Bigbrothers2000 Geplaatst: 29 januari 2009 Delen Geplaatst: 29 januari 2009 Probeer dit eens,,,,,,,,,,,, <newCSconfig> <readers name="Card Readers"> <device> <name>lower</name> <type>Sci</type> <node>/dev/sci0</node> <export>yes</export> <enabled>yes</enabled> <blocksa>No</blocksa> <blockua>No</blockua> <blockga>No</blockga> <!-- <boxkey>0000000000</boxkey> --> <PTShandshake>no</PTShandshake> <crypto-special>no</crypto-special> <carddetect>yes</carddetect> <newcamd_port>32100</newcamd_port> <priority>round</priority> <sid> <allow> <!-- valid value for id are: 4 numbers, if the service id is 3 numbers, add a 0 infront of it. --> <id></id> </allow> <deny> <!-- valid value for id are: 4 numbers, if the service id is 3 numbers, add a 0 infront of it. --> <id></id> </deny> </sid> </device> <device> <name>upper</name> <type>Sci</type> <node>/dev/sci1</node> <export>yes</export> <enabled>yes</enabled> <blocksa>No</blocksa> <blockua>No</blockua> <blockga>No</blockga> <!-- <boxkey>0000000000</boxkey> --> <PTShandshake>no</PTShandshake> <crypto-special>no</crypto-special> <carddetect>yes</carddetect> <newcamd_port>32101</newcamd_port> <priority>round</priority> <sid> <allow> <!-- valid value for id are: 4 numbers, if the service id is 3 numbers, add a 0 infront of it. --> <id></id> </allow> <deny> <!-- valid value for id are: 4 numbers, if the service id is 3 numbers, add a 0 infront of it. --> <id></id> </deny> </sid> </device> </readers> <radegastserver> <!-- valid value for enable are: 0,1 - Enable or Disable radegast server. --> <enabled>no</enabled> <!-- valid value for port are: 0,65535 - Which port to listen for incomming connections. --> <port>10001</port> <!-- valid value for allow are: ALL - Not active yet. --> <allow> <hostname>127.0.0.1</hostname> </allow> </radegastserver> <cache> <emm>10</emm> <ecm>10</ecm> </cache> <debug> <level>verbose</level> <type>init</type> <output>all</output> <logfile></logfile> <console_options></console_options> <file_options></file_options> <udp_host>JE IPBOX IP HIER SHRIJVEN</udp_host> <udp_port>1000</udp_port> <udp_options></udp_options> <tcp_port>3001</tcp_port> <tcp_options></tcp_options> </debug> <newcamdserver> <enabled>yes</enabled> <name>bla</name> <deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey> <userfile>/tmp/users.txt</userfile> <user> <name>ip9000</name> <password>nlbimage</password> <au>on</au> <sidoverride>off</sidoverride> <spider>No</spider> <rate>2</rate> </user> <user> <name>ip9000rec</name> <password>nlbimage</password> <au>on</au> <sidoverride>off</sidoverride> <spider>No</spider> <rate>2</rate> </user> <user> <name>ip9000pip</name> <password>nlbimage</password> <au>on</au> <sidoverride>off</sidoverride> <spider>No</spider> <rate>2</rate> </user> <user> <name>ip9002</name> <password>nlbimage</password> <au>on</au> <sidoverride>off</sidoverride> <spider>No</spider> <rate>2</rate> </user> <user> <name>ip9002rec</name> <password>nlbimage</password> <au>on</au> <sidoverride>off</sidoverride> <spider>No</spider> <rate>2</rate> </user> <user> <name>ip9002pip</name> <password>nlbimage</password> <au>on</au> <sidoverride>off</sidoverride> <spider>No</spider> <rate>2</rate> </user> <user> <name>dummy</name> <password>dummy</password> <au>on</au> <allow>lower</allow> <!--Use this just when you want give free just some readers to your Users --> <allow>upper</allow> <!--Use this just when you want give free just some readers to your Users --> </user> <user> <name>dummy</name> <password>dummy</password> <au>on</au> </user> </newcamdserver> </newCSconfig> Link naar reactie Delen op andere sites Meer opties om te delen...
plex Geplaatst: 30 januari 2009 Auteur Delen Geplaatst: 30 januari 2009 Bedankt ik ga het weer eens proberen. Link naar reactie Delen op andere sites Meer opties om te delen...
wimsel Geplaatst: 13 februari 2009 Delen Geplaatst: 13 februari 2009 Origineel bericht van: Bigbrothers2000 Origineel bericht van: plex Moet je newcs in dezelfde dir zetten als de mgcamd? Alleen de xml van de nescs aanpassn en geen aanpassingen in de mgcam? ipbox=var/tuxbox/config/newcs.xml deze moet je configureren voor je users(als je niet lukt stuur naar mij en ik pas het voor je aan) en op je dreambox, var/keys denk ik daar is je newcamd.list en hier je login gegevens invullen wat je hebt ingevult in je newcs.xml mvg Zo heb in mijn IPboxen ook ingesteld, maar heb nu het probleem dat op beide boxen het beeld stteds even stil staat en na enige tijd de melding: no service. Heb beide boxen in smb wel een andere naam gegeven. Moet ik nog meer wijzigen? Dreambox 7000s, Reelbox Avantgarde 1, Reelbox Avantgarde 2, NetClient, 2*HTPC met openelec Link naar reactie Delen op andere sites Meer opties om te delen...
goofy17 Geplaatst: 15 februari 2009 Delen Geplaatst: 15 februari 2009 Probeer je IP box eens te benaderen in explorer via ipadres:9000 Je komt dan in een fraai menu, waar je gemakkelijk users kunt toevoegen Link naar reactie Delen op andere sites Meer opties om te delen...
