Gast sattaz Geplaatst: 24 augustus 2009 Geplaatst: 24 augustus 2009 Er is een nieuwe officiële firmwareversie voor de AZBox HD: 0.9.3180 OpenSAT is proud to present AZBox HD Firmware - rev. 0.9.3180 (2009.08.23) RELEASE NOTES ~~~~~~~~~~~~~~~ # FIXED ======== - CI can not support HD channel - CI can not send the reply of ENQ - Subtitles are transparent when menu is set to transparent - Unicable is not working - If playing recorded contents on movie player, recorded contents have no sound - Can not add new SAT/TP on SAT/TP Editor - Can not play with After recording - If the channel has the subtitle language, which was selected on setting, subtitle should be showed, automatically # ADDED ======== - DVB-T/C NIT Search - DTS decoding - The menu of "Fixe Interlace on/off" on channel manager For supporting the encoder, which may not respect the spec on this matter. "When progressive_frame = 1 the picture is progressive, the two fields represent the exact same time, and you should not see any comb effect when displaying the frame. Moreover, when progressive_frame = 0, top_field_first is used to indicate which field has to be displayed first." - Satellite Nile Sat 101/102/Altantic Bird4 (7.0W) is missing in the satellite list - Telefonica transponder on Amazonas(61.0W) is missing - Always start in TV mode - "Automatic Reboot Option" to Timer menu # IMPROVED =========== - If you choose a movie from hard disk and in the same folder where the movie is stored there is an .srt or something else the box loads subtile automatically ordered by .smi/.srt/.txt. Best Regards, The OpenSAT/AZBox Team
Satlook Geplaatst: 24 augustus 2009 Geplaatst: 24 augustus 2009 Ik ben weer zeer tevreden over deze firmware, zappen gaat nog sneller dan met de 0.9.3177. Wat ook wel lekker is als je zaplijst een kanaal selecteert hoef je daarna no maar 1 keer op oke te drukken en de zaplijst verdwijnt weer Mooi werk van het AZbox hd team ga zo door DM8000 HD - Newnigma VU+ duo - PLI Triple dragon - PICmod cronbear1 image Echostar 7000 viaccess Gregorian 120 & 90 cm Visiosat bisat
Cobus R Geplaatst: 25 augustus 2009 Geplaatst: 25 augustus 2009 Mooie firmware werkt goed tot nu toe. De Groeten Van Cobus R Vu+ Uno 4K DVB C (FBC) / MaXytec Multibox (Fallback) Ziggo kabel (FTA)
rtificial Geplaatst: 25 augustus 2009 Geplaatst: 25 augustus 2009 Thanks DB800HD ~ AZBox HD Premium ~ Archsat 3/1 ~ Apple TV2 XBMC
liberte Geplaatst: 25 augustus 2009 Geplaatst: 25 augustus 2009 Ik heb geprobeerd om via het internet de box te upgraden. Na de melding bijwerken ging het mis de software werd niet uit gepakt. 2de poging mislukte ook, als ik een reset gaf werkte de box normaal met de oude fw. Ik heb het toen maar via usb gedaan. Wat ik mij afvraag waar blijft die download die niet wordt uitgepakt. Blij met mijn AZbox
MacGuinness Geplaatst: 25 augustus 2009 Geplaatst: 25 augustus 2009 @ sattaz THX! Selfsat H50D2 & Stab HH90 + VU+DUO2 (VTI 6xx) + Onkyo TX-SR508 + LG 55UB850V UHDTV =
Jap Geplaatst: 25 augustus 2009 Geplaatst: 25 augustus 2009 Opnemen en timeshiften van HD zenders op externe HDD gaat niet goed. Hebben meer mensen hier last van ? AZBoxHD : 19.2 - 23.5 - 28.2 (T55) DSR2210 : 19.2 - 28.2
Ibocan-power Geplaatst: 25 augustus 2009 Geplaatst: 25 augustus 2009 Ook met USb heb ik geprobeerd maar hij blijft maar Failed to update zeggen .... Iemand een suggestie ?
Gast azboxhd Geplaatst: 25 augustus 2009 Geplaatst: 25 augustus 2009 een HD opgenomen programa is niet zoals het zou moeten hokt en staat stil. ------------------------------------- johan
Ibocan-power Geplaatst: 25 augustus 2009 Geplaatst: 25 augustus 2009 Ik heb op mijn vraag al oplossing gevonden .. Dat is : wat je download is patch.sit en die .sit heb ik .bin van gemaakt en hij heeft hem nu wel geupdate .
Cobus R Geplaatst: 25 augustus 2009 Geplaatst: 25 augustus 2009 Ja dat klopt dat zullen ze wel doen om dat er sommige virusscanners het niet eens zijn met een .bin bestand (denk ik) De Groeten Van Cobus R Vu+ Uno 4K DVB C (FBC) / MaXytec Multibox (Fallback) Ziggo kabel (FTA)
spikes Geplaatst: 25 augustus 2009 Geplaatst: 25 augustus 2009 Origineel bericht van: Satlook Ik ben weer zeer tevreden over deze firmware, zappen gaat nog sneller dan met de 0.9.3177. Wat ook wel lekker is als je zaplijst een kanaal selecteert hoef je daarna no maar 1 keer op oke te drukken en de zaplijst verdwijnt weer Mooi werk van het AZbox hd team ga zo door Dit is wat ik op een ander board lees: "I have been told that this is the method from now on. Beta testers will get the intermediate firmwares, then the public release will get a new firmware number. If the firmware isn't on azupd . com then it isn't a public release. As 3177 was leaked this wasn't supposed to be the firmware release number. 3177 was a 3180 release candidate. Hope this clears a little confusion." Dus is volgens mij hetzelfde als de 3177. Op een duits forum praten ze over 78 Byte verschil. Dus wat is nu het verschil tussen beide firmwares??
tomlissen Geplaatst: 25 augustus 2009 Geplaatst: 25 augustus 2009 Origineel bericht van: Satlook Ik ben weer zeer tevreden over deze firmware, zappen gaat nog sneller dan met de 0.9.3177. Wat ook wel lekker is als je zaplijst een kanaal selecteert hoef je daarna no maar 1 keer op oke te drukken en de zaplijst verdwijnt weer Mooi werk van het AZbox hd team ga zo door 1 keer klikken? met deze firmware is in het klikken in de zenderlijst niks veranderd volgens mij.
rtificial Geplaatst: 25 augustus 2009 Geplaatst: 25 augustus 2009 Origineel bericht van: tomlissen Origineel bericht van: Satlook Ik ben weer zeer tevreden over deze firmware, zappen gaat nog sneller dan met de 0.9.3177. Wat ook wel lekker is als je zaplijst een kanaal selecteert hoef je daarna no maar 1 keer op oke te drukken en de zaplijst verdwijnt weer Mooi werk van het AZbox hd team ga zo door 1 keer klikken? met deze firmware is in het klikken in de zenderlijst niks veranderd volgens mij. Helemaal mee eens, is niets in veranderd. Das nou nog eens blij maken met een dooie mus Satlook ;-) DB800HD ~ AZBox HD Premium ~ Archsat 3/1 ~ Apple TV2 XBMC
