te delen...
digiruud Geplaatst: 16 april 2009 Delen Geplaatst: 16 april 2009 Origineel bericht van: spaghetto Hallo, Mocht je net als ik gehad heb je dbox niet kunnen flashen via de normale weg dan is er een weg nog,de seriele aansluiting. Ik heb op het internet een tutorial gevonden en deze heb ik zelf uitgeprobeerd(moest wel) en het werkt,alleen is erg langzaam. Hier komt ie en het is in engels.Lsa je slag. Groeten , Spaghetto How To Flash A Dbox2 Using Serial Cable Only. This guide has been written for those who, like myself, found that the only avenue left open to them was to flash their Dbox2 using a serial modem lead, as the normal method of using Image Flashing Assistant (IFA) had not been successful. Make sure before you start this procedure that you print this info out to make it easier to follow and that you place the attached file (u-boot.mot) in the root of C drive. Ignore all quotes "" as they are simply there to simplify matters. Please note that all the input text is "case sensitive" so keep it in lower case only, no CAPITALS. To start with switch off Dbox from the mains and connect it to your PC using serial modem cable only, as this method does not require the use of any network cables or ports. Start up your computer and then start Hyper Terminal by selecting "Start", then "Run" and then type in "hypertrm". This will start Hyper Terminal. Hyper Terminal first asks you to give the new connection a name and an icon, so call the session "dbox" but we can forget about the icon. Click OK. Then when it says "Connect using" select your appropriate com port, usually com1. DO NOT select TCP/IP (Winsock). Then you have to configure the Com port properties, any errors here and the PC will not communicate with the Dbox, so please double check they are as follows:- Bits per second - 9600 Data bits - 8 Parity - None Stop bits - 1 Flow control - Xon/Xoff Press OK to save settings once you have double checked they are as above. Hyper Terminal should now say that it is "connected" in the bottom left hand corner of its window. Now press and hold the "UP" button on your Dbox (not the remote) and turn the power to it back on. Once you see writing like the example given below displayed in the Hyper Terminal window it is safe to release the UP button (normally within seconds). Êdebug: DDF: Calibrating delay loop... debug: DDF: 67.79 BogoMIPS debug: BMon V1.0 mID 01 debug: feID 7a gtxID 0b debug: fpID 5a dsID 01-29.b7.19.07.00.00-d2 debug: HWrev X5 SWrev 0.81 debug: B/Ex/Fl(MB) 32/00/08 WATCHDOG reset enabled debug: &_text 0x10000, &_etext 0x26160, &_data 0x26160, &_edata 0x29c50 debug: &_end 0x347dc, &__stack 0x400000 debug: Memory tests (0x400000 -- 0x2000000) debug: NumberTest: debug: passed debug: MarchTest: debug: passed debug: PermTest: debug: passed dbox2:root> At the prompt type "dl 800000" then press Enter. This message should appear "S record load, offset: 800000" OK, now click on the "Transfer" tab at the top of Hyper Terminal and select "send text file", then when the pop up box appears select "All Files" from the drop down menu at the bottom and then you can negotiate to the location that you have stored the file named "u- boot.mot", for this example we will use the root of C drive. Once you have found it click on it and press "Open" to start the file transfer. At this point you need to find something to do for 45 minutes or so . There is also no on screen verification that it is actually doing anything, but have faith. After the file has been successfully transferred this message should appear:- "dl: start address 0x800000" "dbox2:root >" "dbox2:root >" If so then type in the following:- "chorus 800000" then press Enter. This process starts the file we have just downloaded. We need to stop the attempted connection by pressing the "ctrl" and "c" keys together (ctrl+c) on the keyboard. You need to do this two or three times until the message "Abort" appears. Then type the following:- "loadb 120000 115200" then press Enter. U-boot announces "## Switch Baud rate to 115200 bps and press ENTER...". In Hyper Terminal stop the connection by selecting "Call" then "Disconnect". Click "File" then "Properties" then "Configure" and change the "Bits per second" from "9600" to "115200". Click on OK twice to leave the menus. Select "Call" from Hyper Terminal then "Call" from its menu to reconnect to Dbox. Press Enter on the keyboard to proceed to next step. U-boot announces "## ready for binary (Kermit) download to 0x00120000 at 115200 bps". Click on "Transfer" again on the top of Hyper Terminal and select "Send File". At this point you direct the program to the image that you wish to download into your Dbox. Just use any one of the images available from the download section as they are all "Without Bootloader" already. Once image is selected choose "Kermit" Protocol from the drop down menu at the bottom. Click on "Send". At this point you need to find something to do for another 45 minutes or so . However, this time you can clearly see the progress of the transmitted file within Hyper Terminal and the LCD on the Dbox will show "loading kernel" during the process. After transfer is complete u-boot announces:- "## total size = 0x007E0000 = 8257536 bytes" "## start ADDR = 0x00120000" "## Switch baud rate to 9600 bps and press ESC" In Hyper Terminal stop the connection by selecting "Call" then "Disconnect". Click "File" then "Properties" then "Configure" and change the "Bits per second" back from "115200" to "9600". Click on OK twice to leave the menus. Select "Call" from Hyper Terminal then "Call" from its menu to reconnect to Dbox. Press "Escape" key on the keyboard to proceed to next step. U-boot prompt appears again " = > " so finally type in these instructions:- "protect off 10020000 107fffff" then press Enter. "erase 10020000 107fffff" then press Enter and wait approx 1 minute till it erases all sectors (70 in total). "cp.l 120000 10020000 1f8000" then press Enter. This starts the internal Image Flashing process. Wait approx 2 minutes and "Done" should appear in Hyper Terminal window. Shut down Hyper Terminal program (you need not save anything) unplug Dbox2 from the mains and remove serial lead too. Then apply power to your Dbox2 and hopefully you have just done what you thought was impossible. Well done, you deserve a cuppa. Werkt bij mij perfect Vu plus ultimo 4K Link naar reactie Delen op andere sites Meer opties om te delen...
