Gast Geplaatst: 18 juni 2002 Delen Geplaatst: 18 juni 2002 Hè hè, eindelijk nieuwe firmware. OP http://download.topfield.de/tf4000pvr/TF4000PVR-TOPFIELD-Tfd-SYS_206_Jun12.zip kun je nieuwe offciele firmware van 12 juni vinden voor de 4000PVR. Oh ja, er is al weer een bug ontdekt. De sleep timer schijnt altijd na 10 minuten de TF uit te zetten, ongeacht de waarde die je instelt. Ik heb um nog niet geprobeerd, maar dat zal niet lang meer duren. 1. IRD status of Jun 12 2002 version (1) Device Version : v4.3.54 (2) Application Version : TF-JPC 4.57.38 (3) Last Update : Jun 12 2002 2. Improvements of this version (1) There was a problem in calculating the free space of hdd at the previous official version. It is fixed. The time shifting buffer is also calculated from this version. So, when you are watching the fixed channel, the free space will be decreased little by little to 1 hour buffer size. (2) The instant view image was not correct in case of starting recording a channel while watching other channels of the same TP. It is fixed. (3) There is an added menu item in Main menu -> Installation -> Firmware upgrade -> PID. This is for the OTA via Hotbird or other satellites. For the time being, this is 347 for Astra and Hotbird. OTA via Hotbird is under testing. (4) If you want to stop the recording, just press the stop key two times. You don't have to press V+/V- and OK key. No need for "finger acrobatics". (5) The pause key will work at the software teletext mode in case of playback and time shifting, not live. (6) There was a problem in recognition of some nagravision cam. It is fixed. (7) The EPG can be saved in the HDD. There is an added menu item in Main menu -> System Setting -> Time Setting -> Wakeup time for EPG. If you make it enable, the item of "Satellite for EPG" is also enabled. If you set the timer of "Wakeup time for EPG", the system wakes up, gathers the EPG of the selected satellite and returns to the standby mode. If you make it disabled, the EPG scheme is the same as the previous version, ie. the system does not read the EPG data from the HDD. The system saves only other TS's to reduce the gathering time. The actual TS's EITs are processed at live. We know that it is not so effective for the Astra/Hotbird users. But, this EPG scheme will be useful when the pvr processes the canal+ epg in the future. ( The timer of the delayed recording had a problem. It is almost fixed. 3. Known problems (1) Related to the (6) of above improvements list, some nagravision cam may not be recognized in cam slot 1 (the upper slot) in case of no smart card. So, if the nagravision cam was not recognized for a long time(about 10 seconds), please insert it in the bottom slot. The picture may flicker at some nagravsion channels with some nagravision cam. Ejecting and re-inserting the cam may make it better. Anyway, we will try to fix it. 4. Notice (1) Related to the (7) of above improvements list, the EPG data would not be gathered in case of canal+ in Astra. It seems to have a different EIT format from the DVB-SI. The TF4000PVR does not processs it yet. CU Urkie Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 18 juni 2002 Delen Geplaatst: 18 juni 2002 Link lijkt niet in orde (meer). Ik zal effuh zoeken. Overigens zou het via OTA ook moeten werken. CU Urkie Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 18 juni 2002 Delen Geplaatst: 18 juni 2002 Deze zou wel moeten werken. http://www.topfield.co.kr/technote/main....unctionList.zip CU Urkie Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 18 juni 2002 Delen Geplaatst: 18 juni 2002 Heb hier de beta van deze software getest, en inderdaad zit er een MAJOR bug in de sleeptimer optie. Als dit niet is aangepast in deze officiele versie, adviseer ik voor de mensen die dit vaak gebruiken om nog even te wachten met updaten ! Verder is de EPG functie erg handig, zo is er ineens epg info op de MTV kanalen.(niet allemaal!). Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 18 juni 2002 Delen Geplaatst: 18 juni 2002 Is het bekent of deze fimware op dit moment via Ota loop, Want dit zal de eerste keer zijn voor mijn toppie, en ik weet niet als ik op ok druk of dat hij dan gelijk begin met downloaden. GR.DJ Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 18 juni 2002 Delen Geplaatst: 18 juni 2002 Voordat je OTA kan doen via de astra, zal je eerst de loader moeten updaten. Zonder de update van de loader kan je gewoon op start drukken en krijg je de melding dat je de loader moet aanpassen. Maar kijk HEEL erg uit hiermee ! Als je de update van de loader op enige manier onderbreekt (stroomstoring, pc die hangt etc) dan is het einde oefening, en kan je de TF wegbrengen voor reparatie. Kan beter gewoon maar het kabeltje gebruiken, is veiliger <img src="/ubbthreads/images/icons/wink.gif" alt="" /> Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 18 juni 2002 Delen Geplaatst: 18 juni 2002 Ok Mike, De Soft zit er al in, in het menu staat de Ota geduldig te wachten. Wat ik bedoel is als ik druk op uploade begin hij dan gelijk of krijg ik eerst een bevestiging dat er een nieuwe fimware klaar staat. Dat zou ik graag willen weten .... Voor de rest zal het zo zijn dat ik alle settings kwijt ben bij een nieuwe fimware. Met name de sat posities, alles sttat er nu in en draai als een speer GR.DJ Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 18 juni 2002 Delen Geplaatst: 18 juni 2002 De posities en tp data ben je niet kwijt. Het is alleen zo dat als de TP database is uitgebreid je een factory reset moet doen. Dan ben je dus WEL alles kwijt. Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 19 juni 2002 Delen Geplaatst: 19 juni 2002 Nou ik heb het gestest, Vanavond naar fimware update gegaan in het menu, hij zoekt effe, zegt dan fimware ok , vraag dan weet u het zeker, ik zeg ja, Toppie gaat uit, vervolgens weer aan , geen beeld, display geeft aan 0k49 en tel dan af naar 0k32 , blijf hier vervolgens op stil staan ok32, na 15 minuten nog steeds, ik denk dit is goed mis dus, toppie uitgezet, toppie weer aangezet en alles werk naar behoren. Maar heeft dus niets gedaan betreft update fimware, want die van 15 mei staat er nog in. Klop dit, of wordt ik nu gek, roept u maar. GR.DJ Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 19 juni 2002 Delen Geplaatst: 19 juni 2002 IK had precies hetzelfde met mijn Toppie! Alleen bleef ie bij OT16 hangen. Wel 4 keer. Gewoon op de standby knop drukken en nog een keer proberen. De 5e keer ging alles naar wens en stond de juni sw erin. Eigewijze mensen houden het best lang vol! Sommige erg eigenewijze zelfs wel 5 keer!!!!!!! <img src="/ubbthreads/images/icons/blush.gif" alt="" /> Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Geplaatst: 25 juni 2002 Delen Geplaatst: 25 juni 2002 Inderdaad, na 4 keer liep hij ineens wel door naar 0, Juni versie staat er in. Las elders dar er problemen waren met de EPF funktie, bij geen probleem dus. Dus nu maar wachten op de volgende update. GR.DJ Link naar reactie Delen op andere sites Meer opties om te delen...
