rtificial Geplaatst: 20 augustus 2009 Delen Geplaatst: 20 augustus 2009 Angezien de firmware al gelekt is naar de diverse fora, ook maar hier. Let op, dit is een beta firmware, nog niet officieel gereleased door Opensat, en dus enkel voor testdoeleinden Releasenotes Citaat: # FIXED - CI can not support HD channel - CI can not send the reply of ENQ - Subtitles are transparent when menu is set to transparent - Unicable is not working - If playing recorded contents on movie player, recorded contents have no sound - Can not add new SAT/TP on SAT/TP Editor - Can not play with After recording - If the channel has the subtitle language, which was selected on setting, subtitle should be showed, automatically # ADDED - DVB-T/C NIT Search - DTS decoding - The menu of “Fixe Interlace on/off” on channel manager For supporting the encoder, which may not respect the spec on this matter. “When progressive_frame = 1 the picture is progressive, the two fields represent the exact same time, and you should not see any comb effect when displaying the frame. Moreover, when progressive_frame = 0, top_field_first is used to indicate which field has to be displayed first.” - Satellite Nile Sat 101/102/Altantic Bird4 (7.0W) is missing in the satellite list - Telefonica transponder on Amazonas(61.0W) is missing - Always start in TV mode - “Automatic Reboot Option” to Timer menu # IMPROVED - If you choose a movie from hard disk and in the same folder where the movie is stored there is an .srt or something else the box loads subtile automatically ordered by .smi/.srt/.txt Hier te downloaden : klik DB800HD ~ AZBox HD Premium ~ Archsat 3/1 ~ Apple TV2 XBMC Link naar reactie Delen op andere sites Meer opties om te delen...
MacGuinness Geplaatst: 21 augustus 2009 Delen Geplaatst: 21 augustus 2009 We zitten nog steeds op FW 0.9xxx dus het is allemaal beta. Selfsat H50D2 & Stab HH90 + VU+DUO2 (VTI 6xx) + Onkyo TX-SR508 + LG 55UB850V UHDTV = Link naar reactie Delen op andere sites Meer opties om te delen...
Tonskidutch Geplaatst: 21 augustus 2009 Delen Geplaatst: 21 augustus 2009 Origineel bericht van: MacGuinness We zitten nog steeds op FW 0.9xxx dus het is allemaal beta. uh... Origineel bericht van: rtificial Let op, dit is een beta firmware, nog niet officieel gereleased door Opensat, en dus enkel voor testdoeleinden dat staat er toch ook, waarom dan nog eens melden en wie is "we" ? rtificial, heb je ook als betatester alle gemelde bugfixes en addities positief kunnen testen? ciao Move It On Over George Thorogood & The Destroyers Link naar reactie Delen op andere sites Meer opties om te delen...
rtificial Geplaatst: 21 augustus 2009 Auteur Delen Geplaatst: 21 augustus 2009 Ik ben geen beta-tester hoor. In dat geval had ik de FW hier al helemaal niet gepost. Wat ik tot nu toe ervaren heb van deze FW is het volgende: Zapsnelheid: Lijkt wat verbeterd, maar ik ben misschien snel tevreden. Een seconde of 2 met Mbox vind ik al prima. Ondertiteling: De ondertitel-taal die je in de settings vastlegd wordt nu inderdaad automatisch getoond bij de kanalen waar deze aanwezig is. Niet de teletekst ondertiteling. Dat had ik persoonlijk nog een aardige toevoeging gevonden, omdat er niet altijd de normale dvb ondertitels beschikbaar zijn. Recordings: Opnemen op ingebouwde harddisk, vanuit standby, een geprogrammeerde opname op een gecodeerd kanaal, heeft bij mij vannacht prima gewerkt. Verder zijn me wat optische wijzigingen opgevallen, wat meer uitgebreide disecq instellingen, en een nieuwe functie om de box bijvoorbeeld 1x per dag automatisch te laten rebooten. Doordat ik bij mij dagelijks gebruik eigenlijk niet veel storende bugs ervaar, kan ik ook niet goed beoordelen hoeveel daarvan opgelost is. DB800HD ~ AZBox HD Premium ~ Archsat 3/1 ~ Apple TV2 XBMC Link naar reactie Delen op andere sites Meer opties om te delen...
Tonskidutch Geplaatst: 21 augustus 2009 Delen Geplaatst: 21 augustus 2009 duidelijk dat een betatester niet mag publiceren, maar toch heb je dus een grijze taak een beta firmware presenteren aan de AZbox gemeenschap en dan effe conclusies trekken is zoals je nav mijn vraag deed het minste. bedankt daarvoor ik denk als 2e kijkbox toch ook maar zo'n voetbalbox te kopen... ciao Move It On Over George Thorogood & The Destroyers Link naar reactie Delen op andere sites Meer opties om te delen...
M_Z Geplaatst: 21 augustus 2009 Delen Geplaatst: 21 augustus 2009 Origineel bericht van: Tonskidutch ik denk als 2e kijkbox toch ook maar zo'n voetbalbox te kopen... ciao Kun je best doen, ik heb hem nu ook enkele dagen in huis (EliteHD) en bedacht me gewoon: als er het merknaampje dreambox op had gestaan en we hadden gedaan alsof dit een nieuw model van hun was, dan was volgens mij iedereen laaiend enthousiast. De mediaplayer (ja deze speelt gewoon avi files af zonder moeilijke koppelingen met vlc of zo), de youtubefunctie (ook zonder vlc), en een redelijke client ondersteuning voor CCcam maakt het voor mij althans een hele leuke tweede ontvanger. En eigenlijk weet ik zelfs niet waarom ik nu schrijf "tweede" ontvanger. Ik zie in elk geval dat met deze nieuwe firmware de azbox alweer een stukje volwassener geworden is. M_Z Link naar reactie Delen op andere sites Meer opties om te delen...
rtificial Geplaatst: 21 augustus 2009 Auteur Delen Geplaatst: 21 augustus 2009 Ik denk ook dat nu al, zonder dat de hele source openbaar gemaakt is, de ontvanger al heel interessant is, en daarnaast stabiel te gebruiken door minder hobbyisten. Wat mij betreft kan dat alleen maar beter worden. Mocht de twin-tuner functionaliteit daadwerkelijk gaan werken, en de sourcecode vrijgegeven worden, dan is dit een van de meest interessante hobby ontvangers voor een normaal budget. DB800HD ~ AZBox HD Premium ~ Archsat 3/1 ~ Apple TV2 XBMC Link naar reactie Delen op andere sites Meer opties om te delen...
Tonskidutch Geplaatst: 22 augustus 2009 Delen Geplaatst: 22 augustus 2009 misschien omdat je een eerste kijkdoos hebt? natuurlijk volg ik de draadjes over nieuwe types en ontwikkelingen en natuurlijk heb ik al erg lang een dreambox (die doe ik ook echt niet weg) een van de overwegingen is dat ik de dm800 met enigma2 vorig jaar heb getest en het allemaal te complex en te duur vond met name omdat er maar zeer weinig HD zenders zijn waarop ook twenty-four seven HD uitzendingen zijn te zien (dat mag een ieder voor zich als mening anders waarderen) maar dan is een AZbox als HD receiver toch langzaam maar zeker een heel goede concurent in het gamma van overige HD receivers. ciao Move It On Over George Thorogood & The Destroyers Link naar reactie Delen op andere sites Meer opties om te delen...
M_Z Geplaatst: 22 augustus 2009 Delen Geplaatst: 22 augustus 2009 Hoe zet je die firmware erin? Ik heb de patch.bin op een usb-stick gezet, maar de usb stick wordt niet herkend. En via ethernet kan ik nog geen firmware updaten (wordt aan gewerkt). Op internet is de 0.9.2880 de laatste nieuwe. En nog een newbie vraagje, is de firmware voor de eliteHD dezelfde als voor de PremiumHD ? M_Z Link naar reactie Delen op andere sites Meer opties om te delen...
D_liver Geplaatst: 22 augustus 2009 Delen Geplaatst: 22 augustus 2009 elite en premium geen verschil in fw 2 x Maxytec Multibox 4K 1 x Zgemma H9 combo Link naar reactie Delen op andere sites Meer opties om te delen...
Satlook Geplaatst: 22 augustus 2009 Delen Geplaatst: 22 augustus 2009 Citaat: Hoe zet je die firmware erin? Ik heb de patch.bin op een usb-stick gezet, maar de usb stick wordt niet herkend Eerst de stick geformateerd? (hoef ik eigenlijk niet aan jou te vragen denk) Azbox een keer uit en aanschakelen met de net schakelaar achter op.? Er schijnen ook sticks te zijn die niet werken, dus andere stick proberen. DM8000 HD - Newnigma VU+ duo - PLI Triple dragon - PICmod cronbear1 image Echostar 7000 viaccess Gregorian 120 & 90 cm Visiosat bisat Link naar reactie Delen op andere sites Meer opties om te delen...
M_Z Geplaatst: 23 augustus 2009 Delen Geplaatst: 23 augustus 2009 Perfect ! Gelukt inderdaad, gewoon even de stroom eraf, USB stick erin met de patch.bin en dan start de AZbox op met een upgrade menu. Dit gaat dus ook alweer veel simpeler dan met een dreambox. M_Z Link naar reactie Delen op andere sites Meer opties om te delen...
Cobus R Geplaatst: 23 augustus 2009 Delen Geplaatst: 23 augustus 2009 Als je het weet is het een makkelijke decoder wie erg goed werkt voor de eerste firmware releasses die ook nog eens beta zijn. De Groeten Van Cobus R Vu+ Uno 4K DVB C (FBC) / MaXytec Multibox (Fallback) Ziggo kabel (FTA) Link naar reactie Delen op andere sites Meer opties om te delen...
Satlook Geplaatst: 23 augustus 2009 Delen Geplaatst: 23 augustus 2009 Ja makkelijk die Azbox. Je kan ook heel handig van emu wisselen door op de snel vooruit toets te drukken, dan hoef je niet het plugin menu in DM8000 HD - Newnigma VU+ duo - PLI Triple dragon - PICmod cronbear1 image Echostar 7000 viaccess Gregorian 120 & 90 cm Visiosat bisat Link naar reactie Delen op andere sites Meer opties om te delen...
Gast Willy-NL Geplaatst: 23 augustus 2009 Delen Geplaatst: 23 augustus 2009 Origineel bericht van: Satlook Ja makkelijk die Azbox. Je kan ook heel handig van emu wisselen door op de snel vooruit toets te drukken, dan hoef je niet het plugin menu in Whahaha heb je gelezen op mijn forum;) maar inderdaad een goede optie. Software word steeds beter. Link naar reactie Delen op andere sites Meer opties om te delen...
