Rigolo Geplaatst: 23 juni 2009 Delen Geplaatst: 23 juni 2009 Ik krijg momenteel een helemboel van deze meldingen in mijn TCP-log van NewCS: Code: [ 20:42:14 ] [ Irdeto ] Card AU on reader 0 (Lower Cardreader) was not successfull[ 20:42:14 ] [ Irdeto ] emmok: 0 data00:E0 providerID:00[ 20:42:14 ] [ Irdeto ] Card AU on reader 0 (Lower Cardreader) was not successfull[ 20:42:14 ] [ Irdeto ] emmok: 0 data00:E0 providerID:00[ 20:42:14 ] [ Newcamd ] ECM -> local (OK) [CAID 0604] [Prov 00000000] [sID 0009][ 20:42:15 ] [ Irdeto ] Card AU on reader 0 (Lower Cardreader) was not successfull[ 20:42:15 ] [ Irdeto ] emmok: 0 data00:C8 providerID:10[ 20:42:15 ] [ Irdeto ] Card AU on reader 0 (Lower Cardreader) was not successfull[ 20:42:15 ] [ Irdeto ] emmok: 0 data00:E0 providerID:00[ 20:42:15 ] [ Irdeto ] Card AU on reader 0 (Lower Cardreader) was not successfull[ 20:42:15 ] [ Irdeto ] emmok: 0 data00:C0 providerID:00[ 20:42:15 ] [ Irdeto ] Card AU on reader 0 (Lower Cardreader) was not successfull[ 20:42:15 ] [ Irdeto ] emmok: 0 data00:D8 providerID:30[ 20:42:16 ] [ Irdeto ] Card AU on reader 0 (Lower Cardreader) was successfull[ 20:42:16 ] [ Irdeto ] emmok: 1 data00:02 providerID:00[ 20:42:16 ] [ Irdeto ] Card AU on reader 0 (Lower Cardreader) was not successfull[ 20:42:16 ] [ Irdeto ] emmok: 0 data00:C8 providerID:10[ 20:42:16 ] [ Irdeto ] Card AU on reader 0 (Lower Cardreader) was not successfull[ 20:42:16 ] [ Irdeto ] emmok: 0 data00:02 providerID:00[ 20:42:16 ] [ Irdeto ] Card AU on reader 0 (Lower Cardreader) was not successfull[ 20:42:16 ] [ Irdeto ] emmok: 0 data00:D8 providerID:30[ 20:42:17 ] [ Irdeto ] Card AU on reader 0 (Lower Cardreader) was not successfull[ 20:42:17 ] [ Irdeto ] emmok: 0 data00:D8 providerID:30[ 20:42:17 ] [ Irdeto ] Card AU on reader 0 (Lower Cardreader) was not successfull[ 20:42:17 ] [ Irdeto ] emmok: 0 data00:C8 providerID:10[ 20:42:17 ] [ Irdeto ] Card AU on reader 0 (Lower Cardreader) was not successfull[ 20:42:17 ] [ Irdeto ] emmok: 0 data00:C8 providerID:10[ 20:42:18 ] [ Irdeto ] Card AU on reader 0 (Lower Cardreader) was not successfull[ 20:42:18 ] [ Irdeto ] emmok: 0 data00:C0 providerID:00[ 20:42:18 ] [ Irdeto ] Card AU on reader 0 (Lower Cardreader) was not successfull[ 20:42:18 ] [ Irdeto ] emmok: 0 data00:C0 providerID:00 Zoals je kunt zien werken de ECM berichten (zie 20:42:14) maar gaat er wat mis met de EMM berichten. Maar soms (zie 20:42:16) gaat het wel goed. Omdat ik zag dat het groene ledje op mijn Smargo als een gek stond te knipperen dacht ik al dat er ietst niet lekker liep. als ik cards in tik zie ik het volgende: Code: -> cards.-------------------------------------------------------------------------------------------------------------.| Status | CAID | Enabled | Export | Mhz | PTS | RST | Ecms | Net ECM | Node | Reader ||----------|------|---------|--------|-----|-----|-----|----------|----------|-----------------|--------------'| Inserted | 0604 | Yes | Yes | 357 | No | 0 | 26 | 0 | /dev/ttyUSB0 | 0 (Lower Cardreader)'-----------------------------------------------------------------------------------------'---- --- -- - - en mijn sub zegt: Code: -> subEntitlements for card 0.-------------------------------------------------.| Provider | Channel ID | From | To ||----------|------------|------------|------------|| 00 | 270F | 0x03DC | 0x03EA || 00 | 0007 | 0x03A6 | 0x03C4 || 00 | 000B | 0x081F | 0x083D || 00 | 0009 | 0x081F | 0x083D ||----------|------------|------------|------------| Heeft iemand anders hier ook last van? Ik gebruik een 4012 kaart die ik al tijden gebruik en waarbij mij dit nog nooit is opgevallen. Voor de goede orde hier nog mijn newcs.xml. Dit is op een NSLU2 met openwrt 8.09 en NewCS 1.66RC1 (en /proc/cpu/alignment op 2) met gebruik makend van een Smargo in standaard phoenix mode. Code: <newCSconfig> <readers name="SCI"> <device> <name>Lower Cardreader</name> <type>phoenix</type> <mhz>357</mhz> <node>/dev/ttyUSB0</node> <parity>odd</parity> <reset>normal</reset> <export>Yes</export> <enabled>Yes</enabled> <blocksa>No</blocksa> <blockua>No</blockua> <blockga>No</blockga> <irdeto-camkey>0000000000000000</irdeto-camkey> <irdeto-camkey-data>0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 <crypto-special>No</crypto-special> <ipk>0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 <ucpk>000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 <PTShandshake>No</PTShandshake> <carddetect>yes</carddetect> <newcamd_port>10000</newcamd_port> <autosid>Yes</autosid> <Seca-PPV>no</Seca-PPV> <pincode>0000</pincode> <priority>round</priority> </device> </readers> <radegastserver> <enabled>No</enabled> <port>16000</port> <allow> <hostname>localhost</hostname> </allow> </radegastserver> <cache> <emm>20</emm> <ecm>-1</ecm> </cache> <debug> <password>newcs</password> <level>Internal</level> <type>All</type> <output>tcp</output> <console_options>normal,init</console_options> <tcp_port>1001</tcp_port> <tcp_options>normal,init</tcp_options> </debug> <newcamdserver> <enabled>Yes</enabled> <name>newcs</name> <deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey> <user> <name>local</name> <password>local</password> <port>12000</port> <au>on</au> <sidoverride>off</sidoverride> <spider>No</spider> </user> </newcamdserver> </newCSconfig> Link naar reactie Delen op andere sites Meer opties om te delen...
thunder Geplaatst: 28 juni 2009 Delen Geplaatst: 28 juni 2009 Probeer de kaart/reader eens op 6 mhz te laten draaien. Link naar reactie Delen op andere sites Meer opties om te delen...
Rigolo Geplaatst: 28 juni 2009 Auteur Delen Geplaatst: 28 juni 2009 dat draait hij nu 2 dagen ..... maar nog steeds veel not succesfull meldingen ... Wel is de frequenties van de EMM berichten weer terug op een normaler nivo, maar toch nog tusen de 1 en 5 seconden lijkt het wel. Vindt ik wel heel erg vaak. de ECM's komen eens per 24/25 seconden voorbij. Ik ga morgen newcs maar weer eens op mijn mythbuntu machine er bij instaleren en kijken wat er daar gebeurt. Misschien dat de NSLU2 versie toch niet helemaal lekker werkt, ondanks de alignment "fix". Gelukkig heb ik meerder kaarten hier in huis, en nog een extra smargo over. Hein Link naar reactie Delen op andere sites Meer opties om te delen...
DRG Geplaatst: 29 juni 2009 Delen Geplaatst: 29 juni 2009 er zit vanaf newcs 1.61 een optie om bepaalde emm's te blocken die voor gedonder zorgen ( als ik de readme goed gelezen heb ) "the <blockC0> tag, to block those emm's on Irshitto." Diverse meuk... maar dat boeit niemand toch.. Link naar reactie Delen op andere sites Meer opties om te delen...
Rigolo Geplaatst: 29 juni 2009 Auteur Delen Geplaatst: 29 juni 2009 En wat doen die C0 EMM's dan? (anders dan voor gedonder zorgen?) Ik zie nu wel regelmatig de volgende lijnen voorbij komen: Code: [ 20:16:53 ] [ EMM Added] [CAID 0000][Provider 00000000][sID 0001][ 20:16:53 ] [ EMM Added] [CAID 0000][Provider 00000000][sID 0001][ 20:16:53 ] [ EMM Added] [CAID 0000][Provider 00000000][sID 0001][ 20:16:53 ] [ EMM Added] [CAID 0000][Provider 00000000][sID 0001][ 20:17:00 ] [ EMM Added] [CAID 0000][Provider 00000000][sID 0001] Wat ik ook vreemd vindt ... worden die dan veroorzaakt door die C0 EMM's? Hein Link naar reactie Delen op andere sites Meer opties om te delen...
