Gast Geplaatst: 3 mei 2002 Delen Geplaatst: 3 mei 2002 Is er al bekend wanneer er weer nieuwe firmware uitkomt???????? mvg dirk1 <img border="0" title="" alt="[Glimlach]" src="images/icons/smile.gif" /> <img border="0" title="" alt="[Glimlach]" src="images/icons/smile.gif" /> Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 3 mei 2002 Delen Geplaatst: 3 mei 2002 Er is melding van een beta firmware, maar ik heb hem nog niet gevonden. 1. IRD status of Beta version in May 3 2002 (1) system id : 206 (2) loader version : A3.06 (3) device version : v4.3.50 (4) application version : BETA-JPC 4.57.28 (5) last update : May 03 2002 2. Improvements of this version (1) There was a picture filckering problem in case of more than 1 hour time shifting. It will be enhanced. (2) The maximum duration for the copy function of the recorded file was 2 hours. It is fixed. (3) The VCR bypass function is modifiled due to the request of non-scart market. There is an added menu item of in Main menu -> System Setting -> A/V Output Setting -> VCR Scart Type. If you select "Standard", the TV/Sat key will work as the same way of the previous version. It is for scart market such as europe. If you select "External A/V", pressing the TV/Sat will switch the TV video output to VCR input unconditionally. This is for non-scart market. (4) There was a problem in IRD-to-IRD downloading which is in the menu of Main menu -> Installation. It is fixed. (5) The numeric display of signal level and quality in some installation menus is added. (6) The extended epg in the info box was not re-gathered while the event changes in the same channel. It is fixed. (7) The service name in the EPG was updated every several seconds and it was shown like flickering. It is fixed. ( The copy function of the recorded file failed in case of signla unlocking state. It is fixed. CU Urkie Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 8 mei 2002 Delen Geplaatst: 8 mei 2002 op de tf site nw firmware 6-5 gr rich Link naar reactie Delen op andere sites Meer opties om te delen...
