Hoi lau, linken naar de TDT-image mag niet omdat er -waarschijnlijk- copyrighted bestanden in zitten.
Op het topfield forum is e.e.a. hierover te vinden, op Google en natuurlijk via persoonlijke contacten.
Mut@nt HD51 OpenPli 6 | VU+ Duo | Topfield TF7710HD PVR (Enigma2 / HDMU)
Astra 19.2 | Astra 23.5 | Astra 28.2/5 | Hotbird 13.0 | Eurobird 9.0 | Digitenne
OSCam
  • Reacties 274
Geplaatste afbeeldingen
  • 2 weken later...
Er is een New Release 0.4.1.
Release 0.4.1
The provided image is based on the Linux operating system and includes
the Enigma2 PVR application. Please read this document carefully before
installing the image.
New features and bugfixes (since 0.4.0)
+ Feature: added support for USB automount (autofs)
USB devices are mounted to /autofs/sdb* and /autofs/sdc*.
The directory appears after first access and is unmounted
after 5 seconds without access.
+ Change: introduced support for storing the VFD configuration in the EEPROM
and improved the handling of GMT offset and Daylight Saving Time
(the date does not have to be set to 1970 after booting)
+ Change: reverted the guard time for shutdown prior to timer events and
the wakeup guard time (because the smaller values were too short
when several plugins are started during power-on sequence)
+ Change: improved the animation on the VFD during the Enigma2 start
+ Fix: fixed the problem with starting to record while playback or
timeshift is active
+ Fix: improved forced shutdown (when the box hangs it should be possible
to shutdown the box by pressing the power off button for 5 seconds
instead of unplugging the box from the mains)
+ Fix: added tuxtxt configuration file and a better readable font
+ Fix: added skin_user.xml to prevent green screen on teletext subtitles
+ Fix: recognition and playback of files with the extension .rec
+ Fix: fixed the issue with keyboard blocking the input from remote control
(now both the keyboard and the RC can be used simultaneously)
gr Lau
Gast satbird2002
helaas nog geen CAM support balen cry deze fw gaat het toch echt worden zodra het gefixt is.
  • 2 weken later...
Dat geen CAM-support wordt inmiddels flink irritant. Ik heb inmiddels besloten om me niet meer met Enigma bezig te houden totdat CAM-support voor de SECA-services van CanalDigitaal werkt.
OSCam
Origineel bericht van: Hadrian
Ik heb het anders opgelost... Heb een DM800 gekocht met enigma support ;-)..
Toppie is nu al erbij...
  • 3 weken later...
Heb Enigma2 geladen in mijn Topfield, het werkt fijn als je er even mee gaat stoeien in het menu. Werkt sneller dan de oude firmware en ik ben zeer tevreden. Bedankt TEAM DUCKTALES.Ik hoop dat er meer nieuws blijft komen voor deze firmware.
Ik heb een vraag, ik heb nu 4 sats. Hotbird, Astra, Astra3A en Astra28gr. Ik heb gisteren kanalen laten zoeken maar krijg of vindt niet de gewenste kanalen met name BBC enzv voor de Astra die op 28graden zit.
Kan mij iemand even uitleggen hoe en wat ik in het menu moet veranderen of instellen bij het zoeken van deze kanalen?
alvast bedankt
gr Lau
Kan mij iemand !! helpen met het afstellen of instellen bij Enigma2 config. om nieuwe zenders te laten zoeken??
Met name bij Astra 2 ???
gr Lau
Je moet deze settingslijst erin zetten, dan heb je meteen de Astra2 erbij.
Je kan in satellites.xml transponderinfo toevoegen en wijzigen.
OSCam
Nee, niet met Topset. Dat werkt alleen voor Topfield-firmware.
Je kan het er met FTP inzetten, of vanaf de command-line als je daar een beetje handig mee bent.
OSCam
  • 2 weken later...
Teamducktales heeft weer een nieuwe relaese.
es gibt Neuigkeiten: TeamDucktales war fleißig und hat das Release 4.5
rausgebracht!
Danke an das Team Ducktales
Cool! Interessante Verbesserungen:
+ Feature: o fast forward works at speeds higher than 8x
o rewind now works
at a constant speed (looks like 4x)
+ Change: enabled yellow button for subservice selection
+ Change: enabled resolution 576i in videomode plugin
+ Change: enabled frame rates 23.97, 24, 25, 29.97 and 30 Hz for
1080p in videomode
plugin
+ Change: enabled the **** < and > for volume control if no menus
are
shown
IMPORTANT: In order to
activate this feature do not use
"keepsettings"
in the ini file. Otherwise the mapping will not
be installed. If you
install with "keepsettings" and would like
to use volume **** then
replace the file
/usr/local/share/enigma2/keymap.xml with the one from the
corresponding folder of
rootfs.tar.gz.
+ Change: enabled media highway EPG
+ Fix: improved HDMI handling to resolve issues with some LCDs
+ Fix: improved resolution selection (green button)
+ Fix: fixed the fast forward behavior for TS playback at speeds lower
than 16x
+ Fix: fixed the fast forward and seek behavior for MKV playback
gr Lau
En, doen de kanalen van CDS het al op deze versie? Gewoon, met het bijbehorende kaartje in een cam (van Aston bijv.)?
OSCam
Tja, zou gek zijn van niet :D :
Zou er wél EPG zijn op onze zenders maar geen beeld crazy ?
Groeten,
Saterke
