komt er nog een nieuwe nabilo pure flash voor de 7025
Nabilo DM7025 Pure Flash with Barry Allen 4.6.81 is de laaste pure flash, voor de 7025+.
Werk echt super.
Maar ik lees dat er al een voor de 800 en de 8000 Nabilo Pure Flash 01JUL09 and Barry Allen 4.8.21 bestaat.
Kunje zonder meer, deze software ook in een 7025+ zetten ?
en / of
Komt nabilo misschien met een nieuwe versie voor de 7025+
Origineel bericht van: martin52
Nabilo pure flash voor de 7025 met BA 4.8.20 is op 9 juli jl uitgekomen. En vlak daarna de release of Nabilo Black Hole 7025 v11
klopt maar deze is geen pure flash
Nabilosat DM7025 Pure Flash 09JULY09, with Barry Allen 4.8.20
What is the Nabilosat DM7025 Pure Flash ?
This image is a simple, pure CVS image to install to flash memory. It is reccomended to those who like the multiboot option with Barry Allen. It is light, fast, reliable and, most of all, upated. Therefore, it is the best solution for multiboot purposes.
What is included in this image ?
This image is including the latest available edition of Barry Allen: 4.8.20. Software Manager and Network Browser
Why should I install this image in flash ?
Because it includes all the latest drivers and kernel modules required to install new images in multiboot. Nabilosat team is about to release the latest version of its Black Hole image. If installed to multiboot, the new Black Hole image requires an updated image in the flash memory. For this reason, Nabilosat team prepared this Pure version for you.
How do I install Barry Allen with this image ?
Barry Allen will be automatically installed at the end of the default wizard
Will I loose the images already installed on my media ?
No, you will not loose any of your favourite images, already installed to your media. You will reboot and find them again, ready to be used.
How do I install it to flash ?
You can install it via WebInterface or via serial. However, it is important that you read the simple instructions reported here under.
Release Details
NEW Nabilosat Bootlogo by Army
Barry Allen 4.8.20 included
TARGET_ARCH = "mipsel"
TARGET_OS = "linux"
MACHINE = "dm7025"
DISTRO = "opendreambox"
DISTRO_VERSION = "1.5.0"
TARGET_FPU = "soft"
ENIGMA2_CVS_DATE = "29 June 2009"
ENIGMA2_VERSION = "2.6 experimental"
DRIVERS = "02 July 2009"
SECOND STAGE = "61-pr1"
BARRY_ALLEN_VERSION = "4.8.20"
Instructions
1) Flash your DM 7025 with Web Interface or DreamUp and serial cable
2) Complete the Default Wizard to setup the basic steps
3) Upon Wizard completion, Barry Allen will install automatically, and a Console Window will report the progress
4) Enigma2 will restart as usual
5) Barry Allen is available in the plugin list, ready to install images to multiboot.
Barry Allen will have been installed. You will find your previous images listed, choose your favorite as always.
Warning: Nabilosat pure flash include the 4.8.2 version of BA because the later version of BA are too big (more than 7 mega). You can install this image on newer BA version too and/or if you want, you can upgrade BA to the latest version after image complete installation.
Warning: Because of Enigma2 developers are adding many libraries to the latest versions it is higly recommended to use this image in flash and install Black Hole image 0.11 in Multiboot.
This is because DM7025 flash memory is limited and current E2 images for Dm7025 are very big.
So the best way is to install this image in flash and then install Black Hole DM7025 0.11 in multiboot. In this way you will be not limited by flash capacity and you will have all the space available on your device to add packages, skins and all the plugins you want
