binnen halen http://enigma2.sifteam.eu/index.php?dir=
ppaap
ENIGMA 2 for all DGStation products:
- cuberevo-mini-fta (cuberevo-200hd)
- cuberevo-250hd (ipbox-91hd)
- cuberevo-mini (ipbox-900hd)
- cuberevo-mini2 (ipbox-910hd, cuberevo-3000hd, madtek-3000hd)
- cuberevo-2000hd
- cuberevo-9500hd (cuberevo-7000hd)
- cuberevo (ipbox-9000hd rel1 and rel2)
First boot take a little bit much more than a normal boot, so wait until you can see the bandeau bar (the one with infos on current channel) on the tv screen.
HISTORY:
release 0.5.0:
- fixed a bug on rebooting the system
- better CI cams handling
- support for upper and lower CI slots on the current live tuner, no more needs to put the cam only on the upper one smile
- added new dvdplayer
- support for timeshift
- fixed alpha blending colour on images
- updated e2 cvs to 30/05/2009
- fixed fstab auto mounting for hdd
- vsftpd log on file disabled by default
- fixed a bit keymap for 250hd/200hd, audio subtitles now is mapped
- added autoload of epg (using myepg now the file will be loaded automatically at enigma2 restarts)
- some fixes on mediaplayer for some multimedia files
- many fixes all around for better stability, now i think most part of drivers are done
- updated arabic language
I know there are still some bugs that sometimes break our balls too much, but i'm trying to solve all, just wait and hope
the funniest thing is finding those bugs laugh
I would like to thank all people around Enigma2 for cuberevo, many teams are making really great stuff, i like how cuberevo
community is going on, i think this is the spirit our box should be!
I would like also to thank people making really great plugins, we will win all together! laugh
See you on next release.
  • Reacties 39
heb de nieuwe soft er ingezet , en voorlopig blijft ie stabiel.
ben op zoek naar een file voor incubus 086 in te zetten. Want standaard staan er geen emulators in en men kan ze niet downloaden
herman
dreambox 7000, dreambox 500, dreambox 800, VU duo, Vizyon 820HD
hmmm das apart van een sif team toch?
Hoe zet je deze op een USB stick?
Als linux formatteren en dan kopieren?
Gr,
baZ
There is nothing wrong with having a strong opinion... if it comes with an open mind!
Origineel bericht van: herman9
herman
Ik heb hem er ingezet met de kabel maar heb alleen Hotbird,weet
iemand hoe ik astra er in kan zetten?
groeten
Aad
heb de file incubusCamd_086.tar gevonden.
maar waar moet ik de bestanden:
softCam.Key
Readme
incubusCamd.sh4_e2
incubusCamd.sh4
icubusCamd.prio
incubusCam.conf
zetten, zodat ik de emulator kan activeren. Want in de menu vind ik hier niets terug
herman
Hoi Herman,
Deze staan normaalgesproken in var/bin
Gr,
BaZ
de files in var bin gezet en ipbox herstart, maar vind nergens hoe ik de emulator moet activeren.
herman
Als er geen menu in zit wordt het lastig
makkelijkst is om hm dan via telnet even handmatig te activeren. Als het goed is zit er wel ergens een mogelijkheid om de emu's te downloaden via het menu.
Gr,
BaZ
en kunt u soms zeggen hoe ik dat moet activeren
want in het menu vind ik geen optie om de plugin te downloaden
herman
telnet naar de onvanger
log in (met root)
typ ./var/bin/incubusCamd
Dan zou hij moeten starten.
met het commando ps -A kan je zien of het proces ook daadwerkelijk gestart is.
Gr,
Bas
