Snoopy Geplaatst: 21 januari 2009 Geplaatst: 21 januari 2009 PAS OP: VOOR INSTALLATIE UITVOEREN: - Torrent client is now by default Transmission (btpd removed) **** IMPORTANT NOTE: Please ensure completion with previous downloads with BTPD, as new Transmission client cannot inherit previous downloads Dus eerst je torrents 100% af laten maken en dan pas de update uitvoeren ! . Date:21 January 2009 Firmware Version: 01-17-090116-15-POP-402-000 Release Note: 1. Requires NMT apps 00-17-090115-15-POP-402 2. Browser / System - Improvement on font engine character rendering (30% speed up) - faster navigation on local drives - Use numeric key to input item number to jump to the page where item is located - Improved fileplayer speed - Hebrew translation added - Fixed HDMI display output blackout issue for auto EDID - Discrete RC (Logitech) scancode fix - Updated network share and webservices language packs. - Removed EXT2 option for NMT installation - Note: due to long term reliability issue with EXT2 on device that is frequently turned off abruptly - Additional symbols can be input from "1" key - HTTP download manager (only works with links with special "download" attributes. - File player hide Recycle Bin folder - Fixed 'TV MODE' + '3' key handling bug - Fixed recovery kernel no red screen displayed - Browser image caching fix, should fix some YAMJ crashes or no image issue. - Fixed HDD spin-up during standby - Fixed slow loading of HTML pages 3. Web Services - New UI - customizable icon feature with browse image utility (need NMT apps) - bug fixes on customizable service icon with browse feature. - Web Services page modification - Fixed a "save/remove service" bug - Now able to customise JPG/BMP icon - Fixed slow IR response while playback Internet Radio - Immediate response to STOP during Internet video streaming - Fine-tune Web Service UI 4. Network - Improved SMB server startup time - Improved browsing time for SMB client - Atheros USB WiFi stability fixes - Fixed SMB client hostname resolution picked up wrong IP address from the IP list - Fixed file copy failed from HDD to SMB/NFS with names containing whitespace - Fixed UPnP AV server playall issue broken in previous release - Fixed Samba server halts after device name change - Torrent client is now by default Transmission (btpd removed) **** IMPORTANT NOTE: Please ensure completion with previous downloads with BTPD, as new Transmission client cannot inherit previous downloads. - Fixed torrent schedule page not working - Fixed occasionally newly created SMB/NFS shares doesn't show up in media source list - Atheros USB WiFi added support for TP-Link v2 stick - Fixed persistent private IP when DHCP server unavailable (e.g. cross-cable connection etc) 5. Playback - Bookmark/resume for single playback - 10 bookmarks available now - Press stop to bookmark the last video playback - Press enter / play with focus on bookmarked clip to resume - Press "0" to start from beginning of clip - Auto framerate synchronisation - Framerate sync function in ISO playback, only for 50,60Hz modes (PAL/NTSC) - switch to NTSC(60Hz) when selected mode not applicable.(previously, it will follow TV mode selected) - Use 59.94 for NTSC when matching content detected. - Fixed incorrect data shown on infobar. - Fixed after ISO playback, screen goes blank when framerate sync kicks in - Improved info display - Disable incorrect video MPEG1/2 VBR display. - Fixed incorrect framerate info for video playback (*.mov, *.mp4). - Fixed video bitrate calculation error (less 1 packet every second) - Modified infobar UI (height, spacing and text displayed) - Fixed info bar losing text after paused - Improved accuracy of mpeg1/2 bitrate information - Photo app - Fixed JPEG (PNG / TIFF transcode) from myiHome server cannot be displayed - Fade-In Fade-out effect added for photo transition - Enable large jpeg rotation. (downscale before rotate) - Fixed faded color for jpeg at 360-deg rotation - TV Type setting for DVD playback - the TV type setting is now working for DVD video playback (4:3 and 16:9 only, 16:10 will treat as 16:9) - DVD Menu - new popup menu if MENU key on PCH remote controller is pressed - user can select to jump to ROOT, TITLE, CHAPTER.... etc from the menu - Modified progressive zoom and pan in ISO/IFO playback - Removed up/down keys as prev/next track/td> - VCD *.DAT playback fixed using soft demux - Fixed "repeat" keypress in myiHome when playback audio caused picture playback to halt - Improved handling of MKV H.264 profile and vlevel. - Fixed cannot stream MPEG from UPnP AV server, liveTV - Fixed .pls file unable to start when playback locally (HDD/SMB/NFS) - *.m3u playlist supported. - Fixed TS with stream6 as teletext playback cause out of memory - Fixed MKV H264 L4.1 pixelated video issue 6. Subtitle - Fixed Hebrew SRT subtitle containing invalid character - Fixed subtitle parsing with BOM (UTF8 support only) - Thai subtitle support - Fixed wrong character rendered in Thai subtitle - Changed default subtitle font size to 28 and Y offset to 10 - Exception handling in SSA subtitle parsing - Slight adjustment of subtitle position NMT Apps Version:00-17-090115-15-POP-402 Release Note: 1. Minimum firmware version to use this NMT App is 00-17-090116-15-POP-402-000 2. Improved on samba client browsing time and server boot up time 3. Fixed occasional slow samba response 4. Upgraded to nzbget 0.51 5. Upgraded to nzbgetweb 1.2 (Categories can be modifed in /mnt/syb8634/nzbgetweb/setting.php5) 6. Various Casgle fixes 7. Fixed FTP password saving 8. Improved Setup Page loading time 9. Remove btpd, using Transmission as default BT client 10. Fixed sometimes unable to access casgle web ui 11. Fixed HDD spin-up during standby Note:Unzip into the root of your USB thumbdrive. Browse to usbupdate.html to update. Please DO NOT power off the unit during firmware update, as it will render your unit inoperational.
Snoopy Geplaatst: 21 januari 2009 Auteur Geplaatst: 21 januari 2009 En ja ja ja, hoera, de PCH hervat nu een film vanaf de positie waarop deze is gestopt. Weliswaar met een klein hikje maar dit is al een hele verbetering.
michel130 Geplaatst: 21 januari 2009 Geplaatst: 21 januari 2009 hopelijk is idd het probleem verholpen dat de hdd opeens op spint uit standby modus. Bedankt voor de info, even erin zetten... Dreambox 7000S & 500 & 800 - Maxtor 80GB en Samsung 500GB - USBstick Swap - schotel 80 & 110cm - Moteck SG2100 - lnb titanium 0,2 db & duo lnb - openPLI - Satje07 settings - cccam 2.1.4
Jean-Claude Geplaatst: 21 januari 2009 Geplaatst: 21 januari 2009 hmm - ga toch even een weekje of 2 de kat uit de boom kijken, en de reacties lezen op het NMT forum. de vorige versie heb ik er terug af moeten zwieren omdat TS bestanden er abrubt met ophielden, en bepaalde ISO's niet meer wilden afspelen. lees wel iets van TS bestanden maar met teletext ? de popcorn kan de teletext in een TS toch niet gebruiken om bvb de ondertitels op 888 te laten zien ? DAT zou een serieuze verbetering zijn, nu moet ik nog steeds aparte SRT bestanden aanmaken ....... DreamBox 8000+Xtrend ET10000+Gigablue UHD 4K, openPLi, CCcam, CD+TVV kaarten (gene zever), wavefrontier T90, EMP Centauri 33/12 multiswitch en VEEL te weinig slaap.
Jürgen Geplaatst: 22 januari 2009 Geplaatst: 22 januari 2009 Origineel bericht van: michel130 hopelijk is idd het probleem verholpen dat de hdd opeens op spint uit standby modus. Volgens de Release Notes hierboven is dit probleem verholpen. Zie onder punt 2 de één na laatste regel: - Fixed HDD spin-up during standby MacBook Air M2 2022 - iPad Air 2021 - Iphone XR - Apple TV 4 2021
Snoopy Geplaatst: 22 januari 2009 Auteur Geplaatst: 22 januari 2009 Helemaal lekker is die firmware niet. - Nieuwe torrents die met deze firmware gestart zijn, begonnen en toen gestopt willen deels niet meer het downloaden hervatten - torrents vreten op een of andere manier een gigantische hoeveelheid download capaciteit, veel meer dan de som van het totaal.
Snoopy Geplaatst: 22 januari 2009 Auteur Geplaatst: 22 januari 2009 Hmmm, qua torrents is deze firmware HELEMAAL niet lekker. Nu wil helemaal NIETS meer opstarten, ook nieuwe niet. Ik ga terug naar de vorige firmware.
Jean-Claude Geplaatst: 22 januari 2009 Geplaatst: 22 januari 2009 awel, ik heb de nieuwe versie er toch maar opgezet, en ik moet zeggen dat dit behoorlijk meevalt : ik heb nog geen enkel defect kunnen vinden, alles wat ik aanlever wordt terug afgespeeld, ik kan probleemloos al mijn drives browsen, ISO's en IMG bestanden spelen normaal af, ik merk zelfs een duidelijke verbetering bij het afspelen van NTSC materiaal door gebruik te maken van de 'resyncing' optie. Torrents en Casgle gebruik ik niet, HD spint dus ook niet op. enig minpuntje is dat MJPEG bestanden nog steeds niet ondersteund worden, maar bon, dat stond dus ook niet in de update lijst. er wordt veel geklaagd over de nieuwe defaults voor de ondertitels, maar daar heb ik geen probleem mee. Op mijn installatie komen die grotere ondertitels beter tot hun recht. nee, petje af, ben dik tevreden deze keer. DreamBox 8000+Xtrend ET10000+Gigablue UHD 4K, openPLi, CCcam, CD+TVV kaarten (gene zever), wavefrontier T90, EMP Centauri 33/12 multiswitch en VEEL te weinig slaap.
Snoopy Geplaatst: 23 januari 2009 Auteur Geplaatst: 23 januari 2009 Het lijkt erop dat bij het herstarten van torrents de boodschap 'verifying' (?) verdwenen is en dat je wat meer geduld moet hebben.
naitsirhc Geplaatst: 24 januari 2009 Geplaatst: 24 januari 2009 Het zou fijn zijn, dat geluidsbestanden uit wmvhd digitaal doorgestuurd worden naar de receiver. Kan er digitaal geluid weergegeven door de receiver. Und TschjuB
winwiz Geplaatst: 24 januari 2009 Geplaatst: 24 januari 2009 Origineel bericht van: naitsirhc Het zou fijn zijn, dat geluidsbestanden uit wmvhd digitaal doorgestuurd worden naar de receiver. Kan er digitaal geluid weergegeven door de receiver. Dat is geen probleem echter de meeste receivers bakken er niets van omdat ze geen wmapro kunnen decoderen Synology DS414 + DS1815+(8GB) + iPad Pro 10.5 64Gb (iOS 11) + iPhone 7+ 128 GB (iOS 11) + MacbookPro 15" 2016 (MacOS High Siera 10.13) + Apple Watch Series 3 (WOS 4) + Apple TV3 + Apple TV4 + Nvidia Shield + Microsoft Gecertificeerd.
naitsirhc Geplaatst: 24 januari 2009 Geplaatst: 24 januari 2009 ai...dat had ik niet zo in de gaten..... Dat zal ook het geval met mijn HK zijn Und TschjuB
winwiz Geplaatst: 24 januari 2009 Geplaatst: 24 januari 2009 Maar waarom zet je deze wmv bestanden dan niet om naar mkv? Er staat hier een tooltje die .wmv met wmapro audio omzet naar .mkv waarin de originele videostream zit en omgezette wmapro naar AC3 geluidstream (640kb) Resultaat is dus een .mkv die je gewoon kunt afspelen met 5.1 geluid (AC3 met hoge bitrate) http://www.networkedmediatank.com/showthread.php?tid=11991&page=1 Ik zet een film van 8 gb om in ongeveer 5 minuten. Synology DS414 + DS1815+(8GB) + iPad Pro 10.5 64Gb (iOS 11) + iPhone 7+ 128 GB (iOS 11) + MacbookPro 15" 2016 (MacOS High Siera 10.13) + Apple Watch Series 3 (WOS 4) + Apple TV3 + Apple TV4 + Nvidia Shield + Microsoft Gecertificeerd.
naitsirhc Geplaatst: 25 januari 2009 Geplaatst: 25 januari 2009 Kheb het al een keer geprobeerd, maar werkte toen niet...kzal hem nogmaals proberen. Kijken oftie nu wel doet, met de nieuwe firmware Und TschjuB
naitsirhc Geplaatst: 25 januari 2009 Geplaatst: 25 januari 2009 Hij doet het nu wel. Ik stop er een WMVHD file van 3,26gb in het progje en krij een geconverteerd bestandje van 126MB. Dit zal alleen het geluidsbestand zijn. Moet dit geluidsbestand weer ingevoegd worden in de originele wmvhd bestand? Und TschjuB
